RTEMS 6.1
MISC0 - Miscellaneous Register 0
#define XTALOSC24M_MISC0_REFTOP_PWD_MASK   (0x1U)
#define XTALOSC24M_MISC0_REFTOP_PWD_SHIFT   (0U)
#define XTALOSC24M_MISC0_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_REFTOP_PWD_SHIFT)) & XTALOSC24M_MISC0_REFTOP_PWD_MASK)
#define XTALOSC24M_MISC0_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define XTALOSC24M_MISC0_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define XTALOSC24M_MISC0_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_REFTOP_SELFBIASOFF_MASK)
#define XTALOSC24M_MISC0_REFTOP_VBGADJ_MASK   (0x70U)
#define XTALOSC24M_MISC0_REFTOP_VBGADJ_SHIFT   (4U)
#define XTALOSC24M_MISC0_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_REFTOP_VBGADJ_MASK)
#define XTALOSC24M_MISC0_REFTOP_VBGUP_MASK   (0x80U)
#define XTALOSC24M_MISC0_REFTOP_VBGUP_SHIFT   (7U)
#define XTALOSC24M_MISC0_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_REFTOP_VBGUP_SHIFT)) & XTALOSC24M_MISC0_REFTOP_VBGUP_MASK)
#define XTALOSC24M_MISC0_STOP_MODE_CONFIG_MASK   (0xC00U)
#define XTALOSC24M_MISC0_STOP_MODE_CONFIG_SHIFT   (10U)
#define XTALOSC24M_MISC0_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_STOP_MODE_CONFIG_MASK)
#define XTALOSC24M_MISC0_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define XTALOSC24M_MISC0_DISCON_HIGH_SNVS_SHIFT   (12U)
#define XTALOSC24M_MISC0_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_DISCON_HIGH_SNVS_MASK)
#define XTALOSC24M_MISC0_OSC_I_MASK   (0x6000U)
#define XTALOSC24M_MISC0_OSC_I_SHIFT   (13U)
#define XTALOSC24M_MISC0_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_OSC_I_SHIFT)) & XTALOSC24M_MISC0_OSC_I_MASK)
#define XTALOSC24M_MISC0_OSC_XTALOK_MASK   (0x8000U)
#define XTALOSC24M_MISC0_OSC_XTALOK_SHIFT   (15U)
#define XTALOSC24M_MISC0_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_OSC_XTALOK_SHIFT)) & XTALOSC24M_MISC0_OSC_XTALOK_MASK)
#define XTALOSC24M_MISC0_OSC_XTALOK_EN_MASK   (0x10000U)
#define XTALOSC24M_MISC0_OSC_XTALOK_EN_SHIFT   (16U)
#define XTALOSC24M_MISC0_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_OSC_XTALOK_EN_SHIFT)) & XTALOSC24M_MISC0_OSC_XTALOK_EN_MASK)
#define XTALOSC24M_MISC0_CLKGATE_CTRL_MASK   (0x2000000U)
#define XTALOSC24M_MISC0_CLKGATE_CTRL_SHIFT   (25U)
#define XTALOSC24M_MISC0_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_CLKGATE_CTRL_MASK)
#define XTALOSC24M_MISC0_CLKGATE_DELAY_MASK   (0x1C000000U)
#define XTALOSC24M_MISC0_CLKGATE_DELAY_SHIFT   (26U)
#define XTALOSC24M_MISC0_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_CLKGATE_DELAY_MASK)
#define XTALOSC24M_MISC0_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define XTALOSC24M_MISC0_RTC_XTAL_SOURCE_SHIFT   (29U)
#define XTALOSC24M_MISC0_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_RTC_XTAL_SOURCE_MASK)
#define XTALOSC24M_MISC0_XTAL_24M_PWD_MASK   (0x40000000U)
#define XTALOSC24M_MISC0_XTAL_24M_PWD_SHIFT   (30U)
#define XTALOSC24M_MISC0_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_XTAL_24M_PWD_SHIFT)) & XTALOSC24M_MISC0_XTAL_24M_PWD_MASK)
#define XTALOSC24M_MISC0_VID_PLL_PREDIV_MASK   (0x80000000U)
#define XTALOSC24M_MISC0_VID_PLL_PREDIV_SHIFT   (31U)
#define XTALOSC24M_MISC0_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_VID_PLL_PREDIV_MASK)
MISC0_SET - Miscellaneous Register 0
#define XTALOSC24M_MISC0_SET_REFTOP_PWD_MASK   (0x1U)
#define XTALOSC24M_MISC0_SET_REFTOP_PWD_SHIFT   (0U)
#define XTALOSC24M_MISC0_SET_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_REFTOP_PWD_SHIFT)) & XTALOSC24M_MISC0_SET_REFTOP_PWD_MASK)
#define XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF_MASK)
#define XTALOSC24M_MISC0_SET_REFTOP_VBGADJ_MASK   (0x70U)
#define XTALOSC24M_MISC0_SET_REFTOP_VBGADJ_SHIFT   (4U)
#define XTALOSC24M_MISC0_SET_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_SET_REFTOP_VBGADJ_MASK)
#define XTALOSC24M_MISC0_SET_REFTOP_VBGUP_MASK   (0x80U)
#define XTALOSC24M_MISC0_SET_REFTOP_VBGUP_SHIFT   (7U)
#define XTALOSC24M_MISC0_SET_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_REFTOP_VBGUP_SHIFT)) & XTALOSC24M_MISC0_SET_REFTOP_VBGUP_MASK)
#define XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG_MASK   (0xC00U)
#define XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG_SHIFT   (10U)
#define XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG_MASK)
#define XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS_SHIFT   (12U)
#define XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS_MASK)
#define XTALOSC24M_MISC0_SET_OSC_I_MASK   (0x6000U)
#define XTALOSC24M_MISC0_SET_OSC_I_SHIFT   (13U)
#define XTALOSC24M_MISC0_SET_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_OSC_I_SHIFT)) & XTALOSC24M_MISC0_SET_OSC_I_MASK)
#define XTALOSC24M_MISC0_SET_OSC_XTALOK_MASK   (0x8000U)
#define XTALOSC24M_MISC0_SET_OSC_XTALOK_SHIFT   (15U)
#define XTALOSC24M_MISC0_SET_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_OSC_XTALOK_SHIFT)) & XTALOSC24M_MISC0_SET_OSC_XTALOK_MASK)
#define XTALOSC24M_MISC0_SET_OSC_XTALOK_EN_MASK   (0x10000U)
#define XTALOSC24M_MISC0_SET_OSC_XTALOK_EN_SHIFT   (16U)
#define XTALOSC24M_MISC0_SET_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_OSC_XTALOK_EN_SHIFT)) & XTALOSC24M_MISC0_SET_OSC_XTALOK_EN_MASK)
#define XTALOSC24M_MISC0_SET_CLKGATE_CTRL_MASK   (0x2000000U)
#define XTALOSC24M_MISC0_SET_CLKGATE_CTRL_SHIFT   (25U)
#define XTALOSC24M_MISC0_SET_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_SET_CLKGATE_CTRL_MASK)
#define XTALOSC24M_MISC0_SET_CLKGATE_DELAY_MASK   (0x1C000000U)
#define XTALOSC24M_MISC0_SET_CLKGATE_DELAY_SHIFT   (26U)
#define XTALOSC24M_MISC0_SET_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_SET_CLKGATE_DELAY_MASK)
#define XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE_SHIFT   (29U)
#define XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE_MASK)
#define XTALOSC24M_MISC0_SET_XTAL_24M_PWD_MASK   (0x40000000U)
#define XTALOSC24M_MISC0_SET_XTAL_24M_PWD_SHIFT   (30U)
#define XTALOSC24M_MISC0_SET_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_XTAL_24M_PWD_SHIFT)) & XTALOSC24M_MISC0_SET_XTAL_24M_PWD_MASK)
#define XTALOSC24M_MISC0_SET_VID_PLL_PREDIV_MASK   (0x80000000U)
#define XTALOSC24M_MISC0_SET_VID_PLL_PREDIV_SHIFT   (31U)
#define XTALOSC24M_MISC0_SET_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_SET_VID_PLL_PREDIV_MASK)
MISC0_CLR - Miscellaneous Register 0
#define XTALOSC24M_MISC0_CLR_REFTOP_PWD_MASK   (0x1U)
#define XTALOSC24M_MISC0_CLR_REFTOP_PWD_SHIFT   (0U)
#define XTALOSC24M_MISC0_CLR_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_REFTOP_PWD_SHIFT)) & XTALOSC24M_MISC0_CLR_REFTOP_PWD_MASK)
#define XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF_MASK)
#define XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ_MASK   (0x70U)
#define XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ_SHIFT   (4U)
#define XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ_MASK)
#define XTALOSC24M_MISC0_CLR_REFTOP_VBGUP_MASK   (0x80U)
#define XTALOSC24M_MISC0_CLR_REFTOP_VBGUP_SHIFT   (7U)
#define XTALOSC24M_MISC0_CLR_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_REFTOP_VBGUP_SHIFT)) & XTALOSC24M_MISC0_CLR_REFTOP_VBGUP_MASK)
#define XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG_MASK   (0xC00U)
#define XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG_SHIFT   (10U)
#define XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG_MASK)
#define XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS_SHIFT   (12U)
#define XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS_MASK)
#define XTALOSC24M_MISC0_CLR_OSC_I_MASK   (0x6000U)
#define XTALOSC24M_MISC0_CLR_OSC_I_SHIFT   (13U)
#define XTALOSC24M_MISC0_CLR_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_OSC_I_SHIFT)) & XTALOSC24M_MISC0_CLR_OSC_I_MASK)
#define XTALOSC24M_MISC0_CLR_OSC_XTALOK_MASK   (0x8000U)
#define XTALOSC24M_MISC0_CLR_OSC_XTALOK_SHIFT   (15U)
#define XTALOSC24M_MISC0_CLR_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_OSC_XTALOK_SHIFT)) & XTALOSC24M_MISC0_CLR_OSC_XTALOK_MASK)
#define XTALOSC24M_MISC0_CLR_OSC_XTALOK_EN_MASK   (0x10000U)
#define XTALOSC24M_MISC0_CLR_OSC_XTALOK_EN_SHIFT   (16U)
#define XTALOSC24M_MISC0_CLR_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_OSC_XTALOK_EN_SHIFT)) & XTALOSC24M_MISC0_CLR_OSC_XTALOK_EN_MASK)
#define XTALOSC24M_MISC0_CLR_CLKGATE_CTRL_MASK   (0x2000000U)
#define XTALOSC24M_MISC0_CLR_CLKGATE_CTRL_SHIFT   (25U)
#define XTALOSC24M_MISC0_CLR_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_CLR_CLKGATE_CTRL_MASK)
#define XTALOSC24M_MISC0_CLR_CLKGATE_DELAY_MASK   (0x1C000000U)
#define XTALOSC24M_MISC0_CLR_CLKGATE_DELAY_SHIFT   (26U)
#define XTALOSC24M_MISC0_CLR_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_CLR_CLKGATE_DELAY_MASK)
#define XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE_SHIFT   (29U)
#define XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE_MASK)
#define XTALOSC24M_MISC0_CLR_XTAL_24M_PWD_MASK   (0x40000000U)
#define XTALOSC24M_MISC0_CLR_XTAL_24M_PWD_SHIFT   (30U)
#define XTALOSC24M_MISC0_CLR_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_XTAL_24M_PWD_SHIFT)) & XTALOSC24M_MISC0_CLR_XTAL_24M_PWD_MASK)
#define XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV_MASK   (0x80000000U)
#define XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV_SHIFT   (31U)
#define XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV_MASK)
MISC0_TOG - Miscellaneous Register 0
#define XTALOSC24M_MISC0_TOG_REFTOP_PWD_MASK   (0x1U)
#define XTALOSC24M_MISC0_TOG_REFTOP_PWD_SHIFT   (0U)
#define XTALOSC24M_MISC0_TOG_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_REFTOP_PWD_SHIFT)) & XTALOSC24M_MISC0_TOG_REFTOP_PWD_MASK)
#define XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF_MASK   (0x8U)
#define XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF_SHIFT   (3U)
#define XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF_MASK)
#define XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ_MASK   (0x70U)
#define XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ_SHIFT   (4U)
#define XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ_MASK)
#define XTALOSC24M_MISC0_TOG_REFTOP_VBGUP_MASK   (0x80U)
#define XTALOSC24M_MISC0_TOG_REFTOP_VBGUP_SHIFT   (7U)
#define XTALOSC24M_MISC0_TOG_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_REFTOP_VBGUP_SHIFT)) & XTALOSC24M_MISC0_TOG_REFTOP_VBGUP_MASK)
#define XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG_MASK   (0xC00U)
#define XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG_SHIFT   (10U)
#define XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG_MASK)
#define XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS_MASK   (0x1000U)
#define XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS_SHIFT   (12U)
#define XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS_MASK)
#define XTALOSC24M_MISC0_TOG_OSC_I_MASK   (0x6000U)
#define XTALOSC24M_MISC0_TOG_OSC_I_SHIFT   (13U)
#define XTALOSC24M_MISC0_TOG_OSC_I(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_OSC_I_SHIFT)) & XTALOSC24M_MISC0_TOG_OSC_I_MASK)
#define XTALOSC24M_MISC0_TOG_OSC_XTALOK_MASK   (0x8000U)
#define XTALOSC24M_MISC0_TOG_OSC_XTALOK_SHIFT   (15U)
#define XTALOSC24M_MISC0_TOG_OSC_XTALOK(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_OSC_XTALOK_SHIFT)) & XTALOSC24M_MISC0_TOG_OSC_XTALOK_MASK)
#define XTALOSC24M_MISC0_TOG_OSC_XTALOK_EN_MASK   (0x10000U)
#define XTALOSC24M_MISC0_TOG_OSC_XTALOK_EN_SHIFT   (16U)
#define XTALOSC24M_MISC0_TOG_OSC_XTALOK_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_OSC_XTALOK_EN_SHIFT)) & XTALOSC24M_MISC0_TOG_OSC_XTALOK_EN_MASK)
#define XTALOSC24M_MISC0_TOG_CLKGATE_CTRL_MASK   (0x2000000U)
#define XTALOSC24M_MISC0_TOG_CLKGATE_CTRL_SHIFT   (25U)
#define XTALOSC24M_MISC0_TOG_CLKGATE_CTRL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_TOG_CLKGATE_CTRL_MASK)
#define XTALOSC24M_MISC0_TOG_CLKGATE_DELAY_MASK   (0x1C000000U)
#define XTALOSC24M_MISC0_TOG_CLKGATE_DELAY_SHIFT   (26U)
#define XTALOSC24M_MISC0_TOG_CLKGATE_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_TOG_CLKGATE_DELAY_MASK)
#define XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE_MASK   (0x20000000U)
#define XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE_SHIFT   (29U)
#define XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE_MASK)
#define XTALOSC24M_MISC0_TOG_XTAL_24M_PWD_MASK   (0x40000000U)
#define XTALOSC24M_MISC0_TOG_XTAL_24M_PWD_SHIFT   (30U)
#define XTALOSC24M_MISC0_TOG_XTAL_24M_PWD(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_XTAL_24M_PWD_SHIFT)) & XTALOSC24M_MISC0_TOG_XTAL_24M_PWD_MASK)
#define XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV_MASK   (0x80000000U)
#define XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV_SHIFT   (31U)
#define XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV_MASK)
LOWPWR_CTRL - XTAL OSC (LP) Control Register
#define XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN_MASK   (0x1U)
#define XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN_SHIFT   (0U)
#define XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN_MASK)
#define XTALOSC24M_LOWPWR_CTRL_OSC_SEL_MASK   (0x10U)
#define XTALOSC24M_LOWPWR_CTRL_OSC_SEL_SHIFT   (4U)
#define XTALOSC24M_LOWPWR_CTRL_OSC_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_OSC_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_LPBG_SEL_MASK   (0x20U)
#define XTALOSC24M_LOWPWR_CTRL_LPBG_SEL_SHIFT   (5U)
#define XTALOSC24M_LOWPWR_CTRL_LPBG_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_LPBG_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_LPBG_TEST_MASK   (0x40U)
#define XTALOSC24M_LOWPWR_CTRL_LPBG_TEST_SHIFT   (6U)
#define XTALOSC24M_LOWPWR_CTRL_LPBG_TEST(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_LPBG_TEST_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_LPBG_TEST_MASK)
#define XTALOSC24M_LOWPWR_CTRL_REFTOP_IBIAS_OFF_MASK   (0x80U)
#define XTALOSC24M_LOWPWR_CTRL_REFTOP_IBIAS_OFF_SHIFT   (7U)
#define XTALOSC24M_LOWPWR_CTRL_REFTOP_IBIAS_OFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_REFTOP_IBIAS_OFF_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_REFTOP_IBIAS_OFF_MASK)
#define XTALOSC24M_LOWPWR_CTRL_L1_PWRGATE_MASK   (0x100U)
#define XTALOSC24M_LOWPWR_CTRL_L1_PWRGATE_SHIFT   (8U)
#define XTALOSC24M_LOWPWR_CTRL_L1_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_L1_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_L1_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_L2_PWRGATE_MASK   (0x200U)
#define XTALOSC24M_LOWPWR_CTRL_L2_PWRGATE_SHIFT   (9U)
#define XTALOSC24M_LOWPWR_CTRL_L2_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_L2_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_L2_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CPU_PWRGATE_MASK   (0x400U)
#define XTALOSC24M_LOWPWR_CTRL_CPU_PWRGATE_SHIFT   (10U)
#define XTALOSC24M_LOWPWR_CTRL_CPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CPU_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_DISPLAY_PWRGATE_MASK   (0x800U)
#define XTALOSC24M_LOWPWR_CTRL_DISPLAY_PWRGATE_SHIFT   (11U)
#define XTALOSC24M_LOWPWR_CTRL_DISPLAY_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_DISPLAY_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_DISPLAY_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_RCOSC_CG_OVERRIDE_MASK   (0x2000U)
#define XTALOSC24M_LOWPWR_CTRL_RCOSC_CG_OVERRIDE_SHIFT   (13U)
#define XTALOSC24M_LOWPWR_CTRL_RCOSC_CG_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_RCOSC_CG_OVERRIDE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_RCOSC_CG_OVERRIDE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY_MASK   (0xC000U)
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY_SHIFT   (14U)
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY_MASK)
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT_MASK   (0x10000U)
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT_SHIFT   (16U)
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT_MASK)
#define XTALOSC24M_LOWPWR_CTRL_MIX_PWRGATE_MASK   (0x20000U)
#define XTALOSC24M_LOWPWR_CTRL_MIX_PWRGATE_SHIFT   (17U)
#define XTALOSC24M_LOWPWR_CTRL_MIX_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_MIX_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_MIX_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_GPU_PWRGATE_MASK   (0x40000U)
#define XTALOSC24M_LOWPWR_CTRL_GPU_PWRGATE_SHIFT   (18U)
#define XTALOSC24M_LOWPWR_CTRL_GPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_GPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_GPU_PWRGATE_MASK)
LOWPWR_CTRL_SET - XTAL OSC (LP) Control Register
#define XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN_MASK   (0x1U)
#define XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN_SHIFT   (0U)
#define XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL_MASK   (0x10U)
#define XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL_SHIFT   (4U)
#define XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL_MASK   (0x20U)
#define XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL_SHIFT   (5U)
#define XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_LPBG_TEST_MASK   (0x40U)
#define XTALOSC24M_LOWPWR_CTRL_SET_LPBG_TEST_SHIFT   (6U)
#define XTALOSC24M_LOWPWR_CTRL_SET_LPBG_TEST(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_LPBG_TEST_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_LPBG_TEST_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_REFTOP_IBIAS_OFF_MASK   (0x80U)
#define XTALOSC24M_LOWPWR_CTRL_SET_REFTOP_IBIAS_OFF_SHIFT   (7U)
#define XTALOSC24M_LOWPWR_CTRL_SET_REFTOP_IBIAS_OFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_REFTOP_IBIAS_OFF_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_REFTOP_IBIAS_OFF_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_L1_PWRGATE_MASK   (0x100U)
#define XTALOSC24M_LOWPWR_CTRL_SET_L1_PWRGATE_SHIFT   (8U)
#define XTALOSC24M_LOWPWR_CTRL_SET_L1_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_L1_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_L1_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_L2_PWRGATE_MASK   (0x200U)
#define XTALOSC24M_LOWPWR_CTRL_SET_L2_PWRGATE_SHIFT   (9U)
#define XTALOSC24M_LOWPWR_CTRL_SET_L2_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_L2_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_L2_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_CPU_PWRGATE_MASK   (0x400U)
#define XTALOSC24M_LOWPWR_CTRL_SET_CPU_PWRGATE_SHIFT   (10U)
#define XTALOSC24M_LOWPWR_CTRL_SET_CPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_CPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_CPU_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_MASK   (0x800U)
#define XTALOSC24M_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_SHIFT   (11U)
#define XTALOSC24M_LOWPWR_CTRL_SET_DISPLAY_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_RCOSC_CG_OVERRIDE_MASK   (0x2000U)
#define XTALOSC24M_LOWPWR_CTRL_SET_RCOSC_CG_OVERRIDE_SHIFT   (13U)
#define XTALOSC24M_LOWPWR_CTRL_SET_RCOSC_CG_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_RCOSC_CG_OVERRIDE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_RCOSC_CG_OVERRIDE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY_MASK   (0xC000U)
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY_SHIFT   (14U)
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT_MASK   (0x10000U)
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT_SHIFT   (16U)
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_MIX_PWRGATE_MASK   (0x20000U)
#define XTALOSC24M_LOWPWR_CTRL_SET_MIX_PWRGATE_SHIFT   (17U)
#define XTALOSC24M_LOWPWR_CTRL_SET_MIX_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_MIX_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_MIX_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_SET_GPU_PWRGATE_MASK   (0x40000U)
#define XTALOSC24M_LOWPWR_CTRL_SET_GPU_PWRGATE_SHIFT   (18U)
#define XTALOSC24M_LOWPWR_CTRL_SET_GPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_GPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_GPU_PWRGATE_MASK)
LOWPWR_CTRL_CLR - XTAL OSC (LP) Control Register
#define XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN_MASK   (0x1U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN_SHIFT   (0U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL_MASK   (0x10U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL_SHIFT   (4U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL_MASK   (0x20U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL_SHIFT   (5U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_TEST_MASK   (0x40U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_TEST_SHIFT   (6U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_TEST(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_TEST_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_TEST_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_REFTOP_IBIAS_OFF_MASK   (0x80U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_REFTOP_IBIAS_OFF_SHIFT   (7U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_REFTOP_IBIAS_OFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_REFTOP_IBIAS_OFF_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_REFTOP_IBIAS_OFF_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_L1_PWRGATE_MASK   (0x100U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_L1_PWRGATE_SHIFT   (8U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_L1_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_L1_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_L1_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_L2_PWRGATE_MASK   (0x200U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_L2_PWRGATE_SHIFT   (9U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_L2_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_L2_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_L2_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_CPU_PWRGATE_MASK   (0x400U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_CPU_PWRGATE_SHIFT   (10U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_CPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_CPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_CPU_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_MASK   (0x800U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_SHIFT   (11U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_RCOSC_CG_OVERRIDE_MASK   (0x2000U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_RCOSC_CG_OVERRIDE_SHIFT   (13U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_RCOSC_CG_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_RCOSC_CG_OVERRIDE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_RCOSC_CG_OVERRIDE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY_MASK   (0xC000U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY_SHIFT   (14U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT_MASK   (0x10000U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT_SHIFT   (16U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_MIX_PWRGATE_MASK   (0x20000U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_MIX_PWRGATE_SHIFT   (17U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_MIX_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_MIX_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_MIX_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_CLR_GPU_PWRGATE_MASK   (0x40000U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_GPU_PWRGATE_SHIFT   (18U)
#define XTALOSC24M_LOWPWR_CTRL_CLR_GPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_GPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_GPU_PWRGATE_MASK)
LOWPWR_CTRL_TOG - XTAL OSC (LP) Control Register
#define XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN_MASK   (0x1U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN_SHIFT   (0U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL_MASK   (0x10U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL_SHIFT   (4U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL_MASK   (0x20U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL_SHIFT   (5U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_TEST_MASK   (0x40U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_TEST_SHIFT   (6U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_TEST(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_TEST_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_TEST_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_REFTOP_IBIAS_OFF_MASK   (0x80U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_REFTOP_IBIAS_OFF_SHIFT   (7U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_REFTOP_IBIAS_OFF(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_REFTOP_IBIAS_OFF_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_REFTOP_IBIAS_OFF_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_L1_PWRGATE_MASK   (0x100U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_L1_PWRGATE_SHIFT   (8U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_L1_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_L1_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_L1_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_L2_PWRGATE_MASK   (0x200U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_L2_PWRGATE_SHIFT   (9U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_L2_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_L2_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_L2_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_CPU_PWRGATE_MASK   (0x400U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_CPU_PWRGATE_SHIFT   (10U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_CPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_CPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_CPU_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_MASK   (0x800U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_SHIFT   (11U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_RCOSC_CG_OVERRIDE_MASK   (0x2000U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_RCOSC_CG_OVERRIDE_SHIFT   (13U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_RCOSC_CG_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_RCOSC_CG_OVERRIDE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_RCOSC_CG_OVERRIDE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY_MASK   (0xC000U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY_SHIFT   (14U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT_MASK   (0x10000U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT_SHIFT   (16U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_MIX_PWRGATE_MASK   (0x20000U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_MIX_PWRGATE_SHIFT   (17U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_MIX_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_MIX_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_MIX_PWRGATE_MASK)
#define XTALOSC24M_LOWPWR_CTRL_TOG_GPU_PWRGATE_MASK   (0x40000U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_GPU_PWRGATE_SHIFT   (18U)
#define XTALOSC24M_LOWPWR_CTRL_TOG_GPU_PWRGATE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_GPU_PWRGATE_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_GPU_PWRGATE_MASK)
OSC_CONFIG0 - XTAL OSC Configuration 0 Register
#define XTALOSC24M_OSC_CONFIG0_START_MASK   (0x1U)
#define XTALOSC24M_OSC_CONFIG0_START_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG0_START(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_START_SHIFT)) & XTALOSC24M_OSC_CONFIG0_START_MASK)
#define XTALOSC24M_OSC_CONFIG0_ENABLE_MASK   (0x2U)
#define XTALOSC24M_OSC_CONFIG0_ENABLE_SHIFT   (1U)
#define XTALOSC24M_OSC_CONFIG0_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_ENABLE_SHIFT)) & XTALOSC24M_OSC_CONFIG0_ENABLE_MASK)
#define XTALOSC24M_OSC_CONFIG0_BYPASS_MASK   (0x4U)
#define XTALOSC24M_OSC_CONFIG0_BYPASS_SHIFT   (2U)
#define XTALOSC24M_OSC_CONFIG0_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_BYPASS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_BYPASS_MASK)
#define XTALOSC24M_OSC_CONFIG0_INVERT_MASK   (0x8U)
#define XTALOSC24M_OSC_CONFIG0_INVERT_SHIFT   (3U)
#define XTALOSC24M_OSC_CONFIG0_INVERT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_INVERT_SHIFT)) & XTALOSC24M_OSC_CONFIG0_INVERT_MASK)
#define XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_MASK   (0xFF0U)
#define XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_SHIFT   (4U)
#define XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_SHIFT)) & XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_MASK)
#define XTALOSC24M_OSC_CONFIG0_HYST_PLUS_MASK   (0xF000U)
#define XTALOSC24M_OSC_CONFIG0_HYST_PLUS_SHIFT   (12U)
#define XTALOSC24M_OSC_CONFIG0_HYST_PLUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_HYST_PLUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_HYST_PLUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_HYST_MINUS_MASK   (0xF0000U)
#define XTALOSC24M_OSC_CONFIG0_HYST_MINUS_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG0_HYST_MINUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_HYST_MINUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_HYST_MINUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_CUR_MASK   (0xFF000000U)
#define XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_CUR_SHIFT   (24U)
#define XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG0_RC_OSC_PROG_CUR_MASK)
OSC_CONFIG0_SET - XTAL OSC Configuration 0 Register
#define XTALOSC24M_OSC_CONFIG0_SET_START_MASK   (0x1U)
#define XTALOSC24M_OSC_CONFIG0_SET_START_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG0_SET_START(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_START_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_START_MASK)
#define XTALOSC24M_OSC_CONFIG0_SET_ENABLE_MASK   (0x2U)
#define XTALOSC24M_OSC_CONFIG0_SET_ENABLE_SHIFT   (1U)
#define XTALOSC24M_OSC_CONFIG0_SET_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_ENABLE_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_ENABLE_MASK)
#define XTALOSC24M_OSC_CONFIG0_SET_BYPASS_MASK   (0x4U)
#define XTALOSC24M_OSC_CONFIG0_SET_BYPASS_SHIFT   (2U)
#define XTALOSC24M_OSC_CONFIG0_SET_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_BYPASS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_BYPASS_MASK)
#define XTALOSC24M_OSC_CONFIG0_SET_INVERT_MASK   (0x8U)
#define XTALOSC24M_OSC_CONFIG0_SET_INVERT_SHIFT   (3U)
#define XTALOSC24M_OSC_CONFIG0_SET_INVERT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_INVERT_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_INVERT_MASK)
#define XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_MASK   (0xFF0U)
#define XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_SHIFT   (4U)
#define XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_MASK)
#define XTALOSC24M_OSC_CONFIG0_SET_HYST_PLUS_MASK   (0xF000U)
#define XTALOSC24M_OSC_CONFIG0_SET_HYST_PLUS_SHIFT   (12U)
#define XTALOSC24M_OSC_CONFIG0_SET_HYST_PLUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_HYST_PLUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_HYST_PLUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_SET_HYST_MINUS_MASK   (0xF0000U)
#define XTALOSC24M_OSC_CONFIG0_SET_HYST_MINUS_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG0_SET_HYST_MINUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_HYST_MINUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_HYST_MINUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_CUR_MASK   (0xFF000000U)
#define XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_CUR_SHIFT   (24U)
#define XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG0_SET_RC_OSC_PROG_CUR_MASK)
OSC_CONFIG0_CLR - XTAL OSC Configuration 0 Register
#define XTALOSC24M_OSC_CONFIG0_CLR_START_MASK   (0x1U)
#define XTALOSC24M_OSC_CONFIG0_CLR_START_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG0_CLR_START(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_START_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_START_MASK)
#define XTALOSC24M_OSC_CONFIG0_CLR_ENABLE_MASK   (0x2U)
#define XTALOSC24M_OSC_CONFIG0_CLR_ENABLE_SHIFT   (1U)
#define XTALOSC24M_OSC_CONFIG0_CLR_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_ENABLE_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_ENABLE_MASK)
#define XTALOSC24M_OSC_CONFIG0_CLR_BYPASS_MASK   (0x4U)
#define XTALOSC24M_OSC_CONFIG0_CLR_BYPASS_SHIFT   (2U)
#define XTALOSC24M_OSC_CONFIG0_CLR_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_BYPASS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_BYPASS_MASK)
#define XTALOSC24M_OSC_CONFIG0_CLR_INVERT_MASK   (0x8U)
#define XTALOSC24M_OSC_CONFIG0_CLR_INVERT_SHIFT   (3U)
#define XTALOSC24M_OSC_CONFIG0_CLR_INVERT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_INVERT_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_INVERT_MASK)
#define XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_MASK   (0xFF0U)
#define XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_SHIFT   (4U)
#define XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_MASK)
#define XTALOSC24M_OSC_CONFIG0_CLR_HYST_PLUS_MASK   (0xF000U)
#define XTALOSC24M_OSC_CONFIG0_CLR_HYST_PLUS_SHIFT   (12U)
#define XTALOSC24M_OSC_CONFIG0_CLR_HYST_PLUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_HYST_PLUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_HYST_PLUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_CLR_HYST_MINUS_MASK   (0xF0000U)
#define XTALOSC24M_OSC_CONFIG0_CLR_HYST_MINUS_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG0_CLR_HYST_MINUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_HYST_MINUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_HYST_MINUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_CUR_MASK   (0xFF000000U)
#define XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_CUR_SHIFT   (24U)
#define XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG0_CLR_RC_OSC_PROG_CUR_MASK)
OSC_CONFIG0_TOG - XTAL OSC Configuration 0 Register
#define XTALOSC24M_OSC_CONFIG0_TOG_START_MASK   (0x1U)
#define XTALOSC24M_OSC_CONFIG0_TOG_START_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG0_TOG_START(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_START_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_START_MASK)
#define XTALOSC24M_OSC_CONFIG0_TOG_ENABLE_MASK   (0x2U)
#define XTALOSC24M_OSC_CONFIG0_TOG_ENABLE_SHIFT   (1U)
#define XTALOSC24M_OSC_CONFIG0_TOG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_ENABLE_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_ENABLE_MASK)
#define XTALOSC24M_OSC_CONFIG0_TOG_BYPASS_MASK   (0x4U)
#define XTALOSC24M_OSC_CONFIG0_TOG_BYPASS_SHIFT   (2U)
#define XTALOSC24M_OSC_CONFIG0_TOG_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_BYPASS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_BYPASS_MASK)
#define XTALOSC24M_OSC_CONFIG0_TOG_INVERT_MASK   (0x8U)
#define XTALOSC24M_OSC_CONFIG0_TOG_INVERT_SHIFT   (3U)
#define XTALOSC24M_OSC_CONFIG0_TOG_INVERT(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_INVERT_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_INVERT_MASK)
#define XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_MASK   (0xFF0U)
#define XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_SHIFT   (4U)
#define XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_MASK)
#define XTALOSC24M_OSC_CONFIG0_TOG_HYST_PLUS_MASK   (0xF000U)
#define XTALOSC24M_OSC_CONFIG0_TOG_HYST_PLUS_SHIFT   (12U)
#define XTALOSC24M_OSC_CONFIG0_TOG_HYST_PLUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_HYST_PLUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_HYST_PLUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_TOG_HYST_MINUS_MASK   (0xF0000U)
#define XTALOSC24M_OSC_CONFIG0_TOG_HYST_MINUS_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG0_TOG_HYST_MINUS(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_HYST_MINUS_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_HYST_MINUS_MASK)
#define XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_CUR_MASK   (0xFF000000U)
#define XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_CUR_SHIFT   (24U)
#define XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG0_TOG_RC_OSC_PROG_CUR_MASK)
OSC_CONFIG1 - XTAL OSC Configuration 1 Register
#define XTALOSC24M_OSC_CONFIG1_COUNT_RC_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG1_COUNT_RC_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG1_COUNT_RC_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_COUNT_RC_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG1_COUNT_RC_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG1_COUNT_RC_CUR_MASK   (0xFFF00000U)
#define XTALOSC24M_OSC_CONFIG1_COUNT_RC_CUR_SHIFT   (20U)
#define XTALOSC24M_OSC_CONFIG1_COUNT_RC_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_COUNT_RC_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG1_COUNT_RC_CUR_MASK)
OSC_CONFIG1_SET - XTAL OSC Configuration 1 Register
#define XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_CUR_MASK   (0xFFF00000U)
#define XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_CUR_SHIFT   (20U)
#define XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG1_SET_COUNT_RC_CUR_MASK)
OSC_CONFIG1_CLR - XTAL OSC Configuration 1 Register
#define XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_CUR_MASK   (0xFFF00000U)
#define XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_CUR_SHIFT   (20U)
#define XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG1_CLR_COUNT_RC_CUR_MASK)
OSC_CONFIG1_TOG - XTAL OSC Configuration 1 Register
#define XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_CUR_MASK   (0xFFF00000U)
#define XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_CUR_SHIFT   (20U)
#define XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_CUR(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_CUR_SHIFT)) & XTALOSC24M_OSC_CONFIG1_TOG_COUNT_RC_CUR_MASK)
OSC_CONFIG2 - XTAL OSC Configuration 2 Register
#define XTALOSC24M_OSC_CONFIG2_COUNT_1M_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG2_COUNT_1M_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG2_COUNT_1M_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_COUNT_1M_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG2_COUNT_1M_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG2_ENABLE_1M_MASK   (0x10000U)
#define XTALOSC24M_OSC_CONFIG2_ENABLE_1M_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG2_ENABLE_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_ENABLE_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_ENABLE_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_MUX_1M_MASK   (0x20000U)
#define XTALOSC24M_OSC_CONFIG2_MUX_1M_SHIFT   (17U)
#define XTALOSC24M_OSC_CONFIG2_MUX_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_MUX_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_MUX_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_CLK_1M_ERR_FL_MASK   (0x80000000U)
#define XTALOSC24M_OSC_CONFIG2_CLK_1M_ERR_FL_SHIFT   (31U)
#define XTALOSC24M_OSC_CONFIG2_CLK_1M_ERR_FL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_CLK_1M_ERR_FL_SHIFT)) & XTALOSC24M_OSC_CONFIG2_CLK_1M_ERR_FL_MASK)
OSC_CONFIG2_SET - XTAL OSC Configuration 2 Register
#define XTALOSC24M_OSC_CONFIG2_SET_COUNT_1M_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG2_SET_COUNT_1M_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG2_SET_COUNT_1M_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_SET_COUNT_1M_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG2_SET_COUNT_1M_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG2_SET_ENABLE_1M_MASK   (0x10000U)
#define XTALOSC24M_OSC_CONFIG2_SET_ENABLE_1M_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG2_SET_ENABLE_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_SET_ENABLE_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_SET_ENABLE_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_SET_MUX_1M_MASK   (0x20000U)
#define XTALOSC24M_OSC_CONFIG2_SET_MUX_1M_SHIFT   (17U)
#define XTALOSC24M_OSC_CONFIG2_SET_MUX_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_SET_MUX_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_SET_MUX_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_SET_CLK_1M_ERR_FL_MASK   (0x80000000U)
#define XTALOSC24M_OSC_CONFIG2_SET_CLK_1M_ERR_FL_SHIFT   (31U)
#define XTALOSC24M_OSC_CONFIG2_SET_CLK_1M_ERR_FL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_SET_CLK_1M_ERR_FL_SHIFT)) & XTALOSC24M_OSC_CONFIG2_SET_CLK_1M_ERR_FL_MASK)
OSC_CONFIG2_CLR - XTAL OSC Configuration 2 Register
#define XTALOSC24M_OSC_CONFIG2_CLR_COUNT_1M_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG2_CLR_COUNT_1M_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG2_CLR_COUNT_1M_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_CLR_COUNT_1M_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG2_CLR_COUNT_1M_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG2_CLR_ENABLE_1M_MASK   (0x10000U)
#define XTALOSC24M_OSC_CONFIG2_CLR_ENABLE_1M_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG2_CLR_ENABLE_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_CLR_ENABLE_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_CLR_ENABLE_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_CLR_MUX_1M_MASK   (0x20000U)
#define XTALOSC24M_OSC_CONFIG2_CLR_MUX_1M_SHIFT   (17U)
#define XTALOSC24M_OSC_CONFIG2_CLR_MUX_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_CLR_MUX_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_CLR_MUX_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_CLR_CLK_1M_ERR_FL_MASK   (0x80000000U)
#define XTALOSC24M_OSC_CONFIG2_CLR_CLK_1M_ERR_FL_SHIFT   (31U)
#define XTALOSC24M_OSC_CONFIG2_CLR_CLK_1M_ERR_FL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_CLR_CLK_1M_ERR_FL_SHIFT)) & XTALOSC24M_OSC_CONFIG2_CLR_CLK_1M_ERR_FL_MASK)
OSC_CONFIG2_TOG - XTAL OSC Configuration 2 Register
#define XTALOSC24M_OSC_CONFIG2_TOG_COUNT_1M_TRG_MASK   (0xFFFU)
#define XTALOSC24M_OSC_CONFIG2_TOG_COUNT_1M_TRG_SHIFT   (0U)
#define XTALOSC24M_OSC_CONFIG2_TOG_COUNT_1M_TRG(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_TOG_COUNT_1M_TRG_SHIFT)) & XTALOSC24M_OSC_CONFIG2_TOG_COUNT_1M_TRG_MASK)
#define XTALOSC24M_OSC_CONFIG2_TOG_ENABLE_1M_MASK   (0x10000U)
#define XTALOSC24M_OSC_CONFIG2_TOG_ENABLE_1M_SHIFT   (16U)
#define XTALOSC24M_OSC_CONFIG2_TOG_ENABLE_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_TOG_ENABLE_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_TOG_ENABLE_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_TOG_MUX_1M_MASK   (0x20000U)
#define XTALOSC24M_OSC_CONFIG2_TOG_MUX_1M_SHIFT   (17U)
#define XTALOSC24M_OSC_CONFIG2_TOG_MUX_1M(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_TOG_MUX_1M_SHIFT)) & XTALOSC24M_OSC_CONFIG2_TOG_MUX_1M_MASK)
#define XTALOSC24M_OSC_CONFIG2_TOG_CLK_1M_ERR_FL_MASK   (0x80000000U)
#define XTALOSC24M_OSC_CONFIG2_TOG_CLK_1M_ERR_FL_SHIFT   (31U)
#define XTALOSC24M_OSC_CONFIG2_TOG_CLK_1M_ERR_FL(x)   (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_OSC_CONFIG2_TOG_CLK_1M_ERR_FL_SHIFT)) & XTALOSC24M_OSC_CONFIG2_TOG_CLK_1M_ERR_FL_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL
#define XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_LPBG_SEL_MASK)
LPBG_SEL 0b0..Normal power bandgap 0b1..Low power bandgap
◆ XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL
#define XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_OSC_SEL_MASK)
OSC_SEL 0b0..XTAL OSC 0b1..RC OSC
◆ XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN
#define XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_RC_OSC_EN_MASK)
RC_OSC_EN 0b0..Use XTAL OSC to source the 24MHz clock 0b1..Use RC OSC
◆ XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_DELAY_MASK)
XTALOSC_PWRUP_DELAY 0b00..0.25ms 0b01..0.5ms 0b10..1ms 0b11..2ms
◆ XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT
#define XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_CLR_XTALOSC_PWRUP_STAT_MASK)
XTALOSC_PWRUP_STAT 0b0..Not stable 0b1..Stable and ready to use
◆ XTALOSC24M_LOWPWR_CTRL_LPBG_SEL
#define XTALOSC24M_LOWPWR_CTRL_LPBG_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_LPBG_SEL_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_OSC_SEL
#define XTALOSC24M_LOWPWR_CTRL_OSC_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_OSC_SEL_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN
#define XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_RC_OSC_EN_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL
#define XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_LPBG_SEL_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL
#define XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_OSC_SEL_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN
#define XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_RC_OSC_EN_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_DELAY_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT
#define XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_SET_XTALOSC_PWRUP_STAT_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL
#define XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_LPBG_SEL_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL
#define XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_OSC_SEL_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN
#define XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_RC_OSC_EN_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_DELAY_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT
#define XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_TOG_XTALOSC_PWRUP_STAT_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_DELAY_MASK)
◆ XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT
#define XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT_SHIFT)) & XTALOSC24M_LOWPWR_CTRL_XTALOSC_PWRUP_STAT_MASK)
◆ XTALOSC24M_MISC0_CLKGATE_CTRL
#define XTALOSC24M_MISC0_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_CLKGATE_CTRL_MASK)
CLKGATE_CTRL 0b0..Allow the logic to automatically gate the clock when the XTAL is powered down. 0b1..Prevent the logic from ever gating off the clock.
◆ XTALOSC24M_MISC0_CLKGATE_DELAY
#define XTALOSC24M_MISC0_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_CLKGATE_DELAY_MASK)
CLKGATE_DELAY 0b000..0.5ms 0b001..1.0ms 0b010..2.0ms 0b011..3.0ms 0b100..4.0ms 0b101..5.0ms 0b110..6.0ms 0b111..7.0ms
◆ XTALOSC24M_MISC0_CLR_CLKGATE_CTRL
#define XTALOSC24M_MISC0_CLR_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_CLR_CLKGATE_CTRL_MASK)
◆ XTALOSC24M_MISC0_CLR_CLKGATE_DELAY
#define XTALOSC24M_MISC0_CLR_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_CLR_CLKGATE_DELAY_MASK)
◆ XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS
#define XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_CLR_DISCON_HIGH_SNVS_MASK)
DISCON_HIGH_SNVS 0b0..Turn on the switch 0b1..Turn off the switch
◆ XTALOSC24M_MISC0_CLR_OSC_I
#define XTALOSC24M_MISC0_CLR_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_OSC_I_SHIFT)) & XTALOSC24M_MISC0_CLR_OSC_I_MASK)
OSC_I 0b00..Nominal 0b01..Decrease current by 12.5% 0b10..Decrease current by 25.0% 0b11..Decrease current by 37.5%
◆ XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF
#define XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_CLR_REFTOP_SELFBIASOFF_MASK)
REFTOP_SELFBIASOFF 0b0..Uses coarse bias currents for startup 0b1..Uses bandgap-based bias currents for best performance.
◆ XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ
#define XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_CLR_REFTOP_VBGADJ_MASK)
REFTOP_VBGADJ 0b000..Nominal VBG 0b001..VBG+0.78% 0b010..VBG+1.56% 0b011..VBG+2.34% 0b100..VBG-0.78% 0b101..VBG-1.56% 0b110..VBG-2.34% 0b111..VBG-3.12%
◆ XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE
#define XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_CLR_RTC_XTAL_SOURCE_MASK)
RTC_XTAL_SOURCE 0b0..Internal ring oscillator 0b1..RTC_XTAL
◆ XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG
#define XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_CLR_STOP_MODE_CONFIG_MASK)
STOP_MODE_CONFIG 0b00..All analog except rtc powered down on stop mode assertion. XtalOsc=on, RCOsc=off; 0b01..Certain analog functions such as certain regulators left up. XtalOsc=on, RCOsc=off; 0b10..XtalOsc=off, RCOsc=on, Old BG=on, New BG=off. 0b11..XtalOsc=off, RCOsc=on, Old BG=off, New BG=on.
◆ XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV
#define XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_CLR_VID_PLL_PREDIV_MASK)
VID_PLL_PREDIV 0b0..Divide by 1 0b1..Divide by 2
◆ XTALOSC24M_MISC0_DISCON_HIGH_SNVS
#define XTALOSC24M_MISC0_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_DISCON_HIGH_SNVS_MASK)
◆ XTALOSC24M_MISC0_OSC_I
#define XTALOSC24M_MISC0_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_OSC_I_SHIFT)) & XTALOSC24M_MISC0_OSC_I_MASK)
◆ XTALOSC24M_MISC0_REFTOP_SELFBIASOFF
#define XTALOSC24M_MISC0_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_REFTOP_SELFBIASOFF_MASK)
◆ XTALOSC24M_MISC0_REFTOP_VBGADJ
#define XTALOSC24M_MISC0_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_REFTOP_VBGADJ_MASK)
◆ XTALOSC24M_MISC0_RTC_XTAL_SOURCE
#define XTALOSC24M_MISC0_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_RTC_XTAL_SOURCE_MASK)
◆ XTALOSC24M_MISC0_SET_CLKGATE_CTRL
#define XTALOSC24M_MISC0_SET_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_SET_CLKGATE_CTRL_MASK)
◆ XTALOSC24M_MISC0_SET_CLKGATE_DELAY
#define XTALOSC24M_MISC0_SET_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_SET_CLKGATE_DELAY_MASK)
◆ XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS
#define XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_SET_DISCON_HIGH_SNVS_MASK)
◆ XTALOSC24M_MISC0_SET_OSC_I
#define XTALOSC24M_MISC0_SET_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_OSC_I_SHIFT)) & XTALOSC24M_MISC0_SET_OSC_I_MASK)
◆ XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF
#define XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_SET_REFTOP_SELFBIASOFF_MASK)
◆ XTALOSC24M_MISC0_SET_REFTOP_VBGADJ
#define XTALOSC24M_MISC0_SET_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_SET_REFTOP_VBGADJ_MASK)
◆ XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE
#define XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_SET_RTC_XTAL_SOURCE_MASK)
◆ XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG
#define XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_SET_STOP_MODE_CONFIG_MASK)
◆ XTALOSC24M_MISC0_SET_VID_PLL_PREDIV
#define XTALOSC24M_MISC0_SET_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_SET_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_SET_VID_PLL_PREDIV_MASK)
◆ XTALOSC24M_MISC0_STOP_MODE_CONFIG
#define XTALOSC24M_MISC0_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_STOP_MODE_CONFIG_MASK)
◆ XTALOSC24M_MISC0_TOG_CLKGATE_CTRL
#define XTALOSC24M_MISC0_TOG_CLKGATE_CTRL (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_CLKGATE_CTRL_SHIFT)) & XTALOSC24M_MISC0_TOG_CLKGATE_CTRL_MASK)
◆ XTALOSC24M_MISC0_TOG_CLKGATE_DELAY
#define XTALOSC24M_MISC0_TOG_CLKGATE_DELAY (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_CLKGATE_DELAY_SHIFT)) & XTALOSC24M_MISC0_TOG_CLKGATE_DELAY_MASK)
◆ XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS
#define XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS_SHIFT)) & XTALOSC24M_MISC0_TOG_DISCON_HIGH_SNVS_MASK)
◆ XTALOSC24M_MISC0_TOG_OSC_I
#define XTALOSC24M_MISC0_TOG_OSC_I (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_OSC_I_SHIFT)) & XTALOSC24M_MISC0_TOG_OSC_I_MASK)
◆ XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF
#define XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF_SHIFT)) & XTALOSC24M_MISC0_TOG_REFTOP_SELFBIASOFF_MASK)
◆ XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ
#define XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ_SHIFT)) & XTALOSC24M_MISC0_TOG_REFTOP_VBGADJ_MASK)
◆ XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE
#define XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE_SHIFT)) & XTALOSC24M_MISC0_TOG_RTC_XTAL_SOURCE_MASK)
◆ XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG
#define XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG_SHIFT)) & XTALOSC24M_MISC0_TOG_STOP_MODE_CONFIG_MASK)
◆ XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV
#define XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_TOG_VID_PLL_PREDIV_MASK)
◆ XTALOSC24M_MISC0_VID_PLL_PREDIV
#define XTALOSC24M_MISC0_VID_PLL_PREDIV (   x)    (((uint32_t)(((uint32_t)(x)) << XTALOSC24M_MISC0_VID_PLL_PREDIV_SHIFT)) & XTALOSC24M_MISC0_VID_PLL_PREDIV_MASK)
