RTEMS 6.1
PWD - USB PHY Power-Down Register
#define USBPHY_PWD_RSVD0_MASK   (0x3FFU)
#define USBPHY_PWD_RSVD0_SHIFT   (0U)
#define USBPHY_PWD_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RSVD0_SHIFT)) & USBPHY_PWD_RSVD0_MASK)
#define USBPHY_PWD_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDFS_SHIFT)) & USBPHY_PWD_TXPWDFS_MASK)
#define USBPHY_PWD_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TXPWDIBIAS_MASK)
#define USBPHY_PWD_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDV2I_SHIFT)) & USBPHY_PWD_TXPWDV2I_MASK)
#define USBPHY_PWD_RSVD1_MASK   (0x1E000U)
#define USBPHY_PWD_RSVD1_SHIFT   (13U)
#define USBPHY_PWD_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RSVD1_SHIFT)) & USBPHY_PWD_RSVD1_MASK)
#define USBPHY_PWD_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDENV_SHIFT)) & USBPHY_PWD_RXPWDENV_MASK)
#define USBPHY_PWD_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWD1PT1_SHIFT)) & USBPHY_PWD_RXPWD1PT1_MASK)
#define USBPHY_PWD_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDDIFF_SHIFT)) & USBPHY_PWD_RXPWDDIFF_MASK)
#define USBPHY_PWD_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDRX_SHIFT)) & USBPHY_PWD_RXPWDRX_MASK)
#define USBPHY_PWD_RSVD2_MASK   (0xFFE00000U)
#define USBPHY_PWD_RSVD2_SHIFT   (21U)
#define USBPHY_PWD_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RSVD2_SHIFT)) & USBPHY_PWD_RSVD2_MASK)
PWD_SET - USB PHY Power-Down Register
#define USBPHY_PWD_SET_RSVD0_MASK   (0x3FFU)
#define USBPHY_PWD_SET_RSVD0_SHIFT   (0U)
#define USBPHY_PWD_SET_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RSVD0_SHIFT)) & USBPHY_PWD_SET_RSVD0_MASK)
#define USBPHY_PWD_SET_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_SET_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_SET_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDFS_SHIFT)) & USBPHY_PWD_SET_TXPWDFS_MASK)
#define USBPHY_PWD_SET_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_SET_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_SET_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_SET_TXPWDIBIAS_MASK)
#define USBPHY_PWD_SET_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_SET_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_SET_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDV2I_SHIFT)) & USBPHY_PWD_SET_TXPWDV2I_MASK)
#define USBPHY_PWD_SET_RSVD1_MASK   (0x1E000U)
#define USBPHY_PWD_SET_RSVD1_SHIFT   (13U)
#define USBPHY_PWD_SET_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RSVD1_SHIFT)) & USBPHY_PWD_SET_RSVD1_MASK)
#define USBPHY_PWD_SET_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_SET_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_SET_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDENV_SHIFT)) & USBPHY_PWD_SET_RXPWDENV_MASK)
#define USBPHY_PWD_SET_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_SET_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_SET_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWD1PT1_SHIFT)) & USBPHY_PWD_SET_RXPWD1PT1_MASK)
#define USBPHY_PWD_SET_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_SET_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_SET_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDDIFF_SHIFT)) & USBPHY_PWD_SET_RXPWDDIFF_MASK)
#define USBPHY_PWD_SET_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_SET_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_SET_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDRX_SHIFT)) & USBPHY_PWD_SET_RXPWDRX_MASK)
#define USBPHY_PWD_SET_RSVD2_MASK   (0xFFE00000U)
#define USBPHY_PWD_SET_RSVD2_SHIFT   (21U)
#define USBPHY_PWD_SET_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RSVD2_SHIFT)) & USBPHY_PWD_SET_RSVD2_MASK)
PWD_CLR - USB PHY Power-Down Register
#define USBPHY_PWD_CLR_RSVD0_MASK   (0x3FFU)
#define USBPHY_PWD_CLR_RSVD0_SHIFT   (0U)
#define USBPHY_PWD_CLR_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RSVD0_SHIFT)) & USBPHY_PWD_CLR_RSVD0_MASK)
#define USBPHY_PWD_CLR_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_CLR_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_CLR_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDFS_SHIFT)) & USBPHY_PWD_CLR_TXPWDFS_MASK)
#define USBPHY_PWD_CLR_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_CLR_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_CLR_TXPWDIBIAS_MASK)
#define USBPHY_PWD_CLR_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_CLR_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_CLR_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDV2I_SHIFT)) & USBPHY_PWD_CLR_TXPWDV2I_MASK)
#define USBPHY_PWD_CLR_RSVD1_MASK   (0x1E000U)
#define USBPHY_PWD_CLR_RSVD1_SHIFT   (13U)
#define USBPHY_PWD_CLR_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RSVD1_SHIFT)) & USBPHY_PWD_CLR_RSVD1_MASK)
#define USBPHY_PWD_CLR_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_CLR_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_CLR_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDENV_SHIFT)) & USBPHY_PWD_CLR_RXPWDENV_MASK)
#define USBPHY_PWD_CLR_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_CLR_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_CLR_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWD1PT1_SHIFT)) & USBPHY_PWD_CLR_RXPWD1PT1_MASK)
#define USBPHY_PWD_CLR_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_CLR_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_CLR_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDDIFF_SHIFT)) & USBPHY_PWD_CLR_RXPWDDIFF_MASK)
#define USBPHY_PWD_CLR_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_CLR_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_CLR_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDRX_SHIFT)) & USBPHY_PWD_CLR_RXPWDRX_MASK)
#define USBPHY_PWD_CLR_RSVD2_MASK   (0xFFE00000U)
#define USBPHY_PWD_CLR_RSVD2_SHIFT   (21U)
#define USBPHY_PWD_CLR_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RSVD2_SHIFT)) & USBPHY_PWD_CLR_RSVD2_MASK)
PWD_TOG - USB PHY Power-Down Register
#define USBPHY_PWD_TOG_RSVD0_MASK   (0x3FFU)
#define USBPHY_PWD_TOG_RSVD0_SHIFT   (0U)
#define USBPHY_PWD_TOG_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RSVD0_SHIFT)) & USBPHY_PWD_TOG_RSVD0_MASK)
#define USBPHY_PWD_TOG_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_TOG_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_TOG_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDFS_SHIFT)) & USBPHY_PWD_TOG_TXPWDFS_MASK)
#define USBPHY_PWD_TOG_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_TOG_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TOG_TXPWDIBIAS_MASK)
#define USBPHY_PWD_TOG_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_TOG_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_TOG_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDV2I_SHIFT)) & USBPHY_PWD_TOG_TXPWDV2I_MASK)
#define USBPHY_PWD_TOG_RSVD1_MASK   (0x1E000U)
#define USBPHY_PWD_TOG_RSVD1_SHIFT   (13U)
#define USBPHY_PWD_TOG_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RSVD1_SHIFT)) & USBPHY_PWD_TOG_RSVD1_MASK)
#define USBPHY_PWD_TOG_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_TOG_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_TOG_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDENV_SHIFT)) & USBPHY_PWD_TOG_RXPWDENV_MASK)
#define USBPHY_PWD_TOG_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_TOG_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_TOG_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWD1PT1_SHIFT)) & USBPHY_PWD_TOG_RXPWD1PT1_MASK)
#define USBPHY_PWD_TOG_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_TOG_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_TOG_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDDIFF_SHIFT)) & USBPHY_PWD_TOG_RXPWDDIFF_MASK)
#define USBPHY_PWD_TOG_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_TOG_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_TOG_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDRX_SHIFT)) & USBPHY_PWD_TOG_RXPWDRX_MASK)
#define USBPHY_PWD_TOG_RSVD2_MASK   (0xFFE00000U)
#define USBPHY_PWD_TOG_RSVD2_SHIFT   (21U)
#define USBPHY_PWD_TOG_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RSVD2_SHIFT)) & USBPHY_PWD_TOG_RSVD2_MASK)
TX - USB PHY Transmitter Control Register
#define USBPHY_TX_D_CAL_MASK   (0xFU)
#define USBPHY_TX_D_CAL_SHIFT   (0U)
#define USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TX_D_CAL_MASK)
#define USBPHY_TX_RSVD0_MASK   (0xF0U)
#define USBPHY_TX_RSVD0_SHIFT   (4U)
#define USBPHY_TX_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_RSVD0_SHIFT)) & USBPHY_TX_RSVD0_MASK)
#define USBPHY_TX_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DN_SHIFT)) & USBPHY_TX_TXCAL45DN_MASK)
#define USBPHY_TX_RSVD1_MASK   (0xF000U)
#define USBPHY_TX_RSVD1_SHIFT   (12U)
#define USBPHY_TX_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_RSVD1_SHIFT)) & USBPHY_TX_RSVD1_MASK)
#define USBPHY_TX_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DP_SHIFT)) & USBPHY_TX_TXCAL45DP_MASK)
#define USBPHY_TX_RSVD2_MASK   (0x3F00000U)
#define USBPHY_TX_RSVD2_SHIFT   (20U)
#define USBPHY_TX_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_RSVD2_SHIFT)) & USBPHY_TX_RSVD2_MASK)
#define USBPHY_TX_USBPHY_TX_EDGECTRL_MASK   (0x1C000000U)
#define USBPHY_TX_USBPHY_TX_EDGECTRL_SHIFT   (26U)
#define USBPHY_TX_USBPHY_TX_EDGECTRL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_USBPHY_TX_EDGECTRL_SHIFT)) & USBPHY_TX_USBPHY_TX_EDGECTRL_MASK)
#define USBPHY_TX_RSVD5_MASK   (0xE0000000U)
#define USBPHY_TX_RSVD5_SHIFT   (29U)
#define USBPHY_TX_RSVD5(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_RSVD5_SHIFT)) & USBPHY_TX_RSVD5_MASK)
TX_SET - USB PHY Transmitter Control Register
#define USBPHY_TX_SET_D_CAL_MASK   (0xFU)
#define USBPHY_TX_SET_D_CAL_SHIFT   (0U)
#define USBPHY_TX_SET_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_D_CAL_SHIFT)) & USBPHY_TX_SET_D_CAL_MASK)
#define USBPHY_TX_SET_RSVD0_MASK   (0xF0U)
#define USBPHY_TX_SET_RSVD0_SHIFT   (4U)
#define USBPHY_TX_SET_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_RSVD0_SHIFT)) & USBPHY_TX_SET_RSVD0_MASK)
#define USBPHY_TX_SET_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_SET_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_SET_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DN_SHIFT)) & USBPHY_TX_SET_TXCAL45DN_MASK)
#define USBPHY_TX_SET_RSVD1_MASK   (0xF000U)
#define USBPHY_TX_SET_RSVD1_SHIFT   (12U)
#define USBPHY_TX_SET_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_RSVD1_SHIFT)) & USBPHY_TX_SET_RSVD1_MASK)
#define USBPHY_TX_SET_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_SET_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_SET_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DP_SHIFT)) & USBPHY_TX_SET_TXCAL45DP_MASK)
#define USBPHY_TX_SET_RSVD2_MASK   (0x3F00000U)
#define USBPHY_TX_SET_RSVD2_SHIFT   (20U)
#define USBPHY_TX_SET_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_RSVD2_SHIFT)) & USBPHY_TX_SET_RSVD2_MASK)
#define USBPHY_TX_SET_USBPHY_TX_EDGECTRL_MASK   (0x1C000000U)
#define USBPHY_TX_SET_USBPHY_TX_EDGECTRL_SHIFT   (26U)
#define USBPHY_TX_SET_USBPHY_TX_EDGECTRL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_USBPHY_TX_EDGECTRL_SHIFT)) & USBPHY_TX_SET_USBPHY_TX_EDGECTRL_MASK)
#define USBPHY_TX_SET_RSVD5_MASK   (0xE0000000U)
#define USBPHY_TX_SET_RSVD5_SHIFT   (29U)
#define USBPHY_TX_SET_RSVD5(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_RSVD5_SHIFT)) & USBPHY_TX_SET_RSVD5_MASK)
TX_CLR - USB PHY Transmitter Control Register
#define USBPHY_TX_CLR_D_CAL_MASK   (0xFU)
#define USBPHY_TX_CLR_D_CAL_SHIFT   (0U)
#define USBPHY_TX_CLR_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_D_CAL_SHIFT)) & USBPHY_TX_CLR_D_CAL_MASK)
#define USBPHY_TX_CLR_RSVD0_MASK   (0xF0U)
#define USBPHY_TX_CLR_RSVD0_SHIFT   (4U)
#define USBPHY_TX_CLR_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_RSVD0_SHIFT)) & USBPHY_TX_CLR_RSVD0_MASK)
#define USBPHY_TX_CLR_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_CLR_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_CLR_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DN_SHIFT)) & USBPHY_TX_CLR_TXCAL45DN_MASK)
#define USBPHY_TX_CLR_RSVD1_MASK   (0xF000U)
#define USBPHY_TX_CLR_RSVD1_SHIFT   (12U)
#define USBPHY_TX_CLR_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_RSVD1_SHIFT)) & USBPHY_TX_CLR_RSVD1_MASK)
#define USBPHY_TX_CLR_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_CLR_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_CLR_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DP_SHIFT)) & USBPHY_TX_CLR_TXCAL45DP_MASK)
#define USBPHY_TX_CLR_RSVD2_MASK   (0x3F00000U)
#define USBPHY_TX_CLR_RSVD2_SHIFT   (20U)
#define USBPHY_TX_CLR_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_RSVD2_SHIFT)) & USBPHY_TX_CLR_RSVD2_MASK)
#define USBPHY_TX_CLR_USBPHY_TX_EDGECTRL_MASK   (0x1C000000U)
#define USBPHY_TX_CLR_USBPHY_TX_EDGECTRL_SHIFT   (26U)
#define USBPHY_TX_CLR_USBPHY_TX_EDGECTRL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_USBPHY_TX_EDGECTRL_SHIFT)) & USBPHY_TX_CLR_USBPHY_TX_EDGECTRL_MASK)
#define USBPHY_TX_CLR_RSVD5_MASK   (0xE0000000U)
#define USBPHY_TX_CLR_RSVD5_SHIFT   (29U)
#define USBPHY_TX_CLR_RSVD5(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_RSVD5_SHIFT)) & USBPHY_TX_CLR_RSVD5_MASK)
TX_TOG - USB PHY Transmitter Control Register
#define USBPHY_TX_TOG_D_CAL_MASK   (0xFU)
#define USBPHY_TX_TOG_D_CAL_SHIFT   (0U)
#define USBPHY_TX_TOG_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_D_CAL_SHIFT)) & USBPHY_TX_TOG_D_CAL_MASK)
#define USBPHY_TX_TOG_RSVD0_MASK   (0xF0U)
#define USBPHY_TX_TOG_RSVD0_SHIFT   (4U)
#define USBPHY_TX_TOG_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_RSVD0_SHIFT)) & USBPHY_TX_TOG_RSVD0_MASK)
#define USBPHY_TX_TOG_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_TOG_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_TOG_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DN_SHIFT)) & USBPHY_TX_TOG_TXCAL45DN_MASK)
#define USBPHY_TX_TOG_RSVD1_MASK   (0xF000U)
#define USBPHY_TX_TOG_RSVD1_SHIFT   (12U)
#define USBPHY_TX_TOG_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_RSVD1_SHIFT)) & USBPHY_TX_TOG_RSVD1_MASK)
#define USBPHY_TX_TOG_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_TOG_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_TOG_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DP_SHIFT)) & USBPHY_TX_TOG_TXCAL45DP_MASK)
#define USBPHY_TX_TOG_RSVD2_MASK   (0x3F00000U)
#define USBPHY_TX_TOG_RSVD2_SHIFT   (20U)
#define USBPHY_TX_TOG_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_RSVD2_SHIFT)) & USBPHY_TX_TOG_RSVD2_MASK)
#define USBPHY_TX_TOG_USBPHY_TX_EDGECTRL_MASK   (0x1C000000U)
#define USBPHY_TX_TOG_USBPHY_TX_EDGECTRL_SHIFT   (26U)
#define USBPHY_TX_TOG_USBPHY_TX_EDGECTRL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_USBPHY_TX_EDGECTRL_SHIFT)) & USBPHY_TX_TOG_USBPHY_TX_EDGECTRL_MASK)
#define USBPHY_TX_TOG_RSVD5_MASK   (0xE0000000U)
#define USBPHY_TX_TOG_RSVD5_SHIFT   (29U)
#define USBPHY_TX_TOG_RSVD5(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_RSVD5_SHIFT)) & USBPHY_TX_TOG_RSVD5_MASK)
RX - USB PHY Receiver Control Register
#define USBPHY_RX_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_ENVADJ_SHIFT)) & USBPHY_RX_ENVADJ_MASK)
#define USBPHY_RX_RSVD0_MASK   (0x8U)
#define USBPHY_RX_RSVD0_SHIFT   (3U)
#define USBPHY_RX_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_RSVD0_SHIFT)) & USBPHY_RX_RSVD0_MASK)
#define USBPHY_RX_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_DISCONADJ_SHIFT)) & USBPHY_RX_DISCONADJ_MASK)
#define USBPHY_RX_RSVD1_MASK   (0x3FFF80U)
#define USBPHY_RX_RSVD1_SHIFT   (7U)
#define USBPHY_RX_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_RSVD1_SHIFT)) & USBPHY_RX_RSVD1_MASK)
#define USBPHY_RX_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_RXDBYPASS_SHIFT)) & USBPHY_RX_RXDBYPASS_MASK)
#define USBPHY_RX_RSVD2_MASK   (0xFF800000U)
#define USBPHY_RX_RSVD2_SHIFT   (23U)
#define USBPHY_RX_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_RSVD2_SHIFT)) & USBPHY_RX_RSVD2_MASK)
RX_SET - USB PHY Receiver Control Register
#define USBPHY_RX_SET_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_SET_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_SET_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_ENVADJ_SHIFT)) & USBPHY_RX_SET_ENVADJ_MASK)
#define USBPHY_RX_SET_RSVD0_MASK   (0x8U)
#define USBPHY_RX_SET_RSVD0_SHIFT   (3U)
#define USBPHY_RX_SET_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_RSVD0_SHIFT)) & USBPHY_RX_SET_RSVD0_MASK)
#define USBPHY_RX_SET_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_SET_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_SET_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_DISCONADJ_SHIFT)) & USBPHY_RX_SET_DISCONADJ_MASK)
#define USBPHY_RX_SET_RSVD1_MASK   (0x3FFF80U)
#define USBPHY_RX_SET_RSVD1_SHIFT   (7U)
#define USBPHY_RX_SET_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_RSVD1_SHIFT)) & USBPHY_RX_SET_RSVD1_MASK)
#define USBPHY_RX_SET_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_SET_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_SET_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_RXDBYPASS_SHIFT)) & USBPHY_RX_SET_RXDBYPASS_MASK)
#define USBPHY_RX_SET_RSVD2_MASK   (0xFF800000U)
#define USBPHY_RX_SET_RSVD2_SHIFT   (23U)
#define USBPHY_RX_SET_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_RSVD2_SHIFT)) & USBPHY_RX_SET_RSVD2_MASK)
RX_CLR - USB PHY Receiver Control Register
#define USBPHY_RX_CLR_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_CLR_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_CLR_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_ENVADJ_SHIFT)) & USBPHY_RX_CLR_ENVADJ_MASK)
#define USBPHY_RX_CLR_RSVD0_MASK   (0x8U)
#define USBPHY_RX_CLR_RSVD0_SHIFT   (3U)
#define USBPHY_RX_CLR_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_RSVD0_SHIFT)) & USBPHY_RX_CLR_RSVD0_MASK)
#define USBPHY_RX_CLR_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_CLR_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_CLR_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_DISCONADJ_SHIFT)) & USBPHY_RX_CLR_DISCONADJ_MASK)
#define USBPHY_RX_CLR_RSVD1_MASK   (0x3FFF80U)
#define USBPHY_RX_CLR_RSVD1_SHIFT   (7U)
#define USBPHY_RX_CLR_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_RSVD1_SHIFT)) & USBPHY_RX_CLR_RSVD1_MASK)
#define USBPHY_RX_CLR_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_CLR_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_CLR_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_RXDBYPASS_SHIFT)) & USBPHY_RX_CLR_RXDBYPASS_MASK)
#define USBPHY_RX_CLR_RSVD2_MASK   (0xFF800000U)
#define USBPHY_RX_CLR_RSVD2_SHIFT   (23U)
#define USBPHY_RX_CLR_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_RSVD2_SHIFT)) & USBPHY_RX_CLR_RSVD2_MASK)
RX_TOG - USB PHY Receiver Control Register
#define USBPHY_RX_TOG_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_TOG_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_TOG_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_ENVADJ_SHIFT)) & USBPHY_RX_TOG_ENVADJ_MASK)
#define USBPHY_RX_TOG_RSVD0_MASK   (0x8U)
#define USBPHY_RX_TOG_RSVD0_SHIFT   (3U)
#define USBPHY_RX_TOG_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_RSVD0_SHIFT)) & USBPHY_RX_TOG_RSVD0_MASK)
#define USBPHY_RX_TOG_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_TOG_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_TOG_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_DISCONADJ_SHIFT)) & USBPHY_RX_TOG_DISCONADJ_MASK)
#define USBPHY_RX_TOG_RSVD1_MASK   (0x3FFF80U)
#define USBPHY_RX_TOG_RSVD1_SHIFT   (7U)
#define USBPHY_RX_TOG_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_RSVD1_SHIFT)) & USBPHY_RX_TOG_RSVD1_MASK)
#define USBPHY_RX_TOG_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_TOG_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_TOG_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_RXDBYPASS_SHIFT)) & USBPHY_RX_TOG_RXDBYPASS_MASK)
#define USBPHY_RX_TOG_RSVD2_MASK   (0xFF800000U)
#define USBPHY_RX_TOG_RSVD2_SHIFT   (23U)
#define USBPHY_RX_TOG_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_RSVD2_SHIFT)) & USBPHY_RX_TOG_RSVD2_MASK)
CTRL - USB PHY General Control Register
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_RESUME_IRQ_MASK)
#define USBPHY_CTRL_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_DATA_ON_LRADC_MASK   (0x2000U)
#define USBPHY_CTRL_DATA_ON_LRADC_SHIFT   (13U)
#define USBPHY_CTRL_DATA_ON_LRADC(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DATA_ON_LRADC_SHIFT)) & USBPHY_CTRL_DATA_ON_LRADC_MASK)
#define USBPHY_CTRL_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_ENAUTO_PWRON_PLL_MASK   (0x40000U)
#define USBPHY_CTRL_ENAUTO_PWRON_PLL_SHIFT   (18U)
#define USBPHY_CTRL_ENAUTO_PWRON_PLL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTO_PWRON_PLL_SHIFT)) & USBPHY_CTRL_ENAUTO_PWRON_PLL_MASK)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_RSVD1_MASK   (0x6000000U)
#define USBPHY_CTRL_RSVD1_SHIFT   (25U)
#define USBPHY_CTRL_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RSVD1_SHIFT)) & USBPHY_CTRL_RSVD1_MASK)
#define USBPHY_CTRL_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLKGATE_SHIFT)) & USBPHY_CTRL_CLKGATE_MASK)
#define USBPHY_CTRL_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SFTRST_SHIFT)) & USBPHY_CTRL_SFTRST_MASK)
CTRL_SET - USB PHY General Control Register
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_SET_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_SET_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_SET_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_SET_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_SET_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_SET_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_SET_RESUME_IRQ_MASK)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_SET_DATA_ON_LRADC_MASK   (0x2000U)
#define USBPHY_CTRL_SET_DATA_ON_LRADC_SHIFT   (13U)
#define USBPHY_CTRL_SET_DATA_ON_LRADC(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DATA_ON_LRADC_SHIFT)) & USBPHY_CTRL_SET_DATA_ON_LRADC_MASK)
#define USBPHY_CTRL_SET_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_SET_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_SET_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_SET_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_SET_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_SET_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_SET_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_SET_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_SET_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_SET_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_SET_ENAUTO_PWRON_PLL_MASK   (0x40000U)
#define USBPHY_CTRL_SET_ENAUTO_PWRON_PLL_SHIFT   (18U)
#define USBPHY_CTRL_SET_ENAUTO_PWRON_PLL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTO_PWRON_PLL_SHIFT)) & USBPHY_CTRL_SET_ENAUTO_PWRON_PLL_MASK)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_SET_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_SET_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_SET_RSVD1_MASK   (0x6000000U)
#define USBPHY_CTRL_SET_RSVD1_SHIFT   (25U)
#define USBPHY_CTRL_SET_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RSVD1_SHIFT)) & USBPHY_CTRL_SET_RSVD1_MASK)
#define USBPHY_CTRL_SET_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_SET_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_SET_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_SET_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_SET_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_CLKGATE_MASK)
#define USBPHY_CTRL_SET_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_SET_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_SET_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_SFTRST_SHIFT)) & USBPHY_CTRL_SET_SFTRST_MASK)
CTRL_CLR - USB PHY General Control Register
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_CLR_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_CLR_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_CLR_RESUME_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_CLR_DATA_ON_LRADC_MASK   (0x2000U)
#define USBPHY_CTRL_CLR_DATA_ON_LRADC_SHIFT   (13U)
#define USBPHY_CTRL_CLR_DATA_ON_LRADC(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DATA_ON_LRADC_SHIFT)) & USBPHY_CTRL_CLR_DATA_ON_LRADC_MASK)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL_MASK   (0x40000U)
#define USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL_SHIFT   (18U)
#define USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL_SHIFT)) & USBPHY_CTRL_CLR_ENAUTO_PWRON_PLL_MASK)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_CLR_RSVD1_MASK   (0x6000000U)
#define USBPHY_CTRL_CLR_RSVD1_SHIFT   (25U)
#define USBPHY_CTRL_CLR_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RSVD1_SHIFT)) & USBPHY_CTRL_CLR_RSVD1_MASK)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_CLR_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_CLR_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_CLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_CLKGATE_MASK)
#define USBPHY_CTRL_CLR_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_CLR_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_CLR_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_SFTRST_SHIFT)) & USBPHY_CTRL_CLR_SFTRST_MASK)
CTRL_TOG - USB PHY General Control Register
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_TOG_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_TOG_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_TOG_RESUME_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_TOG_DATA_ON_LRADC_MASK   (0x2000U)
#define USBPHY_CTRL_TOG_DATA_ON_LRADC_SHIFT   (13U)
#define USBPHY_CTRL_TOG_DATA_ON_LRADC(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DATA_ON_LRADC_SHIFT)) & USBPHY_CTRL_TOG_DATA_ON_LRADC_MASK)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL_MASK   (0x40000U)
#define USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL_SHIFT   (18U)
#define USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL_SHIFT)) & USBPHY_CTRL_TOG_ENAUTO_PWRON_PLL_MASK)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_TOG_RSVD1_MASK   (0x6000000U)
#define USBPHY_CTRL_TOG_RSVD1_SHIFT   (25U)
#define USBPHY_CTRL_TOG_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RSVD1_SHIFT)) & USBPHY_CTRL_TOG_RSVD1_MASK)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_TOG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_TOG_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_TOG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_CLKGATE_MASK)
#define USBPHY_CTRL_TOG_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_TOG_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_TOG_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_SFTRST_SHIFT)) & USBPHY_CTRL_TOG_SFTRST_MASK)
STATUS - USB PHY Status Register
#define USBPHY_STATUS_RSVD0_MASK   (0x7U)
#define USBPHY_STATUS_RSVD0_SHIFT   (0U)
#define USBPHY_STATUS_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RSVD0_SHIFT)) & USBPHY_STATUS_RSVD0_MASK)
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK   (0x8U)
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT   (3U)
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT)) & USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK)
#define USBPHY_STATUS_RSVD1_MASK   (0x30U)
#define USBPHY_STATUS_RSVD1_SHIFT   (4U)
#define USBPHY_STATUS_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RSVD1_SHIFT)) & USBPHY_STATUS_RSVD1_MASK)
#define USBPHY_STATUS_DEVPLUGIN_STATUS_MASK   (0x40U)
#define USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT   (6U)
#define USBPHY_STATUS_DEVPLUGIN_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT)) & USBPHY_STATUS_DEVPLUGIN_STATUS_MASK)
#define USBPHY_STATUS_RSVD2_MASK   (0x80U)
#define USBPHY_STATUS_RSVD2_SHIFT   (7U)
#define USBPHY_STATUS_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RSVD2_SHIFT)) & USBPHY_STATUS_RSVD2_MASK)
#define USBPHY_STATUS_OTGID_STATUS_MASK   (0x100U)
#define USBPHY_STATUS_OTGID_STATUS_SHIFT   (8U)
#define USBPHY_STATUS_OTGID_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_OTGID_STATUS_SHIFT)) & USBPHY_STATUS_OTGID_STATUS_MASK)
#define USBPHY_STATUS_RSVD3_MASK   (0x200U)
#define USBPHY_STATUS_RSVD3_SHIFT   (9U)
#define USBPHY_STATUS_RSVD3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RSVD3_SHIFT)) & USBPHY_STATUS_RSVD3_MASK)
#define USBPHY_STATUS_RESUME_STATUS_MASK   (0x400U)
#define USBPHY_STATUS_RESUME_STATUS_SHIFT   (10U)
#define USBPHY_STATUS_RESUME_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RESUME_STATUS_SHIFT)) & USBPHY_STATUS_RESUME_STATUS_MASK)
#define USBPHY_STATUS_RSVD4_MASK   (0xFFFFF800U)
#define USBPHY_STATUS_RSVD4_SHIFT   (11U)
#define USBPHY_STATUS_RSVD4(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RSVD4_SHIFT)) & USBPHY_STATUS_RSVD4_MASK)
DEBUG - USB PHY Debug Register
#define USBPHY_DEBUG_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_RSVD0_MASK   (0xC0U)
#define USBPHY_DEBUG_RSVD0_SHIFT   (6U)
#define USBPHY_DEBUG_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_RSVD0_SHIFT)) & USBPHY_DEBUG_RSVD0_MASK)
#define USBPHY_DEBUG_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_RSVD1_MASK   (0xE000U)
#define USBPHY_DEBUG_RSVD1_SHIFT   (13U)
#define USBPHY_DEBUG_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_RSVD1_SHIFT)) & USBPHY_DEBUG_RSVD1_MASK)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_RSVD2_MASK   (0xE00000U)
#define USBPHY_DEBUG_RSVD2_SHIFT   (21U)
#define USBPHY_DEBUG_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_RSVD2_SHIFT)) & USBPHY_DEBUG_RSVD2_MASK)
#define USBPHY_DEBUG_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLKGATE_SHIFT)) & USBPHY_DEBUG_CLKGATE_MASK)
#define USBPHY_DEBUG_RSVD3_MASK   (0x80000000U)
#define USBPHY_DEBUG_RSVD3_SHIFT   (31U)
#define USBPHY_DEBUG_RSVD3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_RSVD3_SHIFT)) & USBPHY_DEBUG_RSVD3_MASK)
DEBUG_SET - USB PHY Debug Register
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_SET_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_SET_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_SET_RSVD0_MASK   (0xC0U)
#define USBPHY_DEBUG_SET_RSVD0_SHIFT   (6U)
#define USBPHY_DEBUG_SET_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_RSVD0_SHIFT)) & USBPHY_DEBUG_SET_RSVD0_MASK)
#define USBPHY_DEBUG_SET_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_SET_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SET_RSVD1_MASK   (0xE000U)
#define USBPHY_DEBUG_SET_RSVD1_SHIFT   (13U)
#define USBPHY_DEBUG_SET_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_RSVD1_SHIFT)) & USBPHY_DEBUG_SET_RSVD1_MASK)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_SET_RSVD2_MASK   (0xE00000U)
#define USBPHY_DEBUG_SET_RSVD2_SHIFT   (21U)
#define USBPHY_DEBUG_SET_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_RSVD2_SHIFT)) & USBPHY_DEBUG_SET_RSVD2_MASK)
#define USBPHY_DEBUG_SET_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_SET_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_SET_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_SET_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_SET_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_SET_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_SET_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_CLKGATE_SHIFT)) & USBPHY_DEBUG_SET_CLKGATE_MASK)
#define USBPHY_DEBUG_SET_RSVD3_MASK   (0x80000000U)
#define USBPHY_DEBUG_SET_RSVD3_SHIFT   (31U)
#define USBPHY_DEBUG_SET_RSVD3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_RSVD3_SHIFT)) & USBPHY_DEBUG_SET_RSVD3_MASK)
DEBUG_CLR - USB PHY Debug Register
#define USBPHY_DEBUG_CLR_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_CLR_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_CLR_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_CLR_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_CLR_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_CLR_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_CLR_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_CLR_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_CLR_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_CLR_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_CLR_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_CLR_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_CLR_RSVD0_MASK   (0xC0U)
#define USBPHY_DEBUG_CLR_RSVD0_SHIFT   (6U)
#define USBPHY_DEBUG_CLR_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_RSVD0_SHIFT)) & USBPHY_DEBUG_CLR_RSVD0_MASK)
#define USBPHY_DEBUG_CLR_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_CLR_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_CLR_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_CLR_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_CLR_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_CLR_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_CLR_RSVD1_MASK   (0xE000U)
#define USBPHY_DEBUG_CLR_RSVD1_SHIFT   (13U)
#define USBPHY_DEBUG_CLR_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_RSVD1_SHIFT)) & USBPHY_DEBUG_CLR_RSVD1_MASK)
#define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_CLR_RSVD2_MASK   (0xE00000U)
#define USBPHY_DEBUG_CLR_RSVD2_SHIFT   (21U)
#define USBPHY_DEBUG_CLR_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_RSVD2_SHIFT)) & USBPHY_DEBUG_CLR_RSVD2_MASK)
#define USBPHY_DEBUG_CLR_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_CLR_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_CLR_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_CLR_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_CLR_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_CLR_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_CLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_CLKGATE_SHIFT)) & USBPHY_DEBUG_CLR_CLKGATE_MASK)
#define USBPHY_DEBUG_CLR_RSVD3_MASK   (0x80000000U)
#define USBPHY_DEBUG_CLR_RSVD3_SHIFT   (31U)
#define USBPHY_DEBUG_CLR_RSVD3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_RSVD3_SHIFT)) & USBPHY_DEBUG_CLR_RSVD3_MASK)
DEBUG_TOG - USB PHY Debug Register
#define USBPHY_DEBUG_TOG_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_TOG_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_TOG_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_TOG_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_TOG_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_TOG_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_TOG_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_TOG_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_TOG_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_TOG_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_TOG_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_TOG_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_TOG_RSVD0_MASK   (0xC0U)
#define USBPHY_DEBUG_TOG_RSVD0_SHIFT   (6U)
#define USBPHY_DEBUG_TOG_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_RSVD0_SHIFT)) & USBPHY_DEBUG_TOG_RSVD0_MASK)
#define USBPHY_DEBUG_TOG_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_TOG_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_TOG_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_TOG_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_TOG_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_TOG_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_TOG_RSVD1_MASK   (0xE000U)
#define USBPHY_DEBUG_TOG_RSVD1_SHIFT   (13U)
#define USBPHY_DEBUG_TOG_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_RSVD1_SHIFT)) & USBPHY_DEBUG_TOG_RSVD1_MASK)
#define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_TOG_RSVD2_MASK   (0xE00000U)
#define USBPHY_DEBUG_TOG_RSVD2_SHIFT   (21U)
#define USBPHY_DEBUG_TOG_RSVD2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_RSVD2_SHIFT)) & USBPHY_DEBUG_TOG_RSVD2_MASK)
#define USBPHY_DEBUG_TOG_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_TOG_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_TOG_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_TOG_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_TOG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_TOG_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_TOG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_CLKGATE_SHIFT)) & USBPHY_DEBUG_TOG_CLKGATE_MASK)
#define USBPHY_DEBUG_TOG_RSVD3_MASK   (0x80000000U)
#define USBPHY_DEBUG_TOG_RSVD3_SHIFT   (31U)
#define USBPHY_DEBUG_TOG_RSVD3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_RSVD3_SHIFT)) & USBPHY_DEBUG_TOG_RSVD3_MASK)
DEBUG0_STATUS - UTMI Debug Status Register 0
#define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_MASK   (0xFFFFU)
#define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_SHIFT   (0U)
#define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_MASK)
#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_MASK   (0x3FF0000U)
#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_SHIFT   (16U)
#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_MASK)
#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK   (0xFC000000U)
#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_SHIFT   (26U)
#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK)
DEBUG1 - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_RSVD0_MASK   (0x1FFFU)
#define USBPHY_DEBUG1_RSVD0_SHIFT   (0U)
#define USBPHY_DEBUG1_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_RSVD0_SHIFT)) & USBPHY_DEBUG1_RSVD0_MASK)
#define USBPHY_DEBUG1_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_RSVD1_MASK   (0xFFFF8000U)
#define USBPHY_DEBUG1_RSVD1_SHIFT   (15U)
#define USBPHY_DEBUG1_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_RSVD1_SHIFT)) & USBPHY_DEBUG1_RSVD1_MASK)
DEBUG1_SET - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_SET_RSVD0_MASK   (0x1FFFU)
#define USBPHY_DEBUG1_SET_RSVD0_SHIFT   (0U)
#define USBPHY_DEBUG1_SET_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_RSVD0_SHIFT)) & USBPHY_DEBUG1_SET_RSVD0_MASK)
#define USBPHY_DEBUG1_SET_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_SET_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_SET_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_SET_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_SET_RSVD1_MASK   (0xFFFF8000U)
#define USBPHY_DEBUG1_SET_RSVD1_SHIFT   (15U)
#define USBPHY_DEBUG1_SET_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_RSVD1_SHIFT)) & USBPHY_DEBUG1_SET_RSVD1_MASK)
DEBUG1_CLR - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_CLR_RSVD0_MASK   (0x1FFFU)
#define USBPHY_DEBUG1_CLR_RSVD0_SHIFT   (0U)
#define USBPHY_DEBUG1_CLR_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_RSVD0_SHIFT)) & USBPHY_DEBUG1_CLR_RSVD0_MASK)
#define USBPHY_DEBUG1_CLR_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_CLR_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_CLR_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_CLR_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_CLR_RSVD1_MASK   (0xFFFF8000U)
#define USBPHY_DEBUG1_CLR_RSVD1_SHIFT   (15U)
#define USBPHY_DEBUG1_CLR_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_RSVD1_SHIFT)) & USBPHY_DEBUG1_CLR_RSVD1_MASK)
DEBUG1_TOG - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_TOG_RSVD0_MASK   (0x1FFFU)
#define USBPHY_DEBUG1_TOG_RSVD0_SHIFT   (0U)
#define USBPHY_DEBUG1_TOG_RSVD0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_RSVD0_SHIFT)) & USBPHY_DEBUG1_TOG_RSVD0_MASK)
#define USBPHY_DEBUG1_TOG_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_TOG_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_TOG_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_TOG_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_TOG_RSVD1_MASK   (0xFFFF8000U)
#define USBPHY_DEBUG1_TOG_RSVD1_SHIFT   (15U)
#define USBPHY_DEBUG1_TOG_RSVD1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_RSVD1_SHIFT)) & USBPHY_DEBUG1_TOG_RSVD1_MASK)
VERSION - UTMI RTL Version
#define USBPHY_VERSION_STEP_MASK   (0xFFFFU)
#define USBPHY_VERSION_STEP_SHIFT   (0U)
#define USBPHY_VERSION_STEP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_STEP_SHIFT)) & USBPHY_VERSION_STEP_MASK)
#define USBPHY_VERSION_MINOR_MASK   (0xFF0000U)
#define USBPHY_VERSION_MINOR_SHIFT   (16U)
#define USBPHY_VERSION_MINOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_MINOR_SHIFT)) & USBPHY_VERSION_MINOR_MASK)
#define USBPHY_VERSION_MAJOR_MASK   (0xFF000000U)
#define USBPHY_VERSION_MAJOR_SHIFT   (24U)
#define USBPHY_VERSION_MAJOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_MAJOR_SHIFT)) & USBPHY_VERSION_MAJOR_MASK)
PWD - USB PHY Power-Down Register
#define USBPHY_PWD_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDFS_SHIFT)) & USBPHY_PWD_TXPWDFS_MASK)
#define USBPHY_PWD_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TXPWDIBIAS_MASK)
#define USBPHY_PWD_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDV2I_SHIFT)) & USBPHY_PWD_TXPWDV2I_MASK)
#define USBPHY_PWD_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDENV_SHIFT)) & USBPHY_PWD_RXPWDENV_MASK)
#define USBPHY_PWD_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWD1PT1_SHIFT)) & USBPHY_PWD_RXPWD1PT1_MASK)
#define USBPHY_PWD_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDDIFF_SHIFT)) & USBPHY_PWD_RXPWDDIFF_MASK)
#define USBPHY_PWD_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDRX_SHIFT)) & USBPHY_PWD_RXPWDRX_MASK)
PWD_SET - USB PHY Power-Down Register
#define USBPHY_PWD_SET_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_SET_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_SET_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDFS_SHIFT)) & USBPHY_PWD_SET_TXPWDFS_MASK)
#define USBPHY_PWD_SET_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_SET_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_SET_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_SET_TXPWDIBIAS_MASK)
#define USBPHY_PWD_SET_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_SET_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_SET_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDV2I_SHIFT)) & USBPHY_PWD_SET_TXPWDV2I_MASK)
#define USBPHY_PWD_SET_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_SET_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_SET_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDENV_SHIFT)) & USBPHY_PWD_SET_RXPWDENV_MASK)
#define USBPHY_PWD_SET_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_SET_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_SET_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWD1PT1_SHIFT)) & USBPHY_PWD_SET_RXPWD1PT1_MASK)
#define USBPHY_PWD_SET_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_SET_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_SET_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDDIFF_SHIFT)) & USBPHY_PWD_SET_RXPWDDIFF_MASK)
#define USBPHY_PWD_SET_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_SET_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_SET_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDRX_SHIFT)) & USBPHY_PWD_SET_RXPWDRX_MASK)
PWD_CLR - USB PHY Power-Down Register
#define USBPHY_PWD_CLR_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_CLR_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_CLR_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDFS_SHIFT)) & USBPHY_PWD_CLR_TXPWDFS_MASK)
#define USBPHY_PWD_CLR_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_CLR_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_CLR_TXPWDIBIAS_MASK)
#define USBPHY_PWD_CLR_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_CLR_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_CLR_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDV2I_SHIFT)) & USBPHY_PWD_CLR_TXPWDV2I_MASK)
#define USBPHY_PWD_CLR_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_CLR_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_CLR_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDENV_SHIFT)) & USBPHY_PWD_CLR_RXPWDENV_MASK)
#define USBPHY_PWD_CLR_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_CLR_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_CLR_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWD1PT1_SHIFT)) & USBPHY_PWD_CLR_RXPWD1PT1_MASK)
#define USBPHY_PWD_CLR_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_CLR_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_CLR_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDDIFF_SHIFT)) & USBPHY_PWD_CLR_RXPWDDIFF_MASK)
#define USBPHY_PWD_CLR_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_CLR_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_CLR_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDRX_SHIFT)) & USBPHY_PWD_CLR_RXPWDRX_MASK)
PWD_TOG - USB PHY Power-Down Register
#define USBPHY_PWD_TOG_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_TOG_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_TOG_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDFS_SHIFT)) & USBPHY_PWD_TOG_TXPWDFS_MASK)
#define USBPHY_PWD_TOG_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_TOG_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TOG_TXPWDIBIAS_MASK)
#define USBPHY_PWD_TOG_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_TOG_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_TOG_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDV2I_SHIFT)) & USBPHY_PWD_TOG_TXPWDV2I_MASK)
#define USBPHY_PWD_TOG_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_TOG_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_TOG_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDENV_SHIFT)) & USBPHY_PWD_TOG_RXPWDENV_MASK)
#define USBPHY_PWD_TOG_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_TOG_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_TOG_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWD1PT1_SHIFT)) & USBPHY_PWD_TOG_RXPWD1PT1_MASK)
#define USBPHY_PWD_TOG_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_TOG_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_TOG_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDDIFF_SHIFT)) & USBPHY_PWD_TOG_RXPWDDIFF_MASK)
#define USBPHY_PWD_TOG_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_TOG_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_TOG_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDRX_SHIFT)) & USBPHY_PWD_TOG_RXPWDRX_MASK)
TX - USB PHY Transmitter Control Register
#define USBPHY_TX_D_CAL_MASK   (0xFU)
#define USBPHY_TX_D_CAL_SHIFT   (0U)
#define USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TX_D_CAL_MASK)
#define USBPHY_TX_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DN_SHIFT)) & USBPHY_TX_TXCAL45DN_MASK)
#define USBPHY_TX_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DP_SHIFT)) & USBPHY_TX_TXCAL45DP_MASK)
TX_SET - USB PHY Transmitter Control Register
#define USBPHY_TX_SET_D_CAL_MASK   (0xFU)
#define USBPHY_TX_SET_D_CAL_SHIFT   (0U)
#define USBPHY_TX_SET_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_D_CAL_SHIFT)) & USBPHY_TX_SET_D_CAL_MASK)
#define USBPHY_TX_SET_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_SET_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_SET_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DN_SHIFT)) & USBPHY_TX_SET_TXCAL45DN_MASK)
#define USBPHY_TX_SET_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_SET_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_SET_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DP_SHIFT)) & USBPHY_TX_SET_TXCAL45DP_MASK)
TX_CLR - USB PHY Transmitter Control Register
#define USBPHY_TX_CLR_D_CAL_MASK   (0xFU)
#define USBPHY_TX_CLR_D_CAL_SHIFT   (0U)
#define USBPHY_TX_CLR_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_D_CAL_SHIFT)) & USBPHY_TX_CLR_D_CAL_MASK)
#define USBPHY_TX_CLR_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_CLR_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_CLR_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DN_SHIFT)) & USBPHY_TX_CLR_TXCAL45DN_MASK)
#define USBPHY_TX_CLR_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_CLR_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_CLR_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DP_SHIFT)) & USBPHY_TX_CLR_TXCAL45DP_MASK)
TX_TOG - USB PHY Transmitter Control Register
#define USBPHY_TX_TOG_D_CAL_MASK   (0xFU)
#define USBPHY_TX_TOG_D_CAL_SHIFT   (0U)
#define USBPHY_TX_TOG_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_D_CAL_SHIFT)) & USBPHY_TX_TOG_D_CAL_MASK)
#define USBPHY_TX_TOG_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_TOG_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_TOG_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DN_SHIFT)) & USBPHY_TX_TOG_TXCAL45DN_MASK)
#define USBPHY_TX_TOG_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_TOG_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_TOG_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DP_SHIFT)) & USBPHY_TX_TOG_TXCAL45DP_MASK)
RX - USB PHY Receiver Control Register
#define USBPHY_RX_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_ENVADJ_SHIFT)) & USBPHY_RX_ENVADJ_MASK)
#define USBPHY_RX_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_DISCONADJ_SHIFT)) & USBPHY_RX_DISCONADJ_MASK)
#define USBPHY_RX_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_RXDBYPASS_SHIFT)) & USBPHY_RX_RXDBYPASS_MASK)
RX_SET - USB PHY Receiver Control Register
#define USBPHY_RX_SET_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_SET_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_SET_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_ENVADJ_SHIFT)) & USBPHY_RX_SET_ENVADJ_MASK)
#define USBPHY_RX_SET_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_SET_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_SET_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_DISCONADJ_SHIFT)) & USBPHY_RX_SET_DISCONADJ_MASK)
#define USBPHY_RX_SET_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_SET_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_SET_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_RXDBYPASS_SHIFT)) & USBPHY_RX_SET_RXDBYPASS_MASK)
RX_CLR - USB PHY Receiver Control Register
#define USBPHY_RX_CLR_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_CLR_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_CLR_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_ENVADJ_SHIFT)) & USBPHY_RX_CLR_ENVADJ_MASK)
#define USBPHY_RX_CLR_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_CLR_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_CLR_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_DISCONADJ_SHIFT)) & USBPHY_RX_CLR_DISCONADJ_MASK)
#define USBPHY_RX_CLR_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_CLR_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_CLR_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_RXDBYPASS_SHIFT)) & USBPHY_RX_CLR_RXDBYPASS_MASK)
RX_TOG - USB PHY Receiver Control Register
#define USBPHY_RX_TOG_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_TOG_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_TOG_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_ENVADJ_SHIFT)) & USBPHY_RX_TOG_ENVADJ_MASK)
#define USBPHY_RX_TOG_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_TOG_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_TOG_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_DISCONADJ_SHIFT)) & USBPHY_RX_TOG_DISCONADJ_MASK)
#define USBPHY_RX_TOG_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_TOG_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_TOG_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_RXDBYPASS_SHIFT)) & USBPHY_RX_TOG_RXDBYPASS_MASK)
CTRL - USB PHY General Control Register
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_RESUME_IRQ_MASK)
#define USBPHY_CTRL_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLKGATE_SHIFT)) & USBPHY_CTRL_CLKGATE_MASK)
#define USBPHY_CTRL_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SFTRST_SHIFT)) & USBPHY_CTRL_SFTRST_MASK)
CTRL_SET - USB PHY General Control Register
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_SET_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_SET_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_SET_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_SET_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_SET_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_SET_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_SET_RESUME_IRQ_MASK)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_SET_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_SET_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_SET_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_SET_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_SET_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_SET_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_SET_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_SET_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_SET_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_SET_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_SET_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_SET_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_SET_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_SET_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_SET_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_SET_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_SET_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_SET_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_SET_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_SET_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_SET_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_CLKGATE_MASK)
#define USBPHY_CTRL_SET_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_SET_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_SET_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_SFTRST_SHIFT)) & USBPHY_CTRL_SET_SFTRST_MASK)
CTRL_CLR - USB PHY General Control Register
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_CLR_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_CLR_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_CLR_RESUME_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_CLR_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_CLR_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_CLR_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_CLR_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_CLR_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_CLR_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_CLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_CLKGATE_MASK)
#define USBPHY_CTRL_CLR_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_CLR_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_CLR_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_SFTRST_SHIFT)) & USBPHY_CTRL_CLR_SFTRST_MASK)
CTRL_TOG - USB PHY General Control Register
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_TOG_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_TOG_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_TOG_RESUME_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_TOG_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_TOG_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_TOG_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_TOG_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_TOG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_TOG_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_TOG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_CLKGATE_MASK)
#define USBPHY_CTRL_TOG_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_TOG_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_TOG_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_SFTRST_SHIFT)) & USBPHY_CTRL_TOG_SFTRST_MASK)
STATUS - USB PHY Status Register
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK   (0x8U)
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT   (3U)
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT)) & USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK)
#define USBPHY_STATUS_DEVPLUGIN_STATUS_MASK   (0x40U)
#define USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT   (6U)
#define USBPHY_STATUS_DEVPLUGIN_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT)) & USBPHY_STATUS_DEVPLUGIN_STATUS_MASK)
#define USBPHY_STATUS_OTGID_STATUS_MASK   (0x100U)
#define USBPHY_STATUS_OTGID_STATUS_SHIFT   (8U)
#define USBPHY_STATUS_OTGID_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_OTGID_STATUS_SHIFT)) & USBPHY_STATUS_OTGID_STATUS_MASK)
#define USBPHY_STATUS_RESUME_STATUS_MASK   (0x400U)
#define USBPHY_STATUS_RESUME_STATUS_SHIFT   (10U)
#define USBPHY_STATUS_RESUME_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RESUME_STATUS_SHIFT)) & USBPHY_STATUS_RESUME_STATUS_MASK)
DEBUG - USB PHY Debug Register
#define USBPHY_DEBUG_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLKGATE_SHIFT)) & USBPHY_DEBUG_CLKGATE_MASK)
DEBUG_SET - USB PHY Debug Register
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_SET_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_SET_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_SET_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_SET_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_TST_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_MASK)
PLL_SIC - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_PLL_LOCK_MASK)
PLL_SIC_SET - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_SET_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_SET_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_SET_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_SET_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_SET_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_SET_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_SET_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_SET_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_SET_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_SET_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_SET_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_SET_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_SET_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_SET_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_SET_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_SET_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_SET_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_SET_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_SET_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_LOCK_MASK)
PLL_SIC_CLR - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_CLR_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_CLR_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_CLR_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_CLR_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_CLR_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_CLR_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_CLR_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_CLR_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_CLR_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_CLR_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_CLR_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_CLR_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_LOCK_MASK)
PLL_SIC_TOG - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_TOG_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_TOG_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_TOG_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_TOG_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_TOG_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_TOG_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_TOG_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_TOG_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_TOG_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_TOG_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_TOG_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_TOG_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_LOCK_MASK)
USB1_VBUS_DETECT - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DETECT_SET - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DETECT_CLR - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DETECT_TOG - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DET_STAT - USB PHY VBUS Detector Status Register
#define USBPHY_USB1_VBUS_DET_STAT_SESSEND_MASK   (0x1U)
#define USBPHY_USB1_VBUS_DET_STAT_SESSEND_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DET_STAT_SESSEND(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_SESSEND_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_SESSEND_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_BVALID_MASK   (0x2U)
#define USBPHY_USB1_VBUS_DET_STAT_BVALID_SHIFT   (1U)
#define USBPHY_USB1_VBUS_DET_STAT_BVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_BVALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_BVALID_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_AVALID_MASK   (0x4U)
#define USBPHY_USB1_VBUS_DET_STAT_AVALID_SHIFT   (2U)
#define USBPHY_USB1_VBUS_DET_STAT_AVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_AVALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_AVALID_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_MASK)
USB1_CHRG_DETECT - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_BGR_BIAS_MASK)
USB1_CHRG_DETECT_SET - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_MASK)
USB1_CHRG_DETECT_CLR - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_MASK)
USB1_CHRG_DETECT_TOG - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_MASK)
USB1_CHRG_DET_STAT - USB PHY Charger Detect Status Register
#define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_MASK   (0x1U)
#define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_SHIFT   (0U)
#define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_MASK   (0x2U)
#define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_SHIFT   (1U)
#define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_DN_STATE_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DET_STAT_DN_STATE_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DET_STAT_DN_STATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_DN_STATE_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_DN_STATE_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_DP_STATE_MASK   (0x8U)
#define USBPHY_USB1_CHRG_DET_STAT_DP_STATE_SHIFT   (3U)
#define USBPHY_USB1_CHRG_DET_STAT_DP_STATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_DP_STATE_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_DP_STATE_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_MASK   (0x10U)
#define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_SHIFT   (4U)
#define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_MASK)
ANACTRL - USB PHY Analog Control Register
#define USBPHY_ANACTRL_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_DEV_PULLDOWN_MASK)
ANACTRL_SET - USB PHY Analog Control Register
#define USBPHY_ANACTRL_SET_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_SET_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_SET_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_SET_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_SET_DEV_PULLDOWN_MASK)
ANACTRL_CLR - USB PHY Analog Control Register
#define USBPHY_ANACTRL_CLR_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_CLR_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_CLR_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_CLR_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_CLR_DEV_PULLDOWN_MASK)
ANACTRL_TOG - USB PHY Analog Control Register
#define USBPHY_ANACTRL_TOG_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_TOG_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_TOG_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_TOG_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_TOG_DEV_PULLDOWN_MASK)
USB1_LOOPBACK - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTPKT_MASK)
USB1_LOOPBACK_SET - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_SET_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_SET_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTPKT_MASK)
USB1_LOOPBACK_CLR - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTPKT_MASK)
USB1_LOOPBACK_TOG - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTPKT_MASK)
USB1_LOOPBACK_HSFSCNT - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_MASK)
USB1_LOOPBACK_HSFSCNT_SET - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_MASK)
USB1_LOOPBACK_HSFSCNT_CLR - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_MASK)
USB1_LOOPBACK_HSFSCNT_TOG - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_MASK)
TRIM_OVERRIDE_EN - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_MASK)
TRIM_OVERRIDE_EN_SET - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_MASK)
TRIM_OVERRIDE_EN_CLR - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_MASK)
TRIM_OVERRIDE_EN_TOG - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_MASK)
PWD - USB PHY Power-Down Register
#define USBPHY_PWD_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDFS_SHIFT)) & USBPHY_PWD_TXPWDFS_MASK)
#define USBPHY_PWD_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TXPWDIBIAS_MASK)
#define USBPHY_PWD_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDV2I_SHIFT)) & USBPHY_PWD_TXPWDV2I_MASK)
#define USBPHY_PWD_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDENV_SHIFT)) & USBPHY_PWD_RXPWDENV_MASK)
#define USBPHY_PWD_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWD1PT1_SHIFT)) & USBPHY_PWD_RXPWD1PT1_MASK)
#define USBPHY_PWD_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDDIFF_SHIFT)) & USBPHY_PWD_RXPWDDIFF_MASK)
#define USBPHY_PWD_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDRX_SHIFT)) & USBPHY_PWD_RXPWDRX_MASK)
PWD_SET - USB PHY Power-Down Register
#define USBPHY_PWD_SET_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_SET_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_SET_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDFS_SHIFT)) & USBPHY_PWD_SET_TXPWDFS_MASK)
#define USBPHY_PWD_SET_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_SET_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_SET_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_SET_TXPWDIBIAS_MASK)
#define USBPHY_PWD_SET_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_SET_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_SET_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDV2I_SHIFT)) & USBPHY_PWD_SET_TXPWDV2I_MASK)
#define USBPHY_PWD_SET_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_SET_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_SET_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDENV_SHIFT)) & USBPHY_PWD_SET_RXPWDENV_MASK)
#define USBPHY_PWD_SET_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_SET_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_SET_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWD1PT1_SHIFT)) & USBPHY_PWD_SET_RXPWD1PT1_MASK)
#define USBPHY_PWD_SET_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_SET_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_SET_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDDIFF_SHIFT)) & USBPHY_PWD_SET_RXPWDDIFF_MASK)
#define USBPHY_PWD_SET_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_SET_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_SET_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDRX_SHIFT)) & USBPHY_PWD_SET_RXPWDRX_MASK)
PWD_CLR - USB PHY Power-Down Register
#define USBPHY_PWD_CLR_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_CLR_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_CLR_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDFS_SHIFT)) & USBPHY_PWD_CLR_TXPWDFS_MASK)
#define USBPHY_PWD_CLR_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_CLR_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_CLR_TXPWDIBIAS_MASK)
#define USBPHY_PWD_CLR_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_CLR_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_CLR_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDV2I_SHIFT)) & USBPHY_PWD_CLR_TXPWDV2I_MASK)
#define USBPHY_PWD_CLR_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_CLR_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_CLR_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDENV_SHIFT)) & USBPHY_PWD_CLR_RXPWDENV_MASK)
#define USBPHY_PWD_CLR_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_CLR_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_CLR_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWD1PT1_SHIFT)) & USBPHY_PWD_CLR_RXPWD1PT1_MASK)
#define USBPHY_PWD_CLR_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_CLR_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_CLR_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDDIFF_SHIFT)) & USBPHY_PWD_CLR_RXPWDDIFF_MASK)
#define USBPHY_PWD_CLR_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_CLR_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_CLR_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDRX_SHIFT)) & USBPHY_PWD_CLR_RXPWDRX_MASK)
PWD_TOG - USB PHY Power-Down Register
#define USBPHY_PWD_TOG_TXPWDFS_MASK   (0x400U)
#define USBPHY_PWD_TOG_TXPWDFS_SHIFT   (10U)
#define USBPHY_PWD_TOG_TXPWDFS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDFS_SHIFT)) & USBPHY_PWD_TOG_TXPWDFS_MASK)
#define USBPHY_PWD_TOG_TXPWDIBIAS_MASK   (0x800U)
#define USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT   (11U)
#define USBPHY_PWD_TOG_TXPWDIBIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TOG_TXPWDIBIAS_MASK)
#define USBPHY_PWD_TOG_TXPWDV2I_MASK   (0x1000U)
#define USBPHY_PWD_TOG_TXPWDV2I_SHIFT   (12U)
#define USBPHY_PWD_TOG_TXPWDV2I(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDV2I_SHIFT)) & USBPHY_PWD_TOG_TXPWDV2I_MASK)
#define USBPHY_PWD_TOG_RXPWDENV_MASK   (0x20000U)
#define USBPHY_PWD_TOG_RXPWDENV_SHIFT   (17U)
#define USBPHY_PWD_TOG_RXPWDENV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDENV_SHIFT)) & USBPHY_PWD_TOG_RXPWDENV_MASK)
#define USBPHY_PWD_TOG_RXPWD1PT1_MASK   (0x40000U)
#define USBPHY_PWD_TOG_RXPWD1PT1_SHIFT   (18U)
#define USBPHY_PWD_TOG_RXPWD1PT1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWD1PT1_SHIFT)) & USBPHY_PWD_TOG_RXPWD1PT1_MASK)
#define USBPHY_PWD_TOG_RXPWDDIFF_MASK   (0x80000U)
#define USBPHY_PWD_TOG_RXPWDDIFF_SHIFT   (19U)
#define USBPHY_PWD_TOG_RXPWDDIFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDDIFF_SHIFT)) & USBPHY_PWD_TOG_RXPWDDIFF_MASK)
#define USBPHY_PWD_TOG_RXPWDRX_MASK   (0x100000U)
#define USBPHY_PWD_TOG_RXPWDRX_SHIFT   (20U)
#define USBPHY_PWD_TOG_RXPWDRX(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDRX_SHIFT)) & USBPHY_PWD_TOG_RXPWDRX_MASK)
TX - USB PHY Transmitter Control Register
#define USBPHY_TX_D_CAL_MASK   (0xFU)
#define USBPHY_TX_D_CAL_SHIFT   (0U)
#define USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TX_D_CAL_MASK)
#define USBPHY_TX_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DN_SHIFT)) & USBPHY_TX_TXCAL45DN_MASK)
#define USBPHY_TX_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DP_SHIFT)) & USBPHY_TX_TXCAL45DP_MASK)
TX_SET - USB PHY Transmitter Control Register
#define USBPHY_TX_SET_D_CAL_MASK   (0xFU)
#define USBPHY_TX_SET_D_CAL_SHIFT   (0U)
#define USBPHY_TX_SET_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_D_CAL_SHIFT)) & USBPHY_TX_SET_D_CAL_MASK)
#define USBPHY_TX_SET_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_SET_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_SET_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DN_SHIFT)) & USBPHY_TX_SET_TXCAL45DN_MASK)
#define USBPHY_TX_SET_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_SET_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_SET_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DP_SHIFT)) & USBPHY_TX_SET_TXCAL45DP_MASK)
TX_CLR - USB PHY Transmitter Control Register
#define USBPHY_TX_CLR_D_CAL_MASK   (0xFU)
#define USBPHY_TX_CLR_D_CAL_SHIFT   (0U)
#define USBPHY_TX_CLR_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_D_CAL_SHIFT)) & USBPHY_TX_CLR_D_CAL_MASK)
#define USBPHY_TX_CLR_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_CLR_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_CLR_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DN_SHIFT)) & USBPHY_TX_CLR_TXCAL45DN_MASK)
#define USBPHY_TX_CLR_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_CLR_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_CLR_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DP_SHIFT)) & USBPHY_TX_CLR_TXCAL45DP_MASK)
TX_TOG - USB PHY Transmitter Control Register
#define USBPHY_TX_TOG_D_CAL_MASK   (0xFU)
#define USBPHY_TX_TOG_D_CAL_SHIFT   (0U)
#define USBPHY_TX_TOG_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_D_CAL_SHIFT)) & USBPHY_TX_TOG_D_CAL_MASK)
#define USBPHY_TX_TOG_TXCAL45DN_MASK   (0xF00U)
#define USBPHY_TX_TOG_TXCAL45DN_SHIFT   (8U)
#define USBPHY_TX_TOG_TXCAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DN_SHIFT)) & USBPHY_TX_TOG_TXCAL45DN_MASK)
#define USBPHY_TX_TOG_TXCAL45DP_MASK   (0xF0000U)
#define USBPHY_TX_TOG_TXCAL45DP_SHIFT   (16U)
#define USBPHY_TX_TOG_TXCAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DP_SHIFT)) & USBPHY_TX_TOG_TXCAL45DP_MASK)
RX - USB PHY Receiver Control Register
#define USBPHY_RX_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_ENVADJ_SHIFT)) & USBPHY_RX_ENVADJ_MASK)
#define USBPHY_RX_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_DISCONADJ_SHIFT)) & USBPHY_RX_DISCONADJ_MASK)
#define USBPHY_RX_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_RXDBYPASS_SHIFT)) & USBPHY_RX_RXDBYPASS_MASK)
RX_SET - USB PHY Receiver Control Register
#define USBPHY_RX_SET_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_SET_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_SET_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_ENVADJ_SHIFT)) & USBPHY_RX_SET_ENVADJ_MASK)
#define USBPHY_RX_SET_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_SET_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_SET_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_DISCONADJ_SHIFT)) & USBPHY_RX_SET_DISCONADJ_MASK)
#define USBPHY_RX_SET_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_SET_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_SET_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_RXDBYPASS_SHIFT)) & USBPHY_RX_SET_RXDBYPASS_MASK)
RX_CLR - USB PHY Receiver Control Register
#define USBPHY_RX_CLR_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_CLR_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_CLR_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_ENVADJ_SHIFT)) & USBPHY_RX_CLR_ENVADJ_MASK)
#define USBPHY_RX_CLR_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_CLR_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_CLR_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_DISCONADJ_SHIFT)) & USBPHY_RX_CLR_DISCONADJ_MASK)
#define USBPHY_RX_CLR_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_CLR_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_CLR_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_RXDBYPASS_SHIFT)) & USBPHY_RX_CLR_RXDBYPASS_MASK)
RX_TOG - USB PHY Receiver Control Register
#define USBPHY_RX_TOG_ENVADJ_MASK   (0x7U)
#define USBPHY_RX_TOG_ENVADJ_SHIFT   (0U)
#define USBPHY_RX_TOG_ENVADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_ENVADJ_SHIFT)) & USBPHY_RX_TOG_ENVADJ_MASK)
#define USBPHY_RX_TOG_DISCONADJ_MASK   (0x70U)
#define USBPHY_RX_TOG_DISCONADJ_SHIFT   (4U)
#define USBPHY_RX_TOG_DISCONADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_DISCONADJ_SHIFT)) & USBPHY_RX_TOG_DISCONADJ_MASK)
#define USBPHY_RX_TOG_RXDBYPASS_MASK   (0x400000U)
#define USBPHY_RX_TOG_RXDBYPASS_SHIFT   (22U)
#define USBPHY_RX_TOG_RXDBYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_RXDBYPASS_SHIFT)) & USBPHY_RX_TOG_RXDBYPASS_MASK)
CTRL - USB PHY General Control Register
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_RESUME_IRQ_MASK)
#define USBPHY_CTRL_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLKGATE_SHIFT)) & USBPHY_CTRL_CLKGATE_MASK)
#define USBPHY_CTRL_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SFTRST_SHIFT)) & USBPHY_CTRL_SFTRST_MASK)
CTRL_SET - USB PHY General Control Register
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_SET_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_SET_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_SET_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_SET_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_SET_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_SET_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_SET_RESUME_IRQ_MASK)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_SET_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_SET_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_SET_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_SET_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_SET_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_SET_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_SET_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_SET_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_SET_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_SET_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_SET_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_SET_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_SET_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_SET_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_SET_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_SET_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_SET_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_SET_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_SET_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_SET_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_SET_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_SET_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_SET_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_SET_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_CLKGATE_MASK)
#define USBPHY_CTRL_SET_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_SET_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_SET_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_SFTRST_SHIFT)) & USBPHY_CTRL_SET_SFTRST_MASK)
CTRL_CLR - USB PHY General Control Register
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_CLR_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_CLR_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_CLR_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_CLR_RESUME_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_CLR_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_CLR_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_CLR_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_CLR_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_CLR_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_CLR_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_CLR_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_CLR_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_CLR_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_CLR_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_CLR_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_CLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_CLKGATE_MASK)
#define USBPHY_CTRL_CLR_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_CLR_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_CLR_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_SFTRST_SHIFT)) & USBPHY_CTRL_CLR_SFTRST_MASK)
CTRL_TOG - USB PHY General Control Register
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK   (0x1U)
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT   (0U)
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK   (0x2U)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT   (1U)
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK   (0x4U)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT   (2U)
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK   (0x8U)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT   (3U)
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK   (0x10U)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT   (4U)
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK   (0x20U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT   (5U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK   (0x40U)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT   (6U)
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK   (0x80U)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT   (7U)
#define USBPHY_CTRL_TOG_ENOTGIDDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK   (0x100U)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT   (8U)
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK   (0x200U)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT   (9U)
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK)
#define USBPHY_CTRL_TOG_RESUME_IRQ_MASK   (0x400U)
#define USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT   (10U)
#define USBPHY_CTRL_TOG_RESUME_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_TOG_RESUME_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK   (0x800U)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT   (11U)
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK   (0x1000U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT   (12U)
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK   (0x4000U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT   (14U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL2(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK   (0x8000U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT   (15U)
#define USBPHY_CTRL_TOG_ENUTMILEVEL3(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK   (0x10000U)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT   (16U)
#define USBPHY_CTRL_TOG_ENIRQWAKEUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK   (0x20000U)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT   (17U)
#define USBPHY_CTRL_TOG_WAKEUP_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK)
#define USBPHY_CTRL_TOG_AUTORESUME_EN_MASK   (0x40000U)
#define USBPHY_CTRL_TOG_AUTORESUME_EN_SHIFT   (18U)
#define USBPHY_CTRL_TOG_AUTORESUME_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_TOG_AUTORESUME_EN_MASK)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK   (0x80000U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT   (19U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK   (0x100000U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT   (20U)
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK   (0x200000U)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT   (21U)
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK   (0x400000U)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT   (22U)
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK   (0x800000U)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT   (23U)
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK   (0x1000000U)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT   (24U)
#define USBPHY_CTRL_TOG_FSDLL_RST_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK   (0x8000000U)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT   (27U)
#define USBPHY_CTRL_TOG_OTG_ID_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK   (0x10000000U)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT   (28U)
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK   (0x20000000U)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT   (29U)
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK)
#define USBPHY_CTRL_TOG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_CTRL_TOG_CLKGATE_SHIFT   (30U)
#define USBPHY_CTRL_TOG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_CLKGATE_MASK)
#define USBPHY_CTRL_TOG_SFTRST_MASK   (0x80000000U)
#define USBPHY_CTRL_TOG_SFTRST_SHIFT   (31U)
#define USBPHY_CTRL_TOG_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_SFTRST_SHIFT)) & USBPHY_CTRL_TOG_SFTRST_MASK)
STATUS - USB PHY Status Register
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK   (0x8U)
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT   (3U)
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT)) & USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK)
#define USBPHY_STATUS_DEVPLUGIN_STATUS_MASK   (0x40U)
#define USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT   (6U)
#define USBPHY_STATUS_DEVPLUGIN_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT)) & USBPHY_STATUS_DEVPLUGIN_STATUS_MASK)
#define USBPHY_STATUS_OTGID_STATUS_MASK   (0x100U)
#define USBPHY_STATUS_OTGID_STATUS_SHIFT   (8U)
#define USBPHY_STATUS_OTGID_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_OTGID_STATUS_SHIFT)) & USBPHY_STATUS_OTGID_STATUS_MASK)
#define USBPHY_STATUS_RESUME_STATUS_MASK   (0x400U)
#define USBPHY_STATUS_RESUME_STATUS_SHIFT   (10U)
#define USBPHY_STATUS_RESUME_STATUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RESUME_STATUS_SHIFT)) & USBPHY_STATUS_RESUME_STATUS_MASK)
DEBUG - USB PHY Debug Register
#define USBPHY_DEBUG_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLKGATE_SHIFT)) & USBPHY_DEBUG_CLKGATE_MASK)
DEBUG_SET - USB PHY Debug Register
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_SET_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_SET_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_SET_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_SET_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_SET_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_SET_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_SET_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_SET_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_SET_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_SET_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_SET_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_CLKGATE_SHIFT)) & USBPHY_DEBUG_SET_CLKGATE_MASK)
DEBUG_CLR - USB PHY Debug Register
#define USBPHY_DEBUG_CLR_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_CLR_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_CLR_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_CLR_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_CLR_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_CLR_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_CLR_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_CLR_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_CLR_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_CLR_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_CLR_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_CLR_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_CLR_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_CLR_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_CLR_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_CLR_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_CLR_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_CLR_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_CLR_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_CLR_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_CLR_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_CLR_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_CLR_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_CLR_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_CLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_CLKGATE_SHIFT)) & USBPHY_DEBUG_CLR_CLKGATE_MASK)
DEBUG_TOG - USB PHY Debug Register
#define USBPHY_DEBUG_TOG_OTGIDPIOLOCK_MASK   (0x1U)
#define USBPHY_DEBUG_TOG_OTGIDPIOLOCK_SHIFT   (0U)
#define USBPHY_DEBUG_TOG_OTGIDPIOLOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_TOG_OTGIDPIOLOCK_MASK)
#define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_MASK   (0x2U)
#define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_SHIFT   (1U)
#define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_MASK)
#define USBPHY_DEBUG_TOG_HSTPULLDOWN_MASK   (0xCU)
#define USBPHY_DEBUG_TOG_HSTPULLDOWN_SHIFT   (2U)
#define USBPHY_DEBUG_TOG_HSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_TOG_HSTPULLDOWN_MASK)
#define USBPHY_DEBUG_TOG_ENHSTPULLDOWN_MASK   (0x30U)
#define USBPHY_DEBUG_TOG_ENHSTPULLDOWN_SHIFT   (4U)
#define USBPHY_DEBUG_TOG_ENHSTPULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_TOG_ENHSTPULLDOWN_MASK)
#define USBPHY_DEBUG_TOG_TX2RXCOUNT_MASK   (0xF00U)
#define USBPHY_DEBUG_TOG_TX2RXCOUNT_SHIFT   (8U)
#define USBPHY_DEBUG_TOG_TX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_TX2RXCOUNT_MASK)
#define USBPHY_DEBUG_TOG_ENTX2RXCOUNT_MASK   (0x1000U)
#define USBPHY_DEBUG_TOG_ENTX2RXCOUNT_SHIFT   (12U)
#define USBPHY_DEBUG_TOG_ENTX2RXCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_ENTX2RXCOUNT_MASK)
#define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_MASK   (0x1F0000U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_SHIFT   (16U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_MASK)
#define USBPHY_DEBUG_TOG_ENSQUELCHRESET_MASK   (0x1000000U)
#define USBPHY_DEBUG_TOG_ENSQUELCHRESET_SHIFT   (24U)
#define USBPHY_DEBUG_TOG_ENSQUELCHRESET(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_TOG_ENSQUELCHRESET_MASK)
#define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_MASK   (0x1E000000U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_SHIFT   (25U)
#define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_MASK)
#define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_MASK   (0x20000000U)
#define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_SHIFT   (29U)
#define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_MASK)
#define USBPHY_DEBUG_TOG_CLKGATE_MASK   (0x40000000U)
#define USBPHY_DEBUG_TOG_CLKGATE_SHIFT   (30U)
#define USBPHY_DEBUG_TOG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_CLKGATE_SHIFT)) & USBPHY_DEBUG_TOG_CLKGATE_MASK)
DEBUG0_STATUS - UTMI Debug Status Register 0
#define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_MASK   (0xFFFFU)
#define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_SHIFT   (0U)
#define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_MASK)
#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_MASK   (0x3FF0000U)
#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_SHIFT   (16U)
#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_MASK)
#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK   (0xFC000000U)
#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_SHIFT   (26U)
#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK)
DEBUG1 - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_TST_MASK)
DEBUG1_SET - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_SET_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_SET_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_SET_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_SET_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_MASK)
DEBUG1_CLR - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_CLR_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_CLR_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_CLR_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_CLR_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_MASK)
DEBUG1_TOG - UTMI Debug Status Register 1
#define USBPHY_DEBUG1_TOG_ENTAILADJVD_MASK   (0x6000U)
#define USBPHY_DEBUG1_TOG_ENTAILADJVD_SHIFT   (13U)
#define USBPHY_DEBUG1_TOG_ENTAILADJVD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_TOG_ENTAILADJVD_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_MASK   (0x8000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_SHIFT   (15U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_MASK   (0x10000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_SHIFT   (16U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_MASK   (0x20000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_SHIFT   (17U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_MASK   (0x1C0000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_SHIFT   (18U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_MASK   (0x600000U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_SHIFT   (21U)
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_MASK)
VERSION - UTMI RTL Version
#define USBPHY_VERSION_STEP_MASK   (0xFFFFU)
#define USBPHY_VERSION_STEP_SHIFT   (0U)
#define USBPHY_VERSION_STEP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_STEP_SHIFT)) & USBPHY_VERSION_STEP_MASK)
#define USBPHY_VERSION_MINOR_MASK   (0xFF0000U)
#define USBPHY_VERSION_MINOR_SHIFT   (16U)
#define USBPHY_VERSION_MINOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_MINOR_SHIFT)) & USBPHY_VERSION_MINOR_MASK)
#define USBPHY_VERSION_MAJOR_MASK   (0xFF000000U)
#define USBPHY_VERSION_MAJOR_SHIFT   (24U)
#define USBPHY_VERSION_MAJOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_MAJOR_SHIFT)) & USBPHY_VERSION_MAJOR_MASK)
PLL_SIC - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_PLL_LOCK_MASK)
PLL_SIC_SET - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_SET_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_SET_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_SET_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_SET_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_SET_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_SET_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_SET_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_SET_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_SET_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_SET_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_SET_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_SET_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_SET_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_SET_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_SET_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_SET_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_SET_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_SET_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_SET_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_LOCK_MASK)
PLL_SIC_CLR - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_CLR_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_CLR_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_CLR_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_CLR_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_CLR_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_CLR_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_CLR_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_CLR_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_CLR_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_CLR_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_CLR_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_CLR_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_CLR_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_LOCK_MASK)
PLL_SIC_TOG - USB PHY PLL Control/Status Register
#define USBPHY_PLL_SIC_TOG_PLL_POSTDIV_MASK   (0x1CU)
#define USBPHY_PLL_SIC_TOG_PLL_POSTDIV_SHIFT   (2U)
#define USBPHY_PLL_SIC_TOG_PLL_POSTDIV(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_POSTDIV_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_MASK   (0x40U)
#define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_SHIFT   (6U)
#define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_POWER_MASK   (0x1000U)
#define USBPHY_PLL_SIC_TOG_PLL_POWER_SHIFT   (12U)
#define USBPHY_PLL_SIC_TOG_PLL_POWER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_POWER_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_ENABLE_MASK   (0x2000U)
#define USBPHY_PLL_SIC_TOG_PLL_ENABLE_SHIFT   (13U)
#define USBPHY_PLL_SIC_TOG_PLL_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_ENABLE_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_BYPASS_MASK   (0x10000U)
#define USBPHY_PLL_SIC_TOG_PLL_BYPASS_SHIFT   (16U)
#define USBPHY_PLL_SIC_TOG_PLL_BYPASS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_BYPASS_MASK)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_MASK   (0x80000U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_SHIFT   (19U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_MASK)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_MASK   (0x100000U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SHIFT   (20U)
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_TOG_REFBIAS_PWD_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_MASK   (0x200000U)
#define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_SHIFT   (21U)
#define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_MASK   (0x1C00000U)
#define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_SHIFT   (22U)
#define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_MASK)
#define USBPHY_PLL_SIC_TOG_PLL_LOCK_MASK   (0x80000000U)
#define USBPHY_PLL_SIC_TOG_PLL_LOCK_SHIFT   (31U)
#define USBPHY_PLL_SIC_TOG_PLL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_LOCK_MASK)
USB1_VBUS_DETECT - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DETECT_SET - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DETECT_CLR - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DETECT_TOG - USB PHY VBUS Detect Control Register
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK   (0x7U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_MASK   (0x20U)
#define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_SHIFT   (5U)
#define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_MASK   (0x40U)
#define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_SHIFT   (6U)
#define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_MASK   (0x80U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_SHIFT   (7U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_MASK   (0x100U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_SHIFT   (8U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_MASK   (0x600U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_SHIFT   (9U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_MASK   (0x800U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_SHIFT   (11U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_MASK   (0x1000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_SHIFT   (12U)
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_MASK   (0x40000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_SHIFT   (18U)
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_MASK   (0x700000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_SHIFT   (20U)
#define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK   (0x4000000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT   (26U)
#define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK)
#define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_MASK   (0x80000000U)
#define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_SHIFT   (31U)
#define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_MASK)
USB1_VBUS_DET_STAT - USB PHY VBUS Detector Status Register
#define USBPHY_USB1_VBUS_DET_STAT_SESSEND_MASK   (0x1U)
#define USBPHY_USB1_VBUS_DET_STAT_SESSEND_SHIFT   (0U)
#define USBPHY_USB1_VBUS_DET_STAT_SESSEND(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_SESSEND_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_SESSEND_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_BVALID_MASK   (0x2U)
#define USBPHY_USB1_VBUS_DET_STAT_BVALID_SHIFT   (1U)
#define USBPHY_USB1_VBUS_DET_STAT_BVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_BVALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_BVALID_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_AVALID_MASK   (0x4U)
#define USBPHY_USB1_VBUS_DET_STAT_AVALID_SHIFT   (2U)
#define USBPHY_USB1_VBUS_DET_STAT_AVALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_AVALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_AVALID_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_MASK   (0x8U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_SHIFT   (3U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_MASK)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_MASK   (0x10U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_SHIFT   (4U)
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_MASK)
USB1_CHRG_DETECT - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_BGR_BIAS_MASK)
USB1_CHRG_DETECT_SET - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_MASK)
USB1_CHRG_DETECT_CLR - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_MASK)
USB1_CHRG_DETECT_TOG - USB PHY Charger Detect Control Register
#define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_MASK)
#define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_MASK   (0x800000U)
#define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_SHIFT   (23U)
#define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_MASK)
USB1_CHRG_DET_STAT - USB PHY Charger Detect Status Register
#define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_MASK   (0x1U)
#define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_SHIFT   (0U)
#define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_MASK   (0x2U)
#define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_SHIFT   (1U)
#define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_DN_STATE_MASK   (0x4U)
#define USBPHY_USB1_CHRG_DET_STAT_DN_STATE_SHIFT   (2U)
#define USBPHY_USB1_CHRG_DET_STAT_DN_STATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_DN_STATE_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_DN_STATE_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_DP_STATE_MASK   (0x8U)
#define USBPHY_USB1_CHRG_DET_STAT_DP_STATE_SHIFT   (3U)
#define USBPHY_USB1_CHRG_DET_STAT_DP_STATE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_DP_STATE_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_DP_STATE_MASK)
#define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_MASK   (0x10U)
#define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_SHIFT   (4U)
#define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_MASK)
ANACTRL - USB PHY Analog Control Register
#define USBPHY_ANACTRL_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_DEV_PULLDOWN_MASK)
ANACTRL_SET - USB PHY Analog Control Register
#define USBPHY_ANACTRL_SET_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_SET_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_SET_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_SET_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_SET_DEV_PULLDOWN_MASK)
ANACTRL_CLR - USB PHY Analog Control Register
#define USBPHY_ANACTRL_CLR_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_CLR_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_CLR_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_CLR_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_CLR_DEV_PULLDOWN_MASK)
ANACTRL_TOG - USB PHY Analog Control Register
#define USBPHY_ANACTRL_TOG_DEV_PULLDOWN_MASK   (0x400U)
#define USBPHY_ANACTRL_TOG_DEV_PULLDOWN_SHIFT   (10U)
#define USBPHY_ANACTRL_TOG_DEV_PULLDOWN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_TOG_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_TOG_DEV_PULLDOWN_MASK)
USB1_LOOPBACK - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTPKT_MASK)
USB1_LOOPBACK_SET - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_SET_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_SET_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_SET_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTPKT_MASK)
USB1_LOOPBACK_CLR - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_CLR_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_CLR_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTPKT_MASK)
USB1_LOOPBACK_TOG - USB PHY Loopback Control/Status Register
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_MASK   (0x1U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_MASK   (0x2U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_SHIFT   (1U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_MASK   (0x4U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_SHIFT   (2U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_MASK   (0x8U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_SHIFT   (3U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_MASK   (0x10U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_SHIFT   (4U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_MASK   (0x20U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_SHIFT   (5U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_MASK   (0x40U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_SHIFT   (6U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_MASK   (0x80U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_SHIFT   (7U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_MASK   (0x100U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_SHIFT   (8U)
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_MASK   (0x8000U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_SHIFT   (15U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_MASK)
#define USBPHY_USB1_LOOPBACK_TOG_TSTPKT_MASK   (0xFF0000U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTPKT_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_TOG_TSTPKT(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTPKT_MASK)
USB1_LOOPBACK_HSFSCNT - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_MASK)
USB1_LOOPBACK_HSFSCNT_SET - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_MASK)
USB1_LOOPBACK_HSFSCNT_CLR - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_MASK)
USB1_LOOPBACK_HSFSCNT_TOG - USB PHY Loopback Packet Number Select Register
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_MASK   (0xFFFFU)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_SHIFT   (0U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_MASK)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_MASK   (0xFFFF0000U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_SHIFT   (16U)
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_MASK)
TRIM_OVERRIDE_EN - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_MASK)
TRIM_OVERRIDE_EN_SET - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_MASK)
TRIM_OVERRIDE_EN_CLR - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_MASK)
TRIM_OVERRIDE_EN_TOG - USB PHY Trim Override Enable Register
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_MASK   (0x1U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_SHIFT   (0U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK   (0x2U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT   (1U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_MASK   (0x4U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_SHIFT   (2U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_MASK   (0x8U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_SHIFT   (3U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_MASK   (0x10U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_SHIFT   (4U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK   (0x20U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT   (5U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_MASK   (0x40U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_SHIFT   (6U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_MASK   (0x1C00U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_SHIFT   (10U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_MASK   (0x6000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_SHIFT   (13U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_MASK   (0x38000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_SHIFT   (15U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK   (0xC0000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT   (18U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_MASK   (0xF00000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_SHIFT   (20U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_MASK   (0xF000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_SHIFT   (24U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_MASK)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_MASK   (0xF0000000U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_SHIFT   (28U)
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN(x)   (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_MASK)
◆ USBPHY_ANACTRL_CLR_DEV_PULLDOWN [1/2]
#define USBPHY_ANACTRL_CLR_DEV_PULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_CLR_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_CLR_DEV_PULLDOWN_MASK)
DEV_PULLDOWN - DEV_PULLDOWN
◆ USBPHY_ANACTRL_CLR_DEV_PULLDOWN [2/2]
◆ USBPHY_ANACTRL_DEV_PULLDOWN [1/2]
#define USBPHY_ANACTRL_DEV_PULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_DEV_PULLDOWN_MASK)
DEV_PULLDOWN - DEV_PULLDOWN 0b0..The 15kohm nominal pulldowns on the DP and DN pinsare disabled in device mode. 0b1..The 15kohm nominal pulldowns on the DP and DN pinsare enabled in device mode.
◆ USBPHY_ANACTRL_DEV_PULLDOWN [2/2]
◆ USBPHY_ANACTRL_SET_DEV_PULLDOWN [1/2]
#define USBPHY_ANACTRL_SET_DEV_PULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_SET_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_SET_DEV_PULLDOWN_MASK)
◆ USBPHY_ANACTRL_SET_DEV_PULLDOWN [2/2]
◆ USBPHY_ANACTRL_TOG_DEV_PULLDOWN [1/2]
#define USBPHY_ANACTRL_TOG_DEV_PULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_ANACTRL_TOG_DEV_PULLDOWN_SHIFT)) & USBPHY_ANACTRL_TOG_DEV_PULLDOWN_MASK)
◆ USBPHY_ANACTRL_TOG_DEV_PULLDOWN [2/2]
◆ USBPHY_CTRL_AUTORESUME_EN [1/2]
#define USBPHY_CTRL_AUTORESUME_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_AUTORESUME_EN_MASK)
AUTORESUME_EN - AUTORESUME_EN
◆ USBPHY_CTRL_AUTORESUME_EN [2/2]
◆ USBPHY_CTRL_CLKGATE [1/2]
#define USBPHY_CTRL_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLKGATE_SHIFT)) & USBPHY_CTRL_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_CTRL_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_CTRL_CLR_AUTORESUME_EN [1/2]
#define USBPHY_CTRL_CLR_AUTORESUME_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_CLR_AUTORESUME_EN_MASK)
◆ USBPHY_CTRL_CLR_AUTORESUME_EN [2/2]
◆ USBPHY_CTRL_CLR_CLKGATE [1/2]
#define USBPHY_CTRL_CLR_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_CTRL_CLR_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_CTRL_CLR_DEVPLUGIN_IRQ [1/2]
#define USBPHY_CTRL_CLR_DEVPLUGIN_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_IRQ_MASK)
DEVPLUGIN_IRQ - DEVPLUGIN_IRQ
◆ USBPHY_CTRL_CLR_DEVPLUGIN_IRQ [2/2]
◆ USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY [1/2]
#define USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY_MASK)
DEVPLUGIN_POLARITY - DEVPLUGIN_POLARITY
◆ USBPHY_CTRL_CLR_DEVPLUGIN_POLARITY [2/2]
◆ USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE [1/2]
#define USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE_MASK)
ENAUTOCLR_CLKGATE - ENAUTOCLR_CLKGATE
◆ USBPHY_CTRL_CLR_ENAUTOCLR_CLKGATE [2/2]
◆ USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD [1/2]
#define USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD_MASK)
ENAUTOCLR_PHY_PWD - ENAUTOCLR_PHY_PWD
◆ USBPHY_CTRL_CLR_ENAUTOCLR_PHY_PWD [2/2]
◆ USBPHY_CTRL_CLR_ENDEVPLUGINDETECT [1/2]
#define USBPHY_CTRL_CLR_ENDEVPLUGINDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENDEVPLUGINDETECT_MASK)
ENDEVPLUGINDETECT - Enables non-standard resistive plugged-in detection
◆ USBPHY_CTRL_CLR_ENDEVPLUGINDETECT [2/2]
◆ USBPHY_CTRL_CLR_ENDPDMCHG_WKUP [1/2]
#define USBPHY_CTRL_CLR_ENDPDMCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENDPDMCHG_WKUP_MASK)
ENDPDMCHG_WKUP - ENDPDMCHG_WKUP
◆ USBPHY_CTRL_CLR_ENDPDMCHG_WKUP [2/2]
◆ USBPHY_CTRL_CLR_ENHOSTDISCONDETECT [1/2]
#define USBPHY_CTRL_CLR_ENHOSTDISCONDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENHOSTDISCONDETECT_MASK)
ENHOSTDISCONDETECT - ENHOSTDISCONDETECT
◆ USBPHY_CTRL_CLR_ENHOSTDISCONDETECT [2/2]
◆ USBPHY_CTRL_CLR_ENIDCHG_WKUP [1/2]
#define USBPHY_CTRL_CLR_ENIDCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENIDCHG_WKUP_MASK)
ENIDCHG_WKUP - ENIDCHG_WKUP
◆ USBPHY_CTRL_CLR_ENIDCHG_WKUP [2/2]
◆ USBPHY_CTRL_CLR_ENIRQDEVPLUGIN [1/2]
#define USBPHY_CTRL_CLR_ENIRQDEVPLUGIN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_CLR_ENIRQDEVPLUGIN_MASK)
ENIRQDEVPLUGIN - ENIRQDEVPLUGIN
◆ USBPHY_CTRL_CLR_ENIRQDEVPLUGIN [2/2]
◆ USBPHY_CTRL_CLR_ENIRQHOSTDISCON [1/2]
#define USBPHY_CTRL_CLR_ENIRQHOSTDISCON (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_CLR_ENIRQHOSTDISCON_MASK)
ENIRQHOSTDISCON - ENIRQHOSTDISCON
◆ USBPHY_CTRL_CLR_ENIRQHOSTDISCON [2/2]
◆ USBPHY_CTRL_CLR_ENIRQRESUMEDETECT [1/2]
#define USBPHY_CTRL_CLR_ENIRQRESUMEDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENIRQRESUMEDETECT_MASK)
ENIRQRESUMEDETECT - ENIRQRESUMEDETECT
◆ USBPHY_CTRL_CLR_ENIRQRESUMEDETECT [2/2]
◆ USBPHY_CTRL_CLR_ENIRQWAKEUP [1/2]
#define USBPHY_CTRL_CLR_ENIRQWAKEUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_CLR_ENIRQWAKEUP_MASK)
ENIRQWAKEUP - ENIRQWAKEUP
◆ USBPHY_CTRL_CLR_ENIRQWAKEUP [2/2]
◆ USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ_MASK)
ENOTG_ID_CHG_IRQ - ENOTG_ID_CHG_IRQ
◆ USBPHY_CTRL_CLR_ENOTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_CLR_ENOTGIDDETECT [1/2]
#define USBPHY_CTRL_CLR_ENOTGIDDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_CLR_ENOTGIDDETECT_MASK)
ENOTGIDDETECT - ENOTGIDDETECT
◆ USBPHY_CTRL_CLR_ENOTGIDDETECT [2/2]
◆ USBPHY_CTRL_CLR_ENUTMILEVEL2 [1/2]
#define USBPHY_CTRL_CLR_ENUTMILEVEL2 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL2_MASK)
ENUTMILEVEL2 - ENUTMILEVEL2
◆ USBPHY_CTRL_CLR_ENUTMILEVEL2 [2/2]
◆ USBPHY_CTRL_CLR_ENUTMILEVEL3 [1/2]
#define USBPHY_CTRL_CLR_ENUTMILEVEL3 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_CLR_ENUTMILEVEL3_MASK)
ENUTMILEVEL3 - ENUTMILEVEL3
◆ USBPHY_CTRL_CLR_ENUTMILEVEL3 [2/2]
◆ USBPHY_CTRL_CLR_ENVBUSCHG_WKUP [1/2]
#define USBPHY_CTRL_CLR_ENVBUSCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_CLR_ENVBUSCHG_WKUP_MASK)
ENVBUSCHG_WKUP - ENVBUSCHG_WKUP
◆ USBPHY_CTRL_CLR_ENVBUSCHG_WKUP [2/2]
◆ USBPHY_CTRL_CLR_FSDLL_RST_EN [1/2]
#define USBPHY_CTRL_CLR_FSDLL_RST_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_CLR_FSDLL_RST_EN_MASK)
FSDLL_RST_EN - FSDLL_RST_EN
◆ USBPHY_CTRL_CLR_FSDLL_RST_EN [2/2]
◆ USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0 [1/2]
#define USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0_MASK)
HOST_FORCE_LS_SE0 - HOST_FORCE_LS_SE0
◆ USBPHY_CTRL_CLR_HOST_FORCE_LS_SE0 [2/2]
◆ USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ [1/2]
#define USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ_MASK)
HOSTDISCONDETECT_IRQ - HOSTDISCONDETECT_IRQ
◆ USBPHY_CTRL_CLR_HOSTDISCONDETECT_IRQ [2/2]
◆ USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ_MASK)
OTG_ID_CHG_IRQ - OTG_ID_CHG_IRQ
◆ USBPHY_CTRL_CLR_OTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_CLR_OTG_ID_VALUE [1/2]
#define USBPHY_CTRL_CLR_OTG_ID_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_CLR_OTG_ID_VALUE_MASK)
OTG_ID_VALUE - OTG_ID_VALUE
◆ USBPHY_CTRL_CLR_OTG_ID_VALUE [2/2]
◆ USBPHY_CTRL_CLR_RESUME_IRQ [1/2]
#define USBPHY_CTRL_CLR_RESUME_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_CLR_RESUME_IRQ_MASK)
RESUME_IRQ - RESUME_IRQ
◆ USBPHY_CTRL_CLR_RESUME_IRQ [2/2]
◆ USBPHY_CTRL_CLR_RESUMEIRQSTICKY [1/2]
#define USBPHY_CTRL_CLR_RESUMEIRQSTICKY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_CLR_RESUMEIRQSTICKY_MASK)
RESUMEIRQSTICKY - RESUMEIRQSTICKY
◆ USBPHY_CTRL_CLR_RESUMEIRQSTICKY [2/2]
◆ USBPHY_CTRL_CLR_SFTRST [1/2]
#define USBPHY_CTRL_CLR_SFTRST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_SFTRST_SHIFT)) & USBPHY_CTRL_CLR_SFTRST_MASK)
SFTRST - SFTRST
◆ USBPHY_CTRL_CLR_SFTRST [2/2]
SFTRST - SFTRST
◆ USBPHY_CTRL_CLR_UTMI_SUSPENDM [1/2]
#define USBPHY_CTRL_CLR_UTMI_SUSPENDM (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_CLR_UTMI_SUSPENDM_MASK)
UTMI_SUSPENDM - UTMI_SUSPENDM
◆ USBPHY_CTRL_CLR_UTMI_SUSPENDM [2/2]
◆ USBPHY_CTRL_CLR_WAKEUP_IRQ [1/2]
#define USBPHY_CTRL_CLR_WAKEUP_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_CLR_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_CLR_WAKEUP_IRQ_MASK)
WAKEUP_IRQ - WAKEUP_IRQ
◆ USBPHY_CTRL_CLR_WAKEUP_IRQ [2/2]
◆ USBPHY_CTRL_DEVPLUGIN_IRQ [1/2]
#define USBPHY_CTRL_DEVPLUGIN_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_IRQ_MASK)
◆ USBPHY_CTRL_DEVPLUGIN_IRQ [2/2]
◆ USBPHY_CTRL_DEVPLUGIN_POLARITY [1/2]
#define USBPHY_CTRL_DEVPLUGIN_POLARITY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_DEVPLUGIN_POLARITY_MASK)
◆ USBPHY_CTRL_DEVPLUGIN_POLARITY [2/2]
◆ USBPHY_CTRL_ENAUTOCLR_CLKGATE [1/2]
#define USBPHY_CTRL_ENAUTOCLR_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_CLKGATE_MASK)
◆ USBPHY_CTRL_ENAUTOCLR_CLKGATE [2/2]
◆ USBPHY_CTRL_ENAUTOCLR_PHY_PWD [1/2]
#define USBPHY_CTRL_ENAUTOCLR_PHY_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_ENAUTOCLR_PHY_PWD_MASK)
◆ USBPHY_CTRL_ENAUTOCLR_PHY_PWD [2/2]
◆ USBPHY_CTRL_ENDEVPLUGINDETECT [1/2]
#define USBPHY_CTRL_ENDEVPLUGINDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_ENDEVPLUGINDETECT_MASK)
ENDEVPLUGINDETECT - Enables non-standard resistive plugged-in detection 0b0..Disables 200kohm pullup resistors on DP and DN pins 0b1..Enables 200kohm pullup resistors on DP and DN pins
◆ USBPHY_CTRL_ENDEVPLUGINDETECT [2/2]
◆ USBPHY_CTRL_ENDPDMCHG_WKUP [1/2]
#define USBPHY_CTRL_ENDPDMCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENDPDMCHG_WKUP_MASK)
◆ USBPHY_CTRL_ENDPDMCHG_WKUP [2/2]
◆ USBPHY_CTRL_ENHOSTDISCONDETECT [1/2]
#define USBPHY_CTRL_ENHOSTDISCONDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_ENHOSTDISCONDETECT_MASK)
◆ USBPHY_CTRL_ENHOSTDISCONDETECT [2/2]
◆ USBPHY_CTRL_ENIDCHG_WKUP [1/2]
#define USBPHY_CTRL_ENIDCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENIDCHG_WKUP_MASK)
◆ USBPHY_CTRL_ENIDCHG_WKUP [2/2]
◆ USBPHY_CTRL_ENIRQDEVPLUGIN [1/2]
#define USBPHY_CTRL_ENIRQDEVPLUGIN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_ENIRQDEVPLUGIN_MASK)
◆ USBPHY_CTRL_ENIRQDEVPLUGIN [2/2]
◆ USBPHY_CTRL_ENIRQHOSTDISCON [1/2]
#define USBPHY_CTRL_ENIRQHOSTDISCON (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_ENIRQHOSTDISCON_MASK)
◆ USBPHY_CTRL_ENIRQHOSTDISCON [2/2]
◆ USBPHY_CTRL_ENIRQRESUMEDETECT [1/2]
#define USBPHY_CTRL_ENIRQRESUMEDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_ENIRQRESUMEDETECT_MASK)
◆ USBPHY_CTRL_ENIRQRESUMEDETECT [2/2]
◆ USBPHY_CTRL_ENIRQWAKEUP [1/2]
#define USBPHY_CTRL_ENIRQWAKEUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_ENIRQWAKEUP_MASK)
◆ USBPHY_CTRL_ENIRQWAKEUP [2/2]
◆ USBPHY_CTRL_ENOTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_ENOTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_ENOTG_ID_CHG_IRQ_MASK)
◆ USBPHY_CTRL_ENOTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_ENOTGIDDETECT [1/2]
#define USBPHY_CTRL_ENOTGIDDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_ENOTGIDDETECT_MASK)
◆ USBPHY_CTRL_ENOTGIDDETECT [2/2]
◆ USBPHY_CTRL_ENUTMILEVEL2 [1/2]
#define USBPHY_CTRL_ENUTMILEVEL2 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL2_MASK)
◆ USBPHY_CTRL_ENUTMILEVEL2 [2/2]
◆ USBPHY_CTRL_ENUTMILEVEL3 [1/2]
#define USBPHY_CTRL_ENUTMILEVEL3 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_ENUTMILEVEL3_MASK)
◆ USBPHY_CTRL_ENUTMILEVEL3 [2/2]
◆ USBPHY_CTRL_ENVBUSCHG_WKUP [1/2]
#define USBPHY_CTRL_ENVBUSCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_ENVBUSCHG_WKUP_MASK)
◆ USBPHY_CTRL_ENVBUSCHG_WKUP [2/2]
◆ USBPHY_CTRL_FSDLL_RST_EN [1/2]
#define USBPHY_CTRL_FSDLL_RST_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_FSDLL_RST_EN_MASK)
◆ USBPHY_CTRL_FSDLL_RST_EN [2/2]
◆ USBPHY_CTRL_HOST_FORCE_LS_SE0 [1/2]
#define USBPHY_CTRL_HOST_FORCE_LS_SE0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_HOST_FORCE_LS_SE0_MASK)
◆ USBPHY_CTRL_HOST_FORCE_LS_SE0 [2/2]
◆ USBPHY_CTRL_HOSTDISCONDETECT_IRQ [1/2]
#define USBPHY_CTRL_HOSTDISCONDETECT_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_HOSTDISCONDETECT_IRQ_MASK)
◆ USBPHY_CTRL_HOSTDISCONDETECT_IRQ [2/2]
◆ USBPHY_CTRL_OTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_OTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_OTG_ID_CHG_IRQ_MASK)
◆ USBPHY_CTRL_OTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_OTG_ID_VALUE [1/2]
#define USBPHY_CTRL_OTG_ID_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_OTG_ID_VALUE_MASK)
◆ USBPHY_CTRL_OTG_ID_VALUE [2/2]
◆ USBPHY_CTRL_RESUME_IRQ [1/2]
#define USBPHY_CTRL_RESUME_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_RESUME_IRQ_MASK)
◆ USBPHY_CTRL_RESUME_IRQ [2/2]
◆ USBPHY_CTRL_RESUMEIRQSTICKY [1/2]
#define USBPHY_CTRL_RESUMEIRQSTICKY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_RESUMEIRQSTICKY_MASK)
◆ USBPHY_CTRL_RESUMEIRQSTICKY [2/2]
◆ USBPHY_CTRL_SET_AUTORESUME_EN [1/2]
#define USBPHY_CTRL_SET_AUTORESUME_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_SET_AUTORESUME_EN_MASK)
◆ USBPHY_CTRL_SET_AUTORESUME_EN [2/2]
◆ USBPHY_CTRL_SET_CLKGATE [1/2]
#define USBPHY_CTRL_SET_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_CTRL_SET_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_CTRL_SET_DEVPLUGIN_IRQ [1/2]
#define USBPHY_CTRL_SET_DEVPLUGIN_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_IRQ_MASK)
◆ USBPHY_CTRL_SET_DEVPLUGIN_IRQ [2/2]
◆ USBPHY_CTRL_SET_DEVPLUGIN_POLARITY [1/2]
#define USBPHY_CTRL_SET_DEVPLUGIN_POLARITY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_SET_DEVPLUGIN_POLARITY_MASK)
◆ USBPHY_CTRL_SET_DEVPLUGIN_POLARITY [2/2]
◆ USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE [1/2]
#define USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE_MASK)
◆ USBPHY_CTRL_SET_ENAUTOCLR_CLKGATE [2/2]
◆ USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD [1/2]
#define USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD_MASK)
◆ USBPHY_CTRL_SET_ENAUTOCLR_PHY_PWD [2/2]
◆ USBPHY_CTRL_SET_ENDEVPLUGINDETECT [1/2]
#define USBPHY_CTRL_SET_ENDEVPLUGINDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_SET_ENDEVPLUGINDETECT_MASK)
◆ USBPHY_CTRL_SET_ENDEVPLUGINDETECT [2/2]
◆ USBPHY_CTRL_SET_ENDPDMCHG_WKUP [1/2]
#define USBPHY_CTRL_SET_ENDPDMCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENDPDMCHG_WKUP_MASK)
◆ USBPHY_CTRL_SET_ENDPDMCHG_WKUP [2/2]
◆ USBPHY_CTRL_SET_ENHOSTDISCONDETECT [1/2]
#define USBPHY_CTRL_SET_ENHOSTDISCONDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_SET_ENHOSTDISCONDETECT_MASK)
◆ USBPHY_CTRL_SET_ENHOSTDISCONDETECT [2/2]
◆ USBPHY_CTRL_SET_ENIDCHG_WKUP [1/2]
#define USBPHY_CTRL_SET_ENIDCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENIDCHG_WKUP_MASK)
◆ USBPHY_CTRL_SET_ENIDCHG_WKUP [2/2]
◆ USBPHY_CTRL_SET_ENIRQDEVPLUGIN [1/2]
#define USBPHY_CTRL_SET_ENIRQDEVPLUGIN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_SET_ENIRQDEVPLUGIN_MASK)
◆ USBPHY_CTRL_SET_ENIRQDEVPLUGIN [2/2]
◆ USBPHY_CTRL_SET_ENIRQHOSTDISCON [1/2]
#define USBPHY_CTRL_SET_ENIRQHOSTDISCON (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_SET_ENIRQHOSTDISCON_MASK)
◆ USBPHY_CTRL_SET_ENIRQHOSTDISCON [2/2]
◆ USBPHY_CTRL_SET_ENIRQRESUMEDETECT [1/2]
#define USBPHY_CTRL_SET_ENIRQRESUMEDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_SET_ENIRQRESUMEDETECT_MASK)
◆ USBPHY_CTRL_SET_ENIRQRESUMEDETECT [2/2]
◆ USBPHY_CTRL_SET_ENIRQWAKEUP [1/2]
#define USBPHY_CTRL_SET_ENIRQWAKEUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_SET_ENIRQWAKEUP_MASK)
◆ USBPHY_CTRL_SET_ENIRQWAKEUP [2/2]
◆ USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ_MASK)
◆ USBPHY_CTRL_SET_ENOTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_SET_ENOTGIDDETECT [1/2]
#define USBPHY_CTRL_SET_ENOTGIDDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_SET_ENOTGIDDETECT_MASK)
◆ USBPHY_CTRL_SET_ENOTGIDDETECT [2/2]
◆ USBPHY_CTRL_SET_ENUTMILEVEL2 [1/2]
#define USBPHY_CTRL_SET_ENUTMILEVEL2 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL2_MASK)
◆ USBPHY_CTRL_SET_ENUTMILEVEL2 [2/2]
◆ USBPHY_CTRL_SET_ENUTMILEVEL3 [1/2]
#define USBPHY_CTRL_SET_ENUTMILEVEL3 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_SET_ENUTMILEVEL3_MASK)
◆ USBPHY_CTRL_SET_ENUTMILEVEL3 [2/2]
◆ USBPHY_CTRL_SET_ENVBUSCHG_WKUP [1/2]
#define USBPHY_CTRL_SET_ENVBUSCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_SET_ENVBUSCHG_WKUP_MASK)
◆ USBPHY_CTRL_SET_ENVBUSCHG_WKUP [2/2]
◆ USBPHY_CTRL_SET_FSDLL_RST_EN [1/2]
#define USBPHY_CTRL_SET_FSDLL_RST_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_SET_FSDLL_RST_EN_MASK)
◆ USBPHY_CTRL_SET_FSDLL_RST_EN [2/2]
◆ USBPHY_CTRL_SET_HOST_FORCE_LS_SE0 [1/2]
#define USBPHY_CTRL_SET_HOST_FORCE_LS_SE0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_SET_HOST_FORCE_LS_SE0_MASK)
◆ USBPHY_CTRL_SET_HOST_FORCE_LS_SE0 [2/2]
◆ USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ [1/2]
#define USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ_MASK)
◆ USBPHY_CTRL_SET_HOSTDISCONDETECT_IRQ [2/2]
◆ USBPHY_CTRL_SET_OTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_SET_OTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_CHG_IRQ_MASK)
◆ USBPHY_CTRL_SET_OTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_SET_OTG_ID_VALUE [1/2]
#define USBPHY_CTRL_SET_OTG_ID_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_SET_OTG_ID_VALUE_MASK)
◆ USBPHY_CTRL_SET_OTG_ID_VALUE [2/2]
◆ USBPHY_CTRL_SET_RESUME_IRQ [1/2]
#define USBPHY_CTRL_SET_RESUME_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_SET_RESUME_IRQ_MASK)
◆ USBPHY_CTRL_SET_RESUME_IRQ [2/2]
◆ USBPHY_CTRL_SET_RESUMEIRQSTICKY [1/2]
#define USBPHY_CTRL_SET_RESUMEIRQSTICKY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_SET_RESUMEIRQSTICKY_MASK)
◆ USBPHY_CTRL_SET_RESUMEIRQSTICKY [2/2]
◆ USBPHY_CTRL_SET_SFTRST [1/2]
#define USBPHY_CTRL_SET_SFTRST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_SFTRST_SHIFT)) & USBPHY_CTRL_SET_SFTRST_MASK)
SFTRST - SFTRST
◆ USBPHY_CTRL_SET_SFTRST [2/2]
SFTRST - SFTRST
◆ USBPHY_CTRL_SET_UTMI_SUSPENDM [1/2]
#define USBPHY_CTRL_SET_UTMI_SUSPENDM (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_SET_UTMI_SUSPENDM_MASK)
◆ USBPHY_CTRL_SET_UTMI_SUSPENDM [2/2]
◆ USBPHY_CTRL_SET_WAKEUP_IRQ [1/2]
#define USBPHY_CTRL_SET_WAKEUP_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SET_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_SET_WAKEUP_IRQ_MASK)
◆ USBPHY_CTRL_SET_WAKEUP_IRQ [2/2]
◆ USBPHY_CTRL_SFTRST [1/2]
#define USBPHY_CTRL_SFTRST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_SFTRST_SHIFT)) & USBPHY_CTRL_SFTRST_MASK)
SFTRST - SFTRST
◆ USBPHY_CTRL_SFTRST [2/2]
SFTRST - SFTRST
◆ USBPHY_CTRL_TOG_AUTORESUME_EN [1/2]
#define USBPHY_CTRL_TOG_AUTORESUME_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_AUTORESUME_EN_SHIFT)) & USBPHY_CTRL_TOG_AUTORESUME_EN_MASK)
◆ USBPHY_CTRL_TOG_AUTORESUME_EN [2/2]
◆ USBPHY_CTRL_TOG_CLKGATE [1/2]
#define USBPHY_CTRL_TOG_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_CTRL_TOG_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_CTRL_TOG_DEVPLUGIN_IRQ [1/2]
#define USBPHY_CTRL_TOG_DEVPLUGIN_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_IRQ_MASK)
◆ USBPHY_CTRL_TOG_DEVPLUGIN_IRQ [2/2]
◆ USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY [1/2]
#define USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_SHIFT)) & USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY_MASK)
◆ USBPHY_CTRL_TOG_DEVPLUGIN_POLARITY [2/2]
◆ USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE [1/2]
#define USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE_MASK)
◆ USBPHY_CTRL_TOG_ENAUTOCLR_CLKGATE [2/2]
◆ USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD [1/2]
#define USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_SHIFT)) & USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD_MASK)
◆ USBPHY_CTRL_TOG_ENAUTOCLR_PHY_PWD [2/2]
◆ USBPHY_CTRL_TOG_ENDEVPLUGINDETECT [1/2]
#define USBPHY_CTRL_TOG_ENDEVPLUGINDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENDEVPLUGINDETECT_MASK)
◆ USBPHY_CTRL_TOG_ENDEVPLUGINDETECT [2/2]
◆ USBPHY_CTRL_TOG_ENDPDMCHG_WKUP [1/2]
#define USBPHY_CTRL_TOG_ENDPDMCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENDPDMCHG_WKUP_MASK)
◆ USBPHY_CTRL_TOG_ENDPDMCHG_WKUP [2/2]
◆ USBPHY_CTRL_TOG_ENHOSTDISCONDETECT [1/2]
#define USBPHY_CTRL_TOG_ENHOSTDISCONDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENHOSTDISCONDETECT_MASK)
◆ USBPHY_CTRL_TOG_ENHOSTDISCONDETECT [2/2]
◆ USBPHY_CTRL_TOG_ENIDCHG_WKUP [1/2]
#define USBPHY_CTRL_TOG_ENIDCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIDCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENIDCHG_WKUP_MASK)
◆ USBPHY_CTRL_TOG_ENIDCHG_WKUP [2/2]
◆ USBPHY_CTRL_TOG_ENIRQDEVPLUGIN [1/2]
#define USBPHY_CTRL_TOG_ENIRQDEVPLUGIN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_SHIFT)) & USBPHY_CTRL_TOG_ENIRQDEVPLUGIN_MASK)
◆ USBPHY_CTRL_TOG_ENIRQDEVPLUGIN [2/2]
◆ USBPHY_CTRL_TOG_ENIRQHOSTDISCON [1/2]
#define USBPHY_CTRL_TOG_ENIRQHOSTDISCON (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQHOSTDISCON_SHIFT)) & USBPHY_CTRL_TOG_ENIRQHOSTDISCON_MASK)
◆ USBPHY_CTRL_TOG_ENIRQHOSTDISCON [2/2]
◆ USBPHY_CTRL_TOG_ENIRQRESUMEDETECT [1/2]
#define USBPHY_CTRL_TOG_ENIRQRESUMEDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENIRQRESUMEDETECT_MASK)
◆ USBPHY_CTRL_TOG_ENIRQRESUMEDETECT [2/2]
◆ USBPHY_CTRL_TOG_ENIRQWAKEUP [1/2]
#define USBPHY_CTRL_TOG_ENIRQWAKEUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENIRQWAKEUP_SHIFT)) & USBPHY_CTRL_TOG_ENIRQWAKEUP_MASK)
◆ USBPHY_CTRL_TOG_ENIRQWAKEUP [2/2]
◆ USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ_MASK)
◆ USBPHY_CTRL_TOG_ENOTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_TOG_ENOTGIDDETECT [1/2]
#define USBPHY_CTRL_TOG_ENOTGIDDETECT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENOTGIDDETECT_SHIFT)) & USBPHY_CTRL_TOG_ENOTGIDDETECT_MASK)
◆ USBPHY_CTRL_TOG_ENOTGIDDETECT [2/2]
◆ USBPHY_CTRL_TOG_ENUTMILEVEL2 [1/2]
#define USBPHY_CTRL_TOG_ENUTMILEVEL2 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL2_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL2_MASK)
◆ USBPHY_CTRL_TOG_ENUTMILEVEL2 [2/2]
◆ USBPHY_CTRL_TOG_ENUTMILEVEL3 [1/2]
#define USBPHY_CTRL_TOG_ENUTMILEVEL3 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENUTMILEVEL3_SHIFT)) & USBPHY_CTRL_TOG_ENUTMILEVEL3_MASK)
◆ USBPHY_CTRL_TOG_ENUTMILEVEL3 [2/2]
◆ USBPHY_CTRL_TOG_ENVBUSCHG_WKUP [1/2]
#define USBPHY_CTRL_TOG_ENVBUSCHG_WKUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_SHIFT)) & USBPHY_CTRL_TOG_ENVBUSCHG_WKUP_MASK)
◆ USBPHY_CTRL_TOG_ENVBUSCHG_WKUP [2/2]
◆ USBPHY_CTRL_TOG_FSDLL_RST_EN [1/2]
#define USBPHY_CTRL_TOG_FSDLL_RST_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_FSDLL_RST_EN_SHIFT)) & USBPHY_CTRL_TOG_FSDLL_RST_EN_MASK)
◆ USBPHY_CTRL_TOG_FSDLL_RST_EN [2/2]
◆ USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0 [1/2]
#define USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_SHIFT)) & USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0_MASK)
◆ USBPHY_CTRL_TOG_HOST_FORCE_LS_SE0 [2/2]
◆ USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ [1/2]
#define USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_SHIFT)) & USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ_MASK)
◆ USBPHY_CTRL_TOG_HOSTDISCONDETECT_IRQ [2/2]
◆ USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ [1/2]
#define USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ_MASK)
◆ USBPHY_CTRL_TOG_OTG_ID_CHG_IRQ [2/2]
◆ USBPHY_CTRL_TOG_OTG_ID_VALUE [1/2]
#define USBPHY_CTRL_TOG_OTG_ID_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_OTG_ID_VALUE_SHIFT)) & USBPHY_CTRL_TOG_OTG_ID_VALUE_MASK)
◆ USBPHY_CTRL_TOG_OTG_ID_VALUE [2/2]
◆ USBPHY_CTRL_TOG_RESUME_IRQ [1/2]
#define USBPHY_CTRL_TOG_RESUME_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUME_IRQ_SHIFT)) & USBPHY_CTRL_TOG_RESUME_IRQ_MASK)
◆ USBPHY_CTRL_TOG_RESUME_IRQ [2/2]
◆ USBPHY_CTRL_TOG_RESUMEIRQSTICKY [1/2]
#define USBPHY_CTRL_TOG_RESUMEIRQSTICKY (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_RESUMEIRQSTICKY_SHIFT)) & USBPHY_CTRL_TOG_RESUMEIRQSTICKY_MASK)
◆ USBPHY_CTRL_TOG_RESUMEIRQSTICKY [2/2]
◆ USBPHY_CTRL_TOG_SFTRST [1/2]
#define USBPHY_CTRL_TOG_SFTRST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_SFTRST_SHIFT)) & USBPHY_CTRL_TOG_SFTRST_MASK)
SFTRST - SFTRST
◆ USBPHY_CTRL_TOG_SFTRST [2/2]
SFTRST - SFTRST
◆ USBPHY_CTRL_TOG_UTMI_SUSPENDM [1/2]
#define USBPHY_CTRL_TOG_UTMI_SUSPENDM (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_TOG_UTMI_SUSPENDM_MASK)
◆ USBPHY_CTRL_TOG_UTMI_SUSPENDM [2/2]
◆ USBPHY_CTRL_TOG_WAKEUP_IRQ [1/2]
#define USBPHY_CTRL_TOG_WAKEUP_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_TOG_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_TOG_WAKEUP_IRQ_MASK)
◆ USBPHY_CTRL_TOG_WAKEUP_IRQ [2/2]
◆ USBPHY_CTRL_UTMI_SUSPENDM [1/2]
#define USBPHY_CTRL_UTMI_SUSPENDM (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_UTMI_SUSPENDM_SHIFT)) & USBPHY_CTRL_UTMI_SUSPENDM_MASK)
◆ USBPHY_CTRL_UTMI_SUSPENDM [2/2]
◆ USBPHY_CTRL_WAKEUP_IRQ [1/2]
#define USBPHY_CTRL_WAKEUP_IRQ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_CTRL_WAKEUP_IRQ_SHIFT)) & USBPHY_CTRL_WAKEUP_IRQ_MASK)
◆ USBPHY_CTRL_WAKEUP_IRQ [2/2]
◆ USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT [1/2]
#define USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT_MASK)
LOOP_BACK_FAIL_COUNT - LOOP_BACK_FAIL_COUNT
◆ USBPHY_DEBUG0_STATUS_LOOP_BACK_FAIL_COUNT [2/2]
◆ USBPHY_DEBUG0_STATUS_SQUELCH_COUNT [1/2]
#define USBPHY_DEBUG0_STATUS_SQUELCH_COUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_SQUELCH_COUNT_MASK)
SQUELCH_COUNT - SQUELCH_COUNT
◆ USBPHY_DEBUG0_STATUS_SQUELCH_COUNT [2/2]
◆ USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT [1/2]
#define USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_SHIFT)) & USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT_MASK)
UTMI_RXERROR_FAIL_COUNT - UTMI_RXERROR_FAIL_COUNT
◆ USBPHY_DEBUG0_STATUS_UTMI_RXERROR_FAIL_COUNT [2/2]
◆ USBPHY_DEBUG1_CLR_ENTAILADJVD [1/2]
#define USBPHY_DEBUG1_CLR_ENTAILADJVD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_CLR_ENTAILADJVD_MASK)
ENTAILADJVD - ENTAILADJVD
◆ USBPHY_DEBUG1_CLR_ENTAILADJVD [2/2]
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR [1/2]
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR_MASK)
USB2_REFBIAS_LOWPWR - to be added
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_LOWPWR [2/2]
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP [1/2]
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP_MASK)
USB2_REFBIAS_PWDVBGUP - Powers down the bandgap detect logic, will affect vbgup on misc1 register.
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_PWDVBGUP [2/2]
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF [1/2]
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF_MASK)
USB2_REFBIAS_SELFBIASOFF - Set to 1 to disable self bias, 100 us after power up refbias(usb2_refbias_pwd).This can reduce noise on power.
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_SELFBIASOFF [2/2]
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST [1/2]
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST_MASK)
USB2_REFBIAS_TST - Bias current control for usb2_phy
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_TST [2/2]
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ_MASK)
USB2_REFBIAS_VBGADJ - Adjustment bits on bandgap
◆ USBPHY_DEBUG1_CLR_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_DEBUG1_ENTAILADJVD [1/2]
#define USBPHY_DEBUG1_ENTAILADJVD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_ENTAILADJVD_MASK)
ENTAILADJVD - ENTAILADJVD 0b00..Delay is nominal 0b01..Delay is +20% 0b10..Delay is -20% 0b11..Delay is -40%
◆ USBPHY_DEBUG1_ENTAILADJVD [2/2]
◆ USBPHY_DEBUG1_SET_ENTAILADJVD [1/2]
#define USBPHY_DEBUG1_SET_ENTAILADJVD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_SET_ENTAILADJVD_MASK)
◆ USBPHY_DEBUG1_SET_ENTAILADJVD [2/2]
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR [1/2]
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR_MASK)
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_LOWPWR [2/2]
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP [1/2]
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP_MASK)
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_PWDVBGUP [2/2]
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF [1/2]
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF_MASK)
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_SELFBIASOFF [2/2]
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_TST [1/2]
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_TST_MASK)
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_TST [2/2]
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ_MASK)
◆ USBPHY_DEBUG1_SET_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_DEBUG1_TOG_ENTAILADJVD [1/2]
#define USBPHY_DEBUG1_TOG_ENTAILADJVD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_ENTAILADJVD_SHIFT)) & USBPHY_DEBUG1_TOG_ENTAILADJVD_MASK)
◆ USBPHY_DEBUG1_TOG_ENTAILADJVD [2/2]
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR [1/2]
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR_MASK)
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_LOWPWR [2/2]
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP [1/2]
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP_MASK)
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_PWDVBGUP [2/2]
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF [1/2]
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF_MASK)
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_SELFBIASOFF [2/2]
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST [1/2]
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST_MASK)
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_TST [2/2]
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ_MASK)
◆ USBPHY_DEBUG1_TOG_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR [1/2]
#define USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR_MASK)
◆ USBPHY_DEBUG1_USB2_REFBIAS_LOWPWR [2/2]
◆ USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP [1/2]
#define USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP_MASK)
◆ USBPHY_DEBUG1_USB2_REFBIAS_PWDVBGUP [2/2]
◆ USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF [1/2]
#define USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF_MASK)
◆ USBPHY_DEBUG1_USB2_REFBIAS_SELFBIASOFF [2/2]
◆ USBPHY_DEBUG1_USB2_REFBIAS_TST [1/2]
#define USBPHY_DEBUG1_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_TST_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_TST_MASK)
◆ USBPHY_DEBUG1_USB2_REFBIAS_TST [2/2]
◆ USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ_MASK)
◆ USBPHY_DEBUG1_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_DEBUG_CLKGATE [1/2]
#define USBPHY_DEBUG_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLKGATE_SHIFT)) & USBPHY_DEBUG_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_CLR_CLKGATE [1/2]
#define USBPHY_DEBUG_CLR_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_CLKGATE_SHIFT)) & USBPHY_DEBUG_CLR_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_CLR_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD [1/2]
#define USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD_MASK)
DEBUG_INTERFACE_HOLD - DEBUG_INTERFACE_HOLD
◆ USBPHY_DEBUG_CLR_DEBUG_INTERFACE_HOLD [2/2]
◆ USBPHY_DEBUG_CLR_ENHSTPULLDOWN [1/2]
#define USBPHY_DEBUG_CLR_ENHSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_CLR_ENHSTPULLDOWN_MASK)
ENHSTPULLDOWN - ENHSTPULLDOWN
◆ USBPHY_DEBUG_CLR_ENHSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_CLR_ENSQUELCHRESET [1/2]
#define USBPHY_DEBUG_CLR_ENSQUELCHRESET (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_CLR_ENSQUELCHRESET_MASK)
ENSQUELCHRESET - ENSQUELCHRESET
◆ USBPHY_DEBUG_CLR_ENSQUELCHRESET [2/2]
◆ USBPHY_DEBUG_CLR_ENTX2RXCOUNT [1/2]
#define USBPHY_DEBUG_CLR_ENTX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_ENTX2RXCOUNT_MASK)
ENTX2RXCOUNT - ENTX2RXCOUNT
◆ USBPHY_DEBUG_CLR_ENTX2RXCOUNT [2/2]
◆ USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG [1/2]
#define USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG_MASK)
HOST_RESUME_DEBUG - HOST_RESUME_DEBUG
◆ USBPHY_DEBUG_CLR_HOST_RESUME_DEBUG [2/2]
◆ USBPHY_DEBUG_CLR_HSTPULLDOWN [1/2]
#define USBPHY_DEBUG_CLR_HSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_CLR_HSTPULLDOWN_MASK)
HSTPULLDOWN - HSTPULLDOWN
◆ USBPHY_DEBUG_CLR_HSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_CLR_OTGIDPIOLOCK [1/2]
#define USBPHY_DEBUG_CLR_OTGIDPIOLOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_CLR_OTGIDPIOLOCK_MASK)
OTGIDPIOLOCK - OTGIDPIOLOCK
◆ USBPHY_DEBUG_CLR_OTGIDPIOLOCK [2/2]
◆ USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT [1/2]
#define USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT_MASK)
SQUELCHRESETCOUNT - SQUELCHRESETCOUNT
◆ USBPHY_DEBUG_CLR_SQUELCHRESETCOUNT [2/2]
◆ USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH [1/2]
#define USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH_MASK)
SQUELCHRESETLENGTH - SQUELCHRESETLENGTH
◆ USBPHY_DEBUG_CLR_SQUELCHRESETLENGTH [2/2]
◆ USBPHY_DEBUG_CLR_TX2RXCOUNT [1/2]
#define USBPHY_DEBUG_CLR_TX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_CLR_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_CLR_TX2RXCOUNT_MASK)
TX2RXCOUNT - TX2RXCOUNT
◆ USBPHY_DEBUG_CLR_TX2RXCOUNT [2/2]
◆ USBPHY_DEBUG_DEBUG_INTERFACE_HOLD [1/2]
#define USBPHY_DEBUG_DEBUG_INTERFACE_HOLD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_DEBUG_INTERFACE_HOLD_MASK)
◆ USBPHY_DEBUG_DEBUG_INTERFACE_HOLD [2/2]
◆ USBPHY_DEBUG_ENHSTPULLDOWN [1/2]
#define USBPHY_DEBUG_ENHSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_ENHSTPULLDOWN_MASK)
◆ USBPHY_DEBUG_ENHSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_ENSQUELCHRESET [1/2]
#define USBPHY_DEBUG_ENSQUELCHRESET (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_ENSQUELCHRESET_MASK)
◆ USBPHY_DEBUG_ENSQUELCHRESET [2/2]
◆ USBPHY_DEBUG_ENTX2RXCOUNT [1/2]
#define USBPHY_DEBUG_ENTX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_ENTX2RXCOUNT_MASK)
◆ USBPHY_DEBUG_ENTX2RXCOUNT [2/2]
◆ USBPHY_DEBUG_HOST_RESUME_DEBUG [1/2]
#define USBPHY_DEBUG_HOST_RESUME_DEBUG (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_HOST_RESUME_DEBUG_MASK)
◆ USBPHY_DEBUG_HOST_RESUME_DEBUG [2/2]
◆ USBPHY_DEBUG_HSTPULLDOWN [1/2]
#define USBPHY_DEBUG_HSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_HSTPULLDOWN_MASK)
◆ USBPHY_DEBUG_HSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_OTGIDPIOLOCK [1/2]
#define USBPHY_DEBUG_OTGIDPIOLOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_OTGIDPIOLOCK_MASK)
◆ USBPHY_DEBUG_OTGIDPIOLOCK [2/2]
◆ USBPHY_DEBUG_SET_CLKGATE [1/2]
#define USBPHY_DEBUG_SET_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_CLKGATE_SHIFT)) & USBPHY_DEBUG_SET_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_SET_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD [1/2]
#define USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD_MASK)
◆ USBPHY_DEBUG_SET_DEBUG_INTERFACE_HOLD [2/2]
◆ USBPHY_DEBUG_SET_ENHSTPULLDOWN [1/2]
#define USBPHY_DEBUG_SET_ENHSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_ENHSTPULLDOWN_MASK)
◆ USBPHY_DEBUG_SET_ENHSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_SET_ENSQUELCHRESET [1/2]
#define USBPHY_DEBUG_SET_ENSQUELCHRESET (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_SET_ENSQUELCHRESET_MASK)
◆ USBPHY_DEBUG_SET_ENSQUELCHRESET [2/2]
◆ USBPHY_DEBUG_SET_ENTX2RXCOUNT [1/2]
#define USBPHY_DEBUG_SET_ENTX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_ENTX2RXCOUNT_MASK)
◆ USBPHY_DEBUG_SET_ENTX2RXCOUNT [2/2]
◆ USBPHY_DEBUG_SET_HOST_RESUME_DEBUG [1/2]
#define USBPHY_DEBUG_SET_HOST_RESUME_DEBUG (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_SET_HOST_RESUME_DEBUG_MASK)
◆ USBPHY_DEBUG_SET_HOST_RESUME_DEBUG [2/2]
◆ USBPHY_DEBUG_SET_HSTPULLDOWN [1/2]
#define USBPHY_DEBUG_SET_HSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_SET_HSTPULLDOWN_MASK)
◆ USBPHY_DEBUG_SET_HSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_SET_OTGIDPIOLOCK [1/2]
#define USBPHY_DEBUG_SET_OTGIDPIOLOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_SET_OTGIDPIOLOCK_MASK)
◆ USBPHY_DEBUG_SET_OTGIDPIOLOCK [2/2]
◆ USBPHY_DEBUG_SET_SQUELCHRESETCOUNT [1/2]
#define USBPHY_DEBUG_SET_SQUELCHRESETCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SET_SQUELCHRESETCOUNT_MASK)
◆ USBPHY_DEBUG_SET_SQUELCHRESETCOUNT [2/2]
◆ USBPHY_DEBUG_SET_SQUELCHRESETLENGTH [1/2]
#define USBPHY_DEBUG_SET_SQUELCHRESETLENGTH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_SET_SQUELCHRESETLENGTH_MASK)
◆ USBPHY_DEBUG_SET_SQUELCHRESETLENGTH [2/2]
◆ USBPHY_DEBUG_SET_TX2RXCOUNT [1/2]
#define USBPHY_DEBUG_SET_TX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SET_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_SET_TX2RXCOUNT_MASK)
◆ USBPHY_DEBUG_SET_TX2RXCOUNT [2/2]
◆ USBPHY_DEBUG_SQUELCHRESETCOUNT [1/2]
#define USBPHY_DEBUG_SQUELCHRESETCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETCOUNT_MASK)
◆ USBPHY_DEBUG_SQUELCHRESETCOUNT [2/2]
◆ USBPHY_DEBUG_SQUELCHRESETLENGTH [1/2]
#define USBPHY_DEBUG_SQUELCHRESETLENGTH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_SQUELCHRESETLENGTH_MASK)
◆ USBPHY_DEBUG_SQUELCHRESETLENGTH [2/2]
◆ USBPHY_DEBUG_TOG_CLKGATE [1/2]
#define USBPHY_DEBUG_TOG_CLKGATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_CLKGATE_SHIFT)) & USBPHY_DEBUG_TOG_CLKGATE_MASK)
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_TOG_CLKGATE [2/2]
CLKGATE - CLKGATE
◆ USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD [1/2]
#define USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_SHIFT)) & USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD_MASK)
◆ USBPHY_DEBUG_TOG_DEBUG_INTERFACE_HOLD [2/2]
◆ USBPHY_DEBUG_TOG_ENHSTPULLDOWN [1/2]
#define USBPHY_DEBUG_TOG_ENHSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENHSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_TOG_ENHSTPULLDOWN_MASK)
◆ USBPHY_DEBUG_TOG_ENHSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_TOG_ENSQUELCHRESET [1/2]
#define USBPHY_DEBUG_TOG_ENSQUELCHRESET (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENSQUELCHRESET_SHIFT)) & USBPHY_DEBUG_TOG_ENSQUELCHRESET_MASK)
◆ USBPHY_DEBUG_TOG_ENSQUELCHRESET [2/2]
◆ USBPHY_DEBUG_TOG_ENTX2RXCOUNT [1/2]
#define USBPHY_DEBUG_TOG_ENTX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_ENTX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_ENTX2RXCOUNT_MASK)
◆ USBPHY_DEBUG_TOG_ENTX2RXCOUNT [2/2]
◆ USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG [1/2]
#define USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_SHIFT)) & USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG_MASK)
◆ USBPHY_DEBUG_TOG_HOST_RESUME_DEBUG [2/2]
◆ USBPHY_DEBUG_TOG_HSTPULLDOWN [1/2]
#define USBPHY_DEBUG_TOG_HSTPULLDOWN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_HSTPULLDOWN_SHIFT)) & USBPHY_DEBUG_TOG_HSTPULLDOWN_MASK)
◆ USBPHY_DEBUG_TOG_HSTPULLDOWN [2/2]
◆ USBPHY_DEBUG_TOG_OTGIDPIOLOCK [1/2]
#define USBPHY_DEBUG_TOG_OTGIDPIOLOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_OTGIDPIOLOCK_SHIFT)) & USBPHY_DEBUG_TOG_OTGIDPIOLOCK_MASK)
◆ USBPHY_DEBUG_TOG_OTGIDPIOLOCK [2/2]
◆ USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT [1/2]
#define USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT_MASK)
◆ USBPHY_DEBUG_TOG_SQUELCHRESETCOUNT [2/2]
◆ USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH [1/2]
#define USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_SHIFT)) & USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH_MASK)
◆ USBPHY_DEBUG_TOG_SQUELCHRESETLENGTH [2/2]
◆ USBPHY_DEBUG_TOG_TX2RXCOUNT [1/2]
#define USBPHY_DEBUG_TOG_TX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TOG_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TOG_TX2RXCOUNT_MASK)
◆ USBPHY_DEBUG_TOG_TX2RXCOUNT [2/2]
◆ USBPHY_DEBUG_TX2RXCOUNT [1/2]
#define USBPHY_DEBUG_TX2RXCOUNT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_DEBUG_TX2RXCOUNT_SHIFT)) & USBPHY_DEBUG_TX2RXCOUNT_MASK)
◆ USBPHY_DEBUG_TX2RXCOUNT [2/2]
◆ USBPHY_PLL_SIC_CLR_PLL_BYPASS [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_BYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_BYPASS_MASK)
PLL_BYPASS - PLL_BYPASS
◆ USBPHY_PLL_SIC_CLR_PLL_BYPASS [2/2]
◆ USBPHY_PLL_SIC_CLR_PLL_DIV_SEL [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_DIV_SEL_MASK)
PLL_DIV_SEL - PLL_DIV_SEL
◆ USBPHY_PLL_SIC_CLR_PLL_DIV_SEL [2/2]
◆ USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS_MASK)
PLL_EN_USB_CLKS - PLL_EN_USB_CLKS
◆ USBPHY_PLL_SIC_CLR_PLL_EN_USB_CLKS [2/2]
◆ USBPHY_PLL_SIC_CLR_PLL_ENABLE [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_ENABLE_MASK)
PLL_ENABLE - PLL_ENABLE
◆ USBPHY_PLL_SIC_CLR_PLL_ENABLE [2/2]
◆ USBPHY_PLL_SIC_CLR_PLL_LOCK [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_LOCK_MASK)
PLL_LOCK - PLL_LOCK
◆ USBPHY_PLL_SIC_CLR_PLL_LOCK [2/2]
PLL_LOCK - PLL_LOCK
◆ USBPHY_PLL_SIC_CLR_PLL_POSTDIV [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_POSTDIV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_POSTDIV_MASK)
PLL_POSTDIV - PLL_POSTDIV
◆ USBPHY_PLL_SIC_CLR_PLL_POSTDIV [2/2]
◆ USBPHY_PLL_SIC_CLR_PLL_POWER [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_POWER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_POWER_MASK)
PLL_POWER - PLL_POWER
◆ USBPHY_PLL_SIC_CLR_PLL_POWER [2/2]
◆ USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE [1/2]
#define USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE_MASK)
PLL_REG_ENABLE - PLL_REG_ENABLE
◆ USBPHY_PLL_SIC_CLR_PLL_REG_ENABLE [2/2]
◆ USBPHY_PLL_SIC_CLR_REFBIAS_PWD [1/2]
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_CLR_REFBIAS_PWD_MASK)
REFBIAS_PWD - Power down the reference bias
◆ USBPHY_PLL_SIC_CLR_REFBIAS_PWD [2/2]
◆ USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL [1/2]
#define USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL_MASK)
REFBIAS_PWD_SEL - REFBIAS_PWD_SEL
◆ USBPHY_PLL_SIC_CLR_REFBIAS_PWD_SEL [2/2]
◆ USBPHY_PLL_SIC_PLL_BYPASS [1/2]
#define USBPHY_PLL_SIC_PLL_BYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_PLL_BYPASS_MASK)
◆ USBPHY_PLL_SIC_PLL_BYPASS [2/2]
◆ USBPHY_PLL_SIC_PLL_DIV_SEL [1/2]
#define USBPHY_PLL_SIC_PLL_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_PLL_DIV_SEL_MASK)
PLL_DIV_SEL - PLL_DIV_SEL 0b000..Divide by 13 0b001..Divide by 15 0b010..Divide by 16 0b011..Divide by 20 0b100..Divide by 22 0b101..Divide by 25 0b110..Divide by 30 0b111..Divide by 240
◆ USBPHY_PLL_SIC_PLL_DIV_SEL [2/2]
◆ USBPHY_PLL_SIC_PLL_EN_USB_CLKS [1/2]
#define USBPHY_PLL_SIC_PLL_EN_USB_CLKS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_PLL_EN_USB_CLKS_MASK)
◆ USBPHY_PLL_SIC_PLL_EN_USB_CLKS [2/2]
◆ USBPHY_PLL_SIC_PLL_ENABLE [1/2]
#define USBPHY_PLL_SIC_PLL_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_PLL_ENABLE_MASK)
◆ USBPHY_PLL_SIC_PLL_ENABLE [2/2]
◆ USBPHY_PLL_SIC_PLL_LOCK [1/2]
#define USBPHY_PLL_SIC_PLL_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_PLL_LOCK_MASK)
PLL_LOCK - PLL_LOCK 0b0..PLL is not currently locked 0b1..PLL is currently locked
◆ USBPHY_PLL_SIC_PLL_LOCK [2/2]
◆ USBPHY_PLL_SIC_PLL_POSTDIV [1/2]
#define USBPHY_PLL_SIC_PLL_POSTDIV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_PLL_POSTDIV_MASK)
◆ USBPHY_PLL_SIC_PLL_POSTDIV [2/2]
◆ USBPHY_PLL_SIC_PLL_POWER [1/2]
#define USBPHY_PLL_SIC_PLL_POWER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_PLL_POWER_MASK)
◆ USBPHY_PLL_SIC_PLL_POWER [2/2]
◆ USBPHY_PLL_SIC_PLL_REG_ENABLE [1/2]
#define USBPHY_PLL_SIC_PLL_REG_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_PLL_REG_ENABLE_MASK)
◆ USBPHY_PLL_SIC_PLL_REG_ENABLE [2/2]
◆ USBPHY_PLL_SIC_REFBIAS_PWD [1/2]
#define USBPHY_PLL_SIC_REFBIAS_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_REFBIAS_PWD_MASK)
◆ USBPHY_PLL_SIC_REFBIAS_PWD [2/2]
◆ USBPHY_PLL_SIC_REFBIAS_PWD_SEL [1/2]
#define USBPHY_PLL_SIC_REFBIAS_PWD_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_REFBIAS_PWD_SEL_MASK)
REFBIAS_PWD_SEL - REFBIAS_PWD_SEL 0b0..Selects PLL_POWER to control the reference bias 0b1..Selects REFBIAS_PWD to control the reference bias.
◆ USBPHY_PLL_SIC_REFBIAS_PWD_SEL [2/2]
◆ USBPHY_PLL_SIC_SET_PLL_BYPASS [1/2]
#define USBPHY_PLL_SIC_SET_PLL_BYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_BYPASS_MASK)
◆ USBPHY_PLL_SIC_SET_PLL_BYPASS [2/2]
◆ USBPHY_PLL_SIC_SET_PLL_DIV_SEL [1/2]
#define USBPHY_PLL_SIC_SET_PLL_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_DIV_SEL_MASK)
◆ USBPHY_PLL_SIC_SET_PLL_DIV_SEL [2/2]
◆ USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS [1/2]
#define USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS_MASK)
◆ USBPHY_PLL_SIC_SET_PLL_EN_USB_CLKS [2/2]
◆ USBPHY_PLL_SIC_SET_PLL_ENABLE [1/2]
#define USBPHY_PLL_SIC_SET_PLL_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_ENABLE_MASK)
◆ USBPHY_PLL_SIC_SET_PLL_ENABLE [2/2]
◆ USBPHY_PLL_SIC_SET_PLL_LOCK [1/2]
#define USBPHY_PLL_SIC_SET_PLL_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_LOCK_MASK)
PLL_LOCK - PLL_LOCK
◆ USBPHY_PLL_SIC_SET_PLL_LOCK [2/2]
PLL_LOCK - PLL_LOCK
◆ USBPHY_PLL_SIC_SET_PLL_POSTDIV [1/2]
#define USBPHY_PLL_SIC_SET_PLL_POSTDIV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_POSTDIV_MASK)
◆ USBPHY_PLL_SIC_SET_PLL_POSTDIV [2/2]
◆ USBPHY_PLL_SIC_SET_PLL_POWER [1/2]
#define USBPHY_PLL_SIC_SET_PLL_POWER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_POWER_MASK)
◆ USBPHY_PLL_SIC_SET_PLL_POWER [2/2]
◆ USBPHY_PLL_SIC_SET_PLL_REG_ENABLE [1/2]
#define USBPHY_PLL_SIC_SET_PLL_REG_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_SET_PLL_REG_ENABLE_MASK)
◆ USBPHY_PLL_SIC_SET_PLL_REG_ENABLE [2/2]
◆ USBPHY_PLL_SIC_SET_REFBIAS_PWD [1/2]
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_SET_REFBIAS_PWD_MASK)
◆ USBPHY_PLL_SIC_SET_REFBIAS_PWD [2/2]
◆ USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL [1/2]
#define USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL_MASK)
◆ USBPHY_PLL_SIC_SET_REFBIAS_PWD_SEL [2/2]
◆ USBPHY_PLL_SIC_TOG_PLL_BYPASS [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_BYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_BYPASS_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_BYPASS_MASK)
◆ USBPHY_PLL_SIC_TOG_PLL_BYPASS [2/2]
◆ USBPHY_PLL_SIC_TOG_PLL_DIV_SEL [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_DIV_SEL_MASK)
◆ USBPHY_PLL_SIC_TOG_PLL_DIV_SEL [2/2]
◆ USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS_MASK)
◆ USBPHY_PLL_SIC_TOG_PLL_EN_USB_CLKS [2/2]
◆ USBPHY_PLL_SIC_TOG_PLL_ENABLE [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_ENABLE_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_ENABLE_MASK)
◆ USBPHY_PLL_SIC_TOG_PLL_ENABLE [2/2]
◆ USBPHY_PLL_SIC_TOG_PLL_LOCK [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_LOCK_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_LOCK_MASK)
PLL_LOCK - PLL_LOCK
◆ USBPHY_PLL_SIC_TOG_PLL_LOCK [2/2]
PLL_LOCK - PLL_LOCK
◆ USBPHY_PLL_SIC_TOG_PLL_POSTDIV [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_POSTDIV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_POSTDIV_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_POSTDIV_MASK)
◆ USBPHY_PLL_SIC_TOG_PLL_POSTDIV [2/2]
◆ USBPHY_PLL_SIC_TOG_PLL_POWER [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_POWER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_POWER_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_POWER_MASK)
◆ USBPHY_PLL_SIC_TOG_PLL_POWER [2/2]
◆ USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE [1/2]
#define USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_SHIFT)) & USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE_MASK)
◆ USBPHY_PLL_SIC_TOG_PLL_REG_ENABLE [2/2]
◆ USBPHY_PLL_SIC_TOG_REFBIAS_PWD [1/2]
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SHIFT)) & USBPHY_PLL_SIC_TOG_REFBIAS_PWD_MASK)
◆ USBPHY_PLL_SIC_TOG_REFBIAS_PWD [2/2]
◆ USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL [1/2]
#define USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_SHIFT)) & USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL_MASK)
◆ USBPHY_PLL_SIC_TOG_REFBIAS_PWD_SEL [2/2]
◆ USBPHY_PWD_CLR_RXPWD1PT1 [1/2]
#define USBPHY_PWD_CLR_RXPWD1PT1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWD1PT1_SHIFT)) & USBPHY_PWD_CLR_RXPWD1PT1_MASK)
RXPWD1PT1 - RXPWD1PT1
◆ USBPHY_PWD_CLR_RXPWD1PT1 [2/2]
◆ USBPHY_PWD_CLR_RXPWDDIFF [1/2]
#define USBPHY_PWD_CLR_RXPWDDIFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDDIFF_SHIFT)) & USBPHY_PWD_CLR_RXPWDDIFF_MASK)
RXPWDDIFF - RXPWDDIFF
◆ USBPHY_PWD_CLR_RXPWDDIFF [2/2]
◆ USBPHY_PWD_CLR_RXPWDENV [1/2]
#define USBPHY_PWD_CLR_RXPWDENV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDENV_SHIFT)) & USBPHY_PWD_CLR_RXPWDENV_MASK)
RXPWDENV - RXPWDENV
◆ USBPHY_PWD_CLR_RXPWDENV [2/2]
RXPWDENV - RXPWDENV
◆ USBPHY_PWD_CLR_RXPWDRX [1/2]
#define USBPHY_PWD_CLR_RXPWDRX (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_RXPWDRX_SHIFT)) & USBPHY_PWD_CLR_RXPWDRX_MASK)
RXPWDRX - RXPWDRX
◆ USBPHY_PWD_CLR_RXPWDRX [2/2]
RXPWDRX - RXPWDRX
◆ USBPHY_PWD_CLR_TXPWDFS [1/2]
#define USBPHY_PWD_CLR_TXPWDFS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDFS_SHIFT)) & USBPHY_PWD_CLR_TXPWDFS_MASK)
TXPWDFS - TXPWDFS
◆ USBPHY_PWD_CLR_TXPWDFS [2/2]
TXPWDFS - TXPWDFS
◆ USBPHY_PWD_CLR_TXPWDIBIAS [1/2]
#define USBPHY_PWD_CLR_TXPWDIBIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_CLR_TXPWDIBIAS_MASK)
TXPWDIBIAS - TXPWDIBIAS
◆ USBPHY_PWD_CLR_TXPWDIBIAS [2/2]
◆ USBPHY_PWD_CLR_TXPWDV2I [1/2]
#define USBPHY_PWD_CLR_TXPWDV2I (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_CLR_TXPWDV2I_SHIFT)) & USBPHY_PWD_CLR_TXPWDV2I_MASK)
TXPWDV2I - TXPWDV2I
◆ USBPHY_PWD_CLR_TXPWDV2I [2/2]
TXPWDV2I - TXPWDV2I
◆ USBPHY_PWD_RXPWD1PT1 [1/2]
#define USBPHY_PWD_RXPWD1PT1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWD1PT1_SHIFT)) & USBPHY_PWD_RXPWD1PT1_MASK)
RXPWD1PT1 - RXPWD1PT1 0b0..Normal operation 0b1..Power-down the USB full-speed differential receiver.
◆ USBPHY_PWD_RXPWD1PT1 [2/2]
◆ USBPHY_PWD_RXPWDDIFF [1/2]
#define USBPHY_PWD_RXPWDDIFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDDIFF_SHIFT)) & USBPHY_PWD_RXPWDDIFF_MASK)
RXPWDDIFF - RXPWDDIFF 0b0..Normal operation. 0b1..Power-down the USB high-speed differential receiver
◆ USBPHY_PWD_RXPWDDIFF [2/2]
◆ USBPHY_PWD_RXPWDENV [1/2]
#define USBPHY_PWD_RXPWDENV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDENV_SHIFT)) & USBPHY_PWD_RXPWDENV_MASK)
RXPWDENV - RXPWDENV 0b0..Normal operation. 0b1..Power-down the USB high-speed receiver envelope detector (squelch signal)
◆ USBPHY_PWD_RXPWDENV [2/2]
◆ USBPHY_PWD_RXPWDRX [1/2]
#define USBPHY_PWD_RXPWDRX (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_RXPWDRX_SHIFT)) & USBPHY_PWD_RXPWDRX_MASK)
RXPWDRX - RXPWDRX 0b0..Normal operation 0b1..Power-down the entire USB PHY receiver block except for the full-speed differential receiver
◆ USBPHY_PWD_RXPWDRX [2/2]
◆ USBPHY_PWD_SET_RXPWD1PT1 [1/2]
#define USBPHY_PWD_SET_RXPWD1PT1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWD1PT1_SHIFT)) & USBPHY_PWD_SET_RXPWD1PT1_MASK)
◆ USBPHY_PWD_SET_RXPWD1PT1 [2/2]
◆ USBPHY_PWD_SET_RXPWDDIFF [1/2]
#define USBPHY_PWD_SET_RXPWDDIFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDDIFF_SHIFT)) & USBPHY_PWD_SET_RXPWDDIFF_MASK)
◆ USBPHY_PWD_SET_RXPWDDIFF [2/2]
◆ USBPHY_PWD_SET_RXPWDENV [1/2]
#define USBPHY_PWD_SET_RXPWDENV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDENV_SHIFT)) & USBPHY_PWD_SET_RXPWDENV_MASK)
RXPWDENV - RXPWDENV
◆ USBPHY_PWD_SET_RXPWDENV [2/2]
RXPWDENV - RXPWDENV
◆ USBPHY_PWD_SET_RXPWDRX [1/2]
#define USBPHY_PWD_SET_RXPWDRX (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_RXPWDRX_SHIFT)) & USBPHY_PWD_SET_RXPWDRX_MASK)
RXPWDRX - RXPWDRX
◆ USBPHY_PWD_SET_RXPWDRX [2/2]
RXPWDRX - RXPWDRX
◆ USBPHY_PWD_SET_TXPWDFS [1/2]
#define USBPHY_PWD_SET_TXPWDFS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDFS_SHIFT)) & USBPHY_PWD_SET_TXPWDFS_MASK)
TXPWDFS - TXPWDFS
◆ USBPHY_PWD_SET_TXPWDFS [2/2]
TXPWDFS - TXPWDFS
◆ USBPHY_PWD_SET_TXPWDIBIAS [1/2]
#define USBPHY_PWD_SET_TXPWDIBIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_SET_TXPWDIBIAS_MASK)
◆ USBPHY_PWD_SET_TXPWDIBIAS [2/2]
◆ USBPHY_PWD_SET_TXPWDV2I [1/2]
#define USBPHY_PWD_SET_TXPWDV2I (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_SET_TXPWDV2I_SHIFT)) & USBPHY_PWD_SET_TXPWDV2I_MASK)
TXPWDV2I - TXPWDV2I
◆ USBPHY_PWD_SET_TXPWDV2I [2/2]
TXPWDV2I - TXPWDV2I
◆ USBPHY_PWD_TOG_RXPWD1PT1 [1/2]
#define USBPHY_PWD_TOG_RXPWD1PT1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWD1PT1_SHIFT)) & USBPHY_PWD_TOG_RXPWD1PT1_MASK)
◆ USBPHY_PWD_TOG_RXPWD1PT1 [2/2]
◆ USBPHY_PWD_TOG_RXPWDDIFF [1/2]
#define USBPHY_PWD_TOG_RXPWDDIFF (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDDIFF_SHIFT)) & USBPHY_PWD_TOG_RXPWDDIFF_MASK)
◆ USBPHY_PWD_TOG_RXPWDDIFF [2/2]
◆ USBPHY_PWD_TOG_RXPWDENV [1/2]
#define USBPHY_PWD_TOG_RXPWDENV (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDENV_SHIFT)) & USBPHY_PWD_TOG_RXPWDENV_MASK)
RXPWDENV - RXPWDENV
◆ USBPHY_PWD_TOG_RXPWDENV [2/2]
RXPWDENV - RXPWDENV
◆ USBPHY_PWD_TOG_RXPWDRX [1/2]
#define USBPHY_PWD_TOG_RXPWDRX (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_RXPWDRX_SHIFT)) & USBPHY_PWD_TOG_RXPWDRX_MASK)
RXPWDRX - RXPWDRX
◆ USBPHY_PWD_TOG_RXPWDRX [2/2]
RXPWDRX - RXPWDRX
◆ USBPHY_PWD_TOG_TXPWDFS [1/2]
#define USBPHY_PWD_TOG_TXPWDFS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDFS_SHIFT)) & USBPHY_PWD_TOG_TXPWDFS_MASK)
TXPWDFS - TXPWDFS
◆ USBPHY_PWD_TOG_TXPWDFS [2/2]
TXPWDFS - TXPWDFS
◆ USBPHY_PWD_TOG_TXPWDIBIAS [1/2]
#define USBPHY_PWD_TOG_TXPWDIBIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TOG_TXPWDIBIAS_MASK)
◆ USBPHY_PWD_TOG_TXPWDIBIAS [2/2]
◆ USBPHY_PWD_TOG_TXPWDV2I [1/2]
#define USBPHY_PWD_TOG_TXPWDV2I (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TOG_TXPWDV2I_SHIFT)) & USBPHY_PWD_TOG_TXPWDV2I_MASK)
TXPWDV2I - TXPWDV2I
◆ USBPHY_PWD_TOG_TXPWDV2I [2/2]
TXPWDV2I - TXPWDV2I
◆ USBPHY_PWD_TXPWDFS [1/2]
#define USBPHY_PWD_TXPWDFS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDFS_SHIFT)) & USBPHY_PWD_TXPWDFS_MASK)
TXPWDFS - TXPWDFS 0b0..Normal operation. 0b1..Power-down the USB full-speed drivers. This turns off the current starvation sources and puts the drivers into high-impedance output
◆ USBPHY_PWD_TXPWDFS [2/2]
◆ USBPHY_PWD_TXPWDIBIAS [1/2]
#define USBPHY_PWD_TXPWDIBIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDIBIAS_SHIFT)) & USBPHY_PWD_TXPWDIBIAS_MASK)
TXPWDIBIAS - TXPWDIBIAS 0b0..Normal operation 0b1..Power-down the USB PHY current bias block for the transmitter. This bit should be set only when the USB is in suspend mode. This effectively powers down the entire USB transmit path
◆ USBPHY_PWD_TXPWDIBIAS [2/2]
◆ USBPHY_PWD_TXPWDV2I [1/2]
#define USBPHY_PWD_TXPWDV2I (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_PWD_TXPWDV2I_SHIFT)) & USBPHY_PWD_TXPWDV2I_MASK)
TXPWDV2I - TXPWDV2I 0b0..Normal operation. 0b1..Power-down the USB PHY transmit V-to-I converter and the current mirror
◆ USBPHY_PWD_TXPWDV2I [2/2]
◆ USBPHY_RX_CLR_DISCONADJ [1/2]
#define USBPHY_RX_CLR_DISCONADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_DISCONADJ_SHIFT)) & USBPHY_RX_CLR_DISCONADJ_MASK)
DISCONADJ - DISCONADJ
◆ USBPHY_RX_CLR_DISCONADJ [2/2]
◆ USBPHY_RX_CLR_ENVADJ [1/2]
#define USBPHY_RX_CLR_ENVADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_ENVADJ_SHIFT)) & USBPHY_RX_CLR_ENVADJ_MASK)
ENVADJ - ENVADJ
◆ USBPHY_RX_CLR_ENVADJ [2/2]
ENVADJ - ENVADJ
◆ USBPHY_RX_CLR_RXDBYPASS [1/2]
#define USBPHY_RX_CLR_RXDBYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_CLR_RXDBYPASS_SHIFT)) & USBPHY_RX_CLR_RXDBYPASS_MASK)
RXDBYPASS - RXDBYPASS
◆ USBPHY_RX_CLR_RXDBYPASS [2/2]
◆ USBPHY_RX_DISCONADJ [1/2]
#define USBPHY_RX_DISCONADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_DISCONADJ_SHIFT)) & USBPHY_RX_DISCONADJ_MASK)
DISCONADJ - DISCONADJ 0b000..Trip-Level Voltage is 0.56875 V 0b001..Trip-Level Voltage is 0.55000 V 0b010..Trip-Level Voltage is 0.58125 V 0b011..Trip-Level Voltage is 0.60000 V 0b1xx..Reserved
◆ USBPHY_RX_DISCONADJ [2/2]
◆ USBPHY_RX_ENVADJ [1/2]
#define USBPHY_RX_ENVADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_ENVADJ_SHIFT)) & USBPHY_RX_ENVADJ_MASK)
ENVADJ - ENVADJ 0b000..Trip-Level Voltage is 0.1000 V 0b001..Trip-Level Voltage is 0.1125 V 0b010..Trip-Level Voltage is 0.1250 V 0b011..Trip-Level Voltage is 0.0875 V 0b1xx..Reserved
◆ USBPHY_RX_ENVADJ [2/2]
◆ USBPHY_RX_RXDBYPASS [1/2]
#define USBPHY_RX_RXDBYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_RXDBYPASS_SHIFT)) & USBPHY_RX_RXDBYPASS_MASK)
RXDBYPASS - RXDBYPASS 0b0..Normal operation. 0b1..Use the output of the USB_DP single-ended receiver in place of the full-speed differential receiver
◆ USBPHY_RX_RXDBYPASS [2/2]
◆ USBPHY_RX_SET_DISCONADJ [1/2]
#define USBPHY_RX_SET_DISCONADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_DISCONADJ_SHIFT)) & USBPHY_RX_SET_DISCONADJ_MASK)
◆ USBPHY_RX_SET_DISCONADJ [2/2]
◆ USBPHY_RX_SET_ENVADJ [1/2]
#define USBPHY_RX_SET_ENVADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_ENVADJ_SHIFT)) & USBPHY_RX_SET_ENVADJ_MASK)
ENVADJ - ENVADJ
◆ USBPHY_RX_SET_ENVADJ [2/2]
ENVADJ - ENVADJ
◆ USBPHY_RX_SET_RXDBYPASS [1/2]
#define USBPHY_RX_SET_RXDBYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_SET_RXDBYPASS_SHIFT)) & USBPHY_RX_SET_RXDBYPASS_MASK)
◆ USBPHY_RX_SET_RXDBYPASS [2/2]
◆ USBPHY_RX_TOG_DISCONADJ [1/2]
#define USBPHY_RX_TOG_DISCONADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_DISCONADJ_SHIFT)) & USBPHY_RX_TOG_DISCONADJ_MASK)
◆ USBPHY_RX_TOG_DISCONADJ [2/2]
◆ USBPHY_RX_TOG_ENVADJ [1/2]
#define USBPHY_RX_TOG_ENVADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_ENVADJ_SHIFT)) & USBPHY_RX_TOG_ENVADJ_MASK)
ENVADJ - ENVADJ
◆ USBPHY_RX_TOG_ENVADJ [2/2]
ENVADJ - ENVADJ
◆ USBPHY_RX_TOG_RXDBYPASS [1/2]
#define USBPHY_RX_TOG_RXDBYPASS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_RX_TOG_RXDBYPASS_SHIFT)) & USBPHY_RX_TOG_RXDBYPASS_MASK)
◆ USBPHY_RX_TOG_RXDBYPASS [2/2]
◆ USBPHY_STATUS_DEVPLUGIN_STATUS [1/2]
#define USBPHY_STATUS_DEVPLUGIN_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_DEVPLUGIN_STATUS_SHIFT)) & USBPHY_STATUS_DEVPLUGIN_STATUS_MASK)
DEVPLUGIN_STATUS - Status indicator for non-standard resistive plugged-in detection 0b0..No attachment to a USB host is detected 0b1..Cable attachment to a USB host is detected
◆ USBPHY_STATUS_DEVPLUGIN_STATUS [2/2]
◆ USBPHY_STATUS_HOSTDISCONDETECT_STATUS [1/2]
#define USBPHY_STATUS_HOSTDISCONDETECT_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_HOSTDISCONDETECT_STATUS_SHIFT)) & USBPHY_STATUS_HOSTDISCONDETECT_STATUS_MASK)
HOSTDISCONDETECT_STATUS - HOSTDISCONDETECT_STATUS 0b0..USB cable disconnect has not been detected at the local host 0b1..USB cable disconnect has been detected at the local host
◆ USBPHY_STATUS_HOSTDISCONDETECT_STATUS [2/2]
◆ USBPHY_STATUS_OTGID_STATUS [1/2]
#define USBPHY_STATUS_OTGID_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_OTGID_STATUS_SHIFT)) & USBPHY_STATUS_OTGID_STATUS_MASK)
OTGID_STATUS - OTGID_STATUS
◆ USBPHY_STATUS_OTGID_STATUS [2/2]
◆ USBPHY_STATUS_RESUME_STATUS [1/2]
#define USBPHY_STATUS_RESUME_STATUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_STATUS_RESUME_STATUS_SHIFT)) & USBPHY_STATUS_RESUME_STATUS_MASK)
RESUME_STATUS - RESUME_STATUS
◆ USBPHY_STATUS_RESUME_STATUS [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE_MASK)
TRIM_DIV_SEL_OVERRIDE - TRIM_DIV_SEL_OVERRIDE
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_DIV_SEL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
TRIM_ENV_TAIL_ADJ_VD_OVERRIDE - TRIM_ENV_TAIL_ADJ_VD_OVERRIDE
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL_MASK)
TRIM_PLL_CTRL0_DIV_SEL - TRIM_PLL_CTRL0_DIV_SEL
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_PLL_CTRL0_DIV_SEL [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE_MASK)
TRIM_REFBIAS_TST_OVERRIDE - Override enable for bias current control
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_TST_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
TRIM_REFBIAS_VBGADJ_OVERRIDE - Override enable for bandgap adjustment.
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_REFBIAS_VBGADJ_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE_MASK)
TRIM_TX_CAL45DN_OVERRIDE - TRIM_TX_CAL45DN_OVERRIDE
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DN_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE_MASK)
TRIM_TX_CAL45DP_OVERRIDE - TRIM_TX_CAL45DP_OVERRIDE
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_CAL45DP_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE_MASK)
TRIM_TX_D_CAL_OVERRIDE - TRIM_TX_D_CAL_OVERRIDE
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_TX_D_CAL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST_MASK)
TRIM_USB2_REFBIAS_TST - TRIM_USB2_REFBIAS_TST
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_TST [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ_MASK)
TRIM_USB2_REFBIAS_VBGADJ - TRIM_USB2_REFBIAS_VBGADJ
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
TRIM_USB_REG_ENV_TAIL_ADJ_VD - TRIM_USB_REG_ENV_TAIL_ADJ_VD
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USB_REG_ENV_TAIL_ADJ_VD [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN_MASK)
TRIM_USBPHY_TX_CAL45DN - TRIM_USBPHY_TX_CAL45DN
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DN [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP_MASK)
TRIM_USBPHY_TX_CAL45DP - TRIM_USBPHY_TX_CAL45DP
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_CAL45DP [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL_MASK)
TRIM_USBPHY_TX_D_CAL - TRIM_USBPHY_TX_D_CAL
◆ USBPHY_TRIM_OVERRIDE_EN_CLR_TRIM_USBPHY_TX_D_CAL [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_DIV_SEL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_PLL_CTRL0_DIV_SEL [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_TST_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_REFBIAS_VBGADJ_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DN_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_CAL45DP_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_TX_D_CAL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_TST [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USB_REG_ENV_TAIL_ADJ_VD [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DN [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_CAL45DP [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_SET_TRIM_USBPHY_TX_D_CAL [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_DIV_SEL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_PLL_CTRL0_DIV_SEL [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_TST_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_REFBIAS_VBGADJ_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DN_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_CAL45DP_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_TX_D_CAL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_TST [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USB_REG_ENV_TAIL_ADJ_VD [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DN [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_CAL45DP [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TOG_TRIM_USBPHY_TX_D_CAL [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_DIV_SEL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_ENV_TAIL_ADJ_VD_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_PLL_CTRL0_DIV_SEL [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_TST_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_REFBIAS_VBGADJ_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DN_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_CAL45DP_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_TX_D_CAL_OVERRIDE [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_TST [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USB2_REFBIAS_VBGADJ [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USB_REG_ENV_TAIL_ADJ_VD [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DN [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_CAL45DP [2/2]
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL [1/2]
#define USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL_MASK)
◆ USBPHY_TRIM_OVERRIDE_EN_TRIM_USBPHY_TX_D_CAL [2/2]
◆ USBPHY_TX_CLR_D_CAL [1/2]
#define USBPHY_TX_CLR_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_D_CAL_SHIFT)) & USBPHY_TX_CLR_D_CAL_MASK)
D_CAL - D_CAL
◆ USBPHY_TX_CLR_D_CAL [2/2]
D_CAL - D_CAL
◆ USBPHY_TX_CLR_TXCAL45DN [1/2]
#define USBPHY_TX_CLR_TXCAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DN_SHIFT)) & USBPHY_TX_CLR_TXCAL45DN_MASK)
TXCAL45DN - TXCAL45DN
◆ USBPHY_TX_CLR_TXCAL45DN [2/2]
◆ USBPHY_TX_CLR_TXCAL45DP [1/2]
#define USBPHY_TX_CLR_TXCAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_CLR_TXCAL45DP_SHIFT)) & USBPHY_TX_CLR_TXCAL45DP_MASK)
TXCAL45DP - TXCAL45DP
◆ USBPHY_TX_CLR_TXCAL45DP [2/2]
◆ USBPHY_TX_D_CAL [1/2]
#define USBPHY_TX_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_D_CAL_SHIFT)) & USBPHY_TX_D_CAL_MASK)
D_CAL - D_CAL 0b0000..Maximum current, approximately 19% above nominal. 0b0111..Nominal 0b1111..Minimum current, approximately 19% below nominal.
◆ USBPHY_TX_D_CAL [2/2]
◆ USBPHY_TX_SET_D_CAL [1/2]
#define USBPHY_TX_SET_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_D_CAL_SHIFT)) & USBPHY_TX_SET_D_CAL_MASK)
D_CAL - D_CAL
◆ USBPHY_TX_SET_D_CAL [2/2]
D_CAL - D_CAL
◆ USBPHY_TX_SET_TXCAL45DN [1/2]
#define USBPHY_TX_SET_TXCAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DN_SHIFT)) & USBPHY_TX_SET_TXCAL45DN_MASK)
◆ USBPHY_TX_SET_TXCAL45DN [2/2]
◆ USBPHY_TX_SET_TXCAL45DP [1/2]
#define USBPHY_TX_SET_TXCAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_SET_TXCAL45DP_SHIFT)) & USBPHY_TX_SET_TXCAL45DP_MASK)
◆ USBPHY_TX_SET_TXCAL45DP [2/2]
◆ USBPHY_TX_TOG_D_CAL [1/2]
#define USBPHY_TX_TOG_D_CAL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_D_CAL_SHIFT)) & USBPHY_TX_TOG_D_CAL_MASK)
D_CAL - D_CAL
◆ USBPHY_TX_TOG_D_CAL [2/2]
D_CAL - D_CAL
◆ USBPHY_TX_TOG_TXCAL45DN [1/2]
#define USBPHY_TX_TOG_TXCAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DN_SHIFT)) & USBPHY_TX_TOG_TXCAL45DN_MASK)
◆ USBPHY_TX_TOG_TXCAL45DN [2/2]
◆ USBPHY_TX_TOG_TXCAL45DP [1/2]
#define USBPHY_TX_TOG_TXCAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TOG_TXCAL45DP_SHIFT)) & USBPHY_TX_TOG_TXCAL45DP_MASK)
◆ USBPHY_TX_TOG_TXCAL45DP [2/2]
◆ USBPHY_TX_TXCAL45DN [1/2]
#define USBPHY_TX_TXCAL45DN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DN_SHIFT)) & USBPHY_TX_TXCAL45DN_MASK)
◆ USBPHY_TX_TXCAL45DN [2/2]
◆ USBPHY_TX_TXCAL45DP [1/2]
#define USBPHY_TX_TXCAL45DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_TX_TXCAL45DP_SHIFT)) & USBPHY_TX_TXCAL45DP_MASK)
◆ USBPHY_TX_TXCAL45DP [2/2]
◆ USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED [1/2]
#define USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED_MASK)
CHRG_DETECTED - Battery Charging Primary Detection phase output 0b0..Standard Downstream Port (SDP) has been detected 0b1..Charging Port has been detected
◆ USBPHY_USB1_CHRG_DET_STAT_CHRG_DETECTED [2/2]
◆ USBPHY_USB1_CHRG_DET_STAT_DN_STATE [1/2]
#define USBPHY_USB1_CHRG_DET_STAT_DN_STATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_DN_STATE_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_DN_STATE_MASK)
DN_STATE - DN_STATE 0b0..DN pin voltage is < 0.8V 0b1..DN pin voltage is > 2.0V
◆ USBPHY_USB1_CHRG_DET_STAT_DN_STATE [2/2]
◆ USBPHY_USB1_CHRG_DET_STAT_DP_STATE [1/2]
#define USBPHY_USB1_CHRG_DET_STAT_DP_STATE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_DP_STATE_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_DP_STATE_MASK)
DP_STATE - DP_STATE 0b0..DP pin voltage is < 0.8V 0b1..DP pin voltage is > 2.0V
◆ USBPHY_USB1_CHRG_DET_STAT_DP_STATE [2/2]
◆ USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT [1/2]
#define USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT_MASK)
PLUG_CONTACT - Battery Charging Data Contact Detection phase output 0b0..No USB cable attachment has been detected 0b1..A USB cable attachment between the device and host has been detected
◆ USBPHY_USB1_CHRG_DET_STAT_PLUG_CONTACT [2/2]
◆ USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP [1/2]
#define USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_SHIFT)) & USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP_MASK)
SECDET_DCP - Battery Charging Secondary Detection phase output 0b0..Charging Downstream Port (CDP) has been detected 0b1..Downstream Charging Port (DCP) has been detected
◆ USBPHY_USB1_CHRG_DET_STAT_SECDET_DCP [2/2]
◆ USBPHY_USB1_CHRG_DETECT_BGR_BIAS [1/2]
#define USBPHY_USB1_CHRG_DETECT_BGR_BIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_BGR_BIAS_MASK)
BGR_BIAS - BGR_BIAS 0b0..Use local bias powered from USB1_VBUS for 10uA reference (Default) 0b1..Use bandgap bias powered from VREGIN0/VREGIN1 for 10uA reference
◆ USBPHY_USB1_CHRG_DETECT_BGR_BIAS [2/2]
◆ USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS [1/2]
#define USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS_MASK)
BGR_BIAS - BGR_BIAS
◆ USBPHY_USB1_CHRG_DETECT_CLR_BGR_BIAS [2/2]
BGR_BIAS - BGR_BIAS
◆ USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP [1/2]
#define USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP_MASK)
PULLUP_DP - PULLUP_DP
◆ USBPHY_USB1_CHRG_DETECT_CLR_PULLUP_DP [2/2]
◆ USBPHY_USB1_CHRG_DETECT_PULLUP_DP [1/2]
#define USBPHY_USB1_CHRG_DETECT_PULLUP_DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_PULLUP_DP_MASK)
◆ USBPHY_USB1_CHRG_DETECT_PULLUP_DP [2/2]
◆ USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS [1/2]
#define USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS_MASK)
BGR_BIAS - BGR_BIAS
◆ USBPHY_USB1_CHRG_DETECT_SET_BGR_BIAS [2/2]
BGR_BIAS - BGR_BIAS
◆ USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP [1/2]
#define USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP_MASK)
◆ USBPHY_USB1_CHRG_DETECT_SET_PULLUP_DP [2/2]
◆ USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS [1/2]
#define USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_SHIFT)) & USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS_MASK)
BGR_BIAS - BGR_BIAS
◆ USBPHY_USB1_CHRG_DETECT_TOG_BGR_BIAS [2/2]
BGR_BIAS - BGR_BIAS
◆ USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP [1/2]
#define USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_SHIFT)) & USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP_MASK)
◆ USBPHY_USB1_CHRG_DETECT_TOG_PULLUP_DP [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN_MASK)
TSTI_HSFS_MODE_EN - TSTI_HSFS_MODE_EN
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_HSFS_MODE_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN_MASK)
TSTI_TX_EN - TSTI_TX_EN
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ_MASK)
TSTI_TX_HIZ - TSTI_TX_HIZ
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HIZ [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE_MASK)
TSTI_TX_HS_MODE - TSTI_TX_HS_MODE
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_HS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE_MASK)
TSTI_TX_LS_MODE - TSTI_TX_LS_MODE
◆ USBPHY_USB1_LOOPBACK_CLR_TSTI_TX_LS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_TSTPKT [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_TSTPKT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_TSTPKT_MASK)
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_CLR_TSTPKT [2/2]
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0_MASK)
UTMI_DIG_TST0 - UTMI_DIG_TST0
◆ USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1_MASK)
UTMI_DIG_TST1 - UTMI_DIG_TST1
◆ USBPHY_USB1_LOOPBACK_CLR_UTMI_DIG_TST1 [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART_MASK)
UTMI_TESTSTART - UTMI_TESTSTART
◆ USBPHY_USB1_LOOPBACK_CLR_UTMI_TESTSTART [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0_MASK)
UTMO_DIG_TST0 - UTMO_DIG_TST0
◆ USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1_MASK)
UTMO_DIG_TST1 - UTMO_DIG_TST1
◆ USBPHY_USB1_LOOPBACK_CLR_UTMO_DIG_TST1 [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER_MASK)
TSTI_FS_NUMBER - TSTI_FS_NUMBER
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_FS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER_MASK)
TSTI_HS_NUMBER - TSTI_HS_NUMBER
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_CLR_TSTI_HS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER_MASK)
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_FS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER_MASK)
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_SET_TSTI_HS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER_MASK)
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_FS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER_MASK)
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TOG_TSTI_HS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER_MASK)
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_FS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER [1/2]
#define USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_SHIFT)) & USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER_MASK)
◆ USBPHY_USB1_LOOPBACK_HSFSCNT_TSTI_HS_NUMBER [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN [1/2]
#define USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_HSFS_MODE_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN [1/2]
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ [1/2]
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HIZ [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_HS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_TSTI_TX_LS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_TSTPKT [1/2]
#define USBPHY_USB1_LOOPBACK_SET_TSTPKT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_TSTPKT_MASK)
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_SET_TSTPKT [2/2]
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_UTMI_DIG_TST1 [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART [1/2]
#define USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_UTMI_TESTSTART [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1_MASK)
◆ USBPHY_USB1_LOOPBACK_SET_UTMO_DIG_TST1 [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_HSFS_MODE_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HIZ [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_HS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_TSTI_TX_LS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_TSTPKT [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_TSTPKT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_TSTPKT_MASK)
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_TOG_TSTPKT [2/2]
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_UTMI_DIG_TST1 [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_UTMI_TESTSTART [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1_MASK)
◆ USBPHY_USB1_LOOPBACK_TOG_UTMO_DIG_TST1 [2/2]
◆ USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN [1/2]
#define USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN_MASK)
◆ USBPHY_USB1_LOOPBACK_TSTI_HSFS_MODE_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_EN [1/2]
#define USBPHY_USB1_LOOPBACK_TSTI_TX_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_EN_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_EN_MASK)
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_EN [2/2]
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ [1/2]
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ_MASK)
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_HIZ [2/2]
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE_MASK)
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_HS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE [1/2]
#define USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE_MASK)
◆ USBPHY_USB1_LOOPBACK_TSTI_TX_LS_MODE [2/2]
◆ USBPHY_USB1_LOOPBACK_TSTPKT [1/2]
#define USBPHY_USB1_LOOPBACK_TSTPKT (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_TSTPKT_SHIFT)) & USBPHY_USB1_LOOPBACK_TSTPKT_MASK)
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_TSTPKT [2/2]
TSTPKT - TSTPKT
◆ USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0_MASK)
◆ USBPHY_USB1_LOOPBACK_UTMI_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1_MASK)
◆ USBPHY_USB1_LOOPBACK_UTMI_DIG_TST1 [2/2]
◆ USBPHY_USB1_LOOPBACK_UTMI_TESTSTART [1/2]
#define USBPHY_USB1_LOOPBACK_UTMI_TESTSTART (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMI_TESTSTART_MASK)
◆ USBPHY_USB1_LOOPBACK_UTMI_TESTSTART [2/2]
◆ USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0 [1/2]
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0_MASK)
◆ USBPHY_USB1_LOOPBACK_UTMO_DIG_TST0 [2/2]
◆ USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1 [1/2]
#define USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1 (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_SHIFT)) & USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1_MASK)
◆ USBPHY_USB1_LOOPBACK_UTMO_DIG_TST1 [2/2]
◆ USBPHY_USB1_VBUS_DET_STAT_AVALID [1/2]
#define USBPHY_USB1_VBUS_DET_STAT_AVALID (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_AVALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_AVALID_MASK)
AVALID - A-Device Session Valid status 0b0..The VBUS voltage is below the Session Valid threshold 0b1..The VBUS voltage is above the Session Valid threshold
◆ USBPHY_USB1_VBUS_DET_STAT_AVALID [2/2]
◆ USBPHY_USB1_VBUS_DET_STAT_BVALID [1/2]
#define USBPHY_USB1_VBUS_DET_STAT_BVALID (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_BVALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_BVALID_MASK)
BVALID - B-Device Session Valid status 0b0..The VBUS voltage is below the Session Valid threshold 0b1..The VBUS voltage is above the Session Valid threshold
◆ USBPHY_USB1_VBUS_DET_STAT_BVALID [2/2]
◆ USBPHY_USB1_VBUS_DET_STAT_SESSEND [1/2]
#define USBPHY_USB1_VBUS_DET_STAT_SESSEND (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_SESSEND_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_SESSEND_MASK)
SESSEND - Session End indicator 0b0..The VBUS voltage is above the Session Valid threshold 0b1..The VBUS voltage is below the Session Valid threshold
◆ USBPHY_USB1_VBUS_DET_STAT_SESSEND [2/2]
◆ USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID [1/2]
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_MASK)
VBUS_VALID - VBUS voltage status 0b0..VBUS is below the comparator threshold 0b1..VBUS is above the comparator threshold
◆ USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID [2/2]
◆ USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V [1/2]
#define USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_SHIFT)) & USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V_MASK)
VBUS_VALID_3V - VBUS_VALID_3V detector status 0b0..VBUS voltage is below VBUS_VALID_3V threshold 0b1..VBUS voltage is above VBUS_VALID_3V threshold
◆ USBPHY_USB1_VBUS_DET_STAT_VBUS_VALID_3V [2/2]
◆ USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE_MASK)
AVALID_OVERRIDE - Override value for A-Device Session Valid
◆ USBPHY_USB1_VBUS_DETECT_AVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE_MASK)
BVALID_OVERRIDE - Override value for B-Device Session Valid
◆ USBPHY_USB1_VBUS_DETECT_BVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_CLR_AVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_CLR_BVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK)
DISCHARGE_VBUS - Controls VBUS discharge resistor
◆ USBPHY_USB1_VBUS_DETECT_CLR_DISCHARGE_VBUS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR_MASK)
EN_CHARGER_RESISTOR - Enables resistors used for an older method of resistive battery charger detection
◆ USBPHY_USB1_VBUS_DETECT_CLR_EN_CHARGER_RESISTOR [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_MASK)
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE [2/2]
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN_MASK)
ID_OVERRIDE_EN - TBA
◆ USBPHY_USB1_VBUS_DETECT_CLR_ID_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS_MASK)
PWRUP_CMPS - Enables the VBUS_VALID comparator
◆ USBPHY_USB1_VBUS_DETECT_CLR_PWRUP_CMPS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE_MASK)
SESSEND_OVERRIDE - Override value for SESSEND
◆ USBPHY_USB1_VBUS_DETECT_CLR_SESSEND_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN_MASK)
VBUS_OVERRIDE_EN - VBUS detect signal override enable
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUS_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL_MASK)
VBUS_SOURCE_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUS_SOURCE_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE_MASK)
VBUSVALID_OVERRIDE - Override value for VBUS_VALID signal sent to USB controller
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL_MASK)
VBUSVALID_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK)
VBUSVALID_THRESH - VBUSVALID_THRESH
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_THRESH [2/2]
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID [1/2]
#define USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID_MASK)
VBUSVALID_TO_SESSVALID - Selects the comparator used for VBUS_VALID
◆ USBPHY_USB1_VBUS_DETECT_CLR_VBUSVALID_TO_SESSVALID [2/2]
◆ USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS [1/2]
#define USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS_MASK)
DISCHARGE_VBUS - Controls VBUS discharge resistor 0b0..VBUS discharge resistor is disabled (Default) 0b1..VBUS discharge resistor is enabled
◆ USBPHY_USB1_VBUS_DETECT_DISCHARGE_VBUS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR [1/2]
#define USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR_MASK)
EN_CHARGER_RESISTOR - Enables resistors used for an older method of resistive battery charger detection 0b0..Disable resistive charger detection resistors on DP and DP 0b1..Enable resistive charger detection resistors on DP and DP
◆ USBPHY_USB1_VBUS_DETECT_EN_CHARGER_RESISTOR [2/2]
◆ USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_MASK)
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE [2/2]
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN_MASK)
◆ USBPHY_USB1_VBUS_DETECT_ID_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS [1/2]
#define USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS_MASK)
PWRUP_CMPS - Enables the VBUS_VALID comparator 0b000..Powers down the VBUS_VALID comparator 0b001..Enables the SESS_VALID comparator (default) 0b010..Enables the 3Vdetect (default)
◆ USBPHY_USB1_VBUS_DETECT_PWRUP_CMPS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SESSEND_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_AVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_BVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_DISCHARGE_VBUS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_EN_CHARGER_RESISTOR [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_MASK)
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE [2/2]
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_ID_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_PWRUP_CMPS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_SESSEND_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUS_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUS_SOURCE_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_THRESH [2/2]
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID [1/2]
#define USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID_MASK)
◆ USBPHY_USB1_VBUS_DETECT_SET_VBUSVALID_TO_SESSVALID [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_AVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_BVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_DISCHARGE_VBUS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_EN_CHARGER_RESISTOR [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_MASK)
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE [2/2]
ID_OVERRIDE - TBA
◆ USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_ID_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_PWRUP_CMPS [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_SESSEND_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUS_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUS_SOURCE_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_THRESH [2/2]
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID [1/2]
#define USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID_MASK)
◆ USBPHY_USB1_VBUS_DETECT_TOG_VBUSVALID_TO_SESSVALID [2/2]
◆ USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN [1/2]
#define USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN_MASK)
VBUS_OVERRIDE_EN - VBUS detect signal override enable 0b0..Use the results of the internal VBUS_VALID and Session Valid comparators for VBUS_VALID, AVALID, BVALID, and SESSEND (Default) 0b1..Use the override values for VBUS_VALID, AVALID, BVALID, and SESSEND
◆ USBPHY_USB1_VBUS_DETECT_VBUS_OVERRIDE_EN [2/2]
◆ USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL_MASK)
VBUS_SOURCE_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller 0b00..Use the VBUS_VALID comparator results for signal reported to the USB controller (Default) 0b01..Use the Session Valid comparator results for signal reported to the USB controller 0b10..Use the Session Valid comparator results for signal reported to the USB controller 0b11..Reserved, do not use
◆ USBPHY_USB1_VBUS_DETECT_VBUS_SOURCE_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE [1/2]
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE_MASK)
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_OVERRIDE [2/2]
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL [1/2]
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL_MASK)
VBUSVALID_SEL - Selects the source of the VBUS_VALID signal reported to the USB controller 0b0..Use the VBUS_VALID comparator results for signal reported to the USB controller (Default) 0b1..Use the VBUS_VALID_3V detector results for signal reported to the USB controller
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_SEL [2/2]
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH [1/2]
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH_MASK)
VBUSVALID_THRESH - VBUSVALID_THRESH 0b000..4.0 V 0b001..4.1 V 0b010..4.2 V 0b011..4.3 V 0b100..4.4 V (Default) 0b101..4.5 V 0b110..4.6 V 0b111..4.7 V
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_THRESH [2/2]
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID [1/2]
#define USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_SHIFT)) & USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID_MASK)
VBUSVALID_TO_SESSVALID - Selects the comparator used for VBUS_VALID 0b0..Use the VBUS_VALID comparator for VBUS_VALID results 0b1..Use the Session End comparator for VBUS_VALID results. The Session End threshold is >0.8V and <4.0V.
◆ USBPHY_USB1_VBUS_DETECT_VBUSVALID_TO_SESSVALID [2/2]
◆ USBPHY_VERSION_MAJOR [1/2]
#define USBPHY_VERSION_MAJOR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_MAJOR_SHIFT)) & USBPHY_VERSION_MAJOR_MASK)
MAJOR - MAJOR
◆ USBPHY_VERSION_MAJOR [2/2]
MAJOR - MAJOR
◆ USBPHY_VERSION_MINOR [1/2]
#define USBPHY_VERSION_MINOR (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_MINOR_SHIFT)) & USBPHY_VERSION_MINOR_MASK)
MINOR - MINOR
◆ USBPHY_VERSION_MINOR [2/2]
MINOR - MINOR
◆ USBPHY_VERSION_STEP [1/2]
#define USBPHY_VERSION_STEP (   x)    (((uint32_t)(((uint32_t)(x)) << USBPHY_VERSION_STEP_SHIFT)) & USBPHY_VERSION_STEP_MASK)
STEP - STEP
◆ USBPHY_VERSION_STEP [2/2]
STEP - STEP
