RTEMS 6.1
Modules | Files | Macros | Functions | Variables
spec:/testsuites/validation-io-kernel
This validation test suite contains test cases which test the kernel character input/output device provided by the BSP before the system initialization is performed. More...
 spec:/rtems/io/val/kernel
 Tests the functions referenced by BSP_output_char and BSP_poll_char.
file  ts-validation-io-kernel.c
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS   0
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
#define CONFIGURE_SCHEDULER_USER
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES   { }
#define CONFIGURE_IDLE_TASK_STORAGE_SIZE   RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_IDLE_TASK_BODY   IdleBody
#define CONFIGURE_INIT
void boot_card (const char *cmdline)
 Standard system initialization procedure.
const char rtems_test_name [] = "TestsuitesValidationIoKernel"
 Each test must define a test name string.
◆ boot_card()
void boot_card ( const char *  cmdline)
You may pass a command line in cmdline. It is later available via the global bsp_boot_cmdline variable.
This is the C entry point for ALL RTEMS BSPs. It is invoked from the assembly language initialization file usually called start.S which does the basic CPU setup (stack, C runtime environment, zero BSS, load other sections) and calls afterwards boot_card(). The boot card function provides the framework for the BSP initialization sequence. For the basic flow of initialization see RTEMS C User's Guide, Initialization Manager.
This style of initialization ensures that the C++ global constructors are executed after RTEMS is initialized.
