RTEMS 6.1
ts-validation-io-kernel.c File Reference
#include <bsp/bootcard.h>
#include <rtems/test-info.h>
#include <rtems/test.h>
#include <rtems/testopts.h>
#include "tr-io-kernel.h"
#include <rtems/confdefs.h>
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS   0
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
#define CONFIGURE_SCHEDULER_USER
#define CONFIGURE_SCHEDULER_TABLE_ENTRIES   { }
#define CONFIGURE_IDLE_TASK_STORAGE_SIZE   RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_IDLE_TASK_BODY   IdleBody
#define CONFIGURE_INIT
void boot_card (const char *cmdline)
 Standard system initialization procedure.
const char rtems_test_name [] = "TestsuitesValidationIoKernel"
 Each test must define a test name string.
