RTEMS 6.1
Modules | Files | Macros | Variables
spec:/testsuites/userext
This validation test suite contains a test cases related to the invocation of user extensions. More...
 spec:/rtems/userext/val/userext
 Tests the thread user extensions.
file  ts-userext.c
#define CONFIGURE_MAXIMUM_PROCESSORS   2
#define CONFIGURE_INITIAL_EXTENSIONS
#define CONFIGURE_IDLE_TASK_BODY   IdleBody
const char rtems_test_name [] = "TestsuitesUserext"
 Each test must define a test name string.
◆ CONFIGURE_INITIAL_EXTENSIONS
Value:
.thread_begin = ThreadBeginExtension0, \
.thread_create = ThreadCreateExtension0, \
.thread_delete = ThreadDeleteExtension0, \
.thread_exitted = ThreadExittedExtension0, \
.thread_restart = ThreadRestartExtension0, \
.thread_start = ThreadStartExtension0, \
.thread_switch = ThreadSwitchExtension0, \
.thread_terminate = ThreadTerminateExtension0 \
.thread_begin = ThreadBeginExtension1, \
.thread_create = ThreadCreateExtension1, \
.thread_delete = ThreadDeleteExtension1, \
.thread_exitted = ThreadExittedExtension1, \
.thread_restart = ThreadRestartExtension1, \
.thread_start = ThreadStartExtension1, \
.thread_switch = ThreadSwitchExtension1, \
.thread_terminate = ThreadTerminateExtension1 \
