Tests the thread user extensions.
More...
| enum | ExtensionKind {
THREAD_BEGIN
, THREAD_CREATE
, THREAD_DELETE
, THREAD_EXITTED
THREAD_RESTART
, THREAD_START
, THREAD_SWITCH
, THREAD_TERMINATE
EXTENSION_KIND_COUNT
| DEFINE_EXTENSIONS_AND_TABLE (2) |
| DEFINE_EXTENSIONS_AND_TABLE (3) |
| DEFINE_EXTENSIONS_AND_TABLE (4) |
| DEFINE_EXTENSIONS_AND_TABLE (5) |
| DEFINE_EXTENSIONS_AND_TABLE (6) |
void * | IdleBody (uintptr_t arg) |
| T_TEST_CASE_FIXTURE (RtemsUserextValUserext, &RtemsUserextValUserext_Fixture) |
This test case performs the following actions:
- Create five dynamic extensions. Switch to a started thread. Delete three dynamic extension during the thread begin invocation. Clean up the used resources.
- Check that the thread switch extensions were invoked in the right order before the thread begin extensions.
- Check that the thread begin extensions were invoked in the right order.
- Check that the other extensions were not invoked.
- Check that the thread begin extension of the extension set deleted before its turn in the invocation was not invoked.
- Create five dynamic extensions. Create a thread. Delete three dynamic extension during the thread create invocation. Clean up the used resources.
- Check that the thread create extensions were invoked in the right order.
- Check that the thread create extensions were invoked under protection of the allocator mutex.
- Check that the thread create extension of the extension set deleted before its turn in the invocation was not invoked.
- Create five dynamic extensions. Delete a thread. Delete three dynamic extension during the thread delete invocation. Clean up the used resources.
- Check that the thread delete extensions were invoked in the right order.
- Check that the thread delete extensions were invoked under protection of the allocator mutex.
- Check that the thread delete extension of the extension set deleted before its turn in the invocation was not invoked.
- Create five dynamic extensions. Return from a thread entry. Delete three dynamic extension during the thread exitted invocation. Clean up the used resources.
- Check that the thread exitted extensions were invoked in the right order.
- Check that the thread exitted extension of the extension set deleted before its turn in the invocation was not invoked.
- Create five dynamic extensions. Restart a thread. Delete three dynamic extension during the thread restart invocation. Clean up the used resources.
- Check that the thread restart extensions were invoked in the right order.
- Check that the thread restart extension of the extension set deleted before its turn in the invocation was not invoked.
- Create five dynamic extensions. Start a thread. Delete three dynamic extension during the thread start invocation. Clean up the used resources.
- Check that the thread start extensions were invoked in the right order.
- Check that the thread start extension of the extension set deleted before its turn in the invocation was not invoked.
- Create five dynamic extensions. Terminate a thread. Delete three dynamic extension during the thread terminate invocation. Clean up the used resources.
- Check that the thread terminate extensions were invoked in the right order.
- Check that the thread terminate extension of the extension set deleted before its turn in the invocation was not invoked.
- Create five dynamic extensions. Let an idle thread return from its entry. Delete three dynamic extension during the thread exitted invocation. Clean up the used resources.
◆ DEFINE_EXTENSIONS_AND_TABLE
| #define DEFINE_EXTENSIONS_AND_TABLE |
index | ) |
Value: DEFINE_EXTENSIONS( index, static ) \
.thread_begin = ThreadBeginExtension##index, \
.thread_create = ThreadCreateExtension##index, \
.thread_delete = ThreadDeleteExtension##index, \
.thread_exitted = ThreadExittedExtension##index, \
.thread_restart = ThreadRestartExtension##index, \
.thread_start = ThreadStartExtension##index, \
.thread_switch = ThreadSwitchExtension##index, \
.thread_terminate = ThreadTerminateExtension##index \
User extension table.
Definition: userext.h:253
