RTEMS 6.1
#define __HAL_TIM_RESET_HANDLE_STATE(__HANDLE__)
 Reset TIM handle state.
#define __HAL_TIM_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1|=(TIM_CR1_CEN))
 Enable the TIM peripheral.
#define __HAL_TIM_MOE_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->BDTR|=(TIM_BDTR_MOE))
 Enable the TIM main Output.
#define __HAL_TIM_DISABLE(__HANDLE__)
 Disable the TIM peripheral.
#define __HAL_TIM_MOE_DISABLE(__HANDLE__)
 Disable the TIM main Output.
#define __HAL_TIM_MOE_DISABLE_UNCONDITIONALLY(__HANDLE__)   (__HANDLE__)->Instance->BDTR &= ~(TIM_BDTR_MOE)
#define __HAL_TIM_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->DIER |= (__INTERRUPT__))
 Enable the specified TIM interrupt.
#define __HAL_TIM_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->DIER &= ~(__INTERRUPT__))
 Disable the specified TIM interrupt.
#define __HAL_TIM_ENABLE_DMA(__HANDLE__, __DMA__)   ((__HANDLE__)->Instance->DIER |= (__DMA__))
 Enable the specified DMA request.
#define __HAL_TIM_DISABLE_DMA(__HANDLE__, __DMA__)   ((__HANDLE__)->Instance->DIER &= ~(__DMA__))
 Disable the specified DMA request.
#define __HAL_TIM_GET_FLAG(__HANDLE__, __FLAG__)   (((__HANDLE__)->Instance->SR &(__FLAG__)) == (__FLAG__))
 Check whether the specified TIM interrupt flag is set or not.
#define __HAL_TIM_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->SR = ~(__FLAG__))
 Clear the specified TIM interrupt flag.
#define __HAL_TIM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified TIM interrupt source is enabled or not.
#define __HAL_TIM_CLEAR_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->SR = ~(__INTERRUPT__))
 Clear the TIM interrupt pending bits.
#define __HAL_TIM_UIFREMAP_ENABLE(__HANDLE__)   (((__HANDLE__)->Instance->CR1 |= TIM_CR1_UIFREMAP))
#define __HAL_TIM_UIFREMAP_DISABLE(__HANDLE__)   (((__HANDLE__)->Instance->CR1 &= ~TIM_CR1_UIFREMAP))
#define __HAL_TIM_GET_UIFCPY(__COUNTER__)   (((__COUNTER__) & (TIM_CNT_UIFCPY)) == (TIM_CNT_UIFCPY))
#define __HAL_TIM_IS_TIM_COUNTING_DOWN(__HANDLE__)   (((__HANDLE__)->Instance->CR1 &(TIM_CR1_DIR)) == (TIM_CR1_DIR))
 Indicates whether or not the TIM Counter is used as downcounter.
#define __HAL_TIM_SET_PRESCALER(__HANDLE__, __PRESC__)   ((__HANDLE__)->Instance->PSC = (__PRESC__))
 Set the TIM Prescaler on runtime.
#define __HAL_TIM_SET_COUNTER(__HANDLE__, __COUNTER__)   ((__HANDLE__)->Instance->CNT = (__COUNTER__))
 Set the TIM Counter Register value on runtime. Note Please check if the bit 31 of CNT register is used as UIF copy or not, this may affect the counter range in case of 32 bits counter TIM instance. Bit 31 of CNT can be enabled/disabled using __HAL_TIM_UIFREMAP_ENABLE()/__HAL_TIM_UIFREMAP_DISABLE() macros.
#define __HAL_TIM_GET_COUNTER(__HANDLE__)   ((__HANDLE__)->Instance->CNT)
 Get the TIM Counter Register value on runtime.
#define __HAL_TIM_SET_AUTORELOAD(__HANDLE__, __AUTORELOAD__)
 Set the TIM Autoreload Register value on runtime without calling another time any Init function.
#define __HAL_TIM_GET_AUTORELOAD(__HANDLE__)   ((__HANDLE__)->Instance->ARR)
 Get the TIM Autoreload Register value on runtime.
#define __HAL_TIM_SET_CLOCKDIVISION(__HANDLE__, __CKD__)
 Set the TIM Clock Division value on runtime without calling another time any Init function.
#define __HAL_TIM_GET_CLOCKDIVISION(__HANDLE__)   ((__HANDLE__)->Instance->CR1 & TIM_CR1_CKD)
 Get the TIM Clock Division value on runtime.
#define __HAL_TIM_SET_ICPRESCALER(__HANDLE__, __CHANNEL__, __ICPSC__)
 Set the TIM Input Capture prescaler on runtime without calling another time HAL_TIM_IC_ConfigChannel() function.
#define __HAL_TIM_GET_ICPRESCALER(__HANDLE__, __CHANNEL__)
 Get the TIM Input Capture prescaler on runtime.
#define __HAL_TIM_SET_COMPARE(__HANDLE__, __CHANNEL__, __COMPARE__)
 Set the TIM Capture Compare Register value on runtime without calling another time ConfigChannel function.
#define __HAL_TIM_GET_COMPARE(__HANDLE__, __CHANNEL__)
 Get the TIM Capture Compare Register value on runtime.
#define __HAL_TIM_ENABLE_OCxPRELOAD(__HANDLE__, __CHANNEL__)
 Set the TIM Output compare preload.
#define __HAL_TIM_DISABLE_OCxPRELOAD(__HANDLE__, __CHANNEL__)
 Reset the TIM Output compare preload.
#define __HAL_TIM_ENABLE_OCxFAST(__HANDLE__, __CHANNEL__)
 Enable fast mode for a given channel.
#define __HAL_TIM_DISABLE_OCxFAST(__HANDLE__, __CHANNEL__)
 Disable fast mode for a given channel.
#define __HAL_TIM_URS_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1|= TIM_CR1_URS)
 Set the Update Request Source (URS) bit of the TIMx_CR1 register.
#define __HAL_TIM_URS_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR1&=~TIM_CR1_URS)
 Reset the Update Request Source (URS) bit of the TIMx_CR1 register.
#define __HAL_TIM_SET_CAPTUREPOLARITY(__HANDLE__, __CHANNEL__, __POLARITY__)
 Set the TIM Capture x input polarity on runtime.
#define __HAL_TIM_SELECT_CCDMAREQUEST(__HANDLE__, __CCDMA__)    MODIFY_REG((__HANDLE__)->Instance->CR2, TIM_CR2_CCDS, (__CCDMA__))
 Select the Capture/compare DMA request source.
◆ __HAL_TIM_CLEAR_FLAG
#define __HAL_TIM_CLEAR_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__HANDLE__specifies the TIM Handle.
__FLAG__specifies the TIM interrupt flag to clear. This parameter can be one of the following values:
  • TIM_FLAG_UPDATE: Update interrupt flag
  • TIM_FLAG_CC1: Capture/Compare 1 interrupt flag
  • TIM_FLAG_CC2: Capture/Compare 2 interrupt flag
  • TIM_FLAG_CC3: Capture/Compare 3 interrupt flag
  • TIM_FLAG_CC4: Capture/Compare 4 interrupt flag
  • TIM_FLAG_CC5: Compare 5 interrupt flag
  • TIM_FLAG_CC6: Compare 6 interrupt flag
  • TIM_FLAG_COM: Commutation interrupt flag
  • TIM_FLAG_TRIGGER: Trigger interrupt flag
  • TIM_FLAG_BREAK: Break interrupt flag
  • TIM_FLAG_BREAK2: Break 2 interrupt flag
  • TIM_FLAG_SYSTEM_BREAK: System Break interrupt flag
  • TIM_FLAG_CC1OF: Capture/Compare 1 overcapture flag
  • TIM_FLAG_CC2OF: Capture/Compare 2 overcapture flag
  • TIM_FLAG_CC3OF: Capture/Compare 3 overcapture flag
  • TIM_FLAG_CC4OF: Capture/Compare 4 overcapture flag
Return values
Thenew state of FLAG (TRUE or FALSE).
◆ __HAL_TIM_CLEAR_IT
#define __HAL_TIM_CLEAR_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__HANDLE__TIM handle
__INTERRUPT__specifies the interrupt pending bit to clear. This parameter can be one of the following values:
  • TIM_IT_UPDATE: Update interrupt
  • TIM_IT_CC1: Capture/Compare 1 interrupt
  • TIM_IT_CC2: Capture/Compare 2 interrupt
  • TIM_IT_CC3: Capture/Compare 3 interrupt
  • TIM_IT_CC4: Capture/Compare 4 interrupt
  • TIM_IT_COM: Commutation interrupt
  • TIM_IT_TRIGGER: Trigger interrupt
  • TIM_IT_BREAK: Break interrupt
Return values
None
◆ __HAL_TIM_DISABLE
#define __HAL_TIM_DISABLE (   __HANDLE__)
Value:
do { \
if (((__HANDLE__)->Instance->CCER & TIM_CCER_CCxE_MASK) == 0UL) \
if(((__HANDLE__)->Instance->CCER & TIM_CCER_CCxNE_MASK) == 0UL) \
(__HANDLE__)->Instance->CR1 &= ~(TIM_CR1_CEN); \
} while(0)
#define TIM_CR1_CEN
Definition: stm32h723xx.h:19214
Parameters
Return values
None
◆ __HAL_TIM_DISABLE_DMA
#define __HAL_TIM_DISABLE_DMA (   __HANDLE__,
  __DMA__
Parameters
__DMA__specifies the TIM DMA request to disable. This parameter can be one of the following values:
  • TIM_DMA_UPDATE: Update DMA request
  • TIM_DMA_CC1: Capture/Compare 1 DMA request
  • TIM_DMA_CC2: Capture/Compare 2 DMA request
  • TIM_DMA_CC3: Capture/Compare 3 DMA request
  • TIM_DMA_CC4: Capture/Compare 4 DMA request
  • TIM_DMA_COM: Commutation DMA request
  • TIM_DMA_TRIGGER: Trigger DMA request
Return values
None
◆ __HAL_TIM_DISABLE_IT
#define __HAL_TIM_DISABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the TIM interrupt source to disable. This parameter can be one of the following values:
Return values
None
◆ __HAL_TIM_DISABLE_OCxFAST
#define __HAL_TIM_DISABLE_OCxFAST (   __HANDLE__,
  __CHANNEL__
Value:
(((__CHANNEL__) == TIM_CHANNEL_1) ? ((__HANDLE__)->Instance->CCMR1 &= ~TIM_CCMR1_OC1FE) :\
((__CHANNEL__) == TIM_CHANNEL_2) ? ((__HANDLE__)->Instance->CCMR1 &= ~TIM_CCMR1_OC2FE) :\
((__CHANNEL__) == TIM_CHANNEL_3) ? ((__HANDLE__)->Instance->CCMR2 &= ~TIM_CCMR2_OC3FE) :\
((__CHANNEL__) == TIM_CHANNEL_4) ? ((__HANDLE__)->Instance->CCMR2 &= ~TIM_CCMR2_OC4FE) :\
((__CHANNEL__) == TIM_CHANNEL_5) ? ((__HANDLE__)->Instance->CCMR3 &= ~TIM_CCMR3_OC5FE) :\
((__HANDLE__)->Instance->CCMR3 &= ~TIM_CCMR3_OC6FE))
#define TIM_CCMR3_OC6FE
Definition: stm32h723xx.h:19866
#define TIM_CCMR1_OC2FE
Definition: stm32h723xx.h:19509
#define TIM_CCMR2_OC4FE
Definition: stm32h723xx.h:19590
#define TIM_CCMR3_OC5FE
Definition: stm32h723xx.h:19847
#define TIM_CCMR1_OC1FE
Definition: stm32h723xx.h:19484
#define TIM_CCMR2_OC3FE
Definition: stm32h723xx.h:19565
#define TIM_CHANNEL_2
Definition: stm32h7xx_hal_tim.h:814
#define TIM_CHANNEL_3
Definition: stm32h7xx_hal_tim.h:815
#define TIM_CHANNEL_1
Definition: stm32h7xx_hal_tim.h:813
#define TIM_CHANNEL_4
Definition: stm32h7xx_hal_tim.h:816
#define TIM_CHANNEL_5
Definition: stm32h7xx_hal_tim.h:817
Parameters
__HANDLE__TIM handle.
__CHANNEL__TIM Channels to be configured. This parameter can be one of the following values:
  • TIM_CHANNEL_1: TIM Channel 1 selected
  • TIM_CHANNEL_2: TIM Channel 2 selected
  • TIM_CHANNEL_3: TIM Channel 3 selected
  • TIM_CHANNEL_4: TIM Channel 4 selected
  • TIM_CHANNEL_5: TIM Channel 5 selected
  • TIM_CHANNEL_6: TIM Channel 6 selected
Note
When fast mode is disabled CCx output behaves normally depending on counter and CCRx values even when the trigger is ON. The minimum delay to activate CCx output when an active edge occurs on the trigger input is 5 clock cycles.
Return values
None
◆ __HAL_TIM_DISABLE_OCxPRELOAD
#define __HAL_TIM_DISABLE_OCxPRELOAD (   __HANDLE__,
  __CHANNEL__
Value:
(((__CHANNEL__) == TIM_CHANNEL_1) ? ((__HANDLE__)->Instance->CCMR1 &= ~TIM_CCMR1_OC1PE) :\
((__CHANNEL__) == TIM_CHANNEL_2) ? ((__HANDLE__)->Instance->CCMR1 &= ~TIM_CCMR1_OC2PE) :\
((__CHANNEL__) == TIM_CHANNEL_3) ? ((__HANDLE__)->Instance->CCMR2 &= ~TIM_CCMR2_OC3PE) :\
((__CHANNEL__) == TIM_CHANNEL_4) ? ((__HANDLE__)->Instance->CCMR2 &= ~TIM_CCMR2_OC4PE) :\
((__CHANNEL__) == TIM_CHANNEL_5) ? ((__HANDLE__)->Instance->CCMR3 &= ~TIM_CCMR3_OC5PE) :\
((__HANDLE__)->Instance->CCMR3 &= ~TIM_CCMR3_OC6PE))
#define TIM_CCMR1_OC1PE
Definition: stm32h723xx.h:19487
#define TIM_CCMR2_OC3PE
Definition: stm32h723xx.h:19568
#define TIM_CCMR3_OC5PE
Definition: stm32h723xx.h:19850
#define TIM_CCMR2_OC4PE
Definition: stm32h723xx.h:19593
#define TIM_CCMR3_OC6PE
Definition: stm32h723xx.h:19869
#define TIM_CCMR1_OC2PE
Definition: stm32h723xx.h:19512
Parameters
Return values
None
◆ __HAL_TIM_ENABLE
#define __HAL_TIM_ENABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR1|=(TIM_CR1_CEN))
Parameters
Return values
None
◆ __HAL_TIM_ENABLE_DMA
#define __HAL_TIM_ENABLE_DMA (   __HANDLE__,
  __DMA__
Parameters
__DMA__specifies the TIM DMA request to enable. This parameter can be one of the following values:
Return values
None
◆ __HAL_TIM_ENABLE_IT
#define __HAL_TIM_ENABLE_IT (   __HANDLE__,
  __INTERRUPT__
Parameters
__INTERRUPT__specifies the TIM interrupt source to enable. This parameter can be one of the following values:
Return values
None
◆ __HAL_TIM_ENABLE_OCxFAST
#define __HAL_TIM_ENABLE_OCxFAST (   __HANDLE__,
  __CHANNEL__
Value:
(((__CHANNEL__) == TIM_CHANNEL_1) ? ((__HANDLE__)->Instance->CCMR1 |= TIM_CCMR1_OC1FE) :\
((__CHANNEL__) == TIM_CHANNEL_2) ? ((__HANDLE__)->Instance->CCMR1 |= TIM_CCMR1_OC2FE) :\
((__CHANNEL__) == TIM_CHANNEL_3) ? ((__HANDLE__)->Instance->CCMR2 |= TIM_CCMR2_OC3FE) :\
((__CHANNEL__) == TIM_CHANNEL_4) ? ((__HANDLE__)->Instance->CCMR2 |= TIM_CCMR2_OC4FE) :\
((__CHANNEL__) == TIM_CHANNEL_5) ? ((__HANDLE__)->Instance->CCMR3 |= TIM_CCMR3_OC5FE) :\
((__HANDLE__)->Instance->CCMR3 |= TIM_CCMR3_OC6FE))
Parameters
Note
When fast mode is enabled an active edge on the trigger input acts like a compare match on CCx output. Delay to sample the trigger input and to activate CCx output is reduced to 3 clock cycles.
Fast mode acts only if the channel is configured in PWM1 or PWM2 mode.
Return values
None
◆ __HAL_TIM_ENABLE_OCxPRELOAD
#define __HAL_TIM_ENABLE_OCxPRELOAD (   __HANDLE__,
  __CHANNEL__
Value:
(((__CHANNEL__) == TIM_CHANNEL_1) ? ((__HANDLE__)->Instance->CCMR1 |= TIM_CCMR1_OC1PE) :\
((__CHANNEL__) == TIM_CHANNEL_2) ? ((__HANDLE__)->Instance->CCMR1 |= TIM_CCMR1_OC2PE) :\
((__CHANNEL__) == TIM_CHANNEL_3) ? ((__HANDLE__)->Instance->CCMR2 |= TIM_CCMR2_OC3PE) :\
((__CHANNEL__) == TIM_CHANNEL_4) ? ((__HANDLE__)->Instance->CCMR2 |= TIM_CCMR2_OC4PE) :\
((__CHANNEL__) == TIM_CHANNEL_5) ? ((__HANDLE__)->Instance->CCMR3 |= TIM_CCMR3_OC5PE) :\
((__HANDLE__)->Instance->CCMR3 |= TIM_CCMR3_OC6PE))
Parameters
Return values
None
◆ __HAL_TIM_GET_AUTORELOAD
#define __HAL_TIM_GET_AUTORELOAD (   __HANDLE__)    ((__HANDLE__)->Instance->ARR)
Parameters
Return values
16-bitor 32-bit value of the timer auto-reload register(TIMx_ARR)
◆ __HAL_TIM_GET_CLOCKDIVISION
#define __HAL_TIM_GET_CLOCKDIVISION (   __HANDLE__)    ((__HANDLE__)->Instance->CR1 & TIM_CR1_CKD)
Parameters
Return values
Theclock division can be one of the following values:
  • TIM_CLOCKDIVISION_DIV1: tDTS=tCK_INT
  • TIM_CLOCKDIVISION_DIV2: tDTS=2*tCK_INT
  • TIM_CLOCKDIVISION_DIV4: tDTS=4*tCK_INT
◆ __HAL_TIM_GET_COMPARE
#define __HAL_TIM_GET_COMPARE (   __HANDLE__,
  __CHANNEL__
Value:
(((__CHANNEL__) == TIM_CHANNEL_1) ? ((__HANDLE__)->Instance->CCR1) :\
((__CHANNEL__) == TIM_CHANNEL_2) ? ((__HANDLE__)->Instance->CCR2) :\
((__CHANNEL__) == TIM_CHANNEL_3) ? ((__HANDLE__)->Instance->CCR3) :\
((__CHANNEL__) == TIM_CHANNEL_4) ? ((__HANDLE__)->Instance->CCR4) :\
((__CHANNEL__) == TIM_CHANNEL_5) ? ((__HANDLE__)->Instance->CCR5) :\
((__HANDLE__)->Instance->CCR6))
Parameters
__CHANNEL__TIM Channel associated with the capture compare register This parameter can be one of the following values:
  • TIM_CHANNEL_1: get capture/compare 1 register value
  • TIM_CHANNEL_2: get capture/compare 2 register value
  • TIM_CHANNEL_3: get capture/compare 3 register value
  • TIM_CHANNEL_4: get capture/compare 4 register value
  • TIM_CHANNEL_5: get capture/compare 5 register value
  • TIM_CHANNEL_6: get capture/compare 6 register value
Return values
16-bitor 32-bit value of the capture/compare register (TIMx_CCRy)
◆ __HAL_TIM_GET_COUNTER
#define __HAL_TIM_GET_COUNTER (   __HANDLE__)    ((__HANDLE__)->Instance->CNT)
Parameters
Return values
16-bitor 32-bit value of the timer counter register (TIMx_CNT)
◆ __HAL_TIM_GET_FLAG
#define __HAL_TIM_GET_FLAG (   __HANDLE__,
  __FLAG__
Parameters
__FLAG__specifies the TIM interrupt flag to check. This parameter can be one of the following values:
Return values
◆ __HAL_TIM_GET_ICPRESCALER
#define __HAL_TIM_GET_ICPRESCALER (   __HANDLE__,
  __CHANNEL__
Value:
(((__CHANNEL__) == TIM_CHANNEL_1) ? ((__HANDLE__)->Instance->CCMR1 & TIM_CCMR1_IC1PSC) :\
((__CHANNEL__) == TIM_CHANNEL_2) ? (((__HANDLE__)->Instance->CCMR1 & TIM_CCMR1_IC2PSC) >> 8U) :\
((__CHANNEL__) == TIM_CHANNEL_3) ? ((__HANDLE__)->Instance->CCMR2 & TIM_CCMR2_IC3PSC) :\
(((__HANDLE__)->Instance->CCMR2 & TIM_CCMR2_IC4PSC)) >> 8U)
#define TIM_CCMR1_IC2PSC
Definition: stm32h723xx.h:19544
#define TIM_CCMR2_IC4PSC
Definition: stm32h723xx.h:19625
#define TIM_CCMR1_IC1PSC
Definition: stm32h723xx.h:19530
#define TIM_CCMR2_IC3PSC
Definition: stm32h723xx.h:19611
Parameters
  • TIM_CHANNEL_1: get input capture 1 prescaler value
  • TIM_CHANNEL_2: get input capture 2 prescaler value
  • TIM_CHANNEL_3: get input capture 3 prescaler value
  • TIM_CHANNEL_4: get input capture 4 prescaler value
Return values
Theinput capture prescaler can be one of the following values:
  • TIM_ICPSC_DIV1: no prescaler
  • TIM_ICPSC_DIV2: capture is done once every 2 events
  • TIM_ICPSC_DIV4: capture is done once every 4 events
  • TIM_ICPSC_DIV8: capture is done once every 8 events
◆ __HAL_TIM_GET_IT_SOURCE
#define __HAL_TIM_GET_IT_SOURCE (   __HANDLE__,
  __INTERRUPT__
Value:
((((__HANDLE__)->Instance->DIER & (__INTERRUPT__)) \
== (__INTERRUPT__)) ? SET : RESET)
Parameters
__INTERRUPT__specifies the TIM interrupt source to check. This parameter can be one of the following values:
Return values
Thestate of TIM_IT (SET or RESET).
◆ __HAL_TIM_GET_UIFCPY
#define __HAL_TIM_GET_UIFCPY (   __COUNTER__)    (((__COUNTER__) & (TIM_CNT_UIFCPY)) == (TIM_CNT_UIFCPY))
@brief  Get update interrupt flag (UIF) copy status.
@param  __COUNTER__ Counter value.
@retval The state of UIFCPY (TRUE or FALSE).
mode.
◆ __HAL_TIM_IS_TIM_COUNTING_DOWN
#define __HAL_TIM_IS_TIM_COUNTING_DOWN (   __HANDLE__)    (((__HANDLE__)->Instance->CR1 &(TIM_CR1_DIR)) == (TIM_CR1_DIR))
Parameters
Return values
False(Counter used as upcounter) or True (Counter used as downcounter)
Note
This macro is particularly useful to get the counting mode when the timer operates in Center-aligned mode or Encoder mode.
◆ __HAL_TIM_MOE_DISABLE
#define __HAL_TIM_MOE_DISABLE (   __HANDLE__)
Value:
do { \
(__HANDLE__)->Instance->BDTR &= ~(TIM_BDTR_MOE); \
} while(0)
#define TIM_BDTR_MOE
Definition: stm32h723xx.h:19792
Parameters
Return values
None
Note
The Main Output Enable of a timer instance is disabled only if all the CCx and CCxN channels have been disabled
◆ __HAL_TIM_MOE_DISABLE_UNCONDITIONALLY
#define __HAL_TIM_MOE_DISABLE_UNCONDITIONALLY (   __HANDLE__)    (__HANDLE__)->Instance->BDTR &= ~(TIM_BDTR_MOE)
Parameters
Return values
None
Note
The Main Output Enable of a timer instance is disabled unconditionally
◆ __HAL_TIM_MOE_ENABLE
#define __HAL_TIM_MOE_ENABLE (   __HANDLE__)    ((__HANDLE__)->Instance->BDTR|=(TIM_BDTR_MOE))
Parameters
Return values
None
◆ __HAL_TIM_RESET_HANDLE_STATE
#define __HAL_TIM_RESET_HANDLE_STATE (   __HANDLE__)
Value:
do { \
(__HANDLE__)->State = HAL_TIM_STATE_RESET; \
(__HANDLE__)->ChannelState[0] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelState[1] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelState[2] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelState[3] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelState[4] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelState[5] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelNState[0] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelNState[1] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelNState[2] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->ChannelNState[3] = HAL_TIM_CHANNEL_STATE_RESET; \
(__HANDLE__)->DMABurstState = HAL_DMA_BURST_STATE_RESET; \
} while(0)
@ HAL_TIM_CHANNEL_STATE_RESET
Definition: stm32h7xx_hal_tim.h:323
@ HAL_DMA_BURST_STATE_RESET
Definition: stm32h7xx_hal_tim.h:333
@ HAL_TIM_STATE_RESET
Definition: stm32h7xx_hal_tim.h:311
Parameters
Return values
None
◆ __HAL_TIM_SELECT_CCDMAREQUEST
#define __HAL_TIM_SELECT_CCDMAREQUEST (   __HANDLE__,
  __CCDMA__
Parameters
__CCDMA__specifies Capture/compare DMA request source This parameter can be one of the following values:
  • TIM_CCDMAREQUEST_CC: CCx DMA request generated on Capture/Compare event
  • TIM_CCDMAREQUEST_UPDATE: CCx DMA request generated on Update event
Return values
None
◆ __HAL_TIM_SET_AUTORELOAD
#define __HAL_TIM_SET_AUTORELOAD (   __HANDLE__,
  __AUTORELOAD__
Value:
do{ \
(__HANDLE__)->Instance->ARR = (__AUTORELOAD__); \
(__HANDLE__)->Init.Period = (__AUTORELOAD__); \
} while(0)
Parameters
__AUTORELOAD__specifies the Counter register new value.
Return values
None
◆ __HAL_TIM_SET_CAPTUREPOLARITY
#define __HAL_TIM_SET_CAPTUREPOLARITY (   __HANDLE__,
  __CHANNEL__,
  __POLARITY__
Value:
do{ \
TIM_RESET_CAPTUREPOLARITY((__HANDLE__), (__CHANNEL__)); \
TIM_SET_CAPTUREPOLARITY((__HANDLE__), (__CHANNEL__), (__POLARITY__)); \
}while(0)
Parameters
__POLARITY__Polarity for TIx source
  • TIM_INPUTCHANNELPOLARITY_RISING: Rising Edge
  • TIM_INPUTCHANNELPOLARITY_FALLING: Falling Edge
  • TIM_INPUTCHANNELPOLARITY_BOTHEDGE: Rising and Falling Edge
Return values
None
◆ __HAL_TIM_SET_CLOCKDIVISION
#define __HAL_TIM_SET_CLOCKDIVISION (   __HANDLE__,
  __CKD__
Value:
do{ \
(__HANDLE__)->Instance->CR1 &= (~TIM_CR1_CKD); \
(__HANDLE__)->Instance->CR1 |= (__CKD__); \
(__HANDLE__)->Init.ClockDivision = (__CKD__); \
} while(0)
#define TIM_CR1_CKD
Definition: stm32h723xx.h:19240
Parameters
__CKD__specifies the clock division value. This parameter can be one of the following value:
Return values
None
◆ __HAL_TIM_SET_COMPARE
#define __HAL_TIM_SET_COMPARE (   __HANDLE__,
  __CHANNEL__,
  __COMPARE__
Value:
(((__CHANNEL__) == TIM_CHANNEL_1) ? ((__HANDLE__)->Instance->CCR1 = (__COMPARE__)) :\
((__CHANNEL__) == TIM_CHANNEL_2) ? ((__HANDLE__)->Instance->CCR2 = (__COMPARE__)) :\
((__CHANNEL__) == TIM_CHANNEL_3) ? ((__HANDLE__)->Instance->CCR3 = (__COMPARE__)) :\
((__CHANNEL__) == TIM_CHANNEL_4) ? ((__HANDLE__)->Instance->CCR4 = (__COMPARE__)) :\
((__CHANNEL__) == TIM_CHANNEL_5) ? ((__HANDLE__)->Instance->CCR5 = (__COMPARE__)) :\
((__HANDLE__)->Instance->CCR6 = (__COMPARE__)))
Parameters
__COMPARE__specifies the Capture Compare register new value.
Return values
None
◆ __HAL_TIM_SET_COUNTER
#define __HAL_TIM_SET_COUNTER (   __HANDLE__,
  __COUNTER__
Parameters
__COUNTER__specifies the Counter register new value.
Return values
None
◆ __HAL_TIM_SET_ICPRESCALER
#define __HAL_TIM_SET_ICPRESCALER (   __HANDLE__,
  __CHANNEL__,
  __ICPSC__
Value:
do{ \
TIM_RESET_ICPRESCALERVALUE((__HANDLE__), (__CHANNEL__)); \
TIM_SET_ICPRESCALERVALUE((__HANDLE__), (__CHANNEL__), (__ICPSC__)); \
} while(0)
Parameters
__ICPSC__specifies the Input Capture4 prescaler new value. This parameter can be one of the following values:
Return values
None
◆ __HAL_TIM_SET_PRESCALER
#define __HAL_TIM_SET_PRESCALER (   __HANDLE__,
  __PRESC__
Parameters
__PRESC__specifies the Prescaler new value.
Return values
None
◆ __HAL_TIM_UIFREMAP_DISABLE
#define __HAL_TIM_UIFREMAP_DISABLE (   __HANDLE__)    (((__HANDLE__)->Instance->CR1 &= ~TIM_CR1_UIFREMAP))
@brief  Disable update interrupt flag (UIF) remapping.
@param  __HANDLE__ TIM handle.
@retval None
mode.
◆ __HAL_TIM_UIFREMAP_ENABLE
#define __HAL_TIM_UIFREMAP_ENABLE (   __HANDLE__)    (((__HANDLE__)->Instance->CR1 |= TIM_CR1_UIFREMAP))
@brief  Force a continuous copy of the update interrupt flag (UIF) into the timer counter register (bit 31).
@note This allows both the counter value and a potential roll-over condition signalled by the UIFCPY flag to be read
      in an atomic way.
@retval None
mode.
◆ __HAL_TIM_URS_DISABLE
#define __HAL_TIM_URS_DISABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR1&=~TIM_CR1_URS)
Parameters
Note
When the URS bit of the TIMx_CR1 register is reset, any of the following events generate an update interrupt or DMA request (if enabled): _ Counter overflow underflow _ Setting the UG bit _ Update generation through the slave mode controller
Return values
None
◆ __HAL_TIM_URS_ENABLE
#define __HAL_TIM_URS_ENABLE (   __HANDLE__)    ((__HANDLE__)->Instance->CR1|= TIM_CR1_URS)
Parameters
Note
When the URS bit of the TIMx_CR1 register is set, only counter overflow/underflow generates an update interrupt or DMA request (if enabled)
Return values
None
