RTEMS 6.1
__STATIC_INLINE void LL_SWPMI_EnableIT_RDY (SWPMI_TypeDef *SWPMIx)
 Enable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_EnableIT_RDY.
__STATIC_INLINE void LL_SWPMI_EnableIT_SR (SWPMI_TypeDef *SWPMIx)
 Enable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_EnableIT_SR.
__STATIC_INLINE void LL_SWPMI_EnableIT_TC (SWPMI_TypeDef *SWPMIx)
 Enable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_EnableIT_TC.
__STATIC_INLINE void LL_SWPMI_EnableIT_TX (SWPMI_TypeDef *SWPMIx)
 Enable Transmit interrupt @rmtoll IER TIE LL_SWPMI_EnableIT_TX.
__STATIC_INLINE void LL_SWPMI_EnableIT_RX (SWPMI_TypeDef *SWPMIx)
 Enable Receive interrupt @rmtoll IER RIE LL_SWPMI_EnableIT_RX.
__STATIC_INLINE void LL_SWPMI_EnableIT_TXUNR (SWPMI_TypeDef *SWPMIx)
 Enable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_EnableIT_TXUNR.
__STATIC_INLINE void LL_SWPMI_EnableIT_RXOVR (SWPMI_TypeDef *SWPMIx)
 Enable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_EnableIT_RXOVR.
__STATIC_INLINE void LL_SWPMI_EnableIT_RXBER (SWPMI_TypeDef *SWPMIx)
 Enable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_EnableIT_RXBER.
__STATIC_INLINE void LL_SWPMI_EnableIT_TXBE (SWPMI_TypeDef *SWPMIx)
 Enable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_EnableIT_TXBE.
__STATIC_INLINE void LL_SWPMI_EnableIT_RXBF (SWPMI_TypeDef *SWPMIx)
 Enable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_EnableIT_RXBF.
__STATIC_INLINE void LL_SWPMI_DisableIT_RDY (SWPMI_TypeDef *SWPMIx)
 Disable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_DisableIT_RDY.
__STATIC_INLINE void LL_SWPMI_DisableIT_SR (SWPMI_TypeDef *SWPMIx)
 Disable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_DisableIT_SR.
__STATIC_INLINE void LL_SWPMI_DisableIT_TC (SWPMI_TypeDef *SWPMIx)
 Disable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_DisableIT_TC.
__STATIC_INLINE void LL_SWPMI_DisableIT_TX (SWPMI_TypeDef *SWPMIx)
 Disable Transmit interrupt @rmtoll IER TIE LL_SWPMI_DisableIT_TX.
__STATIC_INLINE void LL_SWPMI_DisableIT_RX (SWPMI_TypeDef *SWPMIx)
 Disable Receive interrupt @rmtoll IER RIE LL_SWPMI_DisableIT_RX.
__STATIC_INLINE void LL_SWPMI_DisableIT_TXUNR (SWPMI_TypeDef *SWPMIx)
 Disable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_DisableIT_TXUNR.
__STATIC_INLINE void LL_SWPMI_DisableIT_RXOVR (SWPMI_TypeDef *SWPMIx)
 Disable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_DisableIT_RXOVR.
__STATIC_INLINE void LL_SWPMI_DisableIT_RXBER (SWPMI_TypeDef *SWPMIx)
 Disable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_DisableIT_RXBER.
__STATIC_INLINE void LL_SWPMI_DisableIT_TXBE (SWPMI_TypeDef *SWPMIx)
 Disable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_DisableIT_TXBE.
__STATIC_INLINE void LL_SWPMI_DisableIT_RXBF (SWPMI_TypeDef *SWPMIx)
 Disable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_DisableIT_RXBF.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RDY (SWPMI_TypeDef *SWPMIx)
 Check if SWPMI transceiver ready interrupt is enabled @rmtoll IER RDYIE LL_SWPMI_IsEnabledIT_RDY.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_SR (SWPMI_TypeDef *SWPMIx)
 Check if Slave resume interrupt is enabled @rmtoll IER SRIE LL_SWPMI_IsEnabledIT_SR.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TC (SWPMI_TypeDef *SWPMIx)
 Check if Transmit complete interrupt is enabled @rmtoll IER TCIE LL_SWPMI_IsEnabledIT_TC.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TX (SWPMI_TypeDef *SWPMIx)
 Check if Transmit interrupt is enabled @rmtoll IER TIE LL_SWPMI_IsEnabledIT_TX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RX (SWPMI_TypeDef *SWPMIx)
 Check if Receive interrupt is enabled @rmtoll IER RIE LL_SWPMI_IsEnabledIT_RX.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXUNR (SWPMI_TypeDef *SWPMIx)
 Check if Transmit underrun error interrupt is enabled @rmtoll IER TXUNRIE LL_SWPMI_IsEnabledIT_TXUNR.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXOVR (SWPMI_TypeDef *SWPMIx)
 Check if Receive overrun error interrupt is enabled @rmtoll IER RXOVRIE LL_SWPMI_IsEnabledIT_RXOVR.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBER (SWPMI_TypeDef *SWPMIx)
 Check if Receive CRC error interrupt is enabled @rmtoll IER RXBERIE LL_SWPMI_IsEnabledIT_RXBER.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXBE (SWPMI_TypeDef *SWPMIx)
 Check if Transmit buffer empty interrupt is enabled @rmtoll IER TXBEIE LL_SWPMI_IsEnabledIT_TXBE.
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBF (SWPMI_TypeDef *SWPMIx)
 Check if Receive buffer full interrupt is enabled @rmtoll IER RXBFIE LL_SWPMI_IsEnabledIT_RXBF.
◆ LL_SWPMI_DisableIT_RDY()
__STATIC_INLINE void LL_SWPMI_DisableIT_RDY ( SWPMI_TypeDef SWPMIx)
Parameters
SWPMIxSWPMI Instance
Return values
None
◆ LL_SWPMI_DisableIT_RX()
__STATIC_INLINE void LL_SWPMI_DisableIT_RX ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_RXBER()
__STATIC_INLINE void LL_SWPMI_DisableIT_RXBER ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_RXBF()
__STATIC_INLINE void LL_SWPMI_DisableIT_RXBF ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_RXOVR()
__STATIC_INLINE void LL_SWPMI_DisableIT_RXOVR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_SR()
__STATIC_INLINE void LL_SWPMI_DisableIT_SR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_TC()
__STATIC_INLINE void LL_SWPMI_DisableIT_TC ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_TX()
__STATIC_INLINE void LL_SWPMI_DisableIT_TX ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_TXBE()
__STATIC_INLINE void LL_SWPMI_DisableIT_TXBE ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_DisableIT_TXUNR()
__STATIC_INLINE void LL_SWPMI_DisableIT_TXUNR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_RDY()
__STATIC_INLINE void LL_SWPMI_EnableIT_RDY ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_RX()
__STATIC_INLINE void LL_SWPMI_EnableIT_RX ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_RXBER()
__STATIC_INLINE void LL_SWPMI_EnableIT_RXBER ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_RXBF()
__STATIC_INLINE void LL_SWPMI_EnableIT_RXBF ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_RXOVR()
__STATIC_INLINE void LL_SWPMI_EnableIT_RXOVR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_SR()
__STATIC_INLINE void LL_SWPMI_EnableIT_SR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_TC()
__STATIC_INLINE void LL_SWPMI_EnableIT_TC ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_TX()
__STATIC_INLINE void LL_SWPMI_EnableIT_TX ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_TXBE()
__STATIC_INLINE void LL_SWPMI_EnableIT_TXBE ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_EnableIT_TXUNR()
__STATIC_INLINE void LL_SWPMI_EnableIT_TXUNR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_IsEnabledIT_RDY()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RDY ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
Stateof bit (1 or 0).
◆ LL_SWPMI_IsEnabledIT_RX()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RX ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_RXBER()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBER ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_RXBF()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXBF ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_RXOVR()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_RXOVR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_SR()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_SR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_TC()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TC ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_TX()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TX ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_TXBE()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXBE ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsEnabledIT_TXUNR()
__STATIC_INLINE uint32_t LL_SWPMI_IsEnabledIT_TXUNR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
