RTEMS 6.1
Single Wire Protocol Master Interface SPWMI. More...
#include <stm32h723xx.h>
__IO uint32_t CR
__IO uint32_t BRR
uint32_t RESERVED1
__IO uint32_t ISR
__IO uint32_t ICR
__IO uint32_t IER
__IO uint32_t RFL
__IO uint32_t TDR
__IO uint32_t RDR
__IO uint32_t OR
Field Documentation
◆ BRR
__IO uint32_t SWPMI_TypeDef::BRR
SWPMI bitrate register, Address offset: 0x04
◆ CR
__IO uint32_t SWPMI_TypeDef::CR
SWPMI Configuration/Control register, Address offset: 0x00
◆ ICR
__IO uint32_t SWPMI_TypeDef::ICR
SWPMI Interrupt Flag Clear register, Address offset: 0x10
◆ IER
__IO uint32_t SWPMI_TypeDef::IER
SWPMI Interrupt Enable register, Address offset: 0x14
◆ ISR
__IO uint32_t SWPMI_TypeDef::ISR
SWPMI Interrupt and Status register, Address offset: 0x0C
◆ OR
__IO uint32_t SWPMI_TypeDef::OR
SWPMI Option register, Address offset: 0x24
◆ RDR
__IO uint32_t SWPMI_TypeDef::RDR
SWPMI Receive data register, Address offset: 0x20
◆ RESERVED1
uint32_t SWPMI_TypeDef::RESERVED1
Reserved, 0x08
◆ RFL
__IO uint32_t SWPMI_TypeDef::RFL
SWPMI Receive Frame Length register, Address offset: 0x18
◆ TDR
__IO uint32_t SWPMI_TypeDef::TDR
SWPMI Transmit data register, Address offset: 0x1C
The documentation for this struct was generated from the following files:
