RTEMS 6.1
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBF (SWPMI_TypeDef *SWPMIx)
 Check if the last word of the frame under reception has arrived in SWPMI_RDR. @rmtoll ISR RXBFF LL_SWPMI_IsActiveFlag_RXBF.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXBE (SWPMI_TypeDef *SWPMIx)
 Check if Frame transmission buffer has been emptied @rmtoll ISR TXBEF LL_SWPMI_IsActiveFlag_TXBE.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBER (SWPMI_TypeDef *SWPMIx)
 Check if CRC error in reception has been detected @rmtoll ISR RXBERF LL_SWPMI_IsActiveFlag_RXBER.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXOVR (SWPMI_TypeDef *SWPMIx)
 Check if Overrun in reception has been detected @rmtoll ISR RXOVRF LL_SWPMI_IsActiveFlag_RXOVR.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXUNR (SWPMI_TypeDef *SWPMIx)
 Check if underrun error in transmission has been detected @rmtoll ISR TXUNRF LL_SWPMI_IsActiveFlag_TXUNR.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXNE (SWPMI_TypeDef *SWPMIx)
 Check if Receive data register not empty (it means that Received data is ready to be read in the SWPMI_RDR register) @rmtoll ISR RXNE LL_SWPMI_IsActiveFlag_RXNE.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXE (SWPMI_TypeDef *SWPMIx)
 Check if Transmit data register is empty (it means that Data written in transmit data register SWPMI_TDR has been transmitted and SWPMI_TDR can be written to again) @rmtoll ISR TXE LL_SWPMI_IsActiveFlag_TXE.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TC (SWPMI_TypeDef *SWPMIx)
 Check if Both transmission and reception are completed and SWP is switched to the SUSPENDED state @rmtoll ISR TCF LL_SWPMI_IsActiveFlag_TC.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SR (SWPMI_TypeDef *SWPMIx)
 Check if a Resume by slave state has been detected during the SWP bus SUSPENDED state @rmtoll ISR SRF LL_SWPMI_IsActiveFlag_SR.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SUSP (SWPMI_TypeDef *SWPMIx)
 Check if SWP bus is in SUSPENDED or DEACTIVATED state @rmtoll ISR SUSP LL_SWPMI_IsActiveFlag_SUSP.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_DEACT (SWPMI_TypeDef *SWPMIx)
 Check if SWP bus is in DEACTIVATED state @rmtoll ISR DEACTF LL_SWPMI_IsActiveFlag_DEACT.
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RDYF (SWPMI_TypeDef *SWPMIx)
 Check if SWPMI transceiver is ready @rmtoll ISR RDYF LL_SWPMI_IsActiveFlag_RDYF.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXBF (SWPMI_TypeDef *SWPMIx)
 Clear receive buffer full flag @rmtoll ICR CRXBFF LL_SWPMI_ClearFlag_RXBF.
__STATIC_INLINE void LL_SWPMI_ClearFlag_TXBE (SWPMI_TypeDef *SWPMIx)
 Clear transmit buffer empty flag @rmtoll ICR CTXBEF LL_SWPMI_ClearFlag_TXBE.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXBER (SWPMI_TypeDef *SWPMIx)
 Clear receive CRC error flag @rmtoll ICR CRXBERF LL_SWPMI_ClearFlag_RXBER.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXOVR (SWPMI_TypeDef *SWPMIx)
 Clear receive overrun error flag @rmtoll ICR CRXOVRF LL_SWPMI_ClearFlag_RXOVR.
__STATIC_INLINE void LL_SWPMI_ClearFlag_TXUNR (SWPMI_TypeDef *SWPMIx)
 Clear transmit underrun error flag @rmtoll ICR CTXUNRF LL_SWPMI_ClearFlag_TXUNR.
__STATIC_INLINE void LL_SWPMI_ClearFlag_TC (SWPMI_TypeDef *SWPMIx)
 Clear transfer complete flag @rmtoll ICR CTCF LL_SWPMI_ClearFlag_TC.
__STATIC_INLINE void LL_SWPMI_ClearFlag_SR (SWPMI_TypeDef *SWPMIx)
 Clear slave resume flag @rmtoll ICR CSRF LL_SWPMI_ClearFlag_SR.
__STATIC_INLINE void LL_SWPMI_ClearFlag_RDY (SWPMI_TypeDef *SWPMIx)
 Clear SWPMI transceiver ready flag @rmtoll ISR CRDYF LL_SWPMI_ClearFlag_RDY.
◆ LL_SWPMI_ClearFlag_RDY()
__STATIC_INLINE void LL_SWPMI_ClearFlag_RDY ( SWPMI_TypeDef SWPMIx)
Parameters
SWPMIxSWPMI Instance
Return values
None
◆ LL_SWPMI_ClearFlag_RXBER()
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXBER ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_ClearFlag_RXBF()
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXBF ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_ClearFlag_RXOVR()
__STATIC_INLINE void LL_SWPMI_ClearFlag_RXOVR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_ClearFlag_SR()
__STATIC_INLINE void LL_SWPMI_ClearFlag_SR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_ClearFlag_TC()
__STATIC_INLINE void LL_SWPMI_ClearFlag_TC ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_ClearFlag_TXBE()
__STATIC_INLINE void LL_SWPMI_ClearFlag_TXBE ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_ClearFlag_TXUNR()
__STATIC_INLINE void LL_SWPMI_ClearFlag_TXUNR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
None
◆ LL_SWPMI_IsActiveFlag_DEACT()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_DEACT ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
Stateof bit (1 or 0).
◆ LL_SWPMI_IsActiveFlag_RDYF()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RDYF ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_RXBER()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBER ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_RXBF()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXBF ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_RXNE()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXNE ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_RXOVR()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_RXOVR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_SR()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_SUSP()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_SUSP ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_TC()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TC ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_TXBE()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXBE ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_TXE()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXE ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
◆ LL_SWPMI_IsActiveFlag_TXUNR()
__STATIC_INLINE uint32_t LL_SWPMI_IsActiveFlag_TXUNR ( SWPMI_TypeDef SWPMIx)
Parameters
Return values
