RTEMS 6.1
This group contains the implementation to support the Thread Handler in multiprocessing (MP) configurations. More...
Files | |
| file | threadmp.h |
| This header file provides the interfaces of the Thread Handler Multiprocessing (MP) Support. | |
| file | threadmp.c |
| This source file contains the implementation of _Thread_MP_Handler_initialization(), _Thread_MP_Allocate_proxy(), _Thread_MP_Find_proxy(), _Thread_MP_Free_proxy(). | |
| #define | _Thread_MP_Is_receive(_the_thread) ((_the_thread) == _MPCI_Receive_server_tcb) |
| void | _Thread_MP_Handler_initialization (uint32_t maximum_proxies) |
| Initialize MP thread handler. | |
| Thread_Control * | _Thread_MP_Allocate_proxy (States_Control the_state) |
| Allocates a MP proxy control block from the inactive chain of free proxy control blocks. | |
| Thread_Control * | _Thread_MP_Find_proxy (Objects_Id the_id) |
| Removes the MP proxy control block for the specified id from the active chain of proxy control blocks. | |
| void | _Thread_MP_Extract_proxy (Thread_Control *the_thread) |
| Extracts the proxy of the thread if necessary. | |
| void | _Thread_MP_Free_proxy (Thread_Control *the_thread) |
| Trees a proxy control block to the inactive chain of free proxy control blocks. | |
This handler encapsulates functionality which is related to managing threads in a multiprocessor system configuration. This handler must manage proxies which represent remote threads blocking on local operations.
| #define _Thread_MP_Is_receive | ( | _the_thread | ) | ((_the_thread) == _MPCI_Receive_server_tcb) |
This function returns true if the thread in question is the multiprocessing receive thread.
| Thread_Control * _Thread_MP_Allocate_proxy | ( | States_Control | the_state | ) |
This allocates a proxy control block from the inactive chain of free proxy control blocks.
| the_state | The state for the allocated MP proxy control block. |
| void _Thread_MP_Extract_proxy | ( | Thread_Control * | the_thread | ) |
This routine ensures that if there is a proxy for this thread on another node, it is also dealt with. A proxy is a data that is on the thread queue on the remote node and acts as a proxy for the local thread. If the local thread was waiting on a remote operation, then the remote side of the operation must be cleaned up.
| [in,out] | the_thread | is the thread to determine the proxy. |
| Thread_Control * _Thread_MP_Find_proxy | ( | Objects_Id | the_id | ) |
This function removes the proxy control block for the specified id from the active red-black tree of proxy control blocks.
| the_id | The id of the proxy control block to remove. |
| void _Thread_MP_Handler_initialization | ( | uint32_t | maximum_proxies | ) |
This routine initializes the multiprocessing portion of the Thread Handler.
| maximum_proxies | The maximum number of proxies for the MP thread handler. |
