RTEMS 6.1
This group contains the implementation of CPU Usage Reporting. More...
Files | |
| file | cpuusagedata.c |
| This source file contains the definition of CPU_usage_Uptime_at_last_reset. | |
| file | cpuusagereport.c |
| This source file contains the definition of rtems_cpu_usage_report() and rtems_cpu_usage_report_with_plugin(). | |
| file | cpuusagereset.c |
| This source file contains the definition of rtems_cpu_usage_reset(). | |
| file | cpuusagetop.c |
| This source file contains the definition of rtems_cpu_usage_top() and rtems_cpu_usage_top_with_plugin(). | |
| file | cpuuseimpl.h |
| This header file provides interfaces of the CPU Usage Reporting implementation. | |
| Timestamp_Control | CPU_usage_Uptime_at_last_reset |
| This object provides the uptime timestamp at the last CPU usage reset. | |
