RTEMS 6.1
cpuusagetop.c File Reference
This source file contains the definition of rtems_cpu_usage_top() and rtems_cpu_usage_top_with_plugin(). More...
#include <stdbool.h>
#include <ctype.h>
#include <inttypes.h>
#include <rtems/cpuuse.h>
#include <rtems/printer.h>
#include <rtems/malloc.h>
#include <rtems/score/protectedheap.h>
#include "cpuuseimpl.h"
struct  rtems_cpu_usage_data
#define RTEMS_TOP_SORT_ID   (0)
#define RTEMS_TOP_SORT_REAL_PRI   (1)
#define RTEMS_TOP_SORT_CURRENT_PRI   (2)
#define RTEMS_TOP_SORT_TOTAL   (3)
#define RTEMS_TOP_SORT_CURRENT   (4)
#define RTEMS_TOP_SORT_MAX   (4)
#define CPU_usage_Equal_to(_lhs, _rhs)   _Timestamp_Equal_to( _lhs, _rhs )
#define CPU_usage_Set_to_zero(_time)   _Timestamp_Set_to_zero( _time )
#define CPU_usage_Less_than(_lhs, _rhs)   _Timestamp_Less_than( _lhs, _rhs )
void rtems_cpu_usage_top_with_plugin (const rtems_printer *printer)
void rtems_cpu_usage_top (void)
 Starts an interactive CPU usage reporting using the printk() printer.
