RTEMS 6.1
wkspace.h
2
12/*
13 * COPYRIGHT (c) 1989-2009.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_WKSPACE_H
39#define _RTEMS_SCORE_WKSPACE_H
40
41#include <rtems/score/heap.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
60
67
78void *_Workspace_Allocate( size_t size );
79
92 void *block
93);
94
105 const char *string,
106 size_t len
107);
108
111#ifdef __cplusplus
112}
113#endif
114
115#endif
116/* end of include file */
char * _Workspace_String_duplicate(const char *string, size_t len)
Duplicates string with memory from the workspace.
Definition: wkstringduplicate.c:45
void _Workspace_Free(void *block)
Frees memory to the workspace.
Definition: wkspacefree.c:44
void _Workspace_Handler_initialization(void)
Initializes the workspace handler.
Definition: wkspaceinitmulti.c:43
void * _Workspace_Allocate(size_t size)
Allocates a memory block of the specified size from the workspace.
Definition: wkspaceallocate.c:44
Heap_Control _Workspace_Area
Executive workspace control.
Definition: wkspace.c:44
This header file provides interfaces of the Heap Handler which are used by the implementation and the...
Control block used to manage a heap.
Definition: heap.h:339
