RTEMS 6.1
Interrupt map register n, where n = 0 .. 3 (IRQMAPR)
This group contains register bit definitions. More...
#define GRGPIO_IRQMAPR_IRQMAP_I_0_SHIFT   24
#define GRGPIO_IRQMAPR_IRQMAP_I_0_MASK   0x1f000000U
#define GRGPIO_IRQMAPR_IRQMAP_I_0_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_0_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_0(_val)
#define GRGPIO_IRQMAPR_IRQMAP_I_1_SHIFT   16
#define GRGPIO_IRQMAPR_IRQMAP_I_1_MASK   0x1f0000U
#define GRGPIO_IRQMAPR_IRQMAP_I_1_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_1_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_1(_val)
#define GRGPIO_IRQMAPR_IRQMAP_I_2_SHIFT   8
#define GRGPIO_IRQMAPR_IRQMAP_I_2_MASK   0x1f00U
#define GRGPIO_IRQMAPR_IRQMAP_I_2_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_2_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_2(_val)
#define GRGPIO_IRQMAPR_IRQMAP_I_3_SHIFT   0
#define GRGPIO_IRQMAPR_IRQMAP_I_3_MASK   0x1fU
#define GRGPIO_IRQMAPR_IRQMAP_I_3_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_3_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_3(_val)
◆ GRGPIO_IRQMAPR_IRQMAP_I_0
#define GRGPIO_IRQMAPR_IRQMAP_I_0 (   _val)
Value:
( ( ( _val ) << GRGPIO_IRQMAPR_IRQMAP_I_0_SHIFT ) & \
GRGPIO_IRQMAPR_IRQMAP_I_0_MASK )
◆ GRGPIO_IRQMAPR_IRQMAP_I_0_GET
#define GRGPIO_IRQMAPR_IRQMAP_I_0_GET (   _reg)
Value:
( ( ( _reg ) & GRGPIO_IRQMAPR_IRQMAP_I_0_MASK ) >> \
◆ GRGPIO_IRQMAPR_IRQMAP_I_0_SET
#define GRGPIO_IRQMAPR_IRQMAP_I_0_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRGPIO_IRQMAPR_IRQMAP_I_0_MASK ) | \
GRGPIO_IRQMAPR_IRQMAP_I_0_MASK ) )
◆ GRGPIO_IRQMAPR_IRQMAP_I_1
#define GRGPIO_IRQMAPR_IRQMAP_I_1 (   _val)
Value:
( ( ( _val ) << GRGPIO_IRQMAPR_IRQMAP_I_1_SHIFT ) & \
GRGPIO_IRQMAPR_IRQMAP_I_1_MASK )
◆ GRGPIO_IRQMAPR_IRQMAP_I_1_GET
#define GRGPIO_IRQMAPR_IRQMAP_I_1_GET (   _reg)
Value:
( ( ( _reg ) & GRGPIO_IRQMAPR_IRQMAP_I_1_MASK ) >> \
◆ GRGPIO_IRQMAPR_IRQMAP_I_1_SET
#define GRGPIO_IRQMAPR_IRQMAP_I_1_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRGPIO_IRQMAPR_IRQMAP_I_1_MASK ) | \
GRGPIO_IRQMAPR_IRQMAP_I_1_MASK ) )
◆ GRGPIO_IRQMAPR_IRQMAP_I_2
#define GRGPIO_IRQMAPR_IRQMAP_I_2 (   _val)
Value:
( ( ( _val ) << GRGPIO_IRQMAPR_IRQMAP_I_2_SHIFT ) & \
GRGPIO_IRQMAPR_IRQMAP_I_2_MASK )
◆ GRGPIO_IRQMAPR_IRQMAP_I_2_GET
#define GRGPIO_IRQMAPR_IRQMAP_I_2_GET (   _reg)
Value:
( ( ( _reg ) & GRGPIO_IRQMAPR_IRQMAP_I_2_MASK ) >> \
◆ GRGPIO_IRQMAPR_IRQMAP_I_2_SET
#define GRGPIO_IRQMAPR_IRQMAP_I_2_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRGPIO_IRQMAPR_IRQMAP_I_2_MASK ) | \
GRGPIO_IRQMAPR_IRQMAP_I_2_MASK ) )
◆ GRGPIO_IRQMAPR_IRQMAP_I_3
#define GRGPIO_IRQMAPR_IRQMAP_I_3 (   _val)
Value:
( ( ( _val ) << GRGPIO_IRQMAPR_IRQMAP_I_3_SHIFT ) & \
GRGPIO_IRQMAPR_IRQMAP_I_3_MASK )
◆ GRGPIO_IRQMAPR_IRQMAP_I_3_GET
#define GRGPIO_IRQMAPR_IRQMAP_I_3_GET (   _reg)
Value:
( ( ( _reg ) & GRGPIO_IRQMAPR_IRQMAP_I_3_MASK ) >> \
◆ GRGPIO_IRQMAPR_IRQMAP_I_3_SET
#define GRGPIO_IRQMAPR_IRQMAP_I_3_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRGPIO_IRQMAPR_IRQMAP_I_3_MASK ) | \
GRGPIO_IRQMAPR_IRQMAP_I_3_MASK ) )
