RTEMS 6.1
This group contains the GRGPIO interfaces. More...
Modules | |
| Bypass register (BYPASS) | |
| This group contains register bit definitions. | |
| Capability register (CAP) | |
| I/O port data register (DATA) | |
| I/O port direction register (DIRECTION) | |
| I/O port output register (OUTPUT) | |
| Interrupt available register (IAVAIL) | |
| Interrupt edge register (IEDGE) | |
| Interrupt enable register (IPEN) | |
| Interrupt flag register (IFLAG) | |
| Interrupt map register n, where n = 0 .. 3 (IRQMAPR) | |
| Interrupt mask register (IMASK) | |
| Interrupt polarity register (IPOL) | |
| Logical-AND registers (LAND) | |
| Logical-OR registers (LOR) | |
| Logical-XOR registers (LXOR) | |
| Pulse register (PULSE) | |
Files | |
| file | grgpio-regs.h |
| This header file defines the GRGPIO register block interface. | |
| struct | grgpio |
| This structure defines the GRGPIO register block memory map. More... | |
Typedefs | |
| typedef struct grgpio | grgpio |
| This structure defines the GRGPIO register block memory map. | |
