RTEMS 6.1
Data Structures | Macros | Typedefs
grgpio-regs.h File Reference
This header file defines the GRGPIO register block interface. More...
#include <stdint.h>
struct  grgpio
 This structure defines the GRGPIO register block memory map. More...
#define GRGPIO_DATA_DATA_SHIFT   0
#define GRGPIO_DATA_DATA_MASK   0xffffffffU
#define GRGPIO_DATA_DATA_GET(_reg)
#define GRGPIO_DATA_DATA_SET(_reg, _val)
#define GRGPIO_DATA_DATA(_val)
#define GRGPIO_OUTPUT_DATA_SHIFT   0
#define GRGPIO_OUTPUT_DATA_MASK   0xffffffffU
#define GRGPIO_OUTPUT_DATA_GET(_reg)
#define GRGPIO_OUTPUT_DATA_SET(_reg, _val)
#define GRGPIO_OUTPUT_DATA(_val)
#define GRGPIO_DIRECTION_DIR_SHIFT   0
#define GRGPIO_DIRECTION_DIR_MASK   0xffffffffU
#define GRGPIO_DIRECTION_DIR_GET(_reg)
#define GRGPIO_DIRECTION_DIR_SET(_reg, _val)
#define GRGPIO_DIRECTION_DIR(_val)
#define GRGPIO_IMASK_MASK_SHIFT   0
#define GRGPIO_IMASK_MASK_MASK   0xffffffffU
#define GRGPIO_IMASK_MASK_GET(_reg)
#define GRGPIO_IMASK_MASK_SET(_reg, _val)
#define GRGPIO_IMASK_MASK(_val)
#define GRGPIO_IPOL_POL_SHIFT   0
#define GRGPIO_IPOL_POL_MASK   0xffffffffU
#define GRGPIO_IPOL_POL_GET(_reg)
#define GRGPIO_IPOL_POL_SET(_reg, _val)
#define GRGPIO_IPOL_POL(_val)
#define GRGPIO_IEDGE_EDGE_SHIFT   0
#define GRGPIO_IEDGE_EDGE_MASK   0xffffffffU
#define GRGPIO_IEDGE_EDGE_GET(_reg)
#define GRGPIO_IEDGE_EDGE_SET(_reg, _val)
#define GRGPIO_IEDGE_EDGE(_val)
#define GRGPIO_BYPASS_BYPASS_SHIFT   0
#define GRGPIO_BYPASS_BYPASS_MASK   0xffffffffU
#define GRGPIO_BYPASS_BYPASS_GET(_reg)
#define GRGPIO_BYPASS_BYPASS_SET(_reg, _val)
#define GRGPIO_BYPASS_BYPASS(_val)
#define GRGPIO_CAP_PU   0x40000U
#define GRGPIO_CAP_IER   0x20000U
#define GRGPIO_CAP_IFL   0x10000U
#define GRGPIO_CAP_IRQGEN_SHIFT   8
#define GRGPIO_CAP_IRQGEN_MASK   0x1f00U
#define GRGPIO_CAP_IRQGEN_GET(_reg)
#define GRGPIO_CAP_IRQGEN_SET(_reg, _val)
#define GRGPIO_CAP_IRQGEN(_val)
#define GRGPIO_CAP_NLINES_SHIFT   0
#define GRGPIO_CAP_NLINES_MASK   0x1fU
#define GRGPIO_CAP_NLINES_GET(_reg)
#define GRGPIO_CAP_NLINES_SET(_reg, _val)
#define GRGPIO_CAP_NLINES(_val)
#define GRGPIO_IRQMAPR_IRQMAP_I_0_SHIFT   24
#define GRGPIO_IRQMAPR_IRQMAP_I_0_MASK   0x1f000000U
#define GRGPIO_IRQMAPR_IRQMAP_I_0_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_0_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_0(_val)
#define GRGPIO_IRQMAPR_IRQMAP_I_1_SHIFT   16
#define GRGPIO_IRQMAPR_IRQMAP_I_1_MASK   0x1f0000U
#define GRGPIO_IRQMAPR_IRQMAP_I_1_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_1_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_1(_val)
#define GRGPIO_IRQMAPR_IRQMAP_I_2_SHIFT   8
#define GRGPIO_IRQMAPR_IRQMAP_I_2_MASK   0x1f00U
#define GRGPIO_IRQMAPR_IRQMAP_I_2_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_2_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_2(_val)
#define GRGPIO_IRQMAPR_IRQMAP_I_3_SHIFT   0
#define GRGPIO_IRQMAPR_IRQMAP_I_3_MASK   0x1fU
#define GRGPIO_IRQMAPR_IRQMAP_I_3_GET(_reg)
#define GRGPIO_IRQMAPR_IRQMAP_I_3_SET(_reg, _val)
#define GRGPIO_IRQMAPR_IRQMAP_I_3(_val)
#define GRGPIO_IAVAIL_IMASK_SHIFT   0
#define GRGPIO_IAVAIL_IMASK_MASK   0xffffffffU
#define GRGPIO_IAVAIL_IMASK_GET(_reg)
#define GRGPIO_IAVAIL_IMASK_SET(_reg, _val)
#define GRGPIO_IAVAIL_IMASK(_val)
#define GRGPIO_IFLAG_IFLAG_SHIFT   0
#define GRGPIO_IFLAG_IFLAG_MASK   0xffffffffU
#define GRGPIO_IFLAG_IFLAG_GET(_reg)
#define GRGPIO_IFLAG_IFLAG_SET(_reg, _val)
#define GRGPIO_IFLAG_IFLAG(_val)
#define GRGPIO_IPEN_IPEN_SHIFT   0
#define GRGPIO_IPEN_IPEN_MASK   0xffffffffU
#define GRGPIO_IPEN_IPEN_GET(_reg)
#define GRGPIO_IPEN_IPEN_SET(_reg, _val)
#define GRGPIO_IPEN_IPEN(_val)
#define GRGPIO_PULSE_PULSE_SHIFT   0
#define GRGPIO_PULSE_PULSE_MASK   0xffffffffU
#define GRGPIO_PULSE_PULSE_GET(_reg)
#define GRGPIO_PULSE_PULSE_SET(_reg, _val)
#define GRGPIO_PULSE_PULSE(_val)
#define GRGPIO_LOR_DATA_SHIFT   0
#define GRGPIO_LOR_DATA_MASK   0xffffffffU
#define GRGPIO_LOR_DATA_GET(_reg)
#define GRGPIO_LOR_DATA_SET(_reg, _val)
#define GRGPIO_LOR_DATA(_val)
#define GRGPIO_LAND_DATA_SHIFT   0
#define GRGPIO_LAND_DATA_MASK   0xffffffffU
#define GRGPIO_LAND_DATA_GET(_reg)
#define GRGPIO_LAND_DATA_SET(_reg, _val)
#define GRGPIO_LAND_DATA(_val)
#define GRGPIO_LXOR_DATA_SHIFT   0
#define GRGPIO_LXOR_DATA_MASK   0xffffffffU
#define GRGPIO_LXOR_DATA_GET(_reg)
#define GRGPIO_LXOR_DATA_SET(_reg, _val)
#define GRGPIO_LXOR_DATA(_val)
typedef struct grgpio grgpio
