RTEMS 6.1
GR1553B BC per-RT Bus swap register (BCBS)
This group contains register bit definitions. More...
#define GR1553B_BCBS_SWAP_SHIFT   0
#define GR1553B_BCBS_SWAP_MASK   0xffffffffU
#define GR1553B_BCBS_SWAP_GET(_reg)
#define GR1553B_BCBS_SWAP_SET(_reg, _val)
#define GR1553B_BCBS_SWAP(_val)
◆ GR1553B_BCBS_SWAP
#define GR1553B_BCBS_SWAP (   _val)
Value:
( ( ( _val ) << GR1553B_BCBS_SWAP_SHIFT ) & \
GR1553B_BCBS_SWAP_MASK )
◆ GR1553B_BCBS_SWAP_GET
#define GR1553B_BCBS_SWAP_GET (   _reg)
Value:
( ( ( _reg ) & GR1553B_BCBS_SWAP_MASK ) >> \
◆ GR1553B_BCBS_SWAP_SET
#define GR1553B_BCBS_SWAP_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR1553B_BCBS_SWAP_MASK ) | \
GR1553B_BCBS_SWAP_MASK ) )
