RTEMS 6.1
This group contains the GR1553B interfaces. More...
Modules | |
| GR1553B BC Action Register (BCA) | |
| This group contains register bit definitions. | |
| GR1553B BC Asynchronous list current slot pointer (BCACP) | |
| GR1553B BC Asynchronous list next pointer register (BCANP) | |
| GR1553B BC Status and Config Register (BCSC) | |
| GR1553B BC Timer register (BCT) | |
| GR1553B BC Transfer list current slot pointer (BCTCP) | |
| GR1553B BC Transfer list next pointer register (BCTNP) | |
| GR1553B BC Transfer-triggered IRQ ring position register (BCRP) | |
| GR1553B BC per-RT Bus swap register (BCBS) | |
| GR1553B BM Control register (BMC) | |
| GR1553B BM Log buffer end (BMLBE) | |
| GR1553B BM Log buffer position (BMLBP) | |
| GR1553B BM Log buffer start (BMLBS) | |
| GR1553B BM RT Address filter register (BMRTAF) | |
| GR1553B BM RT Mode code filter register (BMRTMC) | |
| GR1553B BM RT Subaddress filter register (BMRTSF) | |
| GR1553B BM Status register (BMS) | |
| GR1553B BM Time tag control register (BMTTC) | |
| GR1553B Hardware Configuration Register (HC) | |
| GR1553B IRQ Enable Register (IRQE) | |
| GR1553B IRQ Register (IRQ) | |
| GR1553B RT Bus status register (RTBS) | |
| GR1553B RT Config register (RTC) | |
| GR1553B RT Event Log interrupt position register (RTELIP) | |
| GR1553B RT Event log position register (RTELP) | |
| GR1553B RT Event log size mask register (RTELM) | |
| GR1553B RT Mode code control register (RTMCC) | |
| GR1553B RT Status register (RTS) | |
| GR1553B RT Status words register (RTSW) | |
| GR1553B RT Subaddress table base address register (RTSTBA) | |
| GR1553B RT Sync register (RTSY) | |
| GR1553B RT Time tag control register (RTTTC) | |
Files | |
| file | gr1553b-regs.h |
| This header file defines the GR1553B register block interface. | |
| struct | gr1553b |
| This structure defines the GR1553B register block memory map. More... | |
Typedefs | |
| typedef struct gr1553b | gr1553b |
| This structure defines the GR1553B register block memory map. | |
