RTEMS 6.1
Data Structures | Macros | Typedefs
gr1553b-regs.h File Reference
This header file defines the GR1553B register block interface. More...
#include <stdint.h>
struct  gr1553b
 This structure defines the GR1553B register block memory map. More...
#define GR1553B_IRQ_BMTOF   0x20000U
#define GR1553B_IRQ_BMD   0x10000U
#define GR1553B_IRQ_RTTE   0x400U
#define GR1553B_IRQ_RTD   0x200U
#define GR1553B_IRQ_RTEV   0x100U
#define GR1553B_IRQ_BCWK   0x4U
#define GR1553B_IRQ_BCD   0x2U
#define GR1553B_IRQ_BCEV   0x1U
#define GR1553B_IRQE_BMTOE   0x20000U
#define GR1553B_IRQE_BMDE   0x10000U
#define GR1553B_IRQE_RTTEE   0x400U
#define GR1553B_IRQE_RTDE   0x200U
#define GR1553B_IRQE_RTEVE   0x100U
#define GR1553B_IRQE_BCWKE   0x4U
#define GR1553B_IRQE_BCDE   0x2U
#define GR1553B_IRQE_BCEVE   0x1U
#define GR1553B_HC_MOD   0x80000000U
#define GR1553B_HC_CVER   0x1000U
#define GR1553B_HC_XKEYS   0x800U
#define GR1553B_HC_ENDIAN_SHIFT   9
#define GR1553B_HC_ENDIAN_MASK   0x600U
#define GR1553B_HC_ENDIAN_GET(_reg)
#define GR1553B_HC_ENDIAN_SET(_reg, _val)
#define GR1553B_HC_ENDIAN(_val)
#define GR1553B_HC_SCLK   0x100U
#define GR1553B_HC_CCFREQ_SHIFT   0
#define GR1553B_HC_CCFREQ_MASK   0xffU
#define GR1553B_HC_CCFREQ_GET(_reg)
#define GR1553B_HC_CCFREQ_SET(_reg, _val)
#define GR1553B_HC_CCFREQ(_val)
#define GR1553B_BCSC_BCSUP   0x80000000U
#define GR1553B_BCSC_BCFEAT_SHIFT   28
#define GR1553B_BCSC_BCFEAT_MASK   0x70000000U
#define GR1553B_BCSC_BCFEAT_GET(_reg)
#define GR1553B_BCSC_BCFEAT_SET(_reg, _val)
#define GR1553B_BCSC_BCFEAT(_val)
#define GR1553B_BCSC_BCCHK   0x10000U
#define GR1553B_BCSC_ASADL_SHIFT   11
#define GR1553B_BCSC_ASADL_MASK   0xf800U
#define GR1553B_BCSC_ASADL_GET(_reg)
#define GR1553B_BCSC_ASADL_SET(_reg, _val)
#define GR1553B_BCSC_ASADL(_val)
#define GR1553B_BCSC_ASST_SHIFT   8
#define GR1553B_BCSC_ASST_MASK   0x300U
#define GR1553B_BCSC_ASST_GET(_reg)
#define GR1553B_BCSC_ASST_SET(_reg, _val)
#define GR1553B_BCSC_ASST(_val)
#define GR1553B_BCSC_SCADL_SHIFT   3
#define GR1553B_BCSC_SCADL_MASK   0xf8U
#define GR1553B_BCSC_SCADL_GET(_reg)
#define GR1553B_BCSC_SCADL_SET(_reg, _val)
#define GR1553B_BCSC_SCADL(_val)
#define GR1553B_BCSC_SCST_SHIFT   0
#define GR1553B_BCSC_SCST_MASK   0x7U
#define GR1553B_BCSC_SCST_GET(_reg)
#define GR1553B_BCSC_SCST_SET(_reg, _val)
#define GR1553B_BCSC_SCST(_val)
#define GR1553B_BCA_BCKEY_SHIFT   16
#define GR1553B_BCA_BCKEY_MASK   0xffff0000U
#define GR1553B_BCA_BCKEY_GET(_reg)
#define GR1553B_BCA_BCKEY_SET(_reg, _val)
#define GR1553B_BCA_BCKEY(_val)
#define GR1553B_BCA_ASSTP   0x200U
#define GR1553B_BCA_ASSRT   0x100U
#define GR1553B_BCA_CLRT   0x10U
#define GR1553B_BCA_SETT   0x8U
#define GR1553B_BCA_SCSTP   0x4U
#define GR1553B_BCA_SCSUS   0x2U
#define GR1553B_BCA_SCSRT   0x1U
#define GR1553B_BCTNP_POINTER_SHIFT   0
#define GR1553B_BCTNP_POINTER_MASK   0xffffffffU
#define GR1553B_BCTNP_POINTER_GET(_reg)
#define GR1553B_BCTNP_POINTER_SET(_reg, _val)
#define GR1553B_BCTNP_POINTER(_val)
#define GR1553B_BCANP_POINTER_SHIFT   0
#define GR1553B_BCANP_POINTER_MASK   0xffffffffU
#define GR1553B_BCANP_POINTER_GET(_reg)
#define GR1553B_BCANP_POINTER_SET(_reg, _val)
#define GR1553B_BCANP_POINTER(_val)
#define GR1553B_BCT_SCTM_SHIFT   0
#define GR1553B_BCT_SCTM_MASK   0xffffffU
#define GR1553B_BCT_SCTM_GET(_reg)
#define GR1553B_BCT_SCTM_SET(_reg, _val)
#define GR1553B_BCT_SCTM(_val)
#define GR1553B_BCRP_POSITION_SHIFT   0
#define GR1553B_BCRP_POSITION_MASK   0xffffffffU
#define GR1553B_BCRP_POSITION_GET(_reg)
#define GR1553B_BCRP_POSITION_SET(_reg, _val)
#define GR1553B_BCRP_POSITION(_val)
#define GR1553B_BCBS_SWAP_SHIFT   0
#define GR1553B_BCBS_SWAP_MASK   0xffffffffU
#define GR1553B_BCBS_SWAP_GET(_reg)
#define GR1553B_BCBS_SWAP_SET(_reg, _val)
#define GR1553B_BCBS_SWAP(_val)
#define GR1553B_BCTCP_POINTER_SHIFT   0
#define GR1553B_BCTCP_POINTER_MASK   0xffffffffU
#define GR1553B_BCTCP_POINTER_GET(_reg)
#define GR1553B_BCTCP_POINTER_SET(_reg, _val)
#define GR1553B_BCTCP_POINTER(_val)
#define GR1553B_BCACP_POINTER_SHIFT   0
#define GR1553B_BCACP_POINTER_MASK   0xffffffffU
#define GR1553B_BCACP_POINTER_GET(_reg)
#define GR1553B_BCACP_POINTER_SET(_reg, _val)
#define GR1553B_BCACP_POINTER(_val)
#define GR1553B_RTS_RTSUP   0x80000000U
#define GR1553B_RTS_ACT   0x8U
#define GR1553B_RTS_SHDA   0x4U
#define GR1553B_RTS_SHDB   0x2U
#define GR1553B_RTS_RUN   0x1U
#define GR1553B_RTC_RTKEY_SHIFT   16
#define GR1553B_RTC_RTKEY_MASK   0xffff0000U
#define GR1553B_RTC_RTKEY_GET(_reg)
#define GR1553B_RTC_RTKEY_SET(_reg, _val)
#define GR1553B_RTC_RTKEY(_val)
#define GR1553B_RTC_SYS   0x8000U
#define GR1553B_RTC_SYDS   0x4000U
#define GR1553B_RTC_BRS   0x2000U
#define GR1553B_RTC_RTEIS   0x40U
#define GR1553B_RTC_RTADDR_SHIFT   1
#define GR1553B_RTC_RTADDR_MASK   0x3eU
#define GR1553B_RTC_RTADDR_GET(_reg)
#define GR1553B_RTC_RTADDR_SET(_reg, _val)
#define GR1553B_RTC_RTADDR(_val)
#define GR1553B_RTC_RTEN   0x1U
#define GR1553B_RTBS_TFDE   0x100U
#define GR1553B_RTBS_SREQ   0x10U
#define GR1553B_RTBS_BUSY   0x8U
#define GR1553B_RTBS_SSF   0x4U
#define GR1553B_RTBS_DBCA   0x2U
#define GR1553B_RTBS_TFLG   0x1U
#define GR1553B_RTSW_BITW_SHIFT   16
#define GR1553B_RTSW_BITW_MASK   0xffff0000U
#define GR1553B_RTSW_BITW_GET(_reg)
#define GR1553B_RTSW_BITW_SET(_reg, _val)
#define GR1553B_RTSW_BITW(_val)
#define GR1553B_RTSW_VECW_SHIFT   0
#define GR1553B_RTSW_VECW_MASK   0xffffU
#define GR1553B_RTSW_VECW_GET(_reg)
#define GR1553B_RTSW_VECW_SET(_reg, _val)
#define GR1553B_RTSW_VECW(_val)
#define GR1553B_RTSY_SYTM_SHIFT   16
#define GR1553B_RTSY_SYTM_MASK   0xffff0000U
#define GR1553B_RTSY_SYTM_GET(_reg)
#define GR1553B_RTSY_SYTM_SET(_reg, _val)
#define GR1553B_RTSY_SYTM(_val)
#define GR1553B_RTSY_SYD_SHIFT   0
#define GR1553B_RTSY_SYD_MASK   0xffffU
#define GR1553B_RTSY_SYD_GET(_reg)
#define GR1553B_RTSY_SYD_SET(_reg, _val)
#define GR1553B_RTSY_SYD(_val)
#define GR1553B_RTSTBA_SATB_SHIFT   9
#define GR1553B_RTSTBA_SATB_MASK   0xfffffe00U
#define GR1553B_RTSTBA_SATB_GET(_reg)
#define GR1553B_RTSTBA_SATB_SET(_reg, _val)
#define GR1553B_RTSTBA_SATB(_val)
#define GR1553B_RTMCC_RRTB_SHIFT   28
#define GR1553B_RTMCC_RRTB_MASK   0x30000000U
#define GR1553B_RTMCC_RRTB_GET(_reg)
#define GR1553B_RTMCC_RRTB_SET(_reg, _val)
#define GR1553B_RTMCC_RRTB(_val)
#define GR1553B_RTMCC_RRT_SHIFT   26
#define GR1553B_RTMCC_RRT_MASK   0xc000000U
#define GR1553B_RTMCC_RRT_GET(_reg)
#define GR1553B_RTMCC_RRT_SET(_reg, _val)
#define GR1553B_RTMCC_RRT(_val)
#define GR1553B_RTMCC_ITFB_SHIFT   24
#define GR1553B_RTMCC_ITFB_MASK   0x3000000U
#define GR1553B_RTMCC_ITFB_GET(_reg)
#define GR1553B_RTMCC_ITFB_SET(_reg, _val)
#define GR1553B_RTMCC_ITFB(_val)
#define GR1553B_RTMCC_ITF_SHIFT   22
#define GR1553B_RTMCC_ITF_MASK   0xc00000U
#define GR1553B_RTMCC_ITF_GET(_reg)
#define GR1553B_RTMCC_ITF_SET(_reg, _val)
#define GR1553B_RTMCC_ITF(_val)
#define GR1553B_RTMCC_ISTB_SHIFT   20
#define GR1553B_RTMCC_ISTB_MASK   0x300000U
#define GR1553B_RTMCC_ISTB_GET(_reg)
#define GR1553B_RTMCC_ISTB_SET(_reg, _val)
#define GR1553B_RTMCC_ISTB(_val)
#define GR1553B_RTMCC_IST_SHIFT   18
#define GR1553B_RTMCC_IST_MASK   0xc0000U
#define GR1553B_RTMCC_IST_GET(_reg)
#define GR1553B_RTMCC_IST_SET(_reg, _val)
#define GR1553B_RTMCC_IST(_val)
#define GR1553B_RTMCC_DBC_SHIFT   16
#define GR1553B_RTMCC_DBC_MASK   0x30000U
#define GR1553B_RTMCC_DBC_GET(_reg)
#define GR1553B_RTMCC_DBC_SET(_reg, _val)
#define GR1553B_RTMCC_DBC(_val)
#define GR1553B_RTMCC_TBW_SHIFT   14
#define GR1553B_RTMCC_TBW_MASK   0xc000U
#define GR1553B_RTMCC_TBW_GET(_reg)
#define GR1553B_RTMCC_TBW_SET(_reg, _val)
#define GR1553B_RTMCC_TBW(_val)
#define GR1553B_RTMCC_TVW_SHIFT   12
#define GR1553B_RTMCC_TVW_MASK   0x3000U
#define GR1553B_RTMCC_TVW_GET(_reg)
#define GR1553B_RTMCC_TVW_SET(_reg, _val)
#define GR1553B_RTMCC_TVW(_val)
#define GR1553B_RTMCC_TSB_SHIFT   10
#define GR1553B_RTMCC_TSB_MASK   0xc00U
#define GR1553B_RTMCC_TSB_GET(_reg)
#define GR1553B_RTMCC_TSB_SET(_reg, _val)
#define GR1553B_RTMCC_TSB(_val)
#define GR1553B_RTMCC_TS_SHIFT   8
#define GR1553B_RTMCC_TS_MASK   0x300U
#define GR1553B_RTMCC_TS_GET(_reg)
#define GR1553B_RTMCC_TS_SET(_reg, _val)
#define GR1553B_RTMCC_TS(_val)
#define GR1553B_RTMCC_SDB_SHIFT   6
#define GR1553B_RTMCC_SDB_MASK   0xc0U
#define GR1553B_RTMCC_SDB_GET(_reg)
#define GR1553B_RTMCC_SDB_SET(_reg, _val)
#define GR1553B_RTMCC_SDB(_val)
#define GR1553B_RTMCC_SD_SHIFT   4
#define GR1553B_RTMCC_SD_MASK   0x30U
#define GR1553B_RTMCC_SD_GET(_reg)
#define GR1553B_RTMCC_SD_SET(_reg, _val)
#define GR1553B_RTMCC_SD(_val)
#define GR1553B_RTMCC_SB_SHIFT   2
#define GR1553B_RTMCC_SB_MASK   0xcU
#define GR1553B_RTMCC_SB_GET(_reg)
#define GR1553B_RTMCC_SB_SET(_reg, _val)
#define GR1553B_RTMCC_SB(_val)
#define GR1553B_RTMCC_S_SHIFT   0
#define GR1553B_RTMCC_S_MASK   0x3U
#define GR1553B_RTMCC_S_GET(_reg)
#define GR1553B_RTMCC_S_SET(_reg, _val)
#define GR1553B_RTMCC_S(_val)
#define GR1553B_RTTTC_TRES_SHIFT   16
#define GR1553B_RTTTC_TRES_MASK   0xffff0000U
#define GR1553B_RTTTC_TRES_GET(_reg)
#define GR1553B_RTTTC_TRES_SET(_reg, _val)
#define GR1553B_RTTTC_TRES(_val)
#define GR1553B_RTTTC_TVAL_SHIFT   0
#define GR1553B_RTTTC_TVAL_MASK   0xffffU
#define GR1553B_RTTTC_TVAL_GET(_reg)
#define GR1553B_RTTTC_TVAL_SET(_reg, _val)
#define GR1553B_RTTTC_TVAL(_val)
#define GR1553B_RTELM_MASK_SHIFT   0
#define GR1553B_RTELM_MASK_MASK   0xffffffffU
#define GR1553B_RTELM_MASK_GET(_reg)
#define GR1553B_RTELM_MASK_SET(_reg, _val)
#define GR1553B_RTELM_MASK(_val)
#define GR1553B_RTELP_POINTER_SHIFT   0
#define GR1553B_RTELP_POINTER_MASK   0xffffffffU
#define GR1553B_RTELP_POINTER_GET(_reg)
#define GR1553B_RTELP_POINTER_SET(_reg, _val)
#define GR1553B_RTELP_POINTER(_val)
#define GR1553B_RTELIP_POINTER_SHIFT   0
#define GR1553B_RTELIP_POINTER_MASK   0xffffffffU
#define GR1553B_RTELIP_POINTER_GET(_reg)
#define GR1553B_RTELIP_POINTER_SET(_reg, _val)
#define GR1553B_RTELIP_POINTER(_val)
#define GR1553B_BMS_BMSUP   0x80000000U
#define GR1553B_BMS_KEYEN   0x40000000U
#define GR1553B_BMC_BMKEY_SHIFT   16
#define GR1553B_BMC_BMKEY_MASK   0xffff0000U
#define GR1553B_BMC_BMKEY_GET(_reg)
#define GR1553B_BMC_BMKEY_SET(_reg, _val)
#define GR1553B_BMC_BMKEY(_val)
#define GR1553B_BMC_WRSTP   0x20U
#define GR1553B_BMC_EXST   0x10U
#define GR1553B_BMC_IMCL   0x8U
#define GR1553B_BMC_UDWL   0x4U
#define GR1553B_BMC_MANL   0x2U
#define GR1553B_BMC_BMEN   0x1U
#define GR1553B_BMRTAF_MASK_SHIFT   0
#define GR1553B_BMRTAF_MASK_MASK   0xffffffffU
#define GR1553B_BMRTAF_MASK_GET(_reg)
#define GR1553B_BMRTAF_MASK_SET(_reg, _val)
#define GR1553B_BMRTAF_MASK(_val)
#define GR1553B_BMRTSF_MASK_SHIFT   0
#define GR1553B_BMRTSF_MASK_MASK   0xffffffffU
#define GR1553B_BMRTSF_MASK_GET(_reg)
#define GR1553B_BMRTSF_MASK_SET(_reg, _val)
#define GR1553B_BMRTSF_MASK(_val)
#define GR1553B_BMRTMC_STSB   0x40000U
#define GR1553B_BMRTMC_STS   0x20000U
#define GR1553B_BMRTMC_TLC   0x10000U
#define GR1553B_BMRTMC_TSW   0x8000U
#define GR1553B_BMRTMC_RRTB   0x4000U
#define GR1553B_BMRTMC_RRT   0x2000U
#define GR1553B_BMRTMC_ITFB   0x1000U
#define GR1553B_BMRTMC_ITF   0x800U
#define GR1553B_BMRTMC_ISTB   0x400U
#define GR1553B_BMRTMC_IST   0x200U
#define GR1553B_BMRTMC_DBC   0x100U
#define GR1553B_BMRTMC_TBW   0x80U
#define GR1553B_BMRTMC_TVW   0x40U
#define GR1553B_BMRTMC_TSB   0x20U
#define GR1553B_BMRTMC_TS   0x10U
#define GR1553B_BMRTMC_SDB   0x8U
#define GR1553B_BMRTMC_SD   0x4U
#define GR1553B_BMRTMC_SB   0x2U
#define GR1553B_BMRTMC_S   0x1U
#define GR1553B_BMLBS_START_SHIFT   0
#define GR1553B_BMLBS_START_MASK   0xffffffffU
#define GR1553B_BMLBS_START_GET(_reg)
#define GR1553B_BMLBS_START_SET(_reg, _val)
#define GR1553B_BMLBS_START(_val)
#define GR1553B_BMLBE_END_SHIFT   0
#define GR1553B_BMLBE_END_MASK   0xffffffffU
#define GR1553B_BMLBE_END_GET(_reg)
#define GR1553B_BMLBE_END_SET(_reg, _val)
#define GR1553B_BMLBE_END(_val)
#define GR1553B_BMLBP_POSITION_SHIFT   0
#define GR1553B_BMLBP_POSITION_MASK   0xffffffffU
#define GR1553B_BMLBP_POSITION_GET(_reg)
#define GR1553B_BMLBP_POSITION_SET(_reg, _val)
#define GR1553B_BMLBP_POSITION(_val)
#define GR1553B_BMTTC_TRES_SHIFT   24
#define GR1553B_BMTTC_TRES_MASK   0xff000000U
#define GR1553B_BMTTC_TRES_GET(_reg)
#define GR1553B_BMTTC_TRES_SET(_reg, _val)
#define GR1553B_BMTTC_TRES(_val)
#define GR1553B_BMTTC_TVAL_SHIFT   0
#define GR1553B_BMTTC_TVAL_MASK   0xffffffU
#define GR1553B_BMTTC_TVAL_GET(_reg)
#define GR1553B_BMTTC_TVAL_SET(_reg, _val)
#define GR1553B_BMTTC_TVAL(_val)
typedef struct gr1553b gr1553b
