RTEMS 6.1
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
MVME162 Board Support Package. More...
file  bsp.h
 Global BSP definitions.
struct  mcchip_regs
struct  scc_regs
struct  memc040_regs_
struct  cd2401_regs_
#define mcchip   ((mcchip_regs * const) 0xFFF42000)
#define TX_BUFFER_EMPTY   0x04
#define RX_DATA_AVAILABLE   0x01
#define SCC_VECTOR   0x40
#define scc   ((scc_regs * const) 0xFFF45000)
#define ZWRITE0(port, v)   (scc[port].csr = (unsigned char)(v))
#define ZREAD0(port)   (scc[port].csr)
#define ZREAD(port, n)   (ZWRITE0(port, n), (scc[port].csr))
#define ZREADD(port)   (scc[port].csr=0x08, scc[port].csr )
#define ZWRITE(port, n, v)   (ZWRITE0(port, n), ZWRITE0(port, v))
#define ZWRITED(port, v)
#define EXTERN   extern
#define MOT_162BUG_VEC_ADDRESS   0x00000000
#define memc040_1   ((memc040_regs * const) 0xFFF43000)
#define memc040_2   ((memc040_regs * const) 0xFFF43100)
#define cd2401   ((cd2401_regs * const) 0xFFF45000)
#define CD2401_CLK_RATE   20000000
typedef volatile struct memc040_regs_ memc040_regs
typedef volatile struct cd2401_regs_ cd2401_regs
enum  { portB , portA }
bool char_ready (int port, char *ch)
char char_wait (int port)
void char_put (int port, char ch)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
rtems_isr_entry M68Kvec []
void * M68Kvec []
MVME167 Board Support Package.
◆ ZWRITED
#define ZWRITED (   port,
Value:
(scc[port].csr = 0x08, \
Definition: 8xx_immap.h:306
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
