RTEMS 6.1
Data Structures | Macros | Enumerations | Functions | Variables
Global BSP definitions. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <mvme16x_hw.h>
struct  mcchip_regs
struct  scc_regs
#define mcchip   ((mcchip_regs * const) 0xFFF42000)
#define TX_BUFFER_EMPTY   0x04
#define RX_DATA_AVAILABLE   0x01
#define SCC_VECTOR   0x40
#define scc   ((scc_regs * const) 0xFFF45000)
#define ZWRITE0(port, v)   (scc[port].csr = (unsigned char)(v))
#define ZREAD0(port)   (scc[port].csr)
#define ZREAD(port, n)   (ZWRITE0(port, n), (scc[port].csr))
#define ZREADD(port)   (scc[port].csr=0x08, scc[port].csr )
#define ZWRITE(port, n, v)   (ZWRITE0(port, n), ZWRITE0(port, v))
#define ZWRITED(port, v)
#define EXTERN   extern
#define MOT_162BUG_VEC_ADDRESS   0x00000000
enum  { portB , portA }
bool char_ready (int port, char *ch)
char char_wait (int port)
void char_put (int port, char ch)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
rtems_isr_entry M68Kvec []
