RTEMS 6.1
mvme16x_hw.h
2
11/* mvme16x_hw.h
12 *
13 * This include file contains all MVME16x board IO definitions
14 * and was derived by combining the common items in the
15 * mvme162 and mvme167 BSPs.
16 *
17 * COPYRIGHT (c) 1989-2000.
18 * On-Line Applications Research Corporation (OAR).
19 *
20 * Redistribution and use in source and binary forms, with or without
21 * modification, are permitted provided that the following conditions
22 * are met:
23 * 1. Redistributions of source code must retain the above copyright
24 * notice, this list of conditions and the following disclaimer.
25 * 2. Redistributions in binary form must reproduce the above copyright
26 * notice, this list of conditions and the following disclaimer in the
27 * documentation and/or other materials provided with the distribution.
28 *
29 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
30 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
31 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
32 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
33 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
34 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
35 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
36 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
37 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
38 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
39 * POSSIBILITY OF SUCH DAMAGE.
40 */
41
42#ifndef __MVME16xHW_h
43#define __MVME16xHW_h
44
45#include <bsp.h>
46
47#ifdef __cplusplus
48extern "C" {
49#endif
50
59struct rtems_bsdnet_ifconfig;
60int uti596_attach(struct rtems_bsdnet_ifconfig * pConfig, int attaching );
61#define RTEMS_BSP_NETWORK_DRIVER_NAME "uti1"
62#define RTEMS_BSP_NETWORK_DRIVER_ATTACH uti596_attach
63
64/*
65 * This is NOT the base address of local RAM!
66 * This is the base local address of the VMEbus short I/O space. A local
67 * access to this space results in a A16 VMEbus I/O cycle. This base address
68 * is NOT configurable on the MVME167, although the types of VMEbus short I/O
69 * cycles generated when a cycle in the local 0xFFFF0000-0xFFFFFFFF address
70 * range is generated is under control of bits 8-15 of LCSR 0xFFF4002C. The
71 * GCSRs of other boards are accessible only through the VMEbus short I/O
72 * space. See pages 2-45 and 2-7.
73 */
74#define BOARD_BASE_ADDRESS 0xFFFF0000
75
76/*
77 * This address must be added to the BOARD_BASE_ADDRESS to access the GCSR of
78 * other MVMEs in the group, i.e. it represents the offset of the GCSRs in the
79 * VMEbus short I/O space. It also should represent the group address of this
80 * MVME167! The group address is configurable, and must match the address
81 * programmed into the MVME167 through the 167Bug monitor. 0xCC is the address
82 * recommended by Motorola. It is arbitrary.
83 * See pages 2-42 and 2-97 to 2-104.
84 */
85#define GROUP_BASE_ADDRESS 0x0000CC00
86
87/*
88 * Representation of the VMEchip2 LCSR.
89 * Could be made more detailed.
90 */
91
92typedef volatile struct {
93 unsigned long slave_adr[2];
94 unsigned long slave_trn[2];
95 unsigned long slave_ctl;
96 unsigned long mastr_adr[4];
97 unsigned long mastr_trn;
98 unsigned long mastr_att;
99 unsigned long mastr_ctl;
100 unsigned long dma_ctl_1;
101 unsigned long dma_ctl_2;
102 unsigned long dma_loc_cnt;
103 unsigned long dma_vme_cnt;
104 unsigned long dma_byte_cnt;
105 unsigned long dma_adr_cnt;
106 unsigned long dma_status;
107 unsigned long to_ctl;
108 unsigned long timer_cmp_1;
109 unsigned long timer_cnt_1;
110 unsigned long timer_cmp_2;
111 unsigned long timer_cnt_2;
112 unsigned long board_ctl;
113 unsigned long prescaler_cnt;
114 unsigned long intr_stat;
115 unsigned long intr_ena;
116 unsigned long intr_soft_set;
117 unsigned long intr_clear;
118 unsigned long intr_level[4];
119 unsigned long vector_base;
120} lcsr_regs;
121
122/*
123 * Base address of VMEchip2 LCSR
124 * Not configurable on the MVME167.
125 * XXX what about 162?
126 */
127#define lcsr ((lcsr_regs * const) 0xFFF40000)
128
129/*
130 * Vector numbers for the interrupts from the VMEchip2. Use the values
131 * "recommended" by Motorola.
132 * See pages 2-70 to 2-92, and table 2-3.
133 */
134
135/* MIEN (Master Interrupt Enable) bit in LCSR 0xFFF40088. */
136#define MASK_INT 0x00800000
137
138/* The content of VBR0 corresponds to "X" in table 2-3 */
139#define VBR0 0x6
140
141/* The content of VBR1 corresponds to "Y" in table 2-3 */
142#define VBR1 0x7
143
144/*
145 * Representation of the PCCchip2
146 */
147typedef volatile struct pccchip2_regs_ {
148 unsigned char chip_id; /* 0xFFF42000 */
149 unsigned char chip_revision; /* 0xFFF42001 */
150 unsigned char gen_control; /* 0xFFF42002 */
151 unsigned char vector_base; /* 0xFFF42003 */
152 unsigned long timer_cmp_1; /* 0xFFF42004 */
153 unsigned long timer_cnt_1; /* 0xFFF42008 */
154 unsigned long timer_cmp_2; /* 0xFFF4200C */
155 unsigned long timer_cnt_2; /* 0xFFF42010 */
156 unsigned char LSB_prescaler_count;/* 0xFFF42014 */
157 unsigned char prescaler_clock_adjust; /* 0xFFF42015 */
158 unsigned char timer_ctl_2; /* 0xFFF42016 */
159 unsigned char timer_ctl_1; /* 0xFFF42017 */
160 unsigned char gpi_int_ctl; /* 0xFFF42018 */
161 unsigned char gpio_ctl; /* 0xFFF42019 */
162 unsigned char timer_int_ctl_2; /* 0xFFF4201A */
163 unsigned char timer_int_ctl_1; /* 0xFFF4201B */
164 unsigned char SCC_error; /* 0xFFF4201C */
165 unsigned char SCC_modem_int_ctl; /* 0xFFF4201D */
166 unsigned char SCC_tx_int_ctl; /* 0xFFF4201E */
167 unsigned char SCC_rx_int_ctl; /* 0xFFF4201F */
168 unsigned char reserved1[3];
169 unsigned char modem_piack; /* 0xFFF42023 */
170 unsigned char reserved2;
171 unsigned char tx_piack; /* 0xFFF42025 */
172 unsigned char reserved3;
173 unsigned char rx_piack; /* 0xFFF42027 */
174 unsigned char LANC_error; /* 0xFFF42028 */
175 unsigned char reserved4;
176 unsigned char LANC_int_ctl; /* 0xFFF4202A */
177 unsigned char LANC_berr_ctl; /* 0xFFF4202B */
178 unsigned char SCSI_error; /* 0xFFF4202C */
179 unsigned char reserved5[2];
180 unsigned char SCSI_int_ctl; /* 0xFFF4202F */
181 unsigned char print_ack_int_ctl; /* 0xFFF42030 */
182 unsigned char print_fault_int_ctl;/* 0xFFF42031 */
183 unsigned char print_sel_int_ctl; /* 0xFFF42032 */
184 unsigned char print_pe_int_ctl; /* 0xFFF42033 */
185 unsigned char print_busy_int_ctl; /* 0xFFF42034 */
186 unsigned char reserved6;
187 unsigned char print_input_status; /* 0xFFF42036 */
188 unsigned char print_ctl; /* 0xFFF42037 */
189 unsigned char chip_speed; /* 0xFFF42038 */
190 unsigned char reserved7;
191 unsigned char print_data; /* 0xFFF4203A */
192 unsigned char reserved8[3];
193 unsigned char int_level; /* 0xFFF4203E */
194 unsigned char int_mask; /* 0xFFF4203F */
196
197/*
198 * Base address of the PCCchip2.
199 * This is not configurable in the MVME167.
200 */
201#define pccchip2 ((pccchip2_regs * const) 0xFFF42000)
202
203/*
204 * On the MVME162, we have the mcchip and the pccchip2 on
205 * the 167. They are similar but different enough where
206 * we have to reconcile them later.
207 */
208
209/*
210 * Vector numbers for the interrupts from the PCCchip2. Use the values
211 * "recommended" by Motorola.
212 * See page 3-15.
213 */
214#define PCCCHIP2_VBR 0x5
215
216/*
217 * The following registers are located in the VMEbus short
218 * IO space and respond to address modifier codes $29 and $2D.
219 * On FORCE CPU use address gcsr_vme and device /dev/vme16d32.
220 */
221
222typedef volatile struct {
223 unsigned char chip_revision;
224 unsigned char chip_id;
225 unsigned char lmsig;
226 unsigned char board_scr;
227 unsigned short gpr[6];
228} gcsr_regs;
229
230#define gcsr_vme ((gcsr_regs * const) (GROUP_BASE_ADDRESS + BOARD_BASE_ADDRESS))
231#define gcsr ((gcsr_regs * const) 0xFFF40100)
232
233/*
234 * Representation of 82596CA LAN controller: Memory Map
235 */
236typedef volatile struct i82596_regs_ {
237 unsigned short port_lower; /* 0xFFF46000 */
238 unsigned short port_upper; /* 0xFFF46002 */
239 unsigned long chan_attn; /* 0xFFF46004 */
241
242/*
243 * Base address of the 82596.
244 */
245
246#define i82596 ((i82596_regs * const) 0xFFF46000)
247
248/*
249 * Representation of initialization data in NVRAM
250 */
251
252#if defined(mvme167)
253typedef volatile struct nvram_config_ {
254 unsigned char cache_mode; /* 0xFFFC0000 */
255 unsigned char console_mode; /* 0xFFFC0001 */
256 unsigned char console_printk_port; /* 0xFFFC0002 */
257 unsigned char pad1; /* 0xFFFC0003 */
258 unsigned long ipaddr; /* 0xFFFC0004 */
259 unsigned long netmask; /* 0xFFFC0008 */
260 unsigned char enaddr[6]; /* 0xFFFC000C */
261 unsigned short processor_id; /* 0xFFFC0012 */
262 unsigned long rma_start; /* 0xFFFC0014 */
263 unsigned long vma_start; /* 0xFFFC0018 */
264 unsigned long ramsize; /* 0xFFFC001C */
265} nvram_config;
266
267/*
268 * Pointer to the base of User Area NVRAM
269 */
270
271#define nvram ((nvram_config * const) 0xFFFC0000)
272
273#endif
274
275/*
276 * Flag to indicate if J1-4 is on (and parameters should be
277 * sought in User Area NVRAM)
278 *
279 * NOTE: If NVRAM has bad settings, the you want to disable this
280 * on the MVME167.
281 */
282#if defined(mvme167)
283 #define NVRAM_CONFIGURE \
284 ( !( ( (unsigned char)(lcsr->vector_base & 0xFF) ) & 0x10 ) )
285#else
286 #define NVRAM_CONFIGURE 0
287#endif
288
289#ifdef __cplusplus
290}
291#endif
292
293#endif
Definition: mvme16x_hw.h:222
Definition: mvme16x_hw.h:236
Definition: mvme16x_hw.h:92
Definition: mvme16x_hw.h:147
