unsigned char | chip_id |
unsigned char | chip_revision |
unsigned char | gen_control |
unsigned char | vector_base |
unsigned long | timer_cmp_1 |
unsigned long | timer_cnt_1 |
unsigned long | timer_cmp_2 |
unsigned long | timer_cnt_2 |
unsigned char | LSB_prescaler_count |
unsigned char | prescaler_clock_adjust |
unsigned char | timer_ctl_2 |
unsigned char | timer_ctl_1 |
unsigned char | gpi_int_ctl |
unsigned char | gpio_ctl |
unsigned char | timer_int_ctl_2 |
unsigned char | timer_int_ctl_1 |
unsigned char | SCC_error |
unsigned char | SCC_modem_int_ctl |
unsigned char | SCC_tx_int_ctl |
unsigned char | SCC_rx_int_ctl |
unsigned char | reserved1 [3] |
unsigned char | modem_piack |
unsigned char | reserved2 |
unsigned char | tx_piack |
unsigned char | reserved3 |
unsigned char | rx_piack |
unsigned char | LANC_error |
unsigned char | reserved4 |
unsigned char | LANC_int_ctl |
unsigned char | LANC_berr_ctl |
unsigned char | SCSI_error |
unsigned char | reserved5 [2] |
unsigned char | SCSI_int_ctl |
unsigned char | print_ack_int_ctl |
unsigned char | print_fault_int_ctl |
unsigned char | print_sel_int_ctl |
unsigned char | print_pe_int_ctl |
unsigned char | print_busy_int_ctl |
unsigned char | reserved6 |
unsigned char | print_input_status |
unsigned char | print_ctl |
unsigned char | chip_speed |
unsigned char | reserved7 |
unsigned char | print_data |
unsigned char | reserved8 [3] |
unsigned char | int_level |
unsigned char | int_mask |
