RTEMS 6.1
Files | Data Structures | Macros | Functions | Variables
MVME147s Board Support Package. More...
file  bsp.h
 Global BSP definitions.
struct  pcc_map
struct  vme_lcsr_map
struct  vme_gcsr_map
#define RAM_START   0x00007000
#define RAM_END   0x003e0000
#define DRAM_END   0x00400000
#define pcc   ((volatile struct pcc_map * const) 0xfffe1000)
#define vme_lcsr   ((volatile struct vme_lcsr_map * const) 0xfffe2000)
#define vme_gcsr   ((volatile struct vme_gcsr_map * const) 0xfffe2020)
#define z8530   0xfffe3001
#define PCC_BASE_VECTOR   0x40 /* First user int */
#define SCC_VECTOR   PCC_BASE_VECTOR+3
#define TIMER_1_VECTOR   PCC_BASE_VECTOR+8
#define TIMER_2_VECTOR   PCC_BASE_VECTOR+9
#define SOFT_1_VECTOR   PCC_BASE_VECTOR+10
#define SOFT_2_VECTOR   PCC_BASE_VECTOR+11
#define VME_BASE_VECTOR   0x50
#define VME_SIGLP_VECTOR   VME_BASE_VECTOR+1
#define USE_CHANNEL_A   1 /* 1 = use channel A for console */
#define USE_CHANNEL_B   0 /* 1 = use channel B for console */
#define CONSOLE_CONTROL   0xfffe3002
#define CONSOLE_DATA   0xfffe3003
#define FOREVER   1 /* infinite loop */
#define EXTERN   extern
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
rtems_isr_entry M68Kvec []
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
