uint32_t | dma_table_address |
uint32_t | dma_data_address |
uint32_t | dma_bytecount |
uint32_t | dma_data_holding |
uint16_t | timer1_preload |
uint16_t | timer1_count |
uint16_t | timer2_preload |
uint16_t | timer2_count |
uint8_t | timer1_int_control |
uint8_t | timer1_control |
uint8_t | timer2_int_control |
uint8_t | timer2_control |
uint8_t | acfail_int_control |
uint8_t | watchdog_control |
uint8_t | printer_int_control |
uint8_t | printer_control |
uint8_t | dma_int_control |
uint8_t | dma_control |
uint8_t | bus_error_int_control |
uint8_t | dma_status |
uint8_t | abort_int_control |
uint8_t | table_address_function_code |
uint8_t | serial_port_int_control |
uint8_t | general_purpose_control |
uint8_t | lan_int_control |
uint8_t | general_purpose_status |
uint8_t | scsi_port_int_control |
uint8_t | slave_base_address |
uint8_t | software_int_1_control |
uint8_t | int_base_vector |
uint8_t | software_int_2_control |
uint8_t | revision_level |
The documentation for this struct was generated from the following files:
- bsps/m68k/mvme147/include/bsp.h
- bsps/m68k/mvme147s/include/bsp.h
