MCF5329 Board Support Package.
More...
| file | bsp.h |
| | Global BSP definitions.
#define | RTEMS_BSP_NETWORK_DRIVER_NAME "fec0" |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach |
| #define | CONSOLE_PORT 0 |
#define | FEC_IRQ_LEVEL 4 |
#define | PIT3_IRQ_LEVEL 4 |
#define | UART0_IRQ_LEVEL 3 |
#define | UART1_IRQ_LEVEL 3 |
#define | UART2_IRQ_LEVEL 3 |
| typedef volatile unsigned char | vuint8 |
typedef volatile unsigned short | vuint16 |
typedef volatile unsigned long | vuint32 |
◆ CONSOLE_PORT
User Definable configuration
◆ vuint8
| typedef volatile unsigned char vuint8 |
Hardware data structure headers
◆ set_vector()
Install an interrupt handler.
This method installs an interrupt handle.
- Parameters
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
- Returns
- returns old vector
