RTEMS 6.1
Macros | Typedefs | Functions
Global BSP definitions. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <rtems/bspIo.h>
#include <mcf532x/mcf532x.h>
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "fec0"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_fec_driver_attach
#define CONSOLE_PORT   0
#define FEC_IRQ_LEVEL   4
#define PIT3_IRQ_LEVEL   4
#define UART0_IRQ_LEVEL   3
#define UART1_IRQ_LEVEL   3
#define UART2_IRQ_LEVEL   3
typedef volatile unsigned char vuint8
typedef volatile unsigned short vuint16
typedef volatile unsigned long vuint32
int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
uint32_t bsp_get_CPU_clock_speed (void)
uint32_t bsp_get_BUS_clock_speed (void)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
void Init5329 (void)
