MCF548X Board Support Package.
More...
| file | bsp.h |
| | Global BSP definitions.
| file | tm27.h |
| | Time Test 27 routines.
| #define | CONSOLE_PORT 0 |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_mcf548x_fec_driver_attach_detach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME "fec1" |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME2 "fec2" |
uint32_t | get_CPU_clock_speed (void) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| | Install an interrupt handler.
int | rtems_mcf548x_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
void | bsp_cacr_set_flags (uint32_t flags) |
void | bsp_cacr_set_self_clear_flags (uint32_t flags) |
void | bsp_cacr_clear_flags (uint32_t flags) |
const uint8_t | mcf548x_intc_icr_init_values [64] |
◆ CONSOLE_PORT
Hardware data structure headers
User Definable configuration
◆ set_vector()
This method installs an interrupt handle.
- Parameters
| [in] | handler | is the isr routine |
| [in] | vector | is the vector number |
| [in] | type | indicates whether RTEMS or RAW intr |
- Returns
- returns old vector
