RTEMS 6.1
Global BSP definitions. More...
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#include <rtems/bspIo.h>
#include <mcf548x/mcf548x.h>
#define CONSOLE_PORT   0
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_mcf548x_fec_driver_attach_detach
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "fec1"
#define RTEMS_BSP_NETWORK_DRIVER_NAME2   "fec2"
uint32_t get_CPU_clock_speed (void)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
int rtems_mcf548x_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching)
void bsp_cacr_set_flags (uint32_t flags)
void bsp_cacr_set_self_clear_flags (uint32_t flags)
void bsp_cacr_clear_flags (uint32_t flags)
const uint8_t mcf548x_intc_icr_init_values [64]
