RTEMS 6.1
Modules | Files | Macros | Functions | Variables
Motorola 68360 Board Support Package. More...
 M360_SPIDRV Support
 M360_SPIDRV Support Package.
 Stuff for Time Test 27
 Don't bother with hardware – just use a software-interrupt.
file  bsp.h
 Board Support Package for ‘Generic’ Motorola MC68360.
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "scc1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_scc1_driver_attach
#define ATLASHSB_ESR   0x20010000L
#define ATLASHSB_USICR   0x20010001L
#define ATLASHSB_DSRR   0x20010002L
#define ATLASHSB_LED4   0x20010004L
#define ATLASHSB_ROM_U6   0xFF080000L /* U6 flash ROM socket */
int rtems_scc1_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching)
void M360ExecuteRISC (uint16_t command)
void * M360AllocateBufferDescriptors (int count)
void * M360AllocateRiscTimers (int count)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
void _Init68360 (void)
rtems_isr_entry M68Kvec []
char M360DefaultWatchdogFeeder
int m360_clock_rate
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
