RTEMS 6.1
Board Support Package for ‘Generic’ Motorola MC68360. More...
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "scc1" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_scc1_driver_attach |
| #define | ATLASHSB_ESR 0x20010000L |
| #define | ATLASHSB_USICR 0x20010001L |
| #define | ATLASHSB_DSRR 0x20010002L |
| #define | ATLASHSB_LED4 0x20010004L |
| #define | ATLASHSB_ROM_U6 0xFF080000L /* U6 flash ROM socket */ |
| int | rtems_scc1_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| void | M360ExecuteRISC (uint16_t command) |
| void * | M360AllocateBufferDescriptors (int count) |
| void * | M360AllocateRiscTimers (int count) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. | |
| void | _Init68360 (void) |
| rtems_isr_entry | M68Kvec [] |
| char | M360DefaultWatchdogFeeder |
| int | m360_clock_rate |
