RTEMS 6.1
bsp.h
1
9/*
10 * Copyright (c) 1996 Eric Norum <eric@norum.ca>
11 *
12 * COPYRIGHT (c) 1989-1999.
13 * On-Line Applications Research Corporation (OAR).
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef LIBBSP_M68K_GEN68360_BSP_H
21#define LIBBSP_M68K_GEN68360_BSP_H
22
33#include <bspopts.h>
35
36#include <rtems.h>
37
38#ifdef __cplusplus
39extern "C" {
40#endif
41
42struct rtems_bsdnet_ifconfig;
43extern int rtems_scc1_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching);
44#define RTEMS_BSP_NETWORK_DRIVER_NAME "scc1"
45#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_scc1_driver_attach
46
47extern rtems_isr_entry M68Kvec[]; /* vector table address */
48
49/* functions */
50
51void M360ExecuteRISC( uint16_t command );
52void *M360AllocateBufferDescriptors( int count );
53void *M360AllocateRiscTimers( int count );
54extern char M360DefaultWatchdogFeeder;
55
56extern int m360_clock_rate; /* BRG clock rate, defined in console.c */
57
58rtems_isr_entry set_vector(
59 rtems_isr_entry handler,
61 int type
62);
63
64/*
65 * Definitions for Atlas Computer Equipment Inc. High Speed Bridge (HSB)
66 */
67#define ATLASHSB_ESR 0x20010000L
68#define ATLASHSB_USICR 0x20010001L
69#define ATLASHSB_DSRR 0x20010002L
70#define ATLASHSB_LED4 0x20010004L
71#define ATLASHSB_ROM_U6 0xFF080000L /* U6 flash ROM socket */
72
73
74/*
75 * definitions for PGH360 board
76 */
77#if defined(PGH360)
78/*
79 * logical SPI addresses of SPI slaves available
80 */
81#define PGH360_SPI_ADDR_EEPROM 0
82#define PGH360_SPI_ADDR_DISP4_DATA 1
83#define PGH360_SPI_ADDR_DISP4_CTRL 2
84
85/*
86 * Port B bit locations of SPI slave selects
87 */
88#define PGH360_PB_SPI_DISP4_RS_MSK (1<<15)
89#define PGH360_PB_SPI_DISP4_CE_MSK (1<<14)
90#define PGH360_PB_SPI_EEP_CE_MSK (1<< 0)
91#endif /* defined(PGH360) */
92
93/*
94 * Prototypes for BSP methods which cross file boundaries
95 */
96void _Init68360(void);
97
98#ifdef __cplusplus
99}
100#endif
101
104#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: deflate.c:114
