RTEMS 6.1
This group contains register bit definitions. More...
#define GR740_THSENS_STATUS_MAX_SHIFT   24
#define GR740_THSENS_STATUS_MAX_MASK   0x7f000000U
#define GR740_THSENS_STATUS_MAX_GET(_reg)
#define GR740_THSENS_STATUS_MAX_SET(_reg, _val)
#define GR740_THSENS_STATUS_MAX(_val)
#define GR740_THSENS_STATUS_MIN_SHIFT   16
#define GR740_THSENS_STATUS_MIN_MASK   0x7f0000U
#define GR740_THSENS_STATUS_MIN_GET(_reg)
#define GR740_THSENS_STATUS_MIN_SET(_reg, _val)
#define GR740_THSENS_STATUS_MIN(_val)
#define GR740_THSENS_STATUS_SCLK   0x8000U
#define GR740_THSENS_STATUS_WE   0x400U
#define GR740_THSENS_STATUS_UPD   0x200U
#define GR740_THSENS_STATUS_ALACT   0x100U
#define GR740_THSENS_STATUS_DATA_SHIFT   0
#define GR740_THSENS_STATUS_DATA_MASK   0x7fU
#define GR740_THSENS_STATUS_DATA_GET(_reg)
#define GR740_THSENS_STATUS_DATA_SET(_reg, _val)
#define GR740_THSENS_STATUS_DATA(_val)
◆ GR740_THSENS_STATUS_DATA
#define GR740_THSENS_STATUS_DATA (   _val)
Value:
( ( ( _val ) << GR740_THSENS_STATUS_DATA_SHIFT ) & \
GR740_THSENS_STATUS_DATA_MASK )
◆ GR740_THSENS_STATUS_DATA_GET
#define GR740_THSENS_STATUS_DATA_GET (   _reg)
Value:
( ( ( _reg ) & GR740_THSENS_STATUS_DATA_MASK ) >> \
◆ GR740_THSENS_STATUS_DATA_SET
#define GR740_THSENS_STATUS_DATA_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_THSENS_STATUS_DATA_MASK ) | \
GR740_THSENS_STATUS_DATA_MASK ) )
◆ GR740_THSENS_STATUS_MAX
#define GR740_THSENS_STATUS_MAX (   _val)
Value:
( ( ( _val ) << GR740_THSENS_STATUS_MAX_SHIFT ) & \
GR740_THSENS_STATUS_MAX_MASK )
◆ GR740_THSENS_STATUS_MAX_GET
#define GR740_THSENS_STATUS_MAX_GET (   _reg)
Value:
( ( ( _reg ) & GR740_THSENS_STATUS_MAX_MASK ) >> \
◆ GR740_THSENS_STATUS_MAX_SET
#define GR740_THSENS_STATUS_MAX_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_THSENS_STATUS_MAX_MASK ) | \
GR740_THSENS_STATUS_MAX_MASK ) )
◆ GR740_THSENS_STATUS_MIN
#define GR740_THSENS_STATUS_MIN (   _val)
Value:
( ( ( _val ) << GR740_THSENS_STATUS_MIN_SHIFT ) & \
GR740_THSENS_STATUS_MIN_MASK )
◆ GR740_THSENS_STATUS_MIN_GET
#define GR740_THSENS_STATUS_MIN_GET (   _reg)
Value:
( ( ( _reg ) & GR740_THSENS_STATUS_MIN_MASK ) >> \
◆ GR740_THSENS_STATUS_MIN_SET
#define GR740_THSENS_STATUS_MIN_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_THSENS_STATUS_MIN_MASK ) | \
GR740_THSENS_STATUS_MIN_MASK ) )
