This group contains the GR740 Temperatur Sensor Controller interfaces.
More...
| file | gr740-thsens-regs.h |
| | This header file defines the GR740 Temperatur Sensor Controller register block interface.
| struct | gr740_thsens |
| | This structure defines the GR740 Temperatur Sensor Controller register block memory map. More...
typedef struct gr740_thsens | gr740_thsens |
