RTEMS 6.1
PLL current configuration register (PLLCURCFG)
This group contains register bit definitions. More...
#define GR740_IOPLL_PLLCURCFG_SWTAG_SHIFT   27
#define GR740_IOPLL_PLLCURCFG_SWTAG_MASK   0x18000000U
#define GR740_IOPLL_PLLCURCFG_SWTAG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_SWTAG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_SWTAG(_val)
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_SHIFT   18
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_MASK   0x7fc0000U
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG(_val)
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_SHIFT   9
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_MASK   0x3fe00U
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG(_val)
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_SHIFT   0
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_MASK   0x1ffU
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_GET(_reg)
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_SET(_reg, _val)
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG(_val)
◆ GR740_IOPLL_PLLCURCFG_MEMPLLCFG
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLCURCFG_MEMPLLCFG_SHIFT ) & \
GR740_IOPLL_PLLCURCFG_MEMPLLCFG_MASK )
◆ GR740_IOPLL_PLLCURCFG_MEMPLLCFG_GET
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLCURCFG_MEMPLLCFG_MASK ) >> \
◆ GR740_IOPLL_PLLCURCFG_MEMPLLCFG_SET
#define GR740_IOPLL_PLLCURCFG_MEMPLLCFG_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLCURCFG_MEMPLLCFG_MASK ) | \
GR740_IOPLL_PLLCURCFG_MEMPLLCFG_MASK ) )
◆ GR740_IOPLL_PLLCURCFG_SPWPLLCFG
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLCURCFG_SPWPLLCFG_SHIFT ) & \
GR740_IOPLL_PLLCURCFG_SPWPLLCFG_MASK )
◆ GR740_IOPLL_PLLCURCFG_SPWPLLCFG_GET
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLCURCFG_SPWPLLCFG_MASK ) >> \
◆ GR740_IOPLL_PLLCURCFG_SPWPLLCFG_SET
#define GR740_IOPLL_PLLCURCFG_SPWPLLCFG_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLCURCFG_SPWPLLCFG_MASK ) | \
GR740_IOPLL_PLLCURCFG_SPWPLLCFG_MASK ) )
◆ GR740_IOPLL_PLLCURCFG_SWTAG
#define GR740_IOPLL_PLLCURCFG_SWTAG (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLCURCFG_SWTAG_SHIFT ) & \
GR740_IOPLL_PLLCURCFG_SWTAG_MASK )
◆ GR740_IOPLL_PLLCURCFG_SWTAG_GET
#define GR740_IOPLL_PLLCURCFG_SWTAG_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLCURCFG_SWTAG_MASK ) >> \
◆ GR740_IOPLL_PLLCURCFG_SWTAG_SET
#define GR740_IOPLL_PLLCURCFG_SWTAG_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLCURCFG_SWTAG_MASK ) | \
GR740_IOPLL_PLLCURCFG_SWTAG_MASK ) )
◆ GR740_IOPLL_PLLCURCFG_SYSPLLCFG
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG (   _val)
Value:
( ( ( _val ) << GR740_IOPLL_PLLCURCFG_SYSPLLCFG_SHIFT ) & \
GR740_IOPLL_PLLCURCFG_SYSPLLCFG_MASK )
◆ GR740_IOPLL_PLLCURCFG_SYSPLLCFG_GET
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_GET (   _reg)
Value:
( ( ( _reg ) & GR740_IOPLL_PLLCURCFG_SYSPLLCFG_MASK ) >> \
◆ GR740_IOPLL_PLLCURCFG_SYSPLLCFG_SET
#define GR740_IOPLL_PLLCURCFG_SYSPLLCFG_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GR740_IOPLL_PLLCURCFG_SYSPLLCFG_MASK ) | \
GR740_IOPLL_PLLCURCFG_SYSPLLCFG_MASK ) )
