RTEMS 6.1
This group contains the GR740 I/0 and PLL Configuration interfaces. More...
Modules | |
| Alternative function enable register (ALTFUNC) | |
| This group contains register bit definitions. | |
| Configuration lockdown register (LOCKDOWN) | |
| Drive strength configuration register 1 (DRVSTR1) | |
| Drive strength configuration register 2 (DRVSTR2) | |
| FTMCTRL function enable register (FTMFUNC) | |
| LVDS and memory clock pad enable register (LVDSMCLK) | |
| PLL current configuration register (PLLCURCFG) | |
| PLL new configuration register (PLLNEWCFG) | |
| PLL reconfigure command register (PLLRECFG) | |
Files | |
| file | gr740-iopll-regs.h |
| This header file defines the GR740 I/O and PLL configuration register block interface. | |
| struct | gr740_iopll |
| This structure defines the GR740 I/0 and PLL Configuration register block memory map. More... | |
Typedefs | |
| typedef struct gr740_iopll | gr740_iopll |
| This structure defines the GR740 I/0 and PLL Configuration register block memory map. | |
