RTEMS 6.1
Event Recording Configuration
#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
 This configuration option is a boolean feature define.
#define CONFIGURE_RECORD_FATAL_DUMP_BASE64
#define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
#define CONFIGURE_RECORD_INTERRUPTS_ENABLED
#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
 This configuration option is an integer define.
This section describes configuration options related to the event recording.
◆ CONFIGURE_RECORD_EXTENSIONS_ENABLED
In case
then the event record extensions are enabled.
Default Configuration
If this configuration option is undefined, then the described feature is not enabled.
Notes
The record extensions capture thread create, start, restart, delete, switch, begin, exitted and terminate events.
◆ CONFIGURE_RECORD_FATAL_DUMP_BASE64
In case
then the event records are dumped in Base64 encoding in a fatal error extension (see System Termination Procedure).
Notes
This extension can be used to produce crash dumps.
◆ CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
In case
then the event records are compressed by zlib and dumped in Base64 encoding in a fatal error extension (see System Termination Procedure).
Notes
The zlib compression needs about 512KiB of RAM. This extension can be used to produce crash dumps.
◆ CONFIGURE_RECORD_INTERRUPTS_ENABLED
In case
then the interrupt event recording is enabled.
Notes
The interrupt event recording generates interrupt entry and exit events when interrupt entries are dispatched.
◆ CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
The value of this configuration option defines the event record item count per processor.
Default Value
The default value is 0.
Constraints
The following constraints apply to this configuration option:
  • The value of the configuration option shall be greater than or equal to 16.
  • The value of the configuration option shall be less than or equal to SIZE_MAX.
  • The value of the configuration option shall be a power of two.
  • The value of the configuration option shall be less than or equal to a BSP-specific and application-specific value which depends on the size of the memory available to the application.
Notes
The event record buffers are statically allocated for each configured processor (CONFIGURE_MAXIMUM_PROCESSORS). If the value of this configuration option is zero, then nothing is allocated.
