RTEMS 6.1
Files | Data Structures | Macros | Functions | Variables
POSIX Threads Support
Private Support Information for POSIX Threads. More...
file  psxtransschedparam.c
 Translate sched_param into SuperCore Terms.
file  pthreadinitthreads.c
 POSIX Threads Initialize User Threads Body.
struct  posix_initialization_threads_table
#define PTHREAD_MINIMUM_STACK_SIZE   _POSIX_Threads_Minimum_stack_size
void _POSIX_Threads_Initialize_user_thread (void)
 System initialization handler to create the first user POSIX thread.
void _POSIX_Threads_Sporadic_timer (Watchdog_Control *watchdog)
int _POSIX_Thread_Translate_to_sched_policy (const Thread_CPU_budget_operations *operations)
int _POSIX_Thread_Translate_sched_param (int policy, const struct sched_param *param, Thread_Configuration *config)
 Translates the POSIX scheduling policy and parameters to parts of the thread configuration.
const size_t _POSIX_Threads_Minimum_stack_size
const posix_initialization_threads_table _POSIX_Threads_User_thread_table
 Initialization table for the first user POSIX thread.
Thread_Information _POSIX_Threads_Information
const pthread_attr_t _POSIX_Threads_Default_attributes
const Thread_CPU_budget_operations _POSIX_Threads_Sporadic_budget
 The POSIX threads sporadic budget operations.
◆ PTHREAD_MINIMUM_STACK_SIZE
The following sets the minimum stack size for POSIX threads.
◆ _POSIX_Thread_Translate_sched_param()
int _POSIX_Thread_Translate_sched_param ( int  policy,
const struct sched_param *  param,
Thread_Configuration config
Parameters
policyis the POSIX scheduling policy.
paramis the pointer to the POSIX scheduling parameters.
[out]configis the pointer to a thread configuration to set the budget algorithm, callout, and CPU time budget.
Return values
0The operation was successful.
EINVALThe POSIX scheduling policy or parameters were invalid.
Variable Documentation
◆ _POSIX_Threads_Default_attributes
extern
This variable contains the default POSIX Thread attributes.
◆ _POSIX_Threads_Information
extern
The following defines the information control block used to manage this class of objects.
◆ _POSIX_Threads_User_thread_table
extern
This table is used by _POSIX_Threads_Initialize_user_thread() and initialized via <rtems/confdefs.h>.
