RTEMS 6.1
| #define | MU_TR_COUNT (4U) |
| #define | MU_RR_COUNT (4U) |
TR - Processor B Transmit Register 0..Processor B Transmit Register 3 | |
| #define | MU_TR_DATA_MASK (0xFFFFFFFFU) |
| #define | MU_TR_DATA_SHIFT (0U) |
| #define | MU_TR_DATA(x) (((uint32_t)(((uint32_t)(x)) << MU_TR_DATA_SHIFT)) & MU_TR_DATA_MASK) |
RR - Processor B Receive Register 0..Processor B Receive Register 3 | |
| #define | MU_RR_DATA_MASK (0xFFFFFFFFU) |
| #define | MU_RR_DATA_SHIFT (0U) |
| #define | MU_RR_DATA(x) (((uint32_t)(((uint32_t)(x)) << MU_RR_DATA_SHIFT)) & MU_RR_DATA_MASK) |
SR - Processor B Status Register | |
| #define | MU_SR_Fn_MASK (0x7U) |
| #define | MU_SR_Fn_SHIFT (0U) |
| #define | MU_SR_Fn(x) (((uint32_t)(((uint32_t)(x)) << MU_SR_Fn_SHIFT)) & MU_SR_Fn_MASK) |
| #define | MU_SR_EP_MASK (0x10U) |
| #define | MU_SR_EP_SHIFT (4U) |
| #define | MU_SR_EP(x) (((uint32_t)(((uint32_t)(x)) << MU_SR_EP_SHIFT)) & MU_SR_EP_MASK) |
| #define | MU_SR_RS_MASK (0x80U) |
| #define | MU_SR_RS_SHIFT (7U) |
| #define | MU_SR_RS(x) (((uint32_t)(((uint32_t)(x)) << MU_SR_RS_SHIFT)) & MU_SR_RS_MASK) |
| #define | MU_SR_FUP_MASK (0x100U) |
| #define | MU_SR_FUP_SHIFT (8U) |
| #define | MU_SR_FUP(x) (((uint32_t)(((uint32_t)(x)) << MU_SR_FUP_SHIFT)) & MU_SR_FUP_MASK) |
| #define | MU_SR_TEn_MASK (0xF00000U) |
| #define | MU_SR_TEn_SHIFT (20U) |
| #define | MU_SR_TEn(x) (((uint32_t)(((uint32_t)(x)) << MU_SR_TEn_SHIFT)) & MU_SR_TEn_MASK) |
| #define | MU_SR_RFn_MASK (0xF000000U) |
| #define | MU_SR_RFn_SHIFT (24U) |
| #define | MU_SR_RFn(x) (((uint32_t)(((uint32_t)(x)) << MU_SR_RFn_SHIFT)) & MU_SR_RFn_MASK) |
| #define | MU_SR_GIPn_MASK (0xF0000000U) |
| #define | MU_SR_GIPn_SHIFT (28U) |
| #define | MU_SR_GIPn(x) (((uint32_t)(((uint32_t)(x)) << MU_SR_GIPn_SHIFT)) & MU_SR_GIPn_MASK) |
CR - Processor B Control Register | |
| #define | MU_CR_Fn_MASK (0x7U) |
| #define | MU_CR_Fn_SHIFT (0U) |
| #define | MU_CR_Fn(x) (((uint32_t)(((uint32_t)(x)) << MU_CR_Fn_SHIFT)) & MU_CR_Fn_MASK) |
| #define | MU_CR_GIRn_MASK (0xF0000U) |
| #define | MU_CR_GIRn_SHIFT (16U) |
| #define | MU_CR_GIRn(x) (((uint32_t)(((uint32_t)(x)) << MU_CR_GIRn_SHIFT)) & MU_CR_GIRn_MASK) |
| #define | MU_CR_TIEn_MASK (0xF00000U) |
| #define | MU_CR_TIEn_SHIFT (20U) |
| #define | MU_CR_TIEn(x) (((uint32_t)(((uint32_t)(x)) << MU_CR_TIEn_SHIFT)) & MU_CR_TIEn_MASK) |
| #define | MU_CR_RIEn_MASK (0xF000000U) |
| #define | MU_CR_RIEn_SHIFT (24U) |
| #define | MU_CR_RIEn(x) (((uint32_t)(((uint32_t)(x)) << MU_CR_RIEn_SHIFT)) & MU_CR_RIEn_MASK) |
| #define | MU_CR_GIEn_MASK (0xF0000000U) |
| #define | MU_CR_GIEn_SHIFT (28U) |
| #define | MU_CR_GIEn(x) (((uint32_t)(((uint32_t)(x)) << MU_CR_GIEn_SHIFT)) & MU_CR_GIEn_MASK) |
TR - Processor A Transmit Register 0..Processor A Transmit Register 3 | |
RR - Processor A Receive Register 0..Processor A Receive Register 3 | |
SR - Processor A Status Register | |
CR - Processor A Control Register | |
| #define | MU_CR_MUR_MASK (0x20U) |
| #define | MU_CR_MUR_SHIFT (5U) |
| #define | MU_CR_MUR(x) (((uint32_t)(((uint32_t)(x)) << MU_CR_MUR_SHIFT)) & MU_CR_MUR_MASK) |
| #define MU_CR_Fn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_CR_Fn_SHIFT)) & MU_CR_Fn_MASK) |
Fn - Fn 0b000..Clears the Fn bit in the MUA.SR register. 0b001..Sets the Fn bit in the MUA.SR register.
Fn - Fn 0b000..N/A. Self clearing bit (default). 0b001..Asserts the Processor A MU reset.
| #define MU_CR_GIEn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_CR_GIEn_SHIFT)) & MU_CR_GIEn_MASK) |
GIEn - GIEn 0b0000..Disables Processor B General Interrupt n. (default) 0b0001..Enables Processor B General Interrupt n.
GIEn - GIEn 0b0000..Disables Processor A General Interrupt n. (default) 0b0001..Enables Processor A General Interrupt n.
| #define MU_CR_GIRn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_CR_GIRn_SHIFT)) & MU_CR_GIRn_MASK) |
GIRn - GIRn 0b0000..Processor B General Interrupt n is not requested to the Processor A (default). 0b0001..Processor B General Interrupt n is requested to the Processor A.
GIRn - GIRn 0b0000..Processor A General Interrupt n is not requested to the Processor B (default). 0b0001..Processor A General Interrupt n is requested to the Processor B.
| #define MU_CR_MUR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_CR_MUR_SHIFT)) & MU_CR_MUR_MASK) |
MUR - MUR 0b0..N/A. Self clearing bit (default). 0b1..Asserts the Processor A MU reset.
| #define MU_CR_RIEn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_CR_RIEn_SHIFT)) & MU_CR_RIEn_MASK) |
RIEn - RIEn 0b0000..Disables Processor B Receive Interrupt n. (default) 0b0001..Enables Processor B Receive Interrupt n.
RIEn - RIEn 0b0000..Disables Processor A Receive Interrupt n. (default) 0b0001..Enables Processor A Receive Interrupt n.
| #define MU_CR_TIEn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_CR_TIEn_SHIFT)) & MU_CR_TIEn_MASK) |
TIEn - TIEn 0b0000..Disables Processor B Transmit Interrupt n. (default) 0b0001..Enables Processor B Transmit Interrupt n.
TIEn - TIEn 0b0000..Disables Processor A Transmit Interrupt n. (default) 0b0001..Enables Processor A Transmit Interrupt n.
| #define MU_RR_DATA | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_RR_DATA_SHIFT)) & MU_RR_DATA_MASK) |
DATA - RR3
DATA - RR3
| #define MU_SR_EP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_SR_EP_SHIFT)) & MU_SR_EP_MASK) |
EP - EP 0b0..The Processor B-side event is not pending (default). 0b1..The Processor B-side event is pending.
EP - EP 0b0..The Processor A-side event is not pending (default). 0b1..The Processor A-side event is pending.
| #define MU_SR_Fn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_SR_Fn_SHIFT)) & MU_SR_Fn_MASK) |
Fn - Fn 0b000..ABFn bit in MUA.CR register is written 0 (default). 0b001..ABFn bit in MUA.CR register is written 1.
Fn - Fn 0b000..BAFn bit in MUB.CR register is written 0 (default). 0b001..BAFn bit in MUB.CR register is written 1.
| #define MU_SR_FUP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_SR_FUP_SHIFT)) & MU_SR_FUP_MASK) |
FUP - FUP 0b0..No flags updated, initiated by the Processor B, in progress (default) 0b1..Processor B initiated flags update, processing
FUP - FUP 0b0..No flags updated, initiated by the Processor A, in progress (default) 0b1..Processor A initiated flags update, processing
| #define MU_SR_GIPn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_SR_GIPn_SHIFT)) & MU_SR_GIPn_MASK) |
GIPn - GIPn 0b0000..Processor B general purpose interrupt n is not pending. (default) 0b0001..Processor B general purpose interrupt n is pending.
GIPn - GIPn 0b0000..Processor A general purpose interrupt n is not pending. (default) 0b0001..Processor A general purpose interrupt n is pending.
| #define MU_SR_RFn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_SR_RFn_SHIFT)) & MU_SR_RFn_MASK) |
RFn - RFn 0b0000..MUB.RRn register is not full (default). 0b0001..MUB.RRn register has received data from MUA.TRn register and is ready to be read by the Processor B.
RFn - RFn 0b0000..MUA.RRn register is not full (default). 0b0001..MUA.RRn register has received data from MUB.TRn register and is ready to be read by the Processor A.
| #define MU_SR_RS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_SR_RS_SHIFT)) & MU_SR_RS_MASK) |
RS - RS 0b0..The Processor A or the Processor A-side of the MU is not in reset. 0b1..The Processor A or the Processor A-side of the MU is in reset.
RS - RS 0b0..The Processor B-side of the MU is not in reset. 0b1..The Processor B-side of the MU is in reset.
| #define MU_SR_TEn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_SR_TEn_SHIFT)) & MU_SR_TEn_MASK) |
TEn - TEn 0b0000..MUB.TRn register is not empty. 0b0001..MUB.TRn register is empty (default).
TEn - TEn 0b0000..MUA.TRn register is not empty. 0b0001..MUA.TRn register is empty (default).
| #define MU_TR_DATA | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MU_TR_DATA_SHIFT)) & MU_TR_DATA_MASK) |
DATA - TR3
DATA - TR3
