RTEMS 6.1
#define MMCAU_CA_COUNT   (9U)
CASR - Status Register
#define MMCAU_CASR_IC_MASK   (0x1U)
#define MMCAU_CASR_IC_SHIFT   (0U)
#define MMCAU_CASR_IC(x)   (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_IC_SHIFT)) & MMCAU_CASR_IC_MASK)
#define MMCAU_CASR_DPE_MASK   (0x2U)
#define MMCAU_CASR_DPE_SHIFT   (1U)
#define MMCAU_CASR_DPE(x)   (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_DPE_SHIFT)) & MMCAU_CASR_DPE_MASK)
#define MMCAU_CASR_VER_MASK   (0xF0000000U)
#define MMCAU_CASR_VER_SHIFT   (28U)
#define MMCAU_CASR_VER(x)   (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_VER_SHIFT)) & MMCAU_CASR_VER_MASK)
CAA - Accumulator
#define MMCAU_CAA_ACC_MASK   (0xFFFFFFFFU)
#define MMCAU_CAA_ACC_SHIFT   (0U)
#define MMCAU_CAA_ACC(x)   (((uint32_t)(((uint32_t)(x)) << MMCAU_CAA_ACC_SHIFT)) & MMCAU_CAA_ACC_MASK)
CA - General Purpose Register
#define MMCAU_CA_CAn_MASK   (0xFFFFFFFFU)
#define MMCAU_CA_CAn_SHIFT   (0U)
#define MMCAU_CA_CAn(x)   (((uint32_t)(((uint32_t)(x)) << MMCAU_CA_CAn_SHIFT)) & MMCAU_CA_CAn_MASK)
◆ MMCAU_CA_CAn
#define MMCAU_CA_CAn (   x)    (((uint32_t)(((uint32_t)(x)) << MMCAU_CA_CAn_SHIFT)) & MMCAU_CA_CAn_MASK)
CAn - General Purpose Registers
◆ MMCAU_CAA_ACC
#define MMCAU_CAA_ACC (   x)    (((uint32_t)(((uint32_t)(x)) << MMCAU_CAA_ACC_SHIFT)) & MMCAU_CAA_ACC_MASK)
ACC - Accumulator
◆ MMCAU_CASR_DPE
#define MMCAU_CASR_DPE (   x)    (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_DPE_SHIFT)) & MMCAU_CASR_DPE_MASK)
DPE - DES Parity Error 0b0..No error detected. 0b1..DES key parity error detected.
◆ MMCAU_CASR_IC
#define MMCAU_CASR_IC (   x)    (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_IC_SHIFT)) & MMCAU_CASR_IC_MASK)
IC - Illegal Command 0b0..No illegal commands issued. 0b1..Illegal command issued.
◆ MMCAU_CASR_VER
#define MMCAU_CASR_VER (   x)    (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_VER_SHIFT)) & MMCAU_CASR_VER_MASK)
VER - CAU Version 0b0001..Initial CAU version. 0b0010..Second version, added support for SHA-256 algorithm (This is the value on this device).
