RTEMS 6.1
SW_MUX_CTL_PAD - SW_MUX_CTL_PAD_GPIO_LPSR_00 SW MUX Control Register..SW_MUX_CTL_PAD_GPIO_LPSR_15 SW MUX Control Register | |
| #define | IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE_MASK (0xFU) |
| #define | IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE_SHIFT (0U) |
| #define | IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE_SHIFT)) & IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE_MASK) |
| #define | IOMUXC_LPSR_SW_MUX_CTL_PAD_SION_MASK (0x10U) |
| #define | IOMUXC_LPSR_SW_MUX_CTL_PAD_SION_SHIFT (4U) |
| #define | IOMUXC_LPSR_SW_MUX_CTL_PAD_SION(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_MUX_CTL_PAD_SION_SHIFT)) & IOMUXC_LPSR_SW_MUX_CTL_PAD_SION_MASK) |
SW_PAD_CTL_PAD - SW_PAD_CTL_PAD_GPIO_LPSR_00 SW PAD Control Register..SW_PAD_CTL_PAD_GPIO_LPSR_15 SW PAD Control Register | |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE_MASK (0x1U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE_SHIFT (0U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE_MASK) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE_MASK (0x2U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE_SHIFT (1U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE_MASK) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE_MASK (0x4U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE_SHIFT (2U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE_MASK) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS_MASK (0x8U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS_SHIFT (3U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS_MASK) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR_MASK (0x20U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR_SHIFT (5U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR_MASK) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_MASK (0x30000000U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_SHIFT (28U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_MASK) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK_MASK (0xC0000000U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK_SHIFT (30U) |
| #define | IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK_MASK) |
SELECT_INPUT - CAN3_IPP_IND_CANRX_SELECT_INPUT DAISY Register..SAI4_IPP_IND_SAI_TXSYNC_SELECT_INPUT DAISY Register | |
| #define | IOMUXC_LPSR_SELECT_INPUT_DAISY_MASK (0x3U) /* Merged from fields with different position or width, of widths (1, 2), largest definition used */ |
| #define | IOMUXC_LPSR_SELECT_INPUT_DAISY_SHIFT (0U) |
| #define | IOMUXC_LPSR_SELECT_INPUT_DAISY(x) (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SELECT_INPUT_DAISY_SHIFT)) & IOMUXC_LPSR_SELECT_INPUT_DAISY_MASK) /* Merged from fields with different position or width, of widths (1, 2), largest definition used */ |
| #define IOMUXC_LPSR_SELECT_INPUT_DAISY | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SELECT_INPUT_DAISY_SHIFT)) & IOMUXC_LPSR_SELECT_INPUT_DAISY_MASK) /* Merged from fields with different position or width, of widths (1, 2), largest definition used */ |
DAISY - Selecting Pads Involved in Daisy Chain. 0b00..Selecting Pad: GPIO_LPSR_00 for Mode: ALT6 0b01..Selecting Pad: GPIO_LPSR_06 for Mode: ALT3 0b10..Selecting Pad: GPIO_LPSR_10 for Mode: ALT8
| #define IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE_SHIFT)) & IOMUXC_LPSR_SW_MUX_CTL_PAD_MUX_MODE_MASK) |
MUX_MODE - MUX Mode Select Field. 0b1010..Select mux mode: ALT10 mux port: GPIO12_IO10 of instance: GPIO12 0b0000..Select mux mode: ALT0 mux port: JTAG_MUX_TRSTB of instance: JTAG_MUX 0b0001..Select mux mode: ALT1 mux port: LPUART11_CTS_B of instance: LPUART11 0b0010..Select mux mode: ALT2 mux port: LPI2C6_SDA of instance: LPI2C6 0b0011..Select mux mode: ALT3 mux port: MIC_BITSTREAM1 of instance: MIC 0b0100..Select mux mode: ALT4 mux port: LPSPI6_SCK of instance: LPSPI6 0b0101..Select mux mode: ALT5 mux port: GPIO_MUX6_IO10 of instance: GPIO_MUX6 0b0110..Select mux mode: ALT6 mux port: LPI2C5_SCLS of instance: LPI2C5 0b0111..Select mux mode: ALT7 mux port: SAI4_TX_SYNC of instance: SAI4 0b1000..Select mux mode: ALT8 mux port: LPUART12_TXD of instance: LPUART12
| #define IOMUXC_LPSR_SW_MUX_CTL_PAD_SION | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_MUX_CTL_PAD_SION_SHIFT)) & IOMUXC_LPSR_SW_MUX_CTL_PAD_SION_MASK) |
SION - Software Input On Field. 0b1..Force input path of pad GPIO_LPSR_00 0b0..Input Path is determined by functionality
| #define IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_DSE_MASK) |
DSE - Drive Strength Field 0b0..normal driver 0b1..high driver
| #define IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_MASK) |
DWP - Domain write protection 0b00..Both cores are allowed 0b01..CM7 is forbidden 0b10..CM4 is forbidden 0b11..Both cores are forbidden
| #define IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_DWP_LOCK_MASK) |
DWP_LOCK - Domain write protection lock 0b00..Neither of DWP bits is locked 0b01..The lower DWP bit is locked 0b10..The higher DWP bit is locked 0b11..Both DWP bits are locked
| #define IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_ODE_LPSR_MASK) |
ODE_LPSR - Open Drain LPSR Field 0b0..Disabled 0b1..Enabled
| #define IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_PUE_MASK) |
PUE - Pull / Keep Select Field 0b0..Pull Disable 0b1..Pull Enable
| #define IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_PUS_MASK) |
PUS - Pull Up / Down Config. Field 0b0..Weak pull down 0b1..Weak pull up
| #define IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE_SHIFT)) & IOMUXC_LPSR_SW_PAD_CTL_PAD_SRE_MASK) |
SRE - Slew Rate Field 0b0..Slow Slew Rate 0b1..Fast Slew Rate
