RTEMS 6.1
REGION0_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION0_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION0_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION0_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION0_TOP_ADDR_TOP_ADDR_MASK)
REGION0_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION0_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION0_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION0_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION0_BOT_ADDR_BOT_ADDR_MASK)
REGION0_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK_MASK)
REGION0_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK_MASK)
REGION1_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION1_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION1_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION1_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION1_TOP_ADDR_TOP_ADDR_MASK)
REGION1_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION1_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION1_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION1_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION1_BOT_ADDR_BOT_ADDR_MASK)
REGION1_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK_MASK)
REGION1_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK_MASK)
REGION2_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION2_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION2_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION2_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION2_TOP_ADDR_TOP_ADDR_MASK)
REGION2_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION2_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION2_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION2_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION2_BOT_ADDR_BOT_ADDR_MASK)
REGION2_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK_MASK)
REGION2_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK_MASK)
REGION3_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION3_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION3_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION3_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION3_TOP_ADDR_TOP_ADDR_MASK)
REGION3_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION3_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION3_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION3_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION3_BOT_ADDR_BOT_ADDR_MASK)
REGION3_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK_MASK)
REGION3_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK_MASK)
REGION4_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION4_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION4_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION4_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION4_TOP_ADDR_TOP_ADDR_MASK)
REGION4_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION4_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION4_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION4_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION4_BOT_ADDR_BOT_ADDR_MASK)
REGION4_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK_MASK)
REGION4_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK_MASK)
REGION5_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION5_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION5_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION5_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION5_TOP_ADDR_TOP_ADDR_MASK)
REGION5_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION5_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION5_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION5_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION5_BOT_ADDR_BOT_ADDR_MASK)
REGION5_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK_MASK)
REGION5_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK_MASK)
REGION6_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION6_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION6_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION6_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION6_TOP_ADDR_TOP_ADDR_MASK)
REGION6_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION6_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION6_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION6_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION6_BOT_ADDR_BOT_ADDR_MASK)
REGION6_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK_MASK)
REGION6_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK_MASK)
REGION7_TOP_ADDR - End address of IEE region (n)
#define IEE_APC_REGION7_TOP_ADDR_TOP_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION7_TOP_ADDR_TOP_ADDR_SHIFT   (0U)
#define IEE_APC_REGION7_TOP_ADDR_TOP_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION7_TOP_ADDR_TOP_ADDR_MASK)
REGION7_BOT_ADDR - Start address of IEE region (n)
#define IEE_APC_REGION7_BOT_ADDR_BOT_ADDR_MASK   (0x1FFFFFFFU)
#define IEE_APC_REGION7_BOT_ADDR_BOT_ADDR_SHIFT   (0U)
#define IEE_APC_REGION7_BOT_ADDR_BOT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION7_BOT_ADDR_BOT_ADDR_MASK)
REGION7_RDC_D0 - Region control of core domain 0 for region (n)
#define IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS_MASK)
#define IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK_MASK   (0x2U)
#define IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK_SHIFT   (1U)
#define IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK_MASK)
REGION7_RDC_D1 - Region control of core domain 1 for region (n)
#define IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS_MASK   (0x1U)
#define IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS_SHIFT   (0U)
#define IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS_MASK)
#define IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK_MASK   (0x2U)
#define IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK_SHIFT   (1U)
#define IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION0_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION0_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION0_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION0_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK_MASK)
RDC_D0_LOCK - Lock bit for bit 0 0b0..Bit 0 is unlocked 0b1..Bit 0 is locked
◆ IEE_APC_REGION0_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS_MASK)
RDC_D0_WRITE_DIS - Write disable of core domain 1 0b0..Write to TOP_ADDR and BOT_ADDR of this region enabled 0b1..Write to TOP_ADDR and BOT_ADDR of this region disabled
◆ IEE_APC_REGION0_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK_MASK)
RDC_D1_LOCK - Lock bit for bit 0 0b0..Bit 0 is unlocked 0b1..Bit 0 is locked
◆ IEE_APC_REGION0_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS_MASK)
RDC_D1_WRITE_DIS - Write disable of core domain 1 0b0..Write to TOP_ADDR and BOT_ADDR of this region enabled 0b1..Write to TOP_ADDR and BOT_ADDR of this region disabled
◆ IEE_APC_REGION0_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION0_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION0_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION0_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION0_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION0_TOP_ADDR_TOP_ADDR [2/2]
◆ IEE_APC_REGION1_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION1_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION1_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION1_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK_MASK)
◆ IEE_APC_REGION1_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS_MASK)
◆ IEE_APC_REGION1_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION1_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS_MASK)
◆ IEE_APC_REGION1_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION1_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION1_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION1_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION1_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION1_TOP_ADDR_TOP_ADDR [2/2]
◆ IEE_APC_REGION2_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION2_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION2_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION2_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK_MASK)
◆ IEE_APC_REGION2_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS_MASK)
◆ IEE_APC_REGION2_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION2_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS_MASK)
◆ IEE_APC_REGION2_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION2_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION2_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION2_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION2_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION2_TOP_ADDR_TOP_ADDR [2/2]
◆ IEE_APC_REGION3_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION3_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION3_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION3_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK_MASK)
◆ IEE_APC_REGION3_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS_MASK)
◆ IEE_APC_REGION3_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION3_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS_MASK)
◆ IEE_APC_REGION3_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION3_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION3_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION3_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION3_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION3_TOP_ADDR_TOP_ADDR [2/2]
◆ IEE_APC_REGION4_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION4_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION4_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION4_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK_MASK)
◆ IEE_APC_REGION4_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS_MASK)
◆ IEE_APC_REGION4_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION4_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS_MASK)
◆ IEE_APC_REGION4_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION4_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION4_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION4_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION4_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION4_TOP_ADDR_TOP_ADDR [2/2]
◆ IEE_APC_REGION5_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION5_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION5_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION5_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK_MASK)
◆ IEE_APC_REGION5_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS_MASK)
◆ IEE_APC_REGION5_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION5_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS_MASK)
◆ IEE_APC_REGION5_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION5_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION5_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION5_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION5_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION5_TOP_ADDR_TOP_ADDR [2/2]
◆ IEE_APC_REGION6_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION6_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION6_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION6_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK_MASK)
◆ IEE_APC_REGION6_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS_MASK)
◆ IEE_APC_REGION6_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION6_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS_MASK)
◆ IEE_APC_REGION6_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION6_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION6_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION6_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION6_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION6_TOP_ADDR_TOP_ADDR [2/2]
◆ IEE_APC_REGION7_BOT_ADDR_BOT_ADDR [1/2]
#define IEE_APC_REGION7_BOT_ADDR_BOT_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_BOT_ADDR_BOT_ADDR_SHIFT)) & IEE_APC_REGION7_BOT_ADDR_BOT_ADDR_MASK)
◆ IEE_APC_REGION7_BOT_ADDR_BOT_ADDR [2/2]
◆ IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK [1/2]
#define IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK_SHIFT)) & IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK_MASK)
◆ IEE_APC_REGION7_RDC_D0_RDC_D0_LOCK [2/2]
◆ IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS [1/2]
#define IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS_SHIFT)) & IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS_MASK)
◆ IEE_APC_REGION7_RDC_D0_RDC_D0_WRITE_DIS [2/2]
◆ IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK [1/2]
#define IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK_SHIFT)) & IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK_MASK)
◆ IEE_APC_REGION7_RDC_D1_RDC_D1_LOCK [2/2]
◆ IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS [1/2]
#define IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS_SHIFT)) & IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS_MASK)
◆ IEE_APC_REGION7_RDC_D1_RDC_D1_WRITE_DIS [2/2]
◆ IEE_APC_REGION7_TOP_ADDR_TOP_ADDR [1/2]
#define IEE_APC_REGION7_TOP_ADDR_TOP_ADDR (   x)    (((uint32_t)(((uint32_t)(x)) << IEE_APC_REGION7_TOP_ADDR_TOP_ADDR_SHIFT)) & IEE_APC_REGION7_TOP_ADDR_TOP_ADDR_MASK)
◆ IEE_APC_REGION7_TOP_ADDR_TOP_ADDR [2/2]
