RTEMS 6.1
Macros | Functions
HAL TimeBase RTC Alarm Template
#define RTC_CLOCK_SOURCE_HSE
#define RTC_ASYNCH_PREDIV   99U
#define RTC_SYNCH_PREDIV   9U
#define RCC_RTCCLKSOURCE_1MHZ   ((uint32_t)((uint32_t)RCC_BDCR_RTCSEL | (uint32_t)((HSE_VALUE/1000000U) << 12U)))
void RTC_Alarm_IRQHandler (void)
 This function handles RTC ALARM interrupt request.
HAL_StatusTypeDef HAL_InitTick (uint32_t TickPriority)
 This function configures the RTC_ALARMA as a time base source. The time source is configured to have 1ms time base with a dedicated Tick interrupt priority.
void HAL_SuspendTick (void)
 Suspend Tick increment.
void HAL_ResumeTick (void)
 Resume Tick increment.
void HAL_RTC_AlarmAEventCallback (RTC_HandleTypeDef *hrtc)
 ALARM A Event Callback in non blocking mode.
◆ HAL_InitTick()
HAL_StatusTypeDef HAL_InitTick ( uint32_t  TickPriority)
Note
This function is called automatically at the beginning of program after reset by HAL_Init() or at any time when clock is configured, by HAL_RCC_ClockConfig().
Parameters
TickPriorityTick interrupt priority.
Return values
HALstatus
◆ HAL_ResumeTick()
void HAL_ResumeTick ( void  )
Note
Enable the tick increment by Enabling RTC ALARM interrupt.
Return values
None
◆ HAL_RTC_AlarmAEventCallback()
void HAL_RTC_AlarmAEventCallback ( RTC_HandleTypeDef hrtc)
Note
This function is called when RTC_ALARM interrupt took place, inside RTC_ALARM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment a global variable "uwTick" used as application time base.
Parameters
hrtcRTC handle
Return values
None
◆ HAL_SuspendTick()
void HAL_SuspendTick ( void  )
Note
Disable the tick increment by disabling RTC ALARM interrupt.
Return values
None
◆ RTC_Alarm_IRQHandler()
void RTC_Alarm_IRQHandler ( void  )
Return values
None
