RTEMS 6.1
Initialization and de-initialization Functions
Initialization and de-initialization functions. More...
HAL_StatusTypeDef HAL_Init (void)
 This function is used to initialize the HAL Library; it must be the first instruction to be executed in the main program (before to call any other HAL function), it performs the following: Configures the SysTick to generate an interrupt each 1 millisecond, which is clocked by the HSI (at this stage, the clock is not yet configured and thus the system is running from the internal HSI at 16 MHz). Set NVIC Group Priority to 4. Calls the HAL_MspInit() callback function defined in user file "stm32h7xx_hal_msp.c" to do the global low level hardware initialization.
HAL_StatusTypeDef HAL_DeInit (void)
 This function de-Initializes common part of the HAL and stops the systick. This function is optional.
__weak void HAL_MspInit (void)
 Initializes the MSP.
__weak void HAL_MspDeInit (void)
 DeInitializes the MSP.
__weak HAL_StatusTypeDef HAL_InitTick (uint32_t TickPriority)
 This function configures the source of the time base. The time source is configured to have 1ms time base with a dedicated Tick interrupt priority.
              ##### Initialization and de-initialization functions #####
    [..]  This section provides functions allowing to:
      (+) Initializes the Flash interface the NVIC allocation and initial clock
          configuration. It initializes the systick also when timeout is needed
          and the backup domain when enabled.
      (+) De-Initializes common part of the HAL.
      (+) Configure The time base source to have 1ms time base with a dedicated
        (++) SysTick timer is used by default as source of time base, but user
             can eventually implement his proper time base source (a general purpose
             timer for example or other time source), keeping in mind that Time base
             duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
             handled in milliseconds basis.
        (++) Time base configuration function (HAL_InitTick ()) is called automatically
             at the beginning of the program after reset by HAL_Init() or at any time
             when clock is configured, by HAL_RCC_ClockConfig().
        (++) Source of time base is configured  to generate interrupts at regular
             time intervals. Care must be taken if HAL_Delay() is called from a
             peripheral ISR process, the Tick interrupt line must have higher priority
            (numerically lower) than the peripheral interrupt. Otherwise the caller
            ISR process will be blocked.
       (++) functions affecting time base configurations are declared as __weak
             to make  override possible  in case of other  implementations in user file.
◆ HAL_DeInit()
HAL_StatusTypeDef HAL_DeInit ( void  )
Return values
HALstatus
◆ HAL_Init()
HAL_StatusTypeDef HAL_Init ( void  )
Note
SysTick is used as time base for the HAL_Delay() function, the application need to ensure that the SysTick time base is always set to 1 millisecond to have correct HAL operation.
Return values
HALstatus
◆ HAL_InitTick()
HAL_StatusTypeDef HAL_InitTick ( uint32_t  TickPriority)
Note
This function is called automatically at the beginning of program after reset by HAL_Init() or at any time when clock is reconfigured by HAL_RCC_ClockConfig().
In the default implementation, SysTick timer is the source of time base. It is used to generate interrupts at regular time intervals. Care must be taken if HAL_Delay() is called from a peripheral ISR process, the SysTick interrupt must have higher priority (numerically lower) than the peripheral interrupt. Otherwise the caller ISR process will be blocked. The function is declared as __weak to be overwritten in case of other implementation in user file.
Parameters
TickPriorityTick interrupt priority.
Return values
HALstatus
◆ HAL_MspDeInit()
void HAL_MspDeInit ( void  )
Return values
None
◆ HAL_MspInit()
void HAL_MspInit ( void  )
Return values
None
