RTEMS 6.1
VER_ID - Version ID Register
#define EMVSIM_VER_ID_VER_MASK   (0xFFFFFFFFU)
#define EMVSIM_VER_ID_VER_SHIFT   (0U)
#define EMVSIM_VER_ID_VER(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_VER_ID_VER_SHIFT)) & EMVSIM_VER_ID_VER_MASK)
PARAM - Parameter Register
#define EMVSIM_PARAM_RX_FIFO_DEPTH_MASK   (0xFFU)
#define EMVSIM_PARAM_RX_FIFO_DEPTH_SHIFT   (0U)
#define EMVSIM_PARAM_RX_FIFO_DEPTH(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PARAM_RX_FIFO_DEPTH_SHIFT)) & EMVSIM_PARAM_RX_FIFO_DEPTH_MASK)
#define EMVSIM_PARAM_TX_FIFO_DEPTH_MASK   (0xFF00U)
#define EMVSIM_PARAM_TX_FIFO_DEPTH_SHIFT   (8U)
#define EMVSIM_PARAM_TX_FIFO_DEPTH(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PARAM_TX_FIFO_DEPTH_SHIFT)) & EMVSIM_PARAM_TX_FIFO_DEPTH_MASK)
CLKCFG - Clock Configuration Register
#define EMVSIM_CLKCFG_CLK_PRSC_MASK   (0xFFU)
#define EMVSIM_CLKCFG_CLK_PRSC_SHIFT   (0U)
#define EMVSIM_CLKCFG_CLK_PRSC(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CLKCFG_CLK_PRSC_SHIFT)) & EMVSIM_CLKCFG_CLK_PRSC_MASK)
#define EMVSIM_CLKCFG_GPCNT1_CLK_SEL_MASK   (0x300U)
#define EMVSIM_CLKCFG_GPCNT1_CLK_SEL_SHIFT   (8U)
#define EMVSIM_CLKCFG_GPCNT1_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CLKCFG_GPCNT1_CLK_SEL_SHIFT)) & EMVSIM_CLKCFG_GPCNT1_CLK_SEL_MASK)
#define EMVSIM_CLKCFG_GPCNT0_CLK_SEL_MASK   (0xC00U)
#define EMVSIM_CLKCFG_GPCNT0_CLK_SEL_SHIFT   (10U)
#define EMVSIM_CLKCFG_GPCNT0_CLK_SEL(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CLKCFG_GPCNT0_CLK_SEL_SHIFT)) & EMVSIM_CLKCFG_GPCNT0_CLK_SEL_MASK)
DIVISOR - Baud Rate Divisor Register
#define EMVSIM_DIVISOR_DIVISOR_VALUE_MASK   (0x1FFU)
#define EMVSIM_DIVISOR_DIVISOR_VALUE_SHIFT   (0U)
#define EMVSIM_DIVISOR_DIVISOR_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_DIVISOR_DIVISOR_VALUE_SHIFT)) & EMVSIM_DIVISOR_DIVISOR_VALUE_MASK)
CTRL - Control Register
#define EMVSIM_CTRL_IC_MASK   (0x1U)
#define EMVSIM_CTRL_IC_SHIFT   (0U)
#define EMVSIM_CTRL_IC(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_IC_SHIFT)) & EMVSIM_CTRL_IC_MASK)
#define EMVSIM_CTRL_ICM_MASK   (0x2U)
#define EMVSIM_CTRL_ICM_SHIFT   (1U)
#define EMVSIM_CTRL_ICM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_ICM_SHIFT)) & EMVSIM_CTRL_ICM_MASK)
#define EMVSIM_CTRL_ANACK_MASK   (0x4U)
#define EMVSIM_CTRL_ANACK_SHIFT   (2U)
#define EMVSIM_CTRL_ANACK(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_ANACK_SHIFT)) & EMVSIM_CTRL_ANACK_MASK)
#define EMVSIM_CTRL_ONACK_MASK   (0x8U)
#define EMVSIM_CTRL_ONACK_SHIFT   (3U)
#define EMVSIM_CTRL_ONACK(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_ONACK_SHIFT)) & EMVSIM_CTRL_ONACK_MASK)
#define EMVSIM_CTRL_FLSH_RX_MASK   (0x100U)
#define EMVSIM_CTRL_FLSH_RX_SHIFT   (8U)
#define EMVSIM_CTRL_FLSH_RX(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_FLSH_RX_SHIFT)) & EMVSIM_CTRL_FLSH_RX_MASK)
#define EMVSIM_CTRL_FLSH_TX_MASK   (0x200U)
#define EMVSIM_CTRL_FLSH_TX_SHIFT   (9U)
#define EMVSIM_CTRL_FLSH_TX(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_FLSH_TX_SHIFT)) & EMVSIM_CTRL_FLSH_TX_MASK)
#define EMVSIM_CTRL_SW_RST_MASK   (0x400U)
#define EMVSIM_CTRL_SW_RST_SHIFT   (10U)
#define EMVSIM_CTRL_SW_RST(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_SW_RST_SHIFT)) & EMVSIM_CTRL_SW_RST_MASK)
#define EMVSIM_CTRL_KILL_CLOCKS_MASK   (0x800U)
#define EMVSIM_CTRL_KILL_CLOCKS_SHIFT   (11U)
#define EMVSIM_CTRL_KILL_CLOCKS(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_KILL_CLOCKS_SHIFT)) & EMVSIM_CTRL_KILL_CLOCKS_MASK)
#define EMVSIM_CTRL_DOZE_EN_MASK   (0x1000U)
#define EMVSIM_CTRL_DOZE_EN_SHIFT   (12U)
#define EMVSIM_CTRL_DOZE_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_DOZE_EN_SHIFT)) & EMVSIM_CTRL_DOZE_EN_MASK)
#define EMVSIM_CTRL_STOP_EN_MASK   (0x2000U)
#define EMVSIM_CTRL_STOP_EN_SHIFT   (13U)
#define EMVSIM_CTRL_STOP_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_STOP_EN_SHIFT)) & EMVSIM_CTRL_STOP_EN_MASK)
#define EMVSIM_CTRL_RCV_EN_MASK   (0x10000U)
#define EMVSIM_CTRL_RCV_EN_SHIFT   (16U)
#define EMVSIM_CTRL_RCV_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_RCV_EN_SHIFT)) & EMVSIM_CTRL_RCV_EN_MASK)
#define EMVSIM_CTRL_XMT_EN_MASK   (0x20000U)
#define EMVSIM_CTRL_XMT_EN_SHIFT   (17U)
#define EMVSIM_CTRL_XMT_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_XMT_EN_SHIFT)) & EMVSIM_CTRL_XMT_EN_MASK)
#define EMVSIM_CTRL_RCVR_11_MASK   (0x40000U)
#define EMVSIM_CTRL_RCVR_11_SHIFT   (18U)
#define EMVSIM_CTRL_RCVR_11(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_RCVR_11_SHIFT)) & EMVSIM_CTRL_RCVR_11_MASK)
#define EMVSIM_CTRL_RX_DMA_EN_MASK   (0x80000U)
#define EMVSIM_CTRL_RX_DMA_EN_SHIFT   (19U)
#define EMVSIM_CTRL_RX_DMA_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_RX_DMA_EN_SHIFT)) & EMVSIM_CTRL_RX_DMA_EN_MASK)
#define EMVSIM_CTRL_TX_DMA_EN_MASK   (0x100000U)
#define EMVSIM_CTRL_TX_DMA_EN_SHIFT   (20U)
#define EMVSIM_CTRL_TX_DMA_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_TX_DMA_EN_SHIFT)) & EMVSIM_CTRL_TX_DMA_EN_MASK)
#define EMVSIM_CTRL_INV_CRC_VAL_MASK   (0x1000000U)
#define EMVSIM_CTRL_INV_CRC_VAL_SHIFT   (24U)
#define EMVSIM_CTRL_INV_CRC_VAL(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_INV_CRC_VAL_SHIFT)) & EMVSIM_CTRL_INV_CRC_VAL_MASK)
#define EMVSIM_CTRL_CRC_OUT_FLIP_MASK   (0x2000000U)
#define EMVSIM_CTRL_CRC_OUT_FLIP_SHIFT   (25U)
#define EMVSIM_CTRL_CRC_OUT_FLIP(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CRC_OUT_FLIP_SHIFT)) & EMVSIM_CTRL_CRC_OUT_FLIP_MASK)
#define EMVSIM_CTRL_CRC_IN_FLIP_MASK   (0x4000000U)
#define EMVSIM_CTRL_CRC_IN_FLIP_SHIFT   (26U)
#define EMVSIM_CTRL_CRC_IN_FLIP(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CRC_IN_FLIP_SHIFT)) & EMVSIM_CTRL_CRC_IN_FLIP_MASK)
#define EMVSIM_CTRL_CWT_EN_MASK   (0x8000000U)
#define EMVSIM_CTRL_CWT_EN_SHIFT   (27U)
#define EMVSIM_CTRL_CWT_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CWT_EN_SHIFT)) & EMVSIM_CTRL_CWT_EN_MASK)
#define EMVSIM_CTRL_LRC_EN_MASK   (0x10000000U)
#define EMVSIM_CTRL_LRC_EN_SHIFT   (28U)
#define EMVSIM_CTRL_LRC_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_LRC_EN_SHIFT)) & EMVSIM_CTRL_LRC_EN_MASK)
#define EMVSIM_CTRL_CRC_EN_MASK   (0x20000000U)
#define EMVSIM_CTRL_CRC_EN_SHIFT   (29U)
#define EMVSIM_CTRL_CRC_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CRC_EN_SHIFT)) & EMVSIM_CTRL_CRC_EN_MASK)
#define EMVSIM_CTRL_XMT_CRC_LRC_MASK   (0x40000000U)
#define EMVSIM_CTRL_XMT_CRC_LRC_SHIFT   (30U)
#define EMVSIM_CTRL_XMT_CRC_LRC(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_XMT_CRC_LRC_SHIFT)) & EMVSIM_CTRL_XMT_CRC_LRC_MASK)
#define EMVSIM_CTRL_BWT_EN_MASK   (0x80000000U)
#define EMVSIM_CTRL_BWT_EN_SHIFT   (31U)
#define EMVSIM_CTRL_BWT_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_BWT_EN_SHIFT)) & EMVSIM_CTRL_BWT_EN_MASK)
#define ENC_CTRL_CMPIE_MASK   (0x1U)
#define ENC_CTRL_CMPIE_SHIFT   (0U)
#define ENC_CTRL_CMPIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIE_SHIFT)) & ENC_CTRL_CMPIE_MASK)
#define ENC_CTRL_CMPIRQ_MASK   (0x2U)
#define ENC_CTRL_CMPIRQ_SHIFT   (1U)
#define ENC_CTRL_CMPIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIRQ_SHIFT)) & ENC_CTRL_CMPIRQ_MASK)
#define ENC_CTRL_WDE_MASK   (0x4U)
#define ENC_CTRL_WDE_SHIFT   (2U)
#define ENC_CTRL_WDE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_WDE_SHIFT)) & ENC_CTRL_WDE_MASK)
#define ENC_CTRL_DIE_MASK   (0x8U)
#define ENC_CTRL_DIE_SHIFT   (3U)
#define ENC_CTRL_DIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIE_SHIFT)) & ENC_CTRL_DIE_MASK)
#define ENC_CTRL_DIRQ_MASK   (0x10U)
#define ENC_CTRL_DIRQ_SHIFT   (4U)
#define ENC_CTRL_DIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIRQ_SHIFT)) & ENC_CTRL_DIRQ_MASK)
#define ENC_CTRL_XNE_MASK   (0x20U)
#define ENC_CTRL_XNE_SHIFT   (5U)
#define ENC_CTRL_XNE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XNE_SHIFT)) & ENC_CTRL_XNE_MASK)
#define ENC_CTRL_XIP_MASK   (0x40U)
#define ENC_CTRL_XIP_SHIFT   (6U)
#define ENC_CTRL_XIP(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIP_SHIFT)) & ENC_CTRL_XIP_MASK)
#define ENC_CTRL_XIE_MASK   (0x80U)
#define ENC_CTRL_XIE_SHIFT   (7U)
#define ENC_CTRL_XIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIE_SHIFT)) & ENC_CTRL_XIE_MASK)
#define ENC_CTRL_XIRQ_MASK   (0x100U)
#define ENC_CTRL_XIRQ_SHIFT   (8U)
#define ENC_CTRL_XIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIRQ_SHIFT)) & ENC_CTRL_XIRQ_MASK)
#define ENC_CTRL_PH1_MASK   (0x200U)
#define ENC_CTRL_PH1_SHIFT   (9U)
#define ENC_CTRL_PH1(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_PH1_SHIFT)) & ENC_CTRL_PH1_MASK)
#define ENC_CTRL_REV_MASK   (0x400U)
#define ENC_CTRL_REV_SHIFT   (10U)
#define ENC_CTRL_REV(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_REV_SHIFT)) & ENC_CTRL_REV_MASK)
#define ENC_CTRL_SWIP_MASK   (0x800U)
#define ENC_CTRL_SWIP_SHIFT   (11U)
#define ENC_CTRL_SWIP(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_SWIP_SHIFT)) & ENC_CTRL_SWIP_MASK)
#define ENC_CTRL_HNE_MASK   (0x1000U)
#define ENC_CTRL_HNE_SHIFT   (12U)
#define ENC_CTRL_HNE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HNE_SHIFT)) & ENC_CTRL_HNE_MASK)
#define ENC_CTRL_HIP_MASK   (0x2000U)
#define ENC_CTRL_HIP_SHIFT   (13U)
#define ENC_CTRL_HIP(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIP_SHIFT)) & ENC_CTRL_HIP_MASK)
#define ENC_CTRL_HIE_MASK   (0x4000U)
#define ENC_CTRL_HIE_SHIFT   (14U)
#define ENC_CTRL_HIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIE_SHIFT)) & ENC_CTRL_HIE_MASK)
#define ENC_CTRL_HIRQ_MASK   (0x8000U)
#define ENC_CTRL_HIRQ_SHIFT   (15U)
#define ENC_CTRL_HIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIRQ_SHIFT)) & ENC_CTRL_HIRQ_MASK)
#define EWM_CTRL_EWMEN_MASK   (0x1U)
#define EWM_CTRL_EWMEN_SHIFT   (0U)
#define EWM_CTRL_EWMEN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_EWMEN_SHIFT)) & EWM_CTRL_EWMEN_MASK)
#define EWM_CTRL_ASSIN_MASK   (0x2U)
#define EWM_CTRL_ASSIN_SHIFT   (1U)
#define EWM_CTRL_ASSIN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_ASSIN_SHIFT)) & EWM_CTRL_ASSIN_MASK)
#define EWM_CTRL_INEN_MASK   (0x4U)
#define EWM_CTRL_INEN_SHIFT   (2U)
#define EWM_CTRL_INEN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INEN_SHIFT)) & EWM_CTRL_INEN_MASK)
#define EWM_CTRL_INTEN_MASK   (0x8U)
#define EWM_CTRL_INTEN_SHIFT   (3U)
#define EWM_CTRL_INTEN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INTEN_SHIFT)) & EWM_CTRL_INTEN_MASK)
#define PWM_CTRL_DBLEN_MASK   (0x1U)
#define PWM_CTRL_DBLEN_SHIFT   (0U)
#define PWM_CTRL_DBLEN(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLEN_SHIFT)) & PWM_CTRL_DBLEN_MASK)
#define PWM_CTRL_DBLX_MASK   (0x2U)
#define PWM_CTRL_DBLX_SHIFT   (1U)
#define PWM_CTRL_DBLX(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLX_SHIFT)) & PWM_CTRL_DBLX_MASK)
#define PWM_CTRL_LDMOD_MASK   (0x4U)
#define PWM_CTRL_LDMOD_SHIFT   (2U)
#define PWM_CTRL_LDMOD(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDMOD_SHIFT)) & PWM_CTRL_LDMOD_MASK)
#define PWM_CTRL_SPLIT_MASK   (0x8U)
#define PWM_CTRL_SPLIT_SHIFT   (3U)
#define PWM_CTRL_SPLIT(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_SPLIT_SHIFT)) & PWM_CTRL_SPLIT_MASK)
#define PWM_CTRL_PRSC_MASK   (0x70U)
#define PWM_CTRL_PRSC_SHIFT   (4U)
#define PWM_CTRL_PRSC(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_PRSC_SHIFT)) & PWM_CTRL_PRSC_MASK)
#define PWM_CTRL_COMPMODE_MASK   (0x80U)
#define PWM_CTRL_COMPMODE_SHIFT   (7U)
#define PWM_CTRL_COMPMODE(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_COMPMODE_SHIFT)) & PWM_CTRL_COMPMODE_MASK)
#define PWM_CTRL_DT_MASK   (0x300U)
#define PWM_CTRL_DT_SHIFT   (8U)
#define PWM_CTRL_DT(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DT_SHIFT)) & PWM_CTRL_DT_MASK)
#define PWM_CTRL_FULL_MASK   (0x400U)
#define PWM_CTRL_FULL_SHIFT   (10U)
#define PWM_CTRL_FULL(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_FULL_SHIFT)) & PWM_CTRL_FULL_MASK)
#define PWM_CTRL_HALF_MASK   (0x800U)
#define PWM_CTRL_HALF_SHIFT   (11U)
#define PWM_CTRL_HALF(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_HALF_SHIFT)) & PWM_CTRL_HALF_MASK)
#define PWM_CTRL_LDFQ_MASK   (0xF000U)
#define PWM_CTRL_LDFQ_SHIFT   (12U)
#define PWM_CTRL_LDFQ(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDFQ_SHIFT)) & PWM_CTRL_LDFQ_MASK)
#define SRAM_CTRL_RAM_RD_EN_MASK   (0x1U)
#define SRAM_CTRL_RAM_RD_EN_SHIFT   (0U)
#define SRAM_CTRL_RAM_RD_EN(x)   (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_RD_EN_SHIFT)) & SRAM_CTRL_RAM_RD_EN_MASK)
#define SRAM_CTRL_RAM_WR_EN_MASK   (0x2U)
#define SRAM_CTRL_RAM_WR_EN_SHIFT   (1U)
#define SRAM_CTRL_RAM_WR_EN(x)   (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_WR_EN_SHIFT)) & SRAM_CTRL_RAM_WR_EN_MASK)
#define SRAM_CTRL_PWR_EN_MASK   (0x3CU)
#define SRAM_CTRL_PWR_EN_SHIFT   (2U)
#define SRAM_CTRL_PWR_EN(x)   (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_PWR_EN_SHIFT)) & SRAM_CTRL_PWR_EN_MASK)
#define SRAM_CTRL_TAMPER_BLOCK_EN_MASK   (0x40U)
#define SRAM_CTRL_TAMPER_BLOCK_EN_SHIFT   (6U)
#define SRAM_CTRL_TAMPER_BLOCK_EN(x)   (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_BLOCK_EN_SHIFT)) & SRAM_CTRL_TAMPER_BLOCK_EN_MASK)
#define SRAM_CTRL_TAMPER_PWR_OFF_EN_MASK   (0x80U)
#define SRAM_CTRL_TAMPER_PWR_OFF_EN_SHIFT   (7U)
#define SRAM_CTRL_TAMPER_PWR_OFF_EN(x)   (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_PWR_OFF_EN_SHIFT)) & SRAM_CTRL_TAMPER_PWR_OFF_EN_MASK)
#define SRAM_CTRL_LOCK_BIT_MASK   (0xFF0000U)
#define SRAM_CTRL_LOCK_BIT_SHIFT   (16U)
#define SRAM_CTRL_LOCK_BIT(x)   (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_LOCK_BIT_SHIFT)) & SRAM_CTRL_LOCK_BIT_MASK)
#define SSARC_LP_CTRL_DIS_HW_REQ_MASK   (0x8000000U)
#define SSARC_LP_CTRL_DIS_HW_REQ_SHIFT   (27U)
#define SSARC_LP_CTRL_DIS_HW_REQ(x)   (((uint32_t)(((uint32_t)(x)) << SSARC_LP_CTRL_DIS_HW_REQ_SHIFT)) & SSARC_LP_CTRL_DIS_HW_REQ_MASK)
#define SSARC_LP_CTRL_SW_RESET_MASK   (0x80000000U)
#define SSARC_LP_CTRL_SW_RESET_SHIFT   (31U)
#define SSARC_LP_CTRL_SW_RESET(x)   (((uint32_t)(((uint32_t)(x)) << SSARC_LP_CTRL_SW_RESET_SHIFT)) & SSARC_LP_CTRL_SW_RESET_MASK)
INT_MASK - Interrupt Mask Register
#define EMVSIM_INT_MASK_RDT_IM_MASK   (0x1U)
#define EMVSIM_INT_MASK_RDT_IM_SHIFT   (0U)
#define EMVSIM_INT_MASK_RDT_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RDT_IM_SHIFT)) & EMVSIM_INT_MASK_RDT_IM_MASK)
#define EMVSIM_INT_MASK_TC_IM_MASK   (0x2U)
#define EMVSIM_INT_MASK_TC_IM_SHIFT   (1U)
#define EMVSIM_INT_MASK_TC_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TC_IM_SHIFT)) & EMVSIM_INT_MASK_TC_IM_MASK)
#define EMVSIM_INT_MASK_RFO_IM_MASK   (0x4U)
#define EMVSIM_INT_MASK_RFO_IM_SHIFT   (2U)
#define EMVSIM_INT_MASK_RFO_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RFO_IM_SHIFT)) & EMVSIM_INT_MASK_RFO_IM_MASK)
#define EMVSIM_INT_MASK_ETC_IM_MASK   (0x8U)
#define EMVSIM_INT_MASK_ETC_IM_SHIFT   (3U)
#define EMVSIM_INT_MASK_ETC_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_ETC_IM_SHIFT)) & EMVSIM_INT_MASK_ETC_IM_MASK)
#define EMVSIM_INT_MASK_TFE_IM_MASK   (0x10U)
#define EMVSIM_INT_MASK_TFE_IM_SHIFT   (4U)
#define EMVSIM_INT_MASK_TFE_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TFE_IM_SHIFT)) & EMVSIM_INT_MASK_TFE_IM_MASK)
#define EMVSIM_INT_MASK_TNACK_IM_MASK   (0x20U)
#define EMVSIM_INT_MASK_TNACK_IM_SHIFT   (5U)
#define EMVSIM_INT_MASK_TNACK_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TNACK_IM_SHIFT)) & EMVSIM_INT_MASK_TNACK_IM_MASK)
#define EMVSIM_INT_MASK_TFF_IM_MASK   (0x40U)
#define EMVSIM_INT_MASK_TFF_IM_SHIFT   (6U)
#define EMVSIM_INT_MASK_TFF_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TFF_IM_SHIFT)) & EMVSIM_INT_MASK_TFF_IM_MASK)
#define EMVSIM_INT_MASK_TDT_IM_MASK   (0x80U)
#define EMVSIM_INT_MASK_TDT_IM_SHIFT   (7U)
#define EMVSIM_INT_MASK_TDT_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TDT_IM_SHIFT)) & EMVSIM_INT_MASK_TDT_IM_MASK)
#define EMVSIM_INT_MASK_GPCNT0_IM_MASK   (0x100U)
#define EMVSIM_INT_MASK_GPCNT0_IM_SHIFT   (8U)
#define EMVSIM_INT_MASK_GPCNT0_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_GPCNT0_IM_SHIFT)) & EMVSIM_INT_MASK_GPCNT0_IM_MASK)
#define EMVSIM_INT_MASK_CWT_ERR_IM_MASK   (0x200U)
#define EMVSIM_INT_MASK_CWT_ERR_IM_SHIFT   (9U)
#define EMVSIM_INT_MASK_CWT_ERR_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_CWT_ERR_IM_SHIFT)) & EMVSIM_INT_MASK_CWT_ERR_IM_MASK)
#define EMVSIM_INT_MASK_RNACK_IM_MASK   (0x400U)
#define EMVSIM_INT_MASK_RNACK_IM_SHIFT   (10U)
#define EMVSIM_INT_MASK_RNACK_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RNACK_IM_SHIFT)) & EMVSIM_INT_MASK_RNACK_IM_MASK)
#define EMVSIM_INT_MASK_BWT_ERR_IM_MASK   (0x800U)
#define EMVSIM_INT_MASK_BWT_ERR_IM_SHIFT   (11U)
#define EMVSIM_INT_MASK_BWT_ERR_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_BWT_ERR_IM_SHIFT)) & EMVSIM_INT_MASK_BWT_ERR_IM_MASK)
#define EMVSIM_INT_MASK_BGT_ERR_IM_MASK   (0x1000U)
#define EMVSIM_INT_MASK_BGT_ERR_IM_SHIFT   (12U)
#define EMVSIM_INT_MASK_BGT_ERR_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_BGT_ERR_IM_SHIFT)) & EMVSIM_INT_MASK_BGT_ERR_IM_MASK)
#define EMVSIM_INT_MASK_GPCNT1_IM_MASK   (0x2000U)
#define EMVSIM_INT_MASK_GPCNT1_IM_SHIFT   (13U)
#define EMVSIM_INT_MASK_GPCNT1_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_GPCNT1_IM_SHIFT)) & EMVSIM_INT_MASK_GPCNT1_IM_MASK)
#define EMVSIM_INT_MASK_RX_DATA_IM_MASK   (0x4000U)
#define EMVSIM_INT_MASK_RX_DATA_IM_SHIFT   (14U)
#define EMVSIM_INT_MASK_RX_DATA_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RX_DATA_IM_SHIFT)) & EMVSIM_INT_MASK_RX_DATA_IM_MASK)
#define EMVSIM_INT_MASK_PEF_IM_MASK   (0x8000U)
#define EMVSIM_INT_MASK_PEF_IM_SHIFT   (15U)
#define EMVSIM_INT_MASK_PEF_IM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_PEF_IM_SHIFT)) & EMVSIM_INT_MASK_PEF_IM_MASK)
RX_THD - Receiver Threshold Register
#define EMVSIM_RX_THD_RDT_MASK   (0xFU)
#define EMVSIM_RX_THD_RDT_SHIFT   (0U)
#define EMVSIM_RX_THD_RDT(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_THD_RDT_SHIFT)) & EMVSIM_RX_THD_RDT_MASK)
#define EMVSIM_RX_THD_RNCK_THD_MASK   (0xF00U)
#define EMVSIM_RX_THD_RNCK_THD_SHIFT   (8U)
#define EMVSIM_RX_THD_RNCK_THD(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_THD_RNCK_THD_SHIFT)) & EMVSIM_RX_THD_RNCK_THD_MASK)
TX_THD - Transmitter Threshold Register
#define EMVSIM_TX_THD_TDT_MASK   (0xFU)
#define EMVSIM_TX_THD_TDT_SHIFT   (0U)
#define EMVSIM_TX_THD_TDT(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_THD_TDT_SHIFT)) & EMVSIM_TX_THD_TDT_MASK)
#define EMVSIM_TX_THD_TNCK_THD_MASK   (0xF00U)
#define EMVSIM_TX_THD_TNCK_THD_SHIFT   (8U)
#define EMVSIM_TX_THD_TNCK_THD(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_THD_TNCK_THD_SHIFT)) & EMVSIM_TX_THD_TNCK_THD_MASK)
RX_STATUS - Receive Status Register
#define EMVSIM_RX_STATUS_RFO_MASK   (0x1U)
#define EMVSIM_RX_STATUS_RFO_SHIFT   (0U)
#define EMVSIM_RX_STATUS_RFO(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RFO_SHIFT)) & EMVSIM_RX_STATUS_RFO_MASK)
#define EMVSIM_RX_STATUS_RX_DATA_MASK   (0x10U)
#define EMVSIM_RX_STATUS_RX_DATA_SHIFT   (4U)
#define EMVSIM_RX_STATUS_RX_DATA(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RX_DATA_SHIFT)) & EMVSIM_RX_STATUS_RX_DATA_MASK)
#define EMVSIM_RX_STATUS_RDTF_MASK   (0x20U)
#define EMVSIM_RX_STATUS_RDTF_SHIFT   (5U)
#define EMVSIM_RX_STATUS_RDTF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RDTF_SHIFT)) & EMVSIM_RX_STATUS_RDTF_MASK)
#define EMVSIM_RX_STATUS_LRC_OK_MASK   (0x40U)
#define EMVSIM_RX_STATUS_LRC_OK_SHIFT   (6U)
#define EMVSIM_RX_STATUS_LRC_OK(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_LRC_OK_SHIFT)) & EMVSIM_RX_STATUS_LRC_OK_MASK)
#define EMVSIM_RX_STATUS_CRC_OK_MASK   (0x80U)
#define EMVSIM_RX_STATUS_CRC_OK_SHIFT   (7U)
#define EMVSIM_RX_STATUS_CRC_OK(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_CRC_OK_SHIFT)) & EMVSIM_RX_STATUS_CRC_OK_MASK)
#define EMVSIM_RX_STATUS_CWT_ERR_MASK   (0x100U)
#define EMVSIM_RX_STATUS_CWT_ERR_SHIFT   (8U)
#define EMVSIM_RX_STATUS_CWT_ERR(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_CWT_ERR_SHIFT)) & EMVSIM_RX_STATUS_CWT_ERR_MASK)
#define EMVSIM_RX_STATUS_RTE_MASK   (0x200U)
#define EMVSIM_RX_STATUS_RTE_SHIFT   (9U)
#define EMVSIM_RX_STATUS_RTE(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RTE_SHIFT)) & EMVSIM_RX_STATUS_RTE_MASK)
#define EMVSIM_RX_STATUS_BWT_ERR_MASK   (0x400U)
#define EMVSIM_RX_STATUS_BWT_ERR_SHIFT   (10U)
#define EMVSIM_RX_STATUS_BWT_ERR(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_BWT_ERR_SHIFT)) & EMVSIM_RX_STATUS_BWT_ERR_MASK)
#define EMVSIM_RX_STATUS_BGT_ERR_MASK   (0x800U)
#define EMVSIM_RX_STATUS_BGT_ERR_SHIFT   (11U)
#define EMVSIM_RX_STATUS_BGT_ERR(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_BGT_ERR_SHIFT)) & EMVSIM_RX_STATUS_BGT_ERR_MASK)
#define EMVSIM_RX_STATUS_PEF_MASK   (0x1000U)
#define EMVSIM_RX_STATUS_PEF_SHIFT   (12U)
#define EMVSIM_RX_STATUS_PEF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_PEF_SHIFT)) & EMVSIM_RX_STATUS_PEF_MASK)
#define EMVSIM_RX_STATUS_FEF_MASK   (0x2000U)
#define EMVSIM_RX_STATUS_FEF_SHIFT   (13U)
#define EMVSIM_RX_STATUS_FEF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_FEF_SHIFT)) & EMVSIM_RX_STATUS_FEF_MASK)
#define EMVSIM_RX_STATUS_RX_WPTR_MASK   (0xF0000U)
#define EMVSIM_RX_STATUS_RX_WPTR_SHIFT   (16U)
#define EMVSIM_RX_STATUS_RX_WPTR(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RX_WPTR_SHIFT)) & EMVSIM_RX_STATUS_RX_WPTR_MASK)
#define EMVSIM_RX_STATUS_RX_CNT_MASK   (0xF000000U)
#define EMVSIM_RX_STATUS_RX_CNT_SHIFT   (24U)
#define EMVSIM_RX_STATUS_RX_CNT(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RX_CNT_SHIFT)) & EMVSIM_RX_STATUS_RX_CNT_MASK)
TX_STATUS - Transmitter Status Register
#define EMVSIM_TX_STATUS_TNTE_MASK   (0x1U)
#define EMVSIM_TX_STATUS_TNTE_SHIFT   (0U)
#define EMVSIM_TX_STATUS_TNTE(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TNTE_SHIFT)) & EMVSIM_TX_STATUS_TNTE_MASK)
#define EMVSIM_TX_STATUS_TFE_MASK   (0x8U)
#define EMVSIM_TX_STATUS_TFE_SHIFT   (3U)
#define EMVSIM_TX_STATUS_TFE(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TFE_SHIFT)) & EMVSIM_TX_STATUS_TFE_MASK)
#define EMVSIM_TX_STATUS_ETCF_MASK   (0x10U)
#define EMVSIM_TX_STATUS_ETCF_SHIFT   (4U)
#define EMVSIM_TX_STATUS_ETCF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_ETCF_SHIFT)) & EMVSIM_TX_STATUS_ETCF_MASK)
#define EMVSIM_TX_STATUS_TCF_MASK   (0x20U)
#define EMVSIM_TX_STATUS_TCF_SHIFT   (5U)
#define EMVSIM_TX_STATUS_TCF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TCF_SHIFT)) & EMVSIM_TX_STATUS_TCF_MASK)
#define EMVSIM_TX_STATUS_TFF_MASK   (0x40U)
#define EMVSIM_TX_STATUS_TFF_SHIFT   (6U)
#define EMVSIM_TX_STATUS_TFF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TFF_SHIFT)) & EMVSIM_TX_STATUS_TFF_MASK)
#define EMVSIM_TX_STATUS_TDTF_MASK   (0x80U)
#define EMVSIM_TX_STATUS_TDTF_SHIFT   (7U)
#define EMVSIM_TX_STATUS_TDTF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TDTF_SHIFT)) & EMVSIM_TX_STATUS_TDTF_MASK)
#define EMVSIM_TX_STATUS_GPCNT0_TO_MASK   (0x100U)
#define EMVSIM_TX_STATUS_GPCNT0_TO_SHIFT   (8U)
#define EMVSIM_TX_STATUS_GPCNT0_TO(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_GPCNT0_TO_SHIFT)) & EMVSIM_TX_STATUS_GPCNT0_TO_MASK)
#define EMVSIM_TX_STATUS_GPCNT1_TO_MASK   (0x200U)
#define EMVSIM_TX_STATUS_GPCNT1_TO_SHIFT   (9U)
#define EMVSIM_TX_STATUS_GPCNT1_TO(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_GPCNT1_TO_SHIFT)) & EMVSIM_TX_STATUS_GPCNT1_TO_MASK)
#define EMVSIM_TX_STATUS_TX_RPTR_MASK   (0xF0000U)
#define EMVSIM_TX_STATUS_TX_RPTR_SHIFT   (16U)
#define EMVSIM_TX_STATUS_TX_RPTR(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TX_RPTR_SHIFT)) & EMVSIM_TX_STATUS_TX_RPTR_MASK)
#define EMVSIM_TX_STATUS_TX_CNT_MASK   (0xF000000U)
#define EMVSIM_TX_STATUS_TX_CNT_SHIFT   (24U)
#define EMVSIM_TX_STATUS_TX_CNT(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TX_CNT_SHIFT)) & EMVSIM_TX_STATUS_TX_CNT_MASK)
PCSR - Port Control and Status Register
#define EMVSIM_PCSR_SAPD_MASK   (0x1U)
#define EMVSIM_PCSR_SAPD_SHIFT   (0U)
#define EMVSIM_PCSR_SAPD(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SAPD_SHIFT)) & EMVSIM_PCSR_SAPD_MASK)
#define EMVSIM_PCSR_SVCC_EN_MASK   (0x2U)
#define EMVSIM_PCSR_SVCC_EN_SHIFT   (1U)
#define EMVSIM_PCSR_SVCC_EN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SVCC_EN_SHIFT)) & EMVSIM_PCSR_SVCC_EN_MASK)
#define EMVSIM_PCSR_VCCENP_MASK   (0x4U)
#define EMVSIM_PCSR_VCCENP_SHIFT   (2U)
#define EMVSIM_PCSR_VCCENP(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_VCCENP_SHIFT)) & EMVSIM_PCSR_VCCENP_MASK)
#define EMVSIM_PCSR_SRST_MASK   (0x8U)
#define EMVSIM_PCSR_SRST_SHIFT   (3U)
#define EMVSIM_PCSR_SRST(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SRST_SHIFT)) & EMVSIM_PCSR_SRST_MASK)
#define EMVSIM_PCSR_SCEN_MASK   (0x10U)
#define EMVSIM_PCSR_SCEN_SHIFT   (4U)
#define EMVSIM_PCSR_SCEN(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SCEN_SHIFT)) & EMVSIM_PCSR_SCEN_MASK)
#define EMVSIM_PCSR_SCSP_MASK   (0x20U)
#define EMVSIM_PCSR_SCSP_SHIFT   (5U)
#define EMVSIM_PCSR_SCSP(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SCSP_SHIFT)) & EMVSIM_PCSR_SCSP_MASK)
#define EMVSIM_PCSR_SPD_MASK   (0x80U)
#define EMVSIM_PCSR_SPD_SHIFT   (7U)
#define EMVSIM_PCSR_SPD(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPD_SHIFT)) & EMVSIM_PCSR_SPD_MASK)
#define EMVSIM_PCSR_SPDIM_MASK   (0x1000000U)
#define EMVSIM_PCSR_SPDIM_SHIFT   (24U)
#define EMVSIM_PCSR_SPDIM(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDIM_SHIFT)) & EMVSIM_PCSR_SPDIM_MASK)
#define EMVSIM_PCSR_SPDIF_MASK   (0x2000000U)
#define EMVSIM_PCSR_SPDIF_SHIFT   (25U)
#define EMVSIM_PCSR_SPDIF(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDIF_SHIFT)) & EMVSIM_PCSR_SPDIF_MASK)
#define EMVSIM_PCSR_SPDP_MASK   (0x4000000U)
#define EMVSIM_PCSR_SPDP_SHIFT   (26U)
#define EMVSIM_PCSR_SPDP(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDP_SHIFT)) & EMVSIM_PCSR_SPDP_MASK)
#define EMVSIM_PCSR_SPDES_MASK   (0x8000000U)
#define EMVSIM_PCSR_SPDES_SHIFT   (27U)
#define EMVSIM_PCSR_SPDES(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDES_SHIFT)) & EMVSIM_PCSR_SPDES_MASK)
RX_BUF - Receive Data Read Buffer
#define EMVSIM_RX_BUF_RX_BYTE_MASK   (0xFFU)
#define EMVSIM_RX_BUF_RX_BYTE_SHIFT   (0U)
#define EMVSIM_RX_BUF_RX_BYTE(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_BUF_RX_BYTE_SHIFT)) & EMVSIM_RX_BUF_RX_BYTE_MASK)
TX_BUF - Transmit Data Buffer
#define EMVSIM_TX_BUF_TX_BYTE_MASK   (0xFFU)
#define EMVSIM_TX_BUF_TX_BYTE_SHIFT   (0U)
#define EMVSIM_TX_BUF_TX_BYTE(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_BUF_TX_BYTE_SHIFT)) & EMVSIM_TX_BUF_TX_BYTE_MASK)
TX_GETU - Transmitter Guard ETU Value Register
#define EMVSIM_TX_GETU_GETU_MASK   (0xFFU)
#define EMVSIM_TX_GETU_GETU_SHIFT   (0U)
#define EMVSIM_TX_GETU_GETU(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_GETU_GETU_SHIFT)) & EMVSIM_TX_GETU_GETU_MASK)
CWT_VAL - Character Wait Time Value Register
#define EMVSIM_CWT_VAL_CWT_MASK   (0xFFFFU)
#define EMVSIM_CWT_VAL_CWT_SHIFT   (0U)
#define EMVSIM_CWT_VAL_CWT(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_CWT_VAL_CWT_SHIFT)) & EMVSIM_CWT_VAL_CWT_MASK)
BWT_VAL - Block Wait Time Value Register
#define EMVSIM_BWT_VAL_BWT_MASK   (0xFFFFFFFFU)
#define EMVSIM_BWT_VAL_BWT_SHIFT   (0U)
#define EMVSIM_BWT_VAL_BWT(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_BWT_VAL_BWT_SHIFT)) & EMVSIM_BWT_VAL_BWT_MASK)
BGT_VAL - Block Guard Time Value Register
#define EMVSIM_BGT_VAL_BGT_MASK   (0xFFFFU)
#define EMVSIM_BGT_VAL_BGT_SHIFT   (0U)
#define EMVSIM_BGT_VAL_BGT(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_BGT_VAL_BGT_SHIFT)) & EMVSIM_BGT_VAL_BGT_MASK)
GPCNT0_VAL - General Purpose Counter 0 Timeout Value Register
#define EMVSIM_GPCNT0_VAL_GPCNT0_MASK   (0xFFFFU)
#define EMVSIM_GPCNT0_VAL_GPCNT0_SHIFT   (0U)
#define EMVSIM_GPCNT0_VAL_GPCNT0(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_GPCNT0_VAL_GPCNT0_SHIFT)) & EMVSIM_GPCNT0_VAL_GPCNT0_MASK)
GPCNT1_VAL - General Purpose Counter 1 Timeout Value
#define EMVSIM_GPCNT1_VAL_GPCNT1_MASK   (0xFFFFU)
#define EMVSIM_GPCNT1_VAL_GPCNT1_SHIFT   (0U)
#define EMVSIM_GPCNT1_VAL_GPCNT1(x)   (((uint32_t)(((uint32_t)(x)) << EMVSIM_GPCNT1_VAL_GPCNT1_SHIFT)) & EMVSIM_GPCNT1_VAL_GPCNT1_MASK)
◆ EMVSIM_BGT_VAL_BGT [1/2]
#define EMVSIM_BGT_VAL_BGT (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_BGT_VAL_BGT_SHIFT)) & EMVSIM_BGT_VAL_BGT_MASK)
BGT - Block Guard Time Value
◆ EMVSIM_BGT_VAL_BGT [2/2]
◆ EMVSIM_BWT_VAL_BWT [1/2]
#define EMVSIM_BWT_VAL_BWT (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_BWT_VAL_BWT_SHIFT)) & EMVSIM_BWT_VAL_BWT_MASK)
BWT - Block Wait Time Value
◆ EMVSIM_BWT_VAL_BWT [2/2]
◆ EMVSIM_CLKCFG_CLK_PRSC [1/2]
#define EMVSIM_CLKCFG_CLK_PRSC (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CLKCFG_CLK_PRSC_SHIFT)) & EMVSIM_CLKCFG_CLK_PRSC_MASK)
CLK_PRSC - Clock Prescaler Value
◆ EMVSIM_CLKCFG_CLK_PRSC [2/2]
◆ EMVSIM_CLKCFG_GPCNT0_CLK_SEL [1/2]
#define EMVSIM_CLKCFG_GPCNT0_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CLKCFG_GPCNT0_CLK_SEL_SHIFT)) & EMVSIM_CLKCFG_GPCNT0_CLK_SEL_MASK)
GPCNT0_CLK_SEL - General Purpose Counter 0 Clock Select 0b00..Disabled / Reset 0b01..Card Clock 0b10..Receive Clock 0b11..ETU Clock (transmit clock)
◆ EMVSIM_CLKCFG_GPCNT0_CLK_SEL [2/2]
◆ EMVSIM_CLKCFG_GPCNT1_CLK_SEL [1/2]
#define EMVSIM_CLKCFG_GPCNT1_CLK_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CLKCFG_GPCNT1_CLK_SEL_SHIFT)) & EMVSIM_CLKCFG_GPCNT1_CLK_SEL_MASK)
GPCNT1_CLK_SEL - General Purpose Counter 1 Clock Select 0b00..Disabled / Reset 0b01..Card Clock 0b10..Receive Clock 0b11..ETU Clock (transmit clock)
◆ EMVSIM_CLKCFG_GPCNT1_CLK_SEL [2/2]
◆ EMVSIM_CTRL_ANACK [1/2]
#define EMVSIM_CTRL_ANACK (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_ANACK_SHIFT)) & EMVSIM_CTRL_ANACK_MASK)
ANACK - Auto NACK Enable 0b0..NACK generation on errors disabled 0b1..NACK generation on errors enabled
◆ EMVSIM_CTRL_ANACK [2/2]
◆ EMVSIM_CTRL_BWT_EN [1/2]
#define EMVSIM_CTRL_BWT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_BWT_EN_SHIFT)) & EMVSIM_CTRL_BWT_EN_MASK)
BWT_EN - Block Wait Time Counter Enable 0b0..Disable BWT, BGT Counters 0b1..Enable BWT, BGT Counters
◆ EMVSIM_CTRL_BWT_EN [2/2]
◆ EMVSIM_CTRL_CRC_EN [1/2]
#define EMVSIM_CTRL_CRC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CRC_EN_SHIFT)) & EMVSIM_CTRL_CRC_EN_MASK)
CRC_EN - CRC Enable 0b0..16-bit Cyclic Redundancy Checking disabled 0b1..16-bit Cyclic Redundancy Checking enabled
◆ EMVSIM_CTRL_CRC_EN [2/2]
◆ EMVSIM_CTRL_CRC_IN_FLIP [1/2]
#define EMVSIM_CTRL_CRC_IN_FLIP (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CRC_IN_FLIP_SHIFT)) & EMVSIM_CTRL_CRC_IN_FLIP_MASK)
CRC_IN_FLIP - CRC Input Byte's Bit Reversal or Flip Control 0b0..Bits in the input byte are not reversed (i.e. 7:0 remain 7:0) before the CRC calculation 0b1..Bits in the input byte are reversed (i.e. 7:0 becomes 0:7) before CRC calculation
◆ EMVSIM_CTRL_CRC_IN_FLIP [2/2]
◆ EMVSIM_CTRL_CRC_OUT_FLIP [1/2]
#define EMVSIM_CTRL_CRC_OUT_FLIP (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CRC_OUT_FLIP_SHIFT)) & EMVSIM_CTRL_CRC_OUT_FLIP_MASK)
CRC_OUT_FLIP - CRC Output Value Bit Reversal or Flip 0b0..Bits within the CRC output bytes are not reversed i.e. 15:0 remains 15:0 0b1..Bits within the CRC output bytes are reversed i.e. 15:0 becomes {8:15,0:7}
◆ EMVSIM_CTRL_CRC_OUT_FLIP [2/2]
◆ EMVSIM_CTRL_CWT_EN [1/2]
#define EMVSIM_CTRL_CWT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_CWT_EN_SHIFT)) & EMVSIM_CTRL_CWT_EN_MASK)
CWT_EN - Character Wait Time Counter Enable 0b0..Character Wait time Counter is disabled 0b1..Character Wait time counter is enabled
◆ EMVSIM_CTRL_CWT_EN [2/2]
◆ EMVSIM_CTRL_DOZE_EN [1/2]
#define EMVSIM_CTRL_DOZE_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_DOZE_EN_SHIFT)) & EMVSIM_CTRL_DOZE_EN_MASK)
DOZE_EN - Doze Enable 0b0..DOZE instruction gates all internal EMVSIM clocks as well as the Smart Card clock when the transmit FIFO is empty 0b1..DOZE instruction has no effect on EMVSIM module
◆ EMVSIM_CTRL_DOZE_EN [2/2]
◆ EMVSIM_CTRL_FLSH_RX [1/2]
#define EMVSIM_CTRL_FLSH_RX (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_FLSH_RX_SHIFT)) & EMVSIM_CTRL_FLSH_RX_MASK)
FLSH_RX - Flush Receiver Bit 0b0..EMVSIM Receiver normal operation 0b1..EMVSIM Receiver held in Reset
◆ EMVSIM_CTRL_FLSH_RX [2/2]
◆ EMVSIM_CTRL_FLSH_TX [1/2]
#define EMVSIM_CTRL_FLSH_TX (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_FLSH_TX_SHIFT)) & EMVSIM_CTRL_FLSH_TX_MASK)
FLSH_TX - Flush Transmitter Bit 0b0..EMVSIM Transmitter normal operation 0b1..EMVSIM Transmitter held in Reset
◆ EMVSIM_CTRL_FLSH_TX [2/2]
◆ EMVSIM_CTRL_IC [1/2]
#define EMVSIM_CTRL_IC (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_IC_SHIFT)) & EMVSIM_CTRL_IC_MASK)
IC - Inverse Convention 0b0..Direction convention transfers enabled 0b1..Inverse convention transfers enabled
◆ EMVSIM_CTRL_IC [2/2]
◆ EMVSIM_CTRL_ICM [1/2]
#define EMVSIM_CTRL_ICM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_ICM_SHIFT)) & EMVSIM_CTRL_ICM_MASK)
ICM - Initial Character Mode 0b0..Initial Character Mode disabled 0b1..Initial Character Mode enabled
◆ EMVSIM_CTRL_ICM [2/2]
◆ EMVSIM_CTRL_INV_CRC_VAL [1/2]
#define EMVSIM_CTRL_INV_CRC_VAL (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_INV_CRC_VAL_SHIFT)) & EMVSIM_CTRL_INV_CRC_VAL_MASK)
INV_CRC_VAL - Invert bits in the CRC Output Value 0b0..Bits in CRC Output value are not inverted. 0b1..Bits in CRC Output value are inverted.
◆ EMVSIM_CTRL_INV_CRC_VAL [2/2]
◆ EMVSIM_CTRL_KILL_CLOCKS [1/2]
#define EMVSIM_CTRL_KILL_CLOCKS (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_KILL_CLOCKS_SHIFT)) & EMVSIM_CTRL_KILL_CLOCKS_MASK)
KILL_CLOCKS - Kill all internal clocks 0b0..EMVSIM input clock enabled 0b1..EMVSIM input clock is disabled
◆ EMVSIM_CTRL_KILL_CLOCKS [2/2]
◆ EMVSIM_CTRL_LRC_EN [1/2]
#define EMVSIM_CTRL_LRC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_LRC_EN_SHIFT)) & EMVSIM_CTRL_LRC_EN_MASK)
LRC_EN - LRC Enable 0b0..8-bit Linear Redundancy Checking disabled 0b1..8-bit Linear Redundancy Checking enabled
◆ EMVSIM_CTRL_LRC_EN [2/2]
◆ EMVSIM_CTRL_ONACK [1/2]
#define EMVSIM_CTRL_ONACK (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_ONACK_SHIFT)) & EMVSIM_CTRL_ONACK_MASK)
ONACK - Overrun NACK Enable 0b0..NACK generation on overrun is disabled 0b1..NACK generation on overrun is enabled
◆ EMVSIM_CTRL_ONACK [2/2]
◆ EMVSIM_CTRL_RCV_EN [1/2]
#define EMVSIM_CTRL_RCV_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_RCV_EN_SHIFT)) & EMVSIM_CTRL_RCV_EN_MASK)
RCV_EN - Receiver Enable 0b0..EMVSIM Receiver disabled 0b1..EMVSIM Receiver enabled
◆ EMVSIM_CTRL_RCV_EN [2/2]
◆ EMVSIM_CTRL_RCVR_11 [1/2]
#define EMVSIM_CTRL_RCVR_11 (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_RCVR_11_SHIFT)) & EMVSIM_CTRL_RCVR_11_MASK)
RCVR_11 - Receiver 11 ETU Mode Enable 0b0..Receiver configured for 12 ETU operation mode 0b1..Receiver configured for 11 ETU operation mode
◆ EMVSIM_CTRL_RCVR_11 [2/2]
◆ EMVSIM_CTRL_RX_DMA_EN [1/2]
#define EMVSIM_CTRL_RX_DMA_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_RX_DMA_EN_SHIFT)) & EMVSIM_CTRL_RX_DMA_EN_MASK)
RX_DMA_EN - Receive DMA Enable 0b0..No DMA Read Request asserted for Receiver 0b1..DMA Read Request asserted for Receiver
◆ EMVSIM_CTRL_RX_DMA_EN [2/2]
◆ EMVSIM_CTRL_STOP_EN [1/2]
#define EMVSIM_CTRL_STOP_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_STOP_EN_SHIFT)) & EMVSIM_CTRL_STOP_EN_MASK)
STOP_EN - STOP Enable 0b0..STOP instruction shuts down all EMVSIM clocks 0b1..STOP instruction shuts down all clocks except for the Smart Card Clock (SCK) (clock provided to Smart Card)
◆ EMVSIM_CTRL_STOP_EN [2/2]
◆ EMVSIM_CTRL_SW_RST [1/2]
#define EMVSIM_CTRL_SW_RST (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_SW_RST_SHIFT)) & EMVSIM_CTRL_SW_RST_MASK)
SW_RST - Software Reset Bit 0b0..EMVSIM Normal operation 0b1..EMVSIM held in Reset
◆ EMVSIM_CTRL_SW_RST [2/2]
◆ EMVSIM_CTRL_TX_DMA_EN [1/2]
#define EMVSIM_CTRL_TX_DMA_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_TX_DMA_EN_SHIFT)) & EMVSIM_CTRL_TX_DMA_EN_MASK)
TX_DMA_EN - Transmit DMA Enable 0b0..No DMA Write Request asserted for Transmitter 0b1..DMA Write Request asserted for Transmitter
◆ EMVSIM_CTRL_TX_DMA_EN [2/2]
◆ EMVSIM_CTRL_XMT_CRC_LRC [1/2]
#define EMVSIM_CTRL_XMT_CRC_LRC (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_XMT_CRC_LRC_SHIFT)) & EMVSIM_CTRL_XMT_CRC_LRC_MASK)
XMT_CRC_LRC - Transmit CRC or LRC Enable 0b0..No CRC or LRC value is transmitted 0b1..Transmit LRC or CRC info when FIFO empties (whichever is enabled)
◆ EMVSIM_CTRL_XMT_CRC_LRC [2/2]
◆ EMVSIM_CTRL_XMT_EN [1/2]
#define EMVSIM_CTRL_XMT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CTRL_XMT_EN_SHIFT)) & EMVSIM_CTRL_XMT_EN_MASK)
XMT_EN - Transmitter Enable 0b0..EMVSIM Transmitter disabled 0b1..EMVSIM Transmitter enabled
◆ EMVSIM_CTRL_XMT_EN [2/2]
◆ EMVSIM_CWT_VAL_CWT [1/2]
#define EMVSIM_CWT_VAL_CWT (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_CWT_VAL_CWT_SHIFT)) & EMVSIM_CWT_VAL_CWT_MASK)
CWT - Character Wait Time Value
◆ EMVSIM_CWT_VAL_CWT [2/2]
◆ EMVSIM_DIVISOR_DIVISOR_VALUE [1/2]
#define EMVSIM_DIVISOR_DIVISOR_VALUE (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_DIVISOR_DIVISOR_VALUE_SHIFT)) & EMVSIM_DIVISOR_DIVISOR_VALUE_MASK)
DIVISOR_VALUE - Divisor (F/D) Value 0b000000000-0b000000100..Invalid. As per ISO 7816 specification, minimum value of F/D is 5 0b000000101-0b011111111..Divisor value F/D
◆ EMVSIM_DIVISOR_DIVISOR_VALUE [2/2]
◆ EMVSIM_GPCNT0_VAL_GPCNT0 [1/2]
#define EMVSIM_GPCNT0_VAL_GPCNT0 (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_GPCNT0_VAL_GPCNT0_SHIFT)) & EMVSIM_GPCNT0_VAL_GPCNT0_MASK)
GPCNT0 - General Purpose Counter 0 Timeout Value
◆ EMVSIM_GPCNT0_VAL_GPCNT0 [2/2]
◆ EMVSIM_GPCNT1_VAL_GPCNT1 [1/2]
#define EMVSIM_GPCNT1_VAL_GPCNT1 (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_GPCNT1_VAL_GPCNT1_SHIFT)) & EMVSIM_GPCNT1_VAL_GPCNT1_MASK)
GPCNT1 - General Purpose Counter 1 Timeout Value
◆ EMVSIM_GPCNT1_VAL_GPCNT1 [2/2]
◆ EMVSIM_INT_MASK_BGT_ERR_IM [1/2]
#define EMVSIM_INT_MASK_BGT_ERR_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_BGT_ERR_IM_SHIFT)) & EMVSIM_INT_MASK_BGT_ERR_IM_MASK)
BGT_ERR_IM - Block Guard Time Error Interrupt 0b0..BGT_ERR interrupt enabled 0b1..BGT_ERR interrupt masked
◆ EMVSIM_INT_MASK_BGT_ERR_IM [2/2]
◆ EMVSIM_INT_MASK_BWT_ERR_IM [1/2]
#define EMVSIM_INT_MASK_BWT_ERR_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_BWT_ERR_IM_SHIFT)) & EMVSIM_INT_MASK_BWT_ERR_IM_MASK)
BWT_ERR_IM - Block Wait Time Error Interrupt Mask 0b0..BWT_ERR interrupt enabled 0b1..BWT_ERR interrupt masked
◆ EMVSIM_INT_MASK_BWT_ERR_IM [2/2]
◆ EMVSIM_INT_MASK_CWT_ERR_IM [1/2]
#define EMVSIM_INT_MASK_CWT_ERR_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_CWT_ERR_IM_SHIFT)) & EMVSIM_INT_MASK_CWT_ERR_IM_MASK)
CWT_ERR_IM - Character Wait Time Error Interrupt Mask 0b0..CWT_ERR interrupt enabled 0b1..CWT_ERR interrupt masked
◆ EMVSIM_INT_MASK_CWT_ERR_IM [2/2]
◆ EMVSIM_INT_MASK_ETC_IM [1/2]
#define EMVSIM_INT_MASK_ETC_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_ETC_IM_SHIFT)) & EMVSIM_INT_MASK_ETC_IM_MASK)
ETC_IM - Early Transmit Complete Interrupt Mask 0b0..ETC interrupt enabled 0b1..ETC interrupt masked
◆ EMVSIM_INT_MASK_ETC_IM [2/2]
◆ EMVSIM_INT_MASK_GPCNT0_IM [1/2]
#define EMVSIM_INT_MASK_GPCNT0_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_GPCNT0_IM_SHIFT)) & EMVSIM_INT_MASK_GPCNT0_IM_MASK)
GPCNT0_IM - General Purpose Timer 0 Timeout Interrupt Mask 0b0..GPCNT0_TO interrupt enabled 0b1..GPCNT0_TO interrupt masked
◆ EMVSIM_INT_MASK_GPCNT0_IM [2/2]
◆ EMVSIM_INT_MASK_GPCNT1_IM [1/2]
#define EMVSIM_INT_MASK_GPCNT1_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_GPCNT1_IM_SHIFT)) & EMVSIM_INT_MASK_GPCNT1_IM_MASK)
GPCNT1_IM - General Purpose Counter 1 Timeout Interrupt Mask 0b0..GPCNT1_TO interrupt enabled 0b1..GPCNT1_TO interrupt masked
◆ EMVSIM_INT_MASK_GPCNT1_IM [2/2]
◆ EMVSIM_INT_MASK_PEF_IM [1/2]
#define EMVSIM_INT_MASK_PEF_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_PEF_IM_SHIFT)) & EMVSIM_INT_MASK_PEF_IM_MASK)
PEF_IM - Parity Error Interrupt Mask 0b0..PEF interrupt enabled 0b1..PEF interrupt masked
◆ EMVSIM_INT_MASK_PEF_IM [2/2]
◆ EMVSIM_INT_MASK_RDT_IM [1/2]
#define EMVSIM_INT_MASK_RDT_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RDT_IM_SHIFT)) & EMVSIM_INT_MASK_RDT_IM_MASK)
RDT_IM - Receive Data Threshold Interrupt Mask 0b0..RDTF interrupt enabled 0b1..RDTF interrupt masked
◆ EMVSIM_INT_MASK_RDT_IM [2/2]
◆ EMVSIM_INT_MASK_RFO_IM [1/2]
#define EMVSIM_INT_MASK_RFO_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RFO_IM_SHIFT)) & EMVSIM_INT_MASK_RFO_IM_MASK)
RFO_IM - Receive FIFO Overflow Interrupt Mask 0b0..RFO interrupt enabled 0b1..RFO interrupt masked
◆ EMVSIM_INT_MASK_RFO_IM [2/2]
◆ EMVSIM_INT_MASK_RNACK_IM [1/2]
#define EMVSIM_INT_MASK_RNACK_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RNACK_IM_SHIFT)) & EMVSIM_INT_MASK_RNACK_IM_MASK)
RNACK_IM - Receiver NACK Threshold Interrupt Mask 0b0..RTE interrupt enabled 0b1..RTE interrupt masked
◆ EMVSIM_INT_MASK_RNACK_IM [2/2]
◆ EMVSIM_INT_MASK_RX_DATA_IM [1/2]
#define EMVSIM_INT_MASK_RX_DATA_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_RX_DATA_IM_SHIFT)) & EMVSIM_INT_MASK_RX_DATA_IM_MASK)
RX_DATA_IM - Receive Data Interrupt Mask 0b0..RX_DATA interrupt enabled 0b1..RX_DATA interrupt masked
◆ EMVSIM_INT_MASK_RX_DATA_IM [2/2]
◆ EMVSIM_INT_MASK_TC_IM [1/2]
#define EMVSIM_INT_MASK_TC_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TC_IM_SHIFT)) & EMVSIM_INT_MASK_TC_IM_MASK)
TC_IM - Transmit Complete Interrupt Mask 0b0..TCF interrupt enabled 0b1..TCF interrupt masked
◆ EMVSIM_INT_MASK_TC_IM [2/2]
◆ EMVSIM_INT_MASK_TDT_IM [1/2]
#define EMVSIM_INT_MASK_TDT_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TDT_IM_SHIFT)) & EMVSIM_INT_MASK_TDT_IM_MASK)
TDT_IM - Transmit Data Threshold Interrupt Mask 0b0..TDTF interrupt enabled 0b1..TDTF interrupt masked
◆ EMVSIM_INT_MASK_TDT_IM [2/2]
◆ EMVSIM_INT_MASK_TFE_IM [1/2]
#define EMVSIM_INT_MASK_TFE_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TFE_IM_SHIFT)) & EMVSIM_INT_MASK_TFE_IM_MASK)
TFE_IM - Transmit FIFO Empty Interrupt Mask 0b0..TFE interrupt enabled 0b1..TFE interrupt masked
◆ EMVSIM_INT_MASK_TFE_IM [2/2]
◆ EMVSIM_INT_MASK_TFF_IM [1/2]
#define EMVSIM_INT_MASK_TFF_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TFF_IM_SHIFT)) & EMVSIM_INT_MASK_TFF_IM_MASK)
TFF_IM - Transmit FIFO Full Interrupt Mask 0b0..TFF interrupt enabled 0b1..TFF interrupt masked
◆ EMVSIM_INT_MASK_TFF_IM [2/2]
◆ EMVSIM_INT_MASK_TNACK_IM [1/2]
#define EMVSIM_INT_MASK_TNACK_IM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_INT_MASK_TNACK_IM_SHIFT)) & EMVSIM_INT_MASK_TNACK_IM_MASK)
TNACK_IM - Transmit NACK Threshold Interrupt Mask 0b0..TNTE interrupt enabled 0b1..TNTE interrupt masked
◆ EMVSIM_INT_MASK_TNACK_IM [2/2]
◆ EMVSIM_PARAM_RX_FIFO_DEPTH [1/2]
#define EMVSIM_PARAM_RX_FIFO_DEPTH (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PARAM_RX_FIFO_DEPTH_SHIFT)) & EMVSIM_PARAM_RX_FIFO_DEPTH_MASK)
RX_FIFO_DEPTH - Receive FIFO Depth
◆ EMVSIM_PARAM_RX_FIFO_DEPTH [2/2]
◆ EMVSIM_PARAM_TX_FIFO_DEPTH [1/2]
#define EMVSIM_PARAM_TX_FIFO_DEPTH (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PARAM_TX_FIFO_DEPTH_SHIFT)) & EMVSIM_PARAM_TX_FIFO_DEPTH_MASK)
TX_FIFO_DEPTH - Transmit FIFO Depth
◆ EMVSIM_PARAM_TX_FIFO_DEPTH [2/2]
◆ EMVSIM_PCSR_SAPD [1/2]
#define EMVSIM_PCSR_SAPD (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SAPD_SHIFT)) & EMVSIM_PCSR_SAPD_MASK)
SAPD - Auto Power Down Enable 0b0..Auto power down disabled 0b1..Auto power down enabled
◆ EMVSIM_PCSR_SAPD [2/2]
◆ EMVSIM_PCSR_SCEN [1/2]
#define EMVSIM_PCSR_SCEN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SCEN_SHIFT)) & EMVSIM_PCSR_SCEN_MASK)
SCEN - Clock Enable for Smart Card 0b0..Smart Card Clock Disabled 0b1..Smart Card Clock Enabled
◆ EMVSIM_PCSR_SCEN [2/2]
◆ EMVSIM_PCSR_SCSP [1/2]
#define EMVSIM_PCSR_SCSP (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SCSP_SHIFT)) & EMVSIM_PCSR_SCSP_MASK)
SCSP - Smart Card Clock Stop Polarity 0b0..Clock is logic 0 when stopped by SCEN 0b1..Clock is logic 1 when stopped by SCEN
◆ EMVSIM_PCSR_SCSP [2/2]
◆ EMVSIM_PCSR_SPD [1/2]
#define EMVSIM_PCSR_SPD (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPD_SHIFT)) & EMVSIM_PCSR_SPD_MASK)
SPD - Auto Power Down Control 0b0..No effect 0b1..Start Auto Powerdown or Power Down is in progress
◆ EMVSIM_PCSR_SPD [2/2]
◆ EMVSIM_PCSR_SPDES [1/2]
#define EMVSIM_PCSR_SPDES (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDES_SHIFT)) & EMVSIM_PCSR_SPDES_MASK)
SPDES - SIM Presence Detect Edge Select 0b0..Falling edge on the pin 0b1..Rising edge on the pin
◆ EMVSIM_PCSR_SPDES [2/2]
◆ EMVSIM_PCSR_SPDIF [1/2]
#define EMVSIM_PCSR_SPDIF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDIF_SHIFT)) & EMVSIM_PCSR_SPDIF_MASK)
SPDIF - Smart Card Presence Detect Interrupt Flag 0b0..No insertion or removal of Smart Card detected on Port 0b1..Insertion or removal of Smart Card detected on Port
◆ EMVSIM_PCSR_SPDIF [2/2]
◆ EMVSIM_PCSR_SPDIM [1/2]
#define EMVSIM_PCSR_SPDIM (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDIM_SHIFT)) & EMVSIM_PCSR_SPDIM_MASK)
SPDIM - Smart Card Presence Detect Interrupt Mask 0b0..SIM presence detect interrupt is enabled 0b1..SIM presence detect interrupt is masked
◆ EMVSIM_PCSR_SPDIM [2/2]
◆ EMVSIM_PCSR_SPDP [1/2]
#define EMVSIM_PCSR_SPDP (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SPDP_SHIFT)) & EMVSIM_PCSR_SPDP_MASK)
SPDP - Smart Card Presence Detect Pin Status 0b0..SIM Presence Detect pin is logic low 0b1..SIM Presence Detectpin is logic high
◆ EMVSIM_PCSR_SPDP [2/2]
◆ EMVSIM_PCSR_SRST [1/2]
#define EMVSIM_PCSR_SRST (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SRST_SHIFT)) & EMVSIM_PCSR_SRST_MASK)
SRST - Reset to Smart Card 0b0..Smart Card Reset is asserted 0b1..Smart Card Reset is de-asserted
◆ EMVSIM_PCSR_SRST [2/2]
◆ EMVSIM_PCSR_SVCC_EN [1/2]
#define EMVSIM_PCSR_SVCC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_SVCC_EN_SHIFT)) & EMVSIM_PCSR_SVCC_EN_MASK)
SVCC_EN - Vcc Enable for Smart Card 0b0..Smart Card Voltage disabled 0b1..Smart Card Voltage enabled
◆ EMVSIM_PCSR_SVCC_EN [2/2]
◆ EMVSIM_PCSR_VCCENP [1/2]
#define EMVSIM_PCSR_VCCENP (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_PCSR_VCCENP_SHIFT)) & EMVSIM_PCSR_VCCENP_MASK)
VCCENP - VCC Enable Polarity Control 0b0..SVCC_EN is active high. Polarity of SVCC_EN is unchanged. 0b1..SVCC_EN is active low. Polarity of SVCC_EN is inverted.
◆ EMVSIM_PCSR_VCCENP [2/2]
◆ EMVSIM_RX_BUF_RX_BYTE [1/2]
#define EMVSIM_RX_BUF_RX_BYTE (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_BUF_RX_BYTE_SHIFT)) & EMVSIM_RX_BUF_RX_BYTE_MASK)
RX_BYTE - Receive Data Byte Read
◆ EMVSIM_RX_BUF_RX_BYTE [2/2]
◆ EMVSIM_RX_STATUS_BGT_ERR [1/2]
#define EMVSIM_RX_STATUS_BGT_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_BGT_ERR_SHIFT)) & EMVSIM_RX_STATUS_BGT_ERR_MASK)
BGT_ERR - Block Guard Time Error Flag 0b0..Block guard time was sufficient 0b1..Block guard time was too small
◆ EMVSIM_RX_STATUS_BGT_ERR [2/2]
◆ EMVSIM_RX_STATUS_BWT_ERR [1/2]
#define EMVSIM_RX_STATUS_BWT_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_BWT_ERR_SHIFT)) & EMVSIM_RX_STATUS_BWT_ERR_MASK)
BWT_ERR - Block Wait Time Error Flag 0b0..Block wait time not exceeded 0b1..Block wait time was exceeded
◆ EMVSIM_RX_STATUS_BWT_ERR [2/2]
◆ EMVSIM_RX_STATUS_CRC_OK [1/2]
#define EMVSIM_RX_STATUS_CRC_OK (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_CRC_OK_SHIFT)) & EMVSIM_RX_STATUS_CRC_OK_MASK)
CRC_OK - CRC Check OK Flag 0b0..Current CRC value does not match remainder. 0b1..Current calculated CRC value matches the expected result.
◆ EMVSIM_RX_STATUS_CRC_OK [2/2]
◆ EMVSIM_RX_STATUS_CWT_ERR [1/2]
#define EMVSIM_RX_STATUS_CWT_ERR (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_CWT_ERR_SHIFT)) & EMVSIM_RX_STATUS_CWT_ERR_MASK)
CWT_ERR - Character Wait Time Error Flag 0b0..No CWT violation has occurred 0b1..Time between two consecutive characters has exceeded the value in CWT_VAL.
◆ EMVSIM_RX_STATUS_CWT_ERR [2/2]
◆ EMVSIM_RX_STATUS_FEF [1/2]
#define EMVSIM_RX_STATUS_FEF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_FEF_SHIFT)) & EMVSIM_RX_STATUS_FEF_MASK)
FEF - Frame Error Flag 0b0..No frame error detected 0b1..Frame error detected
◆ EMVSIM_RX_STATUS_FEF [2/2]
◆ EMVSIM_RX_STATUS_LRC_OK [1/2]
#define EMVSIM_RX_STATUS_LRC_OK (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_LRC_OK_SHIFT)) & EMVSIM_RX_STATUS_LRC_OK_MASK)
LRC_OK - LRC Check OK Flag 0b0..Current LRC value does not match remainder. 0b1..Current calculated LRC value matches the expected result (i.e. zero).
◆ EMVSIM_RX_STATUS_LRC_OK [2/2]
◆ EMVSIM_RX_STATUS_PEF [1/2]
#define EMVSIM_RX_STATUS_PEF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_PEF_SHIFT)) & EMVSIM_RX_STATUS_PEF_MASK)
PEF - Parity Error Flag 0b0..No parity error detected 0b1..Parity error detected
◆ EMVSIM_RX_STATUS_PEF [2/2]
◆ EMVSIM_RX_STATUS_RDTF [1/2]
#define EMVSIM_RX_STATUS_RDTF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RDTF_SHIFT)) & EMVSIM_RX_STATUS_RDTF_MASK)
RDTF - Receive Data Threshold Interrupt Flag 0b0..Number of unread bytes in receive FIFO less than the value set by RDT 0b1..Number of unread bytes in receive FIFO greater or than equal to value set by RDT.
◆ EMVSIM_RX_STATUS_RDTF [2/2]
◆ EMVSIM_RX_STATUS_RFO [1/2]
#define EMVSIM_RX_STATUS_RFO (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RFO_SHIFT)) & EMVSIM_RX_STATUS_RFO_MASK)
RFO - Receive FIFO Overflow Flag 0b0..No overrun error has occurred 0b1..A byte was received when the received FIFO was already full
◆ EMVSIM_RX_STATUS_RFO [2/2]
◆ EMVSIM_RX_STATUS_RTE [1/2]
#define EMVSIM_RX_STATUS_RTE (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RTE_SHIFT)) & EMVSIM_RX_STATUS_RTE_MASK)
RTE - Received NACK Threshold Error Flag 0b0..Number of NACKs generated by the receiver is less than the value programmed in RNCK_THD 0b1..Number of NACKs generated by the receiver is equal to the value programmed in RNCK_THD
◆ EMVSIM_RX_STATUS_RTE [2/2]
◆ EMVSIM_RX_STATUS_RX_CNT [1/2]
#define EMVSIM_RX_STATUS_RX_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RX_CNT_SHIFT)) & EMVSIM_RX_STATUS_RX_CNT_MASK)
RX_CNT - Receive FIFO Byte Count 0b0000..FIFO is emtpy
◆ EMVSIM_RX_STATUS_RX_CNT [2/2]
◆ EMVSIM_RX_STATUS_RX_DATA [1/2]
#define EMVSIM_RX_STATUS_RX_DATA (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RX_DATA_SHIFT)) & EMVSIM_RX_STATUS_RX_DATA_MASK)
RX_DATA - Receive Data Interrupt Flag 0b0..No new byte is received 0b1..New byte is received ans stored in Receive FIFO
◆ EMVSIM_RX_STATUS_RX_DATA [2/2]
◆ EMVSIM_RX_STATUS_RX_WPTR [1/2]
#define EMVSIM_RX_STATUS_RX_WPTR (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_STATUS_RX_WPTR_SHIFT)) & EMVSIM_RX_STATUS_RX_WPTR_MASK)
RX_WPTR - Receive FIFO Write Pointer Value
◆ EMVSIM_RX_STATUS_RX_WPTR [2/2]
◆ EMVSIM_RX_THD_RDT [1/2]
#define EMVSIM_RX_THD_RDT (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_THD_RDT_SHIFT)) & EMVSIM_RX_THD_RDT_MASK)
RDT - Receiver Data Threshold Value
◆ EMVSIM_RX_THD_RDT [2/2]
◆ EMVSIM_RX_THD_RNCK_THD [1/2]
#define EMVSIM_RX_THD_RNCK_THD (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_RX_THD_RNCK_THD_SHIFT)) & EMVSIM_RX_THD_RNCK_THD_MASK)
RNCK_THD - Receiver NACK Threshold Value
◆ EMVSIM_RX_THD_RNCK_THD [2/2]
◆ EMVSIM_TX_BUF_TX_BYTE [1/2]
#define EMVSIM_TX_BUF_TX_BYTE (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_BUF_TX_BYTE_SHIFT)) & EMVSIM_TX_BUF_TX_BYTE_MASK)
TX_BYTE - Transmit Data Byte
◆ EMVSIM_TX_BUF_TX_BYTE [2/2]
◆ EMVSIM_TX_GETU_GETU [1/2]
#define EMVSIM_TX_GETU_GETU (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_GETU_GETU_SHIFT)) & EMVSIM_TX_GETU_GETU_MASK)
GETU - Transmitter Guard Time Value in ETU
◆ EMVSIM_TX_GETU_GETU [2/2]
◆ EMVSIM_TX_STATUS_ETCF [1/2]
#define EMVSIM_TX_STATUS_ETCF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_ETCF_SHIFT)) & EMVSIM_TX_STATUS_ETCF_MASK)
ETCF - Early Transmit Complete Flag 0b0..Transmit pending or in progress 0b1..Transmit complete
◆ EMVSIM_TX_STATUS_ETCF [2/2]
◆ EMVSIM_TX_STATUS_GPCNT0_TO [1/2]
#define EMVSIM_TX_STATUS_GPCNT0_TO (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_GPCNT0_TO_SHIFT)) & EMVSIM_TX_STATUS_GPCNT0_TO_MASK)
GPCNT0_TO - General Purpose Counter 0 Timeout Flag 0b0..GPCNT0 time not reached, or bit has been cleared. 0b1..General Purpose counter has reached the GPCNT0 value
◆ EMVSIM_TX_STATUS_GPCNT0_TO [2/2]
◆ EMVSIM_TX_STATUS_GPCNT1_TO [1/2]
#define EMVSIM_TX_STATUS_GPCNT1_TO (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_GPCNT1_TO_SHIFT)) & EMVSIM_TX_STATUS_GPCNT1_TO_MASK)
GPCNT1_TO - General Purpose Counter 1 Timeout Flag 0b0..GPCNT1 time not reached, or bit has been cleared. 0b1..General Purpose counter has reached the GPCNT1 value
◆ EMVSIM_TX_STATUS_GPCNT1_TO [2/2]
◆ EMVSIM_TX_STATUS_TCF [1/2]
#define EMVSIM_TX_STATUS_TCF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TCF_SHIFT)) & EMVSIM_TX_STATUS_TCF_MASK)
TCF - Transmit Complete Flag 0b0..Transmit pending or in progress 0b1..Transmit complete
◆ EMVSIM_TX_STATUS_TCF [2/2]
◆ EMVSIM_TX_STATUS_TDTF [1/2]
#define EMVSIM_TX_STATUS_TDTF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TDTF_SHIFT)) & EMVSIM_TX_STATUS_TDTF_MASK)
TDTF - Transmit Data Threshold Flag 0b0..Number of bytes in FIFO is greater than TDT, or bit has been cleared 0b1..Number of bytes in FIFO is less than or equal to TDT
◆ EMVSIM_TX_STATUS_TDTF [2/2]
◆ EMVSIM_TX_STATUS_TFE [1/2]
#define EMVSIM_TX_STATUS_TFE (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TFE_SHIFT)) & EMVSIM_TX_STATUS_TFE_MASK)
TFE - Transmit FIFO Empty Flag 0b0..Transmit FIFO is not empty 0b1..Transmit FIFO is empty
◆ EMVSIM_TX_STATUS_TFE [2/2]
◆ EMVSIM_TX_STATUS_TFF [1/2]
#define EMVSIM_TX_STATUS_TFF (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TFF_SHIFT)) & EMVSIM_TX_STATUS_TFF_MASK)
TFF - Transmit FIFO Full Flag 0b0..Transmit FIFO Full condition has not occurred 0b1..A Transmit FIFO Full condition has occurred
◆ EMVSIM_TX_STATUS_TFF [2/2]
◆ EMVSIM_TX_STATUS_TNTE [1/2]
#define EMVSIM_TX_STATUS_TNTE (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TNTE_SHIFT)) & EMVSIM_TX_STATUS_TNTE_MASK)
TNTE - Transmit NACK Threshold Error Flag 0b0..Transmit NACK threshold has not been reached 0b1..Transmit NACK threshold reached; transmitter frozen
◆ EMVSIM_TX_STATUS_TNTE [2/2]
◆ EMVSIM_TX_STATUS_TX_CNT [1/2]
#define EMVSIM_TX_STATUS_TX_CNT (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TX_CNT_SHIFT)) & EMVSIM_TX_STATUS_TX_CNT_MASK)
TX_CNT - Transmit FIFO Byte Count 0b0000..FIFO is emtpy
◆ EMVSIM_TX_STATUS_TX_CNT [2/2]
◆ EMVSIM_TX_STATUS_TX_RPTR [1/2]
#define EMVSIM_TX_STATUS_TX_RPTR (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_STATUS_TX_RPTR_SHIFT)) & EMVSIM_TX_STATUS_TX_RPTR_MASK)
TX_RPTR - Transmit FIFO Read Pointer
◆ EMVSIM_TX_STATUS_TX_RPTR [2/2]
◆ EMVSIM_TX_THD_TDT [1/2]
#define EMVSIM_TX_THD_TDT (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_THD_TDT_SHIFT)) & EMVSIM_TX_THD_TDT_MASK)
TDT - Transmitter Data Threshold Value
◆ EMVSIM_TX_THD_TDT [2/2]
◆ EMVSIM_TX_THD_TNCK_THD [1/2]
#define EMVSIM_TX_THD_TNCK_THD (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_TX_THD_TNCK_THD_SHIFT)) & EMVSIM_TX_THD_TNCK_THD_MASK)
TNCK_THD - Transmitter NACK Threshold Value
◆ EMVSIM_TX_THD_TNCK_THD [2/2]
◆ EMVSIM_VER_ID_VER [1/2]
#define EMVSIM_VER_ID_VER (   x)    (((uint32_t)(((uint32_t)(x)) << EMVSIM_VER_ID_VER_SHIFT)) & EMVSIM_VER_ID_VER_MASK)
VER - Version ID of the module
◆ EMVSIM_VER_ID_VER [2/2]
◆ ENC_CTRL_CMPIE [1/2]
#define ENC_CTRL_CMPIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIE_SHIFT)) & ENC_CTRL_CMPIE_MASK)
CMPIE - Compare Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_CMPIE [2/2]
◆ ENC_CTRL_CMPIRQ [1/2]
#define ENC_CTRL_CMPIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIRQ_SHIFT)) & ENC_CTRL_CMPIRQ_MASK)
CMPIRQ - Compare Interrupt Request 0b0..No match has occurred (the counter does not match the COMP value) 0b1..COMP match has occurred (the counter matches the COMP value)
◆ ENC_CTRL_CMPIRQ [2/2]
◆ ENC_CTRL_DIE [1/2]
#define ENC_CTRL_DIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIE_SHIFT)) & ENC_CTRL_DIE_MASK)
DIE - Watchdog Timeout Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_DIE [2/2]
◆ ENC_CTRL_DIRQ [1/2]
#define ENC_CTRL_DIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIRQ_SHIFT)) & ENC_CTRL_DIRQ_MASK)
DIRQ - Watchdog Timeout Interrupt Request 0b0..No Watchdog timeout interrupt has occurred 0b1..Watchdog timeout interrupt has occurred
◆ ENC_CTRL_DIRQ [2/2]
◆ ENC_CTRL_HIE [1/2]
#define ENC_CTRL_HIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIE_SHIFT)) & ENC_CTRL_HIE_MASK)
HIE - HOME Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_HIE [2/2]
◆ ENC_CTRL_HIP [1/2]
#define ENC_CTRL_HIP (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIP_SHIFT)) & ENC_CTRL_HIP_MASK)
HIP - Enable HOME to Initialize Position Counters UPOS and LPOS 0b0..No action 0b1..HOME signal initializes the position counter
◆ ENC_CTRL_HIP [2/2]
◆ ENC_CTRL_HIRQ [1/2]
#define ENC_CTRL_HIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIRQ_SHIFT)) & ENC_CTRL_HIRQ_MASK)
HIRQ - HOME Signal Transition Interrupt Request 0b0..No transition on the HOME signal has occurred 0b1..A transition on the HOME signal has occurred
◆ ENC_CTRL_HIRQ [2/2]
◆ ENC_CTRL_HNE [1/2]
#define ENC_CTRL_HNE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HNE_SHIFT)) & ENC_CTRL_HNE_MASK)
HNE - Use Negative Edge of HOME Input 0b0..Use positive-going edge-to-trigger initialization of position counters UPOS and LPOS 0b1..Use negative-going edge-to-trigger initialization of position counters UPOS and LPOS
◆ ENC_CTRL_HNE [2/2]
◆ ENC_CTRL_PH1 [1/2]
#define ENC_CTRL_PH1 (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_PH1_SHIFT)) & ENC_CTRL_PH1_MASK)
PH1 - Enable Signal Phase Count Mode 0b0..Use the standard quadrature decoder, where PHASEA and PHASEB represent a two-phase quadrature signal. 0b1..Bypass the quadrature decoder. A positive transition of the PHASEA input generates a count signal. The PHASEB input and the REV bit control the counter direction: If CTRL[REV] = 0, PHASEB = 0, then count up If CTRL[REV] = 1, PHASEB = 1, then count up If CTRL[REV] = 0, PHASEB = 1, then count down If CTRL[REV] = 1, PHASEB = 0, then count down
◆ ENC_CTRL_PH1 [2/2]
◆ ENC_CTRL_REV [1/2]
#define ENC_CTRL_REV (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_REV_SHIFT)) & ENC_CTRL_REV_MASK)
REV - Enable Reverse Direction Counting 0b0..Count normally 0b1..Count in the reverse direction
◆ ENC_CTRL_REV [2/2]
◆ ENC_CTRL_SWIP [1/2]
#define ENC_CTRL_SWIP (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_SWIP_SHIFT)) & ENC_CTRL_SWIP_MASK)
SWIP - Software-Triggered Initialization of Position Counters UPOS and LPOS 0b0..No action 0b1..Initialize position counter (using upper and lower initialization registers, UINIT and LINIT)
◆ ENC_CTRL_SWIP [2/2]
◆ ENC_CTRL_WDE [1/2]
#define ENC_CTRL_WDE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_WDE_SHIFT)) & ENC_CTRL_WDE_MASK)
WDE - Watchdog Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_WDE [2/2]
◆ ENC_CTRL_XIE [1/2]
#define ENC_CTRL_XIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIE_SHIFT)) & ENC_CTRL_XIE_MASK)
XIE - INDEX Pulse Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_XIE [2/2]
◆ ENC_CTRL_XIP [1/2]
#define ENC_CTRL_XIP (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIP_SHIFT)) & ENC_CTRL_XIP_MASK)
XIP - INDEX Triggered Initialization of Position Counters UPOS and LPOS 0b0..INDEX pulse does not initialize the position counter 0b1..INDEX pulse initializes the position counter
◆ ENC_CTRL_XIP [2/2]
◆ ENC_CTRL_XIRQ [1/2]
#define ENC_CTRL_XIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIRQ_SHIFT)) & ENC_CTRL_XIRQ_MASK)
XIRQ - INDEX Pulse Interrupt Request 0b0..INDEX pulse has not occurred 0b1..INDEX pulse has occurred
◆ ENC_CTRL_XIRQ [2/2]
◆ ENC_CTRL_XNE [1/2]
#define ENC_CTRL_XNE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XNE_SHIFT)) & ENC_CTRL_XNE_MASK)
XNE - Use Negative Edge of INDEX Pulse 0b0..Use positive edge of INDEX pulse 0b1..Use negative edge of INDEX pulse
◆ ENC_CTRL_XNE [2/2]
◆ EWM_CTRL_ASSIN [1/2]
#define EWM_CTRL_ASSIN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_ASSIN_SHIFT)) & EWM_CTRL_ASSIN_MASK)
ASSIN - EWM_in's Assertion State Select. 0b0..Default assert state of the EWM_in signal. 0b1..Inverts the assert state of EWM_in signal.
◆ EWM_CTRL_ASSIN [2/2]
◆ EWM_CTRL_EWMEN [1/2]
#define EWM_CTRL_EWMEN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_EWMEN_SHIFT)) & EWM_CTRL_EWMEN_MASK)
EWMEN - EWM enable. 0b0..EWM module is disabled. 0b1..EWM module is enabled.
◆ EWM_CTRL_EWMEN [2/2]
◆ EWM_CTRL_INEN [1/2]
#define EWM_CTRL_INEN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INEN_SHIFT)) & EWM_CTRL_INEN_MASK)
INEN - Input Enable. 0b0..EWM_in port is disabled. 0b1..EWM_in port is enabled.
◆ EWM_CTRL_INEN [2/2]
◆ EWM_CTRL_INTEN [1/2]
#define EWM_CTRL_INTEN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INTEN_SHIFT)) & EWM_CTRL_INTEN_MASK)
INTEN - Interrupt Enable. 0b1..Generates an interrupt request, when EWM_OUT_b is asserted. 0b0..Deasserts the interrupt request.
◆ EWM_CTRL_INTEN [2/2]
◆ PWM_CTRL_COMPMODE [1/2]
#define PWM_CTRL_COMPMODE (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_COMPMODE_SHIFT)) & PWM_CTRL_COMPMODE_MASK)
COMPMODE - Compare Mode 0b0..The VAL* registers and the PWM counter are compared using an "equal to" method. This means that PWM edges are only produced when the counter is equal to one of the VAL* register values. This implies that a PWMA output that is high at the end of a period will maintain this state until a match with VAL3 clears the output in the following period. 0b1..The VAL* registers and the PWM counter are compared using an "equal to or greater than" method. This means that PWM edges are produced when the counter is equal to or greater than one of the VAL* register values. This implies that a PWMA output that is high at the end of a period could go low at the start of the next period if the starting counter value is greater than (but not necessarily equal to) the new VAL3 value.
◆ PWM_CTRL_COMPMODE [2/2]
◆ PWM_CTRL_DBLEN [1/2]
#define PWM_CTRL_DBLEN (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLEN_SHIFT)) & PWM_CTRL_DBLEN_MASK)
DBLEN - Double Switching Enable 0b0..Double switching disabled. 0b1..Double switching enabled.
◆ PWM_CTRL_DBLEN [2/2]
◆ PWM_CTRL_DBLX [1/2]
#define PWM_CTRL_DBLX (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLX_SHIFT)) & PWM_CTRL_DBLX_MASK)
DBLX - PWMX Double Switching Enable 0b0..PWMX double pulse disabled. 0b1..PWMX double pulse enabled.
◆ PWM_CTRL_DBLX [2/2]
◆ PWM_CTRL_DT [1/2]
#define PWM_CTRL_DT (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DT_SHIFT)) & PWM_CTRL_DT_MASK)
DT - Deadtime
◆ PWM_CTRL_DT [2/2]
DT - Deadtime
◆ PWM_CTRL_FULL [1/2]
#define PWM_CTRL_FULL (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_FULL_SHIFT)) & PWM_CTRL_FULL_MASK)
FULL - Full Cycle Reload 0b0..Full-cycle reloads disabled. 0b1..Full-cycle reloads enabled.
◆ PWM_CTRL_FULL [2/2]
◆ PWM_CTRL_HALF [1/2]
#define PWM_CTRL_HALF (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_HALF_SHIFT)) & PWM_CTRL_HALF_MASK)
HALF - Half Cycle Reload 0b0..Half-cycle reloads disabled. 0b1..Half-cycle reloads enabled.
◆ PWM_CTRL_HALF [2/2]
◆ PWM_CTRL_LDFQ [1/2]
#define PWM_CTRL_LDFQ (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDFQ_SHIFT)) & PWM_CTRL_LDFQ_MASK)
LDFQ - Load Frequency 0b0000..Every PWM opportunity 0b0001..Every 2 PWM opportunities 0b0010..Every 3 PWM opportunities 0b0011..Every 4 PWM opportunities 0b0100..Every 5 PWM opportunities 0b0101..Every 6 PWM opportunities 0b0110..Every 7 PWM opportunities 0b0111..Every 8 PWM opportunities 0b1000..Every 9 PWM opportunities 0b1001..Every 10 PWM opportunities 0b1010..Every 11 PWM opportunities 0b1011..Every 12 PWM opportunities 0b1100..Every 13 PWM opportunities 0b1101..Every 14 PWM opportunities 0b1110..Every 15 PWM opportunities 0b1111..Every 16 PWM opportunities
◆ PWM_CTRL_LDFQ [2/2]
◆ PWM_CTRL_LDMOD [1/2]
#define PWM_CTRL_LDMOD (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDMOD_SHIFT)) & PWM_CTRL_LDMOD_MASK)
LDMOD - Load Mode Select 0b0..Buffered registers of this submodule are loaded and take effect at the next PWM reload if MCTRL[LDOK] is set. 0b1..Buffered registers of this submodule are loaded and take effect immediately upon MCTRL[LDOK] being set. In this case it is not necessary to set CTRL[FULL] or CTRL[HALF].
◆ PWM_CTRL_LDMOD [2/2]
◆ PWM_CTRL_PRSC [1/2]
#define PWM_CTRL_PRSC (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_PRSC_SHIFT)) & PWM_CTRL_PRSC_MASK)
PRSC - Prescaler 0b000..Prescaler 1 0b001..Prescaler 2 0b010..Prescaler 4 0b011..Prescaler 8 0b100..Prescaler 16 0b101..Prescaler 32 0b110..Prescaler 64 0b111..Prescaler 128
◆ PWM_CTRL_PRSC [2/2]
◆ PWM_CTRL_SPLIT [1/2]
#define PWM_CTRL_SPLIT (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_SPLIT_SHIFT)) & PWM_CTRL_SPLIT_MASK)
SPLIT - Split the DBLPWM signal to PWMA and PWMB 0b0..DBLPWM is not split. PWMA and PWMB each have double pulses. 0b1..DBLPWM is split to PWMA and PWMB.
◆ PWM_CTRL_SPLIT [2/2]
◆ SRAM_CTRL_LOCK_BIT [1/2]
#define SRAM_CTRL_LOCK_BIT (   x)    (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_LOCK_BIT_SHIFT)) & SRAM_CTRL_LOCK_BIT_MASK)
LOCK_BIT - Lock bits
◆ SRAM_CTRL_LOCK_BIT [2/2]
◆ SRAM_CTRL_PWR_EN [1/2]
#define SRAM_CTRL_PWR_EN (   x)    (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_PWR_EN_SHIFT)) & SRAM_CTRL_PWR_EN_MASK)
PWR_EN - Power Enable (with lock)
◆ SRAM_CTRL_PWR_EN [2/2]
◆ SRAM_CTRL_RAM_RD_EN [1/2]
#define SRAM_CTRL_RAM_RD_EN (   x)    (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_RD_EN_SHIFT)) & SRAM_CTRL_RAM_RD_EN_MASK)
RAM_RD_EN - RAM Read Enable (with lock) 0b0..Disable read access 0b1..Enable read access
◆ SRAM_CTRL_RAM_RD_EN [2/2]
◆ SRAM_CTRL_RAM_WR_EN [1/2]
#define SRAM_CTRL_RAM_WR_EN (   x)    (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_WR_EN_SHIFT)) & SRAM_CTRL_RAM_WR_EN_MASK)
RAM_WR_EN - RAM Write Enable (with lock) 0b0..Disable write access 0b1..Enable write access
◆ SRAM_CTRL_RAM_WR_EN [2/2]
◆ SRAM_CTRL_TAMPER_BLOCK_EN [1/2]
#define SRAM_CTRL_TAMPER_BLOCK_EN (   x)    (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_BLOCK_EN_SHIFT)) & SRAM_CTRL_TAMPER_BLOCK_EN_MASK)
TAMPER_BLOCK_EN - Tamper Block Enable (with lock) 0b0..Allow R/W access to secure RAM when tamper is detected 0b1..Block R/W access to secure RAM when tamper is detected
◆ SRAM_CTRL_TAMPER_BLOCK_EN [2/2]
◆ SRAM_CTRL_TAMPER_PWR_OFF_EN [1/2]
#define SRAM_CTRL_TAMPER_PWR_OFF_EN (   x)    (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_PWR_OFF_EN_SHIFT)) & SRAM_CTRL_TAMPER_PWR_OFF_EN_MASK)
TAMPER_PWR_OFF_EN - Turn off power on tamper event (with lock) 0b0..Disable the turn off function when tamper is detected 0b1..Turn off power for all secure RAM banks when tamper is detected
◆ SRAM_CTRL_TAMPER_PWR_OFF_EN [2/2]
◆ SSARC_LP_CTRL_DIS_HW_REQ [1/2]
#define SSARC_LP_CTRL_DIS_HW_REQ (   x)    (((uint32_t)(((uint32_t)(x)) << SSARC_LP_CTRL_DIS_HW_REQ_SHIFT)) & SSARC_LP_CTRL_DIS_HW_REQ_MASK)
DIS_HW_REQ - Save/Restore request disable 0b0..PGMC save/restore requests enabled 0b1..PGMC save/restore requests disabled
◆ SSARC_LP_CTRL_DIS_HW_REQ [2/2]
◆ SSARC_LP_CTRL_SW_RESET [1/2]
#define SSARC_LP_CTRL_SW_RESET (   x)    (((uint32_t)(((uint32_t)(x)) << SSARC_LP_CTRL_SW_RESET_SHIFT)) & SSARC_LP_CTRL_SW_RESET_MASK)
SW_RESET - Software reset
◆ SSARC_LP_CTRL_SW_RESET [2/2]
