RTEMS 6.1
#define DMAMUX_CHCFG_COUNT   (32U)
CHCFG - Channel 0 Configuration Register..Channel 31 Configuration Register
#define DMAMUX_CHCFG_SOURCE_MASK   (0x7FU)
#define DMAMUX_CHCFG_SOURCE_SHIFT   (0U)
#define DMAMUX_CHCFG_SOURCE(x)   (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_SOURCE_SHIFT)) & DMAMUX_CHCFG_SOURCE_MASK)
#define DMAMUX_CHCFG_A_ON_MASK   (0x20000000U)
#define DMAMUX_CHCFG_A_ON_SHIFT   (29U)
#define DMAMUX_CHCFG_A_ON(x)   (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_A_ON_SHIFT)) & DMAMUX_CHCFG_A_ON_MASK)
#define DMAMUX_CHCFG_TRIG_MASK   (0x40000000U)
#define DMAMUX_CHCFG_TRIG_SHIFT   (30U)
#define DMAMUX_CHCFG_TRIG(x)   (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_TRIG_SHIFT)) & DMAMUX_CHCFG_TRIG_MASK)
#define DMAMUX_CHCFG_ENBL_MASK   (0x80000000U)
#define DMAMUX_CHCFG_ENBL_SHIFT   (31U)
#define DMAMUX_CHCFG_ENBL(x)   (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_ENBL_SHIFT)) & DMAMUX_CHCFG_ENBL_MASK)
#define DMAMUX_CHCFG_SOURCE_MASK   (0xFFU)
◆ DMAMUX_CHCFG_A_ON [1/3]
#define DMAMUX_CHCFG_A_ON (   x)    (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_A_ON_SHIFT)) & DMAMUX_CHCFG_A_ON_MASK)
A_ON - DMA Channel Always Enable 0b0..DMA Channel Always ON function is disabled 0b1..DMA Channel Always ON function is enabled
◆ DMAMUX_CHCFG_A_ON [2/3]
◆ DMAMUX_CHCFG_A_ON [3/3]
◆ DMAMUX_CHCFG_ENBL [1/3]
#define DMAMUX_CHCFG_ENBL (   x)    (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_ENBL_SHIFT)) & DMAMUX_CHCFG_ENBL_MASK)
ENBL - DMA Mux Channel Enable 0b0..DMA Mux channel is disabled 0b1..DMA Mux channel is enabled
◆ DMAMUX_CHCFG_ENBL [2/3]
◆ DMAMUX_CHCFG_ENBL [3/3]
◆ DMAMUX_CHCFG_SOURCE [1/3]
#define DMAMUX_CHCFG_SOURCE (   x)    (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_SOURCE_SHIFT)) & DMAMUX_CHCFG_SOURCE_MASK)
SOURCE - DMA Channel Source (Slot Number)
◆ DMAMUX_CHCFG_SOURCE [2/3]
◆ DMAMUX_CHCFG_SOURCE [3/3]
◆ DMAMUX_CHCFG_TRIG [1/3]
#define DMAMUX_CHCFG_TRIG (   x)    (((uint32_t)(((uint32_t)(x)) << DMAMUX_CHCFG_TRIG_SHIFT)) & DMAMUX_CHCFG_TRIG_MASK)
TRIG - DMA Channel Trigger Enable 0b0..Triggering is disabled. If triggering is disabled and ENBL is set, the DMA Channel will simply route the specified source to the DMA channel. (Normal mode) 0b1..Triggering is enabled. If triggering is enabled and ENBL is set, the DMA_CH_MUX is in Periodic Trigger mode.
◆ DMAMUX_CHCFG_TRIG [2/3]
◆ DMAMUX_CHCFG_TRIG [3/3]
