#define | DCIC_DCICC_IC_EN_MASK (0x1U) |
#define | DCIC_DCICC_IC_EN_SHIFT (0U) |
| #define | DCIC_DCICC_IC_EN(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_IC_EN_SHIFT)) & DCIC_DCICC_IC_EN_MASK) |
#define | DCIC_DCICC_DE_POL_MASK (0x10U) |
#define | DCIC_DCICC_DE_POL_SHIFT (4U) |
| #define | DCIC_DCICC_DE_POL(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_DE_POL_SHIFT)) & DCIC_DCICC_DE_POL_MASK) |
#define | DCIC_DCICC_HSYNC_POL_MASK (0x20U) |
#define | DCIC_DCICC_HSYNC_POL_SHIFT (5U) |
| #define | DCIC_DCICC_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_HSYNC_POL_SHIFT)) & DCIC_DCICC_HSYNC_POL_MASK) |
#define | DCIC_DCICC_VSYNC_POL_MASK (0x40U) |
#define | DCIC_DCICC_VSYNC_POL_SHIFT (6U) |
| #define | DCIC_DCICC_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_VSYNC_POL_SHIFT)) & DCIC_DCICC_VSYNC_POL_MASK) |
#define | DCIC_DCICC_CLK_POL_MASK (0x80U) |
#define | DCIC_DCICC_CLK_POL_SHIFT (7U) |
| #define | DCIC_DCICC_CLK_POL(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_CLK_POL_SHIFT)) & DCIC_DCICC_CLK_POL_MASK) |
#define | DCIC_DCICIC_EI_MASK_MASK (0x1U) |
#define | DCIC_DCICIC_EI_MASK_SHIFT (0U) |
| #define | DCIC_DCICIC_EI_MASK(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_EI_MASK_SHIFT)) & DCIC_DCICIC_EI_MASK_MASK) |
#define | DCIC_DCICIC_FI_MASK_MASK (0x2U) |
#define | DCIC_DCICIC_FI_MASK_SHIFT (1U) |
| #define | DCIC_DCICIC_FI_MASK(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_FI_MASK_SHIFT)) & DCIC_DCICIC_FI_MASK_MASK) |
#define | DCIC_DCICIC_FREEZE_MASK_MASK (0x8U) |
#define | DCIC_DCICIC_FREEZE_MASK_SHIFT (3U) |
| #define | DCIC_DCICIC_FREEZE_MASK(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_FREEZE_MASK_SHIFT)) & DCIC_DCICIC_FREEZE_MASK_MASK) |
#define | DCIC_DCICIC_EXT_SIG_EN_MASK (0x10000U) |
#define | DCIC_DCICIC_EXT_SIG_EN_SHIFT (16U) |
| #define | DCIC_DCICIC_EXT_SIG_EN(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_EXT_SIG_EN_SHIFT)) & DCIC_DCICIC_EXT_SIG_EN_MASK) |
#define | DCIC_DCICS_ROI_MATCH_STAT_MASK (0xFFFFU) |
#define | DCIC_DCICS_ROI_MATCH_STAT_SHIFT (0U) |
| #define | DCIC_DCICS_ROI_MATCH_STAT(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_ROI_MATCH_STAT_SHIFT)) & DCIC_DCICS_ROI_MATCH_STAT_MASK) |
#define | DCIC_DCICS_EI_STAT_MASK (0x10000U) |
#define | DCIC_DCICS_EI_STAT_SHIFT (16U) |
| #define | DCIC_DCICS_EI_STAT(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_EI_STAT_SHIFT)) & DCIC_DCICS_EI_STAT_MASK) |
#define | DCIC_DCICS_FI_STAT_MASK (0x20000U) |
#define | DCIC_DCICS_FI_STAT_SHIFT (17U) |
| #define | DCIC_DCICS_FI_STAT(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_FI_STAT_SHIFT)) & DCIC_DCICS_FI_STAT_MASK) |
#define | DCIC_DCICRC_START_OFFSET_X_MASK (0x1FFFU) |
#define | DCIC_DCICRC_START_OFFSET_X_SHIFT (0U) |
#define | DCIC_DCICRC_START_OFFSET_X(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_START_OFFSET_X_SHIFT)) & DCIC_DCICRC_START_OFFSET_X_MASK) |
#define | DCIC_DCICRC_START_OFFSET_Y_MASK (0xFFF0000U) |
#define | DCIC_DCICRC_START_OFFSET_Y_SHIFT (16U) |
#define | DCIC_DCICRC_START_OFFSET_Y(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_START_OFFSET_Y_SHIFT)) & DCIC_DCICRC_START_OFFSET_Y_MASK) |
#define | DCIC_DCICRC_ROI_FREEZE_MASK (0x40000000U) |
#define | DCIC_DCICRC_ROI_FREEZE_SHIFT (30U) |
| #define | DCIC_DCICRC_ROI_FREEZE(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_ROI_FREEZE_SHIFT)) & DCIC_DCICRC_ROI_FREEZE_MASK) |
#define | DCIC_DCICRC_ROI_EN_MASK (0x80000000U) |
#define | DCIC_DCICRC_ROI_EN_SHIFT (31U) |
| #define | DCIC_DCICRC_ROI_EN(x) (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_ROI_EN_SHIFT)) & DCIC_DCICRC_ROI_EN_MASK) |
