#define | CCM_OBS_OBSERVE_CONTROL_COUNT (6U) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_COUNT (6U) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_COUNT (6U) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_COUNT (6U) |
#define | CCM_OBS_OBSERVE_STATUS0_COUNT (6U) |
#define | CCM_OBS_OBSERVE_AUTHEN_COUNT (6U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_COUNT (6U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_COUNT (6U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_COUNT (6U) |
#define | CCM_OBS_OBSERVE_FREQUENCY_CURRENT_COUNT (6U) |
#define | CCM_OBS_OBSERVE_FREQUENCY_MIN_COUNT (6U) |
#define | CCM_OBS_OBSERVE_FREQUENCY_MAX_COUNT (6U) |
#define | CCM_OBS_OBSERVE_CONTROL_SELECT_MASK (0x1FFU) |
#define | CCM_OBS_OBSERVE_CONTROL_SELECT_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_CONTROL_SELECT(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SELECT_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_RAW_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_CONTROL_RAW_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_CONTROL_RAW(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_RAW_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_INV_MASK (0x2000U) |
#define | CCM_OBS_OBSERVE_CONTROL_INV_SHIFT (13U) |
| #define | CCM_OBS_OBSERVE_CONTROL_INV(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_INV_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_RESET_MASK (0x8000U) |
#define | CCM_OBS_OBSERVE_CONTROL_RESET_SHIFT (15U) |
| #define | CCM_OBS_OBSERVE_CONTROL_RESET(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_RESET_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_DIVIDE_MASK (0xFF0000U) |
#define | CCM_OBS_OBSERVE_CONTROL_DIVIDE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_CONTROL_DIVIDE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_DIVIDE_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_OFF_MASK (0x1000000U) |
#define | CCM_OBS_OBSERVE_CONTROL_OFF_SHIFT (24U) |
| #define | CCM_OBS_OBSERVE_CONTROL_OFF(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_OFF_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_SELECT_MASK (0x1FFU) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_SELECT_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_CONTROL_SET_SELECT(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_SELECT_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_RAW_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_RAW_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_CONTROL_SET_RAW(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_RAW_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_INV_MASK (0x2000U) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_INV_SHIFT (13U) |
| #define | CCM_OBS_OBSERVE_CONTROL_SET_INV(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_INV_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_RESET_MASK (0x8000U) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_RESET_SHIFT (15U) |
| #define | CCM_OBS_OBSERVE_CONTROL_SET_RESET(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_RESET_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_MASK (0xFF0000U) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_OFF_MASK (0x1000000U) |
#define | CCM_OBS_OBSERVE_CONTROL_SET_OFF_SHIFT (24U) |
| #define | CCM_OBS_OBSERVE_CONTROL_SET_OFF(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_OFF_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_MASK (0x1FFU) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_CONTROL_CLR_SELECT(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_RAW_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_RAW_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_CONTROL_CLR_RAW(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_RAW_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_INV_MASK (0x2000U) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_INV_SHIFT (13U) |
| #define | CCM_OBS_OBSERVE_CONTROL_CLR_INV(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_INV_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_RESET_MASK (0x8000U) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_RESET_SHIFT (15U) |
| #define | CCM_OBS_OBSERVE_CONTROL_CLR_RESET(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_RESET_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_MASK (0xFF0000U) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_OFF_MASK (0x1000000U) |
#define | CCM_OBS_OBSERVE_CONTROL_CLR_OFF_SHIFT (24U) |
| #define | CCM_OBS_OBSERVE_CONTROL_CLR_OFF(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_OFF_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_MASK (0x1FFU) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_CONTROL_TOG_SELECT(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_RAW_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_RAW_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_CONTROL_TOG_RAW(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_RAW_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_INV_MASK (0x2000U) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_INV_SHIFT (13U) |
| #define | CCM_OBS_OBSERVE_CONTROL_TOG_INV(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_INV_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_RESET_MASK (0x8000U) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_RESET_SHIFT (15U) |
| #define | CCM_OBS_OBSERVE_CONTROL_TOG_RESET(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_RESET_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_MASK (0xFF0000U) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_MASK) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_OFF_MASK (0x1000000U) |
#define | CCM_OBS_OBSERVE_CONTROL_TOG_OFF_SHIFT (24U) |
| #define | CCM_OBS_OBSERVE_CONTROL_TOG_OFF(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_OFF_MASK) |
#define | CCM_OBS_OBSERVE_STATUS0_SELECT_MASK (0x1FFU) |
#define | CCM_OBS_OBSERVE_STATUS0_SELECT_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_STATUS0_SELECT(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_SELECT_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_SELECT_MASK) |
#define | CCM_OBS_OBSERVE_STATUS0_RAW_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_STATUS0_RAW_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_STATUS0_RAW(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_RAW_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_RAW_MASK) |
#define | CCM_OBS_OBSERVE_STATUS0_INV_MASK (0x2000U) |
#define | CCM_OBS_OBSERVE_STATUS0_INV_SHIFT (13U) |
| #define | CCM_OBS_OBSERVE_STATUS0_INV(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_INV_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_INV_MASK) |
#define | CCM_OBS_OBSERVE_STATUS0_RESET_MASK (0x8000U) |
#define | CCM_OBS_OBSERVE_STATUS0_RESET_SHIFT (15U) |
| #define | CCM_OBS_OBSERVE_STATUS0_RESET(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_RESET_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_RESET_MASK) |
#define | CCM_OBS_OBSERVE_STATUS0_DIVIDE_MASK (0xFF0000U) |
#define | CCM_OBS_OBSERVE_STATUS0_DIVIDE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_STATUS0_DIVIDE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_DIVIDE_MASK) |
#define | CCM_OBS_OBSERVE_STATUS0_OFF_MASK (0x1000000U) |
#define | CCM_OBS_OBSERVE_STATUS0_OFF_SHIFT (24U) |
| #define | CCM_OBS_OBSERVE_STATUS0_OFF(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_OFF_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_OFF_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TZ_USER_MASK (0x1U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TZ_USER_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TZ_USER(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TZ_USER_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TZ_NS_MASK (0x2U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TZ_NS_SHIFT (1U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TZ_NS(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TZ_NS_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_MASK (0x10U) |
#define | CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_SHIFT (4U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_MASK (0xF00U) |
#define | CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_SHIFT (8U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_MASK (0x10000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_MASK (0x100000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_SHIFT (20U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_MASK (0x1U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_MASK (0x2U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_SHIFT (1U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_MASK (0x10U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_SHIFT (4U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_MASK (0xF00U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_SHIFT (8U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_MASK (0x10000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_MASK (0x100000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_SHIFT (20U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_MASK (0x1U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_MASK (0x2U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_SHIFT (1U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_MASK (0x10U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_SHIFT (4U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_MASK (0xF00U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_SHIFT (8U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_MASK (0x10000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_MASK (0x100000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_SHIFT (20U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_MASK (0x1U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_SHIFT (0U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_MASK (0x2U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_SHIFT (1U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_MASK (0x10U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_SHIFT (4U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_MASK (0xF00U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_SHIFT (8U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_MASK (0x1000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_SHIFT (12U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_MASK (0x10000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_SHIFT (16U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_MASK) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_MASK (0x100000U) |
#define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_SHIFT (20U) |
| #define | CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE(x) (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_MASK) |
