RTEMS 6.1
Files | Data Structures | Functions
spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-secondary
Tests a fatal error. More...
file  tr-fatal-sparc-leon3-cache-snooping-disabled-secondary.c
file  tr-fatal-sparc-leon3-cache-snooping-disabled-secondary.h
struct  BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context
 Test context for spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-secondary test case. More...
void __real_bsp_start_on_secondary_processor (struct Per_CPU_Control *cpu_self)
void __wrap_bsp_start_on_secondary_processor (struct Per_CPU_Control *cpu_self)
void BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case.
This test case performs the following actions:
◆ BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run()
void BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run ( rtems_fatal_source  source,
Parameters
sourceis fatal source.
codeis fatal code.
